ES1AF
ES1JF
THRU
1.0 AMP SURFACE MOUNT SUPER FAST RECTIFIERS
VOLTAGE RANGE
50 to 600 Volts
CURRENT
1.0 Ampere
FEATURES
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Fast switching speed
SMAF
.146(3.7)
.130(3.3)
.063(1.6)
.051(1.3)
MECHANICAL DATA
.193(4.9)
.173(4.4)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
.008(0.20)
.005(0.12)
.047(1.20)
.035(0.90)
.106(2.7)
.094(2.4)
.047(1.2)
.031(0.8)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
ES1AF ES1BF ES1CF ES1DF ES1EF ES1GF ES1JF
50
35
50
100
70
100
150
105
150
at Ta=25 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 1.0A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Ta=100 C
Maximum Reverse Recovery Time (Note 1)
Typical Junction Capacitance (Note 2)
Typical Thermal Resistance RqJA (Note 3)
Operating and Storage Temperature Range TJ, TSTG
200
140
200
300
210
300
400
280
400
600
420
600
UNITS
V
V
V
A
1.0
25
5.0
A
V
A
500
35
A
nS
15
80
-65 +150
pF
C/W
C
1.25
0.95
1.7
Marking Code
NOTES:
1. Reverse Recovery Time test condition: IF=0.5A, IR=1.0A, IRR=0.25A
2. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3. Thermal Resistance from Junction to Ambient.
REV 1.0 2015 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES ( ES1AF THRU ES1JF)
FIG.2-TYPICAL FORWARD CURRENT
DERATING CURVE
FIG.1- TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERISTIC
trr
10W
NONINDUCTIVE
D.U.T.
25Vdc
(approx.)
+0.5A
PULSE
GENERATOR
(NOTE 2)
AVERAGE FORWARD CURRENT,(A)
50W
NONINDUCTIVE
-0.25A
1W
NONINDUCTIVE
OSCILLISCOPE
(NOTE 1)
-1.0A
NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF.
1cm
2. Rise Time= 10ns max., Source Impedance= 50 ohms.
1.2
1.0
0.8
Single Phase
0.6
Half Wave 60Hz
Resistive Or Inductive Load
0.4
0.375"(9.5mm) Lead Length
0.2
SET TIME BASE FOR
50
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
CHARACTERISTICS
50
10
10
ES
1D
F
REVERSE LEAKAGE CURRENT, ( A)
50
F
1J
ES
1E
F-
ES
1G
F
F1A
ES
1.0
ES
INSTANTANEOUS FORWARD CURRENT,(A)
FIG.3-TYPICAL FORWARD
3.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
.01
.4
.6
.8
1.0
1.2
1.4
1.6
100
125
150
175
3.0
1.0
Tj=100 C
Tj=25 C
0.1
.01
1.8
60
80
100 120 140
PERCENT OF RATED PEAK REVERSE VOLTAGE,(%)
FORWARD VOLTAGE,(V)
FIG.6-TYPICAL JUNCTION CAPACITANCE
FIG.5-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
175
50
JUNCTION CAPACITANCE,(pF)
PEAK FORWARD SURGE CURRENT,(A)
75
AMBIENT TEMPERATURE,( C)
50 / 10ns / cm
40
30
Tj=25 C
8.3ms Single Half
Sine Wave
JEDEC method
10
150
125
100
75
50
25
5
10
NUMBER OF CYCLES AT 60Hz
50
100
.01
.05
.1
.5
1
5
10
50
100
REVERSE VOLTAGE,(V)
REV 1.0 2015 JAN
PAGE:2/2
很抱歉,暂时无法提供与“ES1JF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.03749
- 100+0.03499
- 300+0.03249
- 500+0.03000
- 2000+0.02875
- 5000+0.02800
