SS22 THRU SS210
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIE
20V-100V 2.0A
FEATURES
• Ideal for automated placement
• Guardring for overvoltage protection
• Low power losses, high efficiency
• Low forward voltage drop
• High surge capability
• Meets MSL level 1, per J-STD-020, LF maximum
peak of 260 °C
• Solder dip 260 °C, 40 s
• Component in accordance to RoHS 2002/95/EC
and WEEE 2002/96/EC
MECHANICAL DATA
Case: DO-214AC (SMA)
Epoxy meets UL 94V-0 flammability rating
Terminals: Matte tin plated leads, solderable per
J-STD-002 and JESD22-B102
E3 suffix for consumer grade, meets JESD 201 class
1A whisker test, HE3 suffix for high reliability grade
(AEC Q101 qualified), meets JESD 201 class 2 whisker test
Polarity: Color band denotes cathode end
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25oC ambient temperature unless otherwise specified
SS22
SS23 SS24 SS25 SS26
SS28 SS29 SS210
SS22
SS23 SS24 SS25 SS26
SS28 SS29 SS210
UNITS
Device marking code
Maximum repetitive peak reverse voltage
VRRM
40
50
60
80
90
100
V
Maximum RMS voltage
VRWS
14
21
28
35
42
56
63
70
V
Maximum DC blocking voltage
VDC
40
50
60
80
90
100
V
Maximum average forward rectified current at
TL=90
IF(AV)
2.0
A
Peak forward surge current 8.3ms single
half-sine-wave
IFSM
75
A
Maximum instantaneous forward voltage
at I FM=2.0A (NOTE1)
VF
Maximum DC reverse current
TJ=25
at rated DC blocking voltage TJ=125
Maximum thermal resistance
Operating temperature range
Storage temperature range
IR
R
JL
0.50
0.75
0.85
0.4
0.03
10
5.0
28
V
mA
o
C/W
TJ
-55 ---- +125
o
C
TSTG
-55 ---- +150
o
C
1 of 2
SS22 THRU SS210
RATINGS AND CHARACTERISTIC CURVES
SS22
1.0
P.C.B. Mounted on
0.2 x 0.2" (5.0 x 5.0 mm)
Copper Pad Areas
0.5
At Rated TL
8.3 ms Single Half Sine-Wave
Peak Forward Surge Current (A)
Resistive or
Inductive Load
1.5
SS22 - SS24
SS25 & SS26
80
60
40
70
90
110
130
170
150
10
1
100
Lead Temperature (°C)
Number of Cycles at 60 Hz
Figure 1. Forward Current Derating Curve
Figure 2. Maximum Non-Repetitive Surge Current
1000
10
Pulse Width = 300 µs
1 % Duty Cycle
TJ = 150 °C
1
Junction Capacitance (pF)
100
TJ = 25 °C
TJ = 125 °C
0.1
SS22 - SS24
SS25 & SS26
0.01
0.4
0.6
0.8
1.0
1.4
1.2
1.6
100
SS22 - SS24
SS25 & SS26
TJ = 25 °C
f = 1.0 MHz
Vsig = 50 mVp-p
10
0.1
1
10
100
Instantaneous Forward Voltage (V)
Reverse Voltage (V)
Figure 3. Typical Instantaneous Forward Characteristics
Figure 5. Typical Junction Capacitance
100
Instantaneous Reverse Current (mA)
Average Forward Current (A)
SS210
100
2.0
Instantaneous Forward Current (A)
THRU
SS22 - SS24
SS25 & SS26
TA = 125 °C
10
1
TA = 75 °C
0.1
TA = 25 °C
0.01
0.001
60
80
100
Percent of Rated Peak Reverse Voltage (%)
Figure 4. Typical Reverse Current Characteristics
2 of 2
很抱歉,暂时无法提供与“SS24/SMB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.19200
- 50+0.17760
- 200+0.16560
- 600+0.15360
- 1500+0.14400
- 3000+0.13800
