DA5R5473AF
DA5R5473AF
    KORCHIP(高奇普)
    CAP_9.5X5MM_TM
    超级电容器 CAP_9.5X5MM_TM 47mF -20~+80% 5.5V
DA5R5473AF 数据手册
DA series | Features | • Automatic assembly available (A-type) • Low ESR • Low self-discharge, low leakage current • Space saving design | Applications| • Memory back-up for Video, Audio, Cameras, Camcorder, Telephones, Printer, Car stereo, Computer, Notebook PC, Rice cooker, Set top box, CCTV, PDP, Boiler, DVD-RW, DSC, etc. A-TYPE V-TYPE H- TYPE | Specifications | Items Characteristics Rated working voltage 5.5VDC Operating temperature -25 to +70℃ Maximum surge voltage 6.3VDC Nominal Cap. range 0.022 to 0.1F Capacitance tolerance -20% to +80% (at 25℃) Low temperature(-25℃) characteristics Capacitance change : ≤ 50% of the spec. value at +25℃ ESR change : Less than five times of the spec. value at +25℃ Endurance (5.5Vdc, 70℃, 1000Hrs.) Capacitance change : ≤ 30% of the spec. value at +25℃ ESR change : Less than four times of the spec. value at +25℃ | Dimensions in mm(not to scale) | V-TYPE A-TYPE (Ammo-taping) H- TYPE ※ D : 12.0 mm (0.022F, 0.047F) 14.0 mm (0.1F) | Standard products | Part number Operating voltage (V) DA 5R5 223 DA 5R5 473 DA 5R5 104 5.5 Capacitance (F) ESR (Ω, @1kHz) Size (mm) A×B×C×P 0.022 ≤ 150 10.5×9.5×5.0×5.0 0.047 ≤ 60 10.5×9.5×5.0×5.0 0.1 ≤ 60 12.5×11.5×5.0×5.0 Note : It is not allowed to go through reflow (IR, Atmosphere heating methods etc.) process Homepage : http://www.korchip.com Head office : 82-31-361-8031~6 (Fax : 82-31-361-8080) E-mail : starcap@korchip.com
DA5R5473AF 价格&库存
很抱歉,暂时无法提供与“DA5R5473AF”相匹配的价格&库存,您可以联系我们找货
DA5R5473AF
    • 1+4.86860
    库存:30
