C2
C3
2x 8.80
4x 1.80
C6
C5
C7
SW
GND
5x 1.30
2.44
GND
SW/GND
4x 1.30
11.20
E
C7
GND
14.10
14.00
2x 0.90
2x 14.00
2x 8.80
F
C1
C1 C5 C2 C6 C3
6x 3.70
3.32
4.40
G
2.98
1.43
1.27
Pick&Place area
6x 3.50
5x 1.27
6.35
6x 1.20
6.35
6x 0.90
H
Specifications
2.71 2.54 3.61
Material
Plastic Housing: High Temperature Thermoplastic
UL94V-0, Black
Contact Terminal: Copper Alloy
Metallic Shell: SUS
2x 12.30
Recommended PCB Layout
(Viewed from Component Side - Tolerance:±0.05mm)
0.80
1.40
0.40
0.60+0.15
-0.05
12.40
Solder Area
Keep Out Area
Component Outline
D
Plating
Contact :1µ" Gold over 50µ" Nickel
Shell: 30µ" Nickel over all
Circuit Diagram for Card Detect Switch
Card Inserted
2.54
4x 1.20
C
Without Card
(Normally Open)
S/W
S/W
C5
C5
Ordering Grid
SIM8060
6
X
14
No. of Contacts
6
Switch
0 = Without
B
A
Request Samples
and Quotation
Locating Peg
00 = Without
Profile Height
14 = 1.43mm
Part Number
Product Description
SIM8060
Nano SIM Card Connector
Hinged Type,SMT,6Pin, 1.43mm Profile
Drawing Date
8.00
11.20
6th September 2018
By
Detail
1
Mechanical & Environmental
Operating Temperature: -20°C to +60°C
Durability : 5,000 cycles
(1500pcs per reel)
(Contact SW removed from component)
6x 0.50
00
Packing Options
A = Tape & Reel
1 = With
A
Electrical
Voltage rating: 125V AC/DC
Current Rating: 0.5 Amp AC/DC Max.
Contact Resistance: 80 mΩ Max.
Dielectric Withstanding Voltage:500V AC (60 Sec Min. )
Insulation Resistance: 100 MΩ Min.@100V DC
2
3
4
Revision
Date
5
CC
Drawing
Release
A
06/09/18
Tolerances (Except as Noted)
Length
Angle
X.X ± 0.15
X.XX ± 0.10
X.XXX ± 0.05
± 1°
Units:
Metric (mm)
C
3rd Angle Projection
6
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
1/4
H
1
2
Slide metal lid from 'LOCK' position
to 'OPEN' position
Open metal lid to allow Nano SIM card to be inserted
G
F
E
3
Place Nano SIM card against contacts, chip face down
4
Close metal lid and slide back to 'LOCK' position
D
C
B
Part Number
Product Description
SIM8060
Drawing Date
6th September 2018
A
By
Detail
Revision
Date
1
2
3
4
5
CC
Drawing
Release
A
06/09/18
Length
X.X ± 0.15
X.XX ± 0.10
X.XXX ± 0.05
Angle
Units:
Metric (mm)
± 1°
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
2/4
H
25.00mm Mini
G
15.00mm Micro
12.30mm Nano
D
8.80mm Nano
E
12.00mm Micro
15.00mm Mini
F
C1----->VCC
C2----->RST
Nano SIM
C3----->CLK
C5----->GND
C6----->Vpp
C7----->I/O
Micro SIM
Mini SIM
C
Reference
B
Part Number
Product Description
SIM8060
Drawing Date
6th September 2018
A
By
Detail
Revision
Date
1
2
3
4
5
CC
Drawing
Release
A
06/09/18
Length
X.X ± 0.15
X.XX ± 0.10
X.XXX ± 0.05
Angle
Units:
Metric (mm)
± 1°
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
3/4
H
28
Pull out direction
Cover Tape
Label
G
Ø10
Ø330
Carrier Tape
Unloaded section
Empty 10pcs
Unloaded section
Empty 10pcs
loaded section
1500 pcs
F
Reel
1500pcsX10=15000pcs
Pcs/Reel
E
1500
Reels/Carton Pcs/Carton
10
15000
Carton
Dimensions
345 x 345 x 315mm
1.75
Pull out direction
C
1.
Ø
2.00
20.00
4.00
50
Carton
11.58
24.00
D
B
Part Number
Product Description
SIM8060
Drawing Date
6th September 2018
A
By
Detail
Revision
Date
1
2
3
4
5
CC
Drawing
Release
A
06/09/18
Length
X.X ± 0.15
X.XX ± 0.10
X.XXX ± 0.05
Angle
Units:
Metric (mm)
± 1°
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
4/4
SIM8060-6-0-14-00-A 价格&库存
很抱歉,暂时无法提供与“SIM8060-6-0-14-00-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+11.581651+1.40189
- 10+9.7982610+1.18603
- 25+9.3943125+1.13713
- 50+9.1952350+1.11303
- 100+8.79501100+1.06459
- 250+7.99555250+0.96782
- 500+7.19607500+0.87105
- 国内价格 香港价格
- 1500+5.996791500+0.72588
- 3000+5.796913000+0.70169
- 7500+5.597017500+0.67749
- 10500+5.3171610500+0.64361
- 15000+5.1972315000+0.62910
