SS22-210 SERIES
SCHOTTKY
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS
ROHS
FEATURES
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250℃/10 seconds at terminals
The plastic material carries U/L recognition 94V-O
MECHANICAL DATA
Case: JEDEC DO -214AC. molded plastic
Terminals: Axial leads. Solderable per MIL - STD - 750
Method 2026
Polarity: Color band denotes cathode
Weight: 0.003 ounce. 0.093 grams
Mounting position: Any
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 ℃ ambient temperature unless otherwise specified.
Single phase. half wave. 60HZ. resistive or inductive load. For capacitive load. derate current by 20%
Characteristic
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
RMS Reverse Voltage
Average Rectified Output Current @TL = 75°C
Symbol
SS22
SS23
SS24
SS25
SS26
SS28
SS29
SS210 Unit
VRRM
VRWM
VR
40
50
60
80
90
100
V
VR(RMS)
14
21
28
35
42
56
64
71
V
IO
2.0
A
Non-Repetitive Peak Forward Surge Current
8.3ms Single half sine-wave superimposed on
rated load (JEDEC Method)
IFSM
50
A
Forward Voltage
@IF = 1.0A
VFM
@TA = 25°C
@TA = 100°C
IRM
0.5
mA
RJL
RJA
28
88
°C/W
Tj
-65 to +125
°C
TSTG
-65 to +150
°C
Peak Reverse Current
At Rated DC Blocking Voltage
Typical Thermal Resistance (Note 1)
Operating Temperature Range
Storage Temperature Range
NOTE:
0.55
0.70
0.85
V
1. Measured at 1.0MHZ and applied reverse voltage of 4.0V DC
2. P.C.B.mounted with 0.2×0.2 (5.0×5.0mm)copper pad areas
Rev 8: Nov 2014
bufan
www.born-tw.com
Page 1 of 2
SS22-210 SERIES
2.0
1.0
50
75
100
125
150
TL , LEAD TEMPERATURE (ºC)
Fig. 1 Forward Current Derating Curve
SS25 - SS26
SS22 - SS24
1.0
SS28 - S210
0.1
Tj - 25ºC
IF Pulse Width = 300 µs
0.01
0.8
1.2
VF, INSTANTANEOUS FWD VOLTAGE (V)
Fig. 2 Typ. Forward Characteristics
1000
50
T j = 25°C
f = 1 MHz
Single Half-Sine-Wave
(JEDEC Method)
Tj = 100°C
40
Cj, JUNCTION CAPACITANCE (pF)
IFSM, PEAK FORWARD SURGE CURRENT (A)
ROHS
10
IF, INSTANTANEOUS FORWARD CURRENT (A)
I(AV), AVERAGE FORWARD CURRENT (A)
SCHOTTKY
30
100
10
100
NUMBER OF CYCLES AT 60 Hz
Fig. 3 Max Non-Repetitive Peak Fwd Surge Current
IR, INSTANTANEOUS REVERSE CURRENT (mA)
1
0.1
1
10
100
VR, REVERSE VOLTAGE (V)
Fig. 4 Typical Junction Capacitance
100
10
Tj = 100ºC
1.0
Tj = 75ºC
0.1
0.01
Tj = 25ºC
0.001
60
100 120 140
40
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig. 5 Typical Reverse Characteristics
Rev 8: Nov 2014
www.born-tw.com
Page 2 of 2
很抱歉,暂时无法提供与“SS210”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.18250
- 100+0.17000
- 300+0.15750
- 500+0.14500
- 2000+0.13875
- 5000+0.13500
