AH3G.102
AH3G.102
    ANTENNAHOME(德诺菲)
    ANT_D8X109MM
    H108橡胶SMA-J,2G/3G GSM/GPRS天线 ANT_D8X109MM
AH3G.102 数据手册
AntennaHome 产 品/Product : 料 号/PN : - Antenna and Solutions Supplier H108 Rubber SMA-J ,2G/3G GSM/GPRS Antenna AH3G.101 应 用/Application : GSM/GPRS/WCDMA/NB-IoT/Cat.1/LoRa 868/915M, includes frequencies of 824M~2170MHz wireless products 电气参数(Electrical Properties) 频率/Frequency: 824~2170 MHz 输入阻抗/Impedance: 50Ω 驻波比/VSWR: ≤2.5 增益/Gain: 2.0 dBi 极化方式/Polarization: Vertical / Omni 机械参数(Mechanical Properties) 接头&线缆/Conn&Cable: SMA-J 材料&颜色/Material&Color: Copper / ABS 安装方式/Mounting: SMA connector 尺寸/Size: ¢8×H108 mm 重量/Weight: 6.0 g/pcs 工作温度/Operate Temp: -40 ~ +85 ℃ AntennaHome - Antenna and Solutions Supplier 关联产品/Relation Product SMA-K DIP (AHCG.202) SMA-K ASSY (AHCG.101) PCB 2.4G (AH2G.201) H200 FiberGlass (AH2G.501) 产品手册/ Product Catalogue 免费样品申请 Ask free sample 下载地址/Download Link: http://docs.AntennaHome.com/ant/catalogue.pdf Online Support Contact Us E-mail : CS@AntennaHome.com Website : Http://www.AntennaHome.com
AH3G.102 价格&库存
很抱歉,暂时无法提供与“AH3G.102”相匹配的价格&库存,您可以联系我们找货
