1N5817W THRU 1N5819W
SCHOTTKY BARRIER RECTIFIERS
PINNING
PIN
FEATURES
DESCRIPTION
M etal silicon junction, majority carrier conduction
1
Cathode
G uarding for overvoltage protection
2
Anode
L ow power loss, high efficiency
H igh current capability
2
l ow forward voltage drop
H igh surge capability
1
Top View
F or use in low voltage, high frequency inverters,
Marking Code: 1N5817W---SJ
1N5818W---SK
1N5819W---SJ
free wheeling, and polarity protection applications
Simplified outline SOD-123 and symbol
MECHANICAL DATA
Case: SOD-123
Terminals: Solderable per MIL-STD-750, Method 2026
Approx. Weight:16mg/0.00056oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Symbols
1N5817W
1N5818W
1N5819W
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
40
V
Maximum RMS voltage
V RMS
14
21
28
V
Maximum DC Blocking Voltage
V DC
40
V
Maximum Average Forward Rectified Current
I F(AV)
1
A
Peak Forward Surge Current, 8.3ms Single Half Sine-wave
Superimposed On Rated Load (JEDEC method)
I FSM
25
A
at 1 A
at 3 A
VF
Parameter
Maximum Instantaneous Forward Voltage
0.45
0.75
0.55
0.875
0.6
0.9
V
Maximum Instantaneous Reverse Current at TA = 25°C
Rated DC Reverse Voltage
TA = 100°C
IR
1
10
mA
Typical Junction Capacitance
Cj
110
pF
T j , T stg
-55 ~ +150
°C
Storage and Operating Junction Temperature Range
www.tw-gmc.com
1
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
resistive or inductive load
0.0
25
75
50
100
125
150
10 4
10 3
T J =125°C
10 2
T J =75°C
10 1
T J =25°C
10 0
Case Temperature (°C)
Junction Capacitance ( pF)
5°
C
=2
TJ
12
5°C
0.5
TJ =
Instaneous Forward Current (A)
80
100
500
1.0
0.2
0.1
0.2
0.4
0.3
0.5
0.6
0.7
8.3 ms Single Half Sine Wave
(JEDEC Method)
25
10
05
00
1
10
100
50
1
10
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
30
200
0.1
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
60
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
100
Number of Cycles at 50Hz
www.tw-gmc.com
40
Percent of Rated Peak Reverse Voltage(%)
1
2
100
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123
A
D
b
E
A1
C
∠ALL ROUND
L1
E1
SOD-123 mechanical data
A
C
D
E
E1
L1
b
A1
max
1.3
0.22
1.8
2.8
3.9
0.45
0.7
0.2
min
0.9
0.09
1.5
2.5
3.6
0.25
0.5
max
51
8.7
71
110
154
18
28
min
35
3.5
59
98
142
10
UNIT
mm
9°
mil
The recommended mounting pad size
2.0
(79)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
www.tw-gmc.com
1
3
8
很抱歉,暂时无法提供与“1N5817W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.09396
- 200+0.08816
- 500+0.08236
- 1000+0.07656
- 3000+0.07366
- 6000+0.06960
