S2A - S2M
2.0 AMPS. Surface Mount Rectifiers
SMB/DO-214AA
Features
For surface mounted application
Glass passivated junction chip.
Low forward voltage drop
High current capability
Easy pick and place
High surge current capability
Plastic material used carries Underwriters
Laboratory Classification 94V-0
High temperature soldering:
o
260 C / 10 seconds at terminals
Mechanical Data
Dimensions in inches and (millimeters)
Case: Molded plastic
Terminals: Pure tin plated, lead free.
Polarity: Indicated by cathode band
Packaging: 12mm tape
Weight: 0.093 gram
Maximum Ratings and Electrical Characteristics
Rating at 25 oC ambient temperature unless otherwise specified.
Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%
Type Number
Symbol S2A
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
@TL =100 oC
Peak Forward Surge Current, 8.3 ms Single
Half Sine-wave Superimposed on Rated
Load (JEDEC method )
Maximum Instantaneous Forward Voltage
@ 2.0A
VRRM
VRMS
V DC
Typical Reverse Recovery Time ( Note 1 )
Typical Junction Capacitance ( Note 2 )
Typical Thermal resistance (Note 3)
Operating Temperature Range
S2D
S2G
S2J
S2K
S2M
Units
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
I(AV)
2.0
A
IFSM
50
A
VF
1.15
V
5.0
125
1.5
30
16
53
-55 to +150
-55 to +150
uA
uA
uS
pF
o
Maximum DC Reverse Current @ TA =25 C
at Rated DC Blocking Voltage @ TA=125 oC
50
35
50
S2B
IR
Trr
Cj
R θJL
R θJA
TJ
Storage Temperature Range
T STG
1. Reverse Recovery Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A
Notes:
2. Measured at 1 MHz and Applied V R=4.0 Volts
3. Measured on P.C. Board with 0.4” x 0.4” (10mm x 10mm) Copper Pad Areas.
o
C/W
o
o
C
C
S2A - S2M
RATINGS AND CHARACTERISTIC CURVES (S2A THRU S2M)
FIG.2- TYPICAL REVERSE CHARACTERISTICS
10
2.0
Tj=125 0C
INSTANTANEOUS REVERSE CURRENT. ( A)
AVERAGE FORWARD CURRENT. (A)
FIG.1- MAXIMUM FORWARD CURRENT DERATING
CURVE
1.5
SINGLE PHASE
HALF SIZE WAVE 60Hz
RESISTIVE OR
INDUCTIVE LOAD
10mm2 PAD AREAS
1.0
0.5
50
60
70
80
90
100
110
120
130
140
150 1
o
LEAD TEMPERATURE. ( C)
FIG.3- MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
Tj=100 0C
1
0.1
Tj=25 0C
0.01
8.3ms Single Half Sine Wave
JEDEC Method
40
40
60
80
100
120
140
30
FIG.5- TYPICAL FORWARD CHARACTERISTICS
10
10
10
NUMBER OF CYCLES AT 60Hz
1
100
FIG.4- TYPICAL JUNCTION CAPACITANCE
60
JUNCTION CAPACITANCE.(pF)
PERCENT OF RATED PEAK REVERSE VOLTAGE. (%)
INSTANTANEOUS FORWARD CURRENT. (A)
PEAK FORWARD SURGE CURRENT. (A)
50
40
Tj=25 0C
f=1.0MHz
Vsig=50mVp-p
6
4
1
0.1
Tj=25 C
PULSE WIDTH-300 S
2% DUTY CYCLE
2
1
0.1
0.2
0.4
1
2
4
10
0.01
0.4
100
0.6
REVERSE VOLTAGE. (V)
0.8
1.0
FIG.6- REVERSE RECOVERY TIME CHARACTERISTIC AND TEST CIRCUIT DIAGRAM
50W
NONINDUCTIVE
10W
NONINDUCTIVE
trr
+0.5A
DUT
50Vdc
(approx)
PULSE
GENERATOR
(NOTE 2)
1W
NON
INDUCTIVE
1.2
FORWARD VOLTAGE. (V)
OSCILLOSCOPE
(NOTE 1)
NOTES: 1. Rise Time=7ns max. Input Impedance=
1 megohm 22pf
2. Rise Time=10ns max. Sourse Impedance=
50 ohms
-0.25A
-1.0A
1cm
SET TIME BASE FOR
5/ 10ns/ cm
1.4
1.6
很抱歉,暂时无法提供与“S2B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.28062
- 100+0.22878
- 300+0.20286
- 3000+0.17561
- 6000+0.16006
- 9000+0.15228
