UT8205AG-AG6
www.VBsemi.tw
Dual N-Channel MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
RDS(on) (Ω)
ID (A)
0.024 at VGS = 4.5 V
6.0
0.028 at VGS = 2.5 V
5.0
• Halogen-free Option Available
• TrenchFET® Power MOSFETs
• 100 % Rg Tested
• Compliant to RoHS Directive 2002/95/EC
Pb-free
Available
RoHS*
COMPLIANT
TSOP6
Top View
S1
D1/D2
S2
1 6
2 5
3 4
D
D
G1
D1/D2
G2
G1
G2
S1
S2
ABSOLUTE MAXIMUM RATINGS TA = 25 °C, unless otherwise noted
Parameter
Symbol
10 s
Steady State
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
± 12
Continuous Drain Current (TJ = 150 °C)a
TA = 25 °C
TA = 70 °C
Continuous Source Current (Diode Conduction)a
IS
TA = 25 °C
TA = 70 °C
PD
5.2
4.8
4.2
30
1.5
A
1.0
1.5
1.0
0.96
0.64
TJ, Tstg
Operating Junction and Storage Temperature Range
V
6.0
IDM
Pulsed Drain Current
Maximum Power Dissipationa
ID
Unit
- 55 to 150
W
°C
THERMAL RESISTANCE RATINGS
Parameter
Maximum Junction-to-Ambienta
Maximum Junction-to-Foot (Drain)
Symbol
t ≤ 10 s
Steady State
Steady State
Notes:
a. Surface Mounted on FR4 board, t ≤ 10 s.
* Pb containing terminations are not RoHS compliant, exemptions may apply.
E-mail:China@VBsemi TEL:86-755-83251052
RthJA
RthJF
Typ.
Max.
72
83
100
120
55
70
Unit
°C/W
UT8205AG-AG6
www.VBsemi.tw
SPECIFICATIONS TJ = 25 °C, unless otherwise noted
Parameter
Symbol
Test Conditions
Min.
VGS(th)
VDS = VGS, ID = 250 µA
0.5
IGSS
Typ.a
Max.
Unit
1.5
V
VDS = 0 V, VGS = ± 4.5 V
± 200
nA
VDS = 20 V, VGS = 0 V
1
VDS = 20 V, VGS = 0 V, TJ = 70 °C
25
Static
Gate Threshold Voltage
Gate-Body Leakage
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currentb
ID(on)
Drain-Source On-State Resistanceb
Voltageb
30
A
VGS = 4.5 V, ID = 5.5 A
0.024
VGS = 2.5 V, ID = 3.5 A
0.028
gfs
VDS = 10 V, ID = 5.5 A
30
VSD
IS = 1.5 A, VGS = 0 V
0.71
1.2
12
18
VDS = 10 V, VGS = 4.5 V, ID = 5.5 A
2.2
RDS(on)
Forward Transconductanceb
Diode Forward
VDS ≤ 5 V, VGS = 4.5 V
µA
Ω
S
V
a
Dynamic
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
3.6
Turn-On Delay Time
td(on)
245
365
330
495
860
1300
510
765
VDD = 10 V, RL = 10 Ω
ID ≅ 1 A, VGEN = 4.5 V, RG = 6 Ω
tr
Rise Time
td(off)
Turn-Off Delay Time
tf
Fall Time
nC
ns
Notes:
a. For design aid only; not subject to production testing.
b. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted
10000
1000
8
I GSS - Gate Current (A)
I GSS - Gate Current (mA)
10
6
4
100
10
TJ = 150 °C
1
2
TJ = 25 °C
0.1
6
9
12
15
VGS - Gate-to-Source Voltage (V)
Gate-Current vs. Gate-Source Voltage
18
6
9
12
Gate Current vs. Gate-Source Voltage
15
UT8205AG-AG6
www.VBsemi.tw
6.0
6.0
VGS = 5 thru 3 V
2.5 V
2.5
I D - Drain Current (A)
4.5
2.0
1.5
1.0
2V
0.5
2
3
1.0
TC = 125 °C
25 °C
- 55 °C
4
5
0.5
1.0
2.0
2.5
Output Characteristics
Transfer Characteristics
3.0
5
0.05
0.04
0.03
VGS = 2.5 V
VGS = 4.5 V
0.02
VDS = 10 V
ID = 5.5 A
4
3
2
1
5
15
25
3
6
On-Resistance vs. Drain Current
15
40
VGS = 4.5 V
ID = 5.5 A
I S - Source Current (A)
10
1.2
1.0
0.8
0.6
- 50
12
Gate Charge
1.6
1.4
9
Qg - Total Gate Charge (nC)
ID - Drain Current (A)
R DS(on) - On-Resistance
(Normalized)
1.5
VDS - Drain-to-Source Voltage (V)
0.06
R DS(on) - On-Resistance (Ω)
1.5
0.5
1V
TJ = 150 °C
TJ = 25 °C
1
0.1
- 25
50
75
100
125
TJ - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
150
0.6
0.9
1.2
VSD - Source-to-Drain Voltage (V)
Source-Drain Diode Forward Voltage
1.5
UT8205AG-AG6
www.VBsemi.tw
0.05
0.4
0.04
0.2
0.03
V GS(th) Variance (V)
ID = 250 µA
ID = 5.5 A
0.02
0.01
0.0
- 0.2
- 0.4
0.00
2
3
4
5
- 0.6
- 50
6
- 25
50
75
100
150
125
TJ - Temperature (°C)
On-Resistance vs. Gate-to-Source Voltage
Threshold Voltage
10
200
Limited by R DS(on)*
160
Power (W)
5
120
80
1 ms
1
100 ms
0.1
40
10 ms
1s
10 s
TC = 25 °C
Single Pulse
DC
0.01
0.01
0.1
1
10
0.1
Time (s)
Single Pulse Power
10
100
1
* VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area, Junction-to-Case
2
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
Notes:
0.1
0.1
PDM
0.05
t1
t2
1. Duty Cycle, D =
0.02
t1
t2
2. Per Unit Base = R thJA = 115 °C/W
3. T JM - TA = PDMZthJA(t)
Single Pulse
0.01
10 -4
10 -3
4. Surface Mounted
10 -2
10 -1
1
10
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Ambient
100
600
UT8205AG-AG6
www.VBsemi.tw
2
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10 -4
10 -3
10 -2
10 -1
Normalized Thermal Transient Impedance, Junction-to-Foot
1
10
UT8205AG-AG6
www.VBsemi.tw
TSOP: 5/6−LEAD
JEDEC Part Number: MO-193C
e1
e1
5
4
6
E1
1
2
5
4
E
E1
1
3
2
3
-B-
e
b
E
-B-
e
0.15 M C B A
5-LEAD TSOP
b
0.15 M C B A
6-LEAD TSOP
4x 1
-A-
D
0.17 Ref
c
R
R
A2 A
L2
Gauge Plane
Seating Plane
Seating Plane
0.08
C
L
A1
-C-
(L1)
4x 1
MILLIMETERS
Dim
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
L2
R
Min
Nom
Max
Min
Nom
Max
0.91
1.10
0.036
0.043
0.01
0.10
0.0004
0.004
0.90
1.00
0.035
0.038
0.039
0.30
0.32
0.45
0.012
0.013
0.018
0.10
0.15
0.20
0.004
0.006
0.008
2.95
3.05
3.10
0.116
0.120
0.122
2.70
2.85
2.98
0.106
0.112
0.117
1.55
1.65
1.70
0.061
0.065
0.067
0.95 BSC
0.0374 BSC
1.80
1.90
2.00
0.071
0.075
0.079
0.32
0.50
0.012
0.020
0.60 Ref
0.024 Ref
0.25 BSC
0.010 BSC
0.10
0.004
8
8
7 Nom
1
ECN: C-06593-Rev. I, 18-Dec-06
DWG: 5540
INCHES
7 Nom
UT8205AG-AG6
www.VBsemi.tw
RECOMMENDED MINIMUM PADS FOR TSOP-6
0.099
0.039
0.020
0.019
(1.001)
(0.508)
(0.493)
Recommended Minimum Pads
Dimensions in Inches/(mm)
0.064
(1.626)
0.028
(0.699)
(3.023)
0.119
(2.510)
UT8205AG-AG6
www.VBsemi.tw
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives ( collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to
the product.(www.VBsemi.tw)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: ( 1) any application and all liability arising out of or use of any products; ( 2) any and all liability,
including but not limited to special, consequential damages or incidental ; ( 3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
R oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 R i Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.tw)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
