MB1S~MB10S
Single Phase 1.0Amp Glass passivated Bridge Rectifiers
Features
MBS
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Idea for printed circuit board
Glass passivated Junction chip
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed
250 C/10 seconds at terminals
Mechanical Data
Case: Molded plastic body
Terminals: Solder plated, solderable per MIL-STD-750, Method 2026
Polarity: Polarity symbol marking on body
Mounting Position: Any
Dimensions in inches and (millimeters)
Weight : 0.008 ounce, 0.22 grams
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,
for capacitive load current derate by 20%.
SYMBOLS
MB1S
MB2S
MB4S
MB6S
MB8S
MB10S UNITS
Maximum repetitive peak reverse voltage
VRRM
100
200
400
600
800
1000
VOLTS
Maximum RMS voltage
VRMS
70
140
280
420
560
700
VOLTS
Maximum DC blocking voltage
VDC
100
200
400
600
800
1000
VOLTS
Maximum average forward rectified current
at TL =30 C On glass-epoxy P.C.B (Note 1)
I(AV)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
IFSM
Maximum instantaneous forward voltage at 1.0A
1.0
Amp
35.0
Amps
VF
1.0
Volts
Maximum DC reverse current T A =25 C
at rated DC blocking voltage TA=125 C
IR
5.0
500
uA
Typical junction capacitance (Note 2)
CJ
25.0
pF
RqJA
55.0
C/W
TJ,TSTG
-50 to +155
C
Typical thermal resistance
Operating junction and storage temperature range
Note:1.Mounted on glass epoxy PC board with 1.3*1.3mm solder pad
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
Rev.2013A
Page 1
MB1S~MB10S
Ratings And Characteristic Curves
MB1S THRU MB10S
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT PERLEG
35
Peak Forward Surage Current
Amperes
1.0
0.9
0.8
Amperes
Average Forward Rectified Current
FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT
0.7
0.6
0.5
0.4
0.3
0.2
60
80
100
120
140
30
25
f=50Hz
10
5
160
1Cycle
10
FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS
1
Amperes
Instantneous Forward Current
10
TJ=25
Pulse Width=300us
1% Duty Cycle
0.01
0.2 0.4
0.6
0.8
1.0
1.2
1.4
1.6
Volts
Instantaneou Foward Voltage
100
Micro Amperes
Instantaneous Reverse Leakage Current
FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS
0.1
100
Number of cycles
Ambient Temperature
Tj = 125°C
10
1.0
Tj = 25°C
0.1
0.01
60
80
100
120
140
Percent Of Rated Peak Reverse Voltage(%)
FIG. 5-TYPICAL JUNCTION CAPACTITANE
30
TJ=25
f=1.0MHZ
Vsig=50mV p-p
pF
Junction Capacitance
25
15
10
5
1
10
100
200
Volts
Reverse Voltage
Rev.2013A
Page 2
很抱歉,暂时无法提供与“MB8S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.16000
- 50+0.14800
- 200+0.13800
- 600+0.12800
- 1500+0.12000
- 3000+0.11500
