SL32B THRU SL310B
Reverse Voltage - 20 to 100 Volts
Forward Current - 3.0 Ampere
LOW FORWARD VOLTAGE SCHOTTKY BARRIER DIODES
Features
DO-214AA/SMB
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
0.155(3.94)
0.130(3.30)
0.086 (2.20)
0.071 (1.80)
0.185(4.70)
0.160(4.06)
High forward surge current capability
0.012(0.305)
0.006(0.152)
High temperature soldering guaranteed:
260°C/10 seconds at terminals
0.096(2.44)
0.084(2.13)
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
Mechanical Data
0.220(5.59)
0.200(5.08)
Case : JEDEC DO-214AA/SMB Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.003ounce, 0.093 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=90℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 3.0A
Maximum DC reverse current
at rated DCblocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
VRRM
VRMS
VDC
MDD
SL32B
MDD
SL33B
MDD
SL34B
MDD
SL35B
MDD
SL36B
21
30
40
28
40
50
35
50
60
42
60
MDD
MDD
SL38B SL310B
80
56
80
100
70
100
UNITS
V
V
V
I(AV)
3.0
A
IFSM
70
A
VF
0.45
IR
CJ
RJA
Operating junction and storage temperature range TJ,TSTG
0.50
0.70
0.2
10.0
0.5
20.0
500
300
V
mA
pF
68.0
℃/W
-55 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
DN:T20518A0
http://www.microdiode.com
Rev:2020A0
Page :1
SL32B THRU SL310B
FIG. 1- FORWARD CURRENT DERATING CURVE
3.0
P.C.B mounted on
2.0*2.0"(5.0*5.0cm)
copper pad areas
2.4
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.8
1.2
SL32B-SL36B
SL38B-SL310B
0.6
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
70
56
42
28
14
175
8.3ms SINGLE HALF SINE-WAVE
1
10
NUMBER OF CYCLES AT 60 Hz
LEAD TEMPERATURE, C
50
INSTANTANEOUS FORWARD
CURRENT,AMPERES
TJ=25 C
10.0
1
SL32B-SL34B
SL35B-SL36B
SL38B-SL310B
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
0.1
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
2000
1000
TJ=25 C
100
SL32B-SL34B
SL35B-SL310B
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
0.9
TRANSIENT THERMAL IMPEDANCE,
C/W
0.01
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2020A0
Page :2
SL32B THRU SL310B
Packing information
P0
P1
unit:mm
d
E
Item
F
B
A
Symbol
Tolerance
SMB
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.41
2.42
1 5.0
330.00
50.00
13.00
1.75
5.55
8.00
4.00
2.00
0.30
12.00
12.30
W
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
P
D2
D1
T
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
BOX
(pcs)
INNER
BOX
(mm)
REEL
DIA,
(mm)
SMB
13"
3,000
4.0
6,000
190*190*41
330
CARTON
SIZE
(mm)
365*365*360
CARTON
(pcs)
48,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
A
B
C
D
E
Unit (mm)
2.8
2.4
Unit (inch)
0.110
4.6
0.094
0.181
2.2
7.0
0.086
0.276
Important Notice and Disclaimer
Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and
specifications at any time without notice. Customers should obtain and confirm the latest product information and
specifications before final design,purchase or use.
Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its
products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application
assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with
products which are purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode
Electronics (Jiangsu).
Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support
devices or systems without express written approval of Microdiode Electronics (Jiangsu).
Rev:2020A0
Page :3
很抱歉,暂时无法提供与“SL54B-SMB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.74000
- 50+0.68000
- 200+0.63000
- 600+0.58000
- 1500+0.54000
- 3000+0.51500
