SS32-SS320
SCHOTTKY BARRIER DIODE
FEATURES
Small Surface Mount device
Low power loss, high efficiency
High forward surge current capability
For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
SMA(DO-214AC)
MECHANICAL DATA
Case: SMA(DO-214AC)
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.065 grams (approximate)
MAXIMUM RATINGS AND CHARACTERISTICS(TA = 25°C unless otherwise noted)
Parameter
Symbol SS32 SS34 SS34A SS36 SS38 SS310 SS312 SS315 SS320 Unit
Repetitive
peak
reverse VRRM
45
60
80
100 120 150 200
V
voltage
VRMS
RMS Reverse Voltage
14
28 31.5 42
56
70
84
105 140
V
VR
DC Reverse Voltage
Non-Repetitive Peak Forward
Surge Current @ t = 8.3 ms
Mean rectifying current
IFSM
80
A
IF
3.0
A
Thermal
Resistance
Junction To Ambient(2)
RθJA
70
°C/W
From
45
60
80
100
120
150
200
V
Junction Temperature
TJ
-55 ~+125
°C
Storage Temperature
TSTG
-55 ~+150
°C
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
0.95
0.85
Unit Conditions
V
Forward voltage
VF
Reverse current T=25°C
IR
0.5
0.3
mA
Reverse current T=100°C
IR
5
3
mA
Junction capacitance(1)
CJ
450
400
0.55
0.70
NOTE:
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD
E-mail:hkt@heketai.com
IF=3A
V=VR
pF VR=4V,f=1MHZ
1/4
SS32-SS320
Typical Characteristics
Fig.2 Typical Reverse Characteristics
Fig.1 Forward Current Derating Curve
10 4
Instaneous Reverse Current ( μA)
Average Forward Current (A)
3.5
3.0
2.4
1.8
1.2
0.6
Single phase half-wave 60 Hz
resistive or inductive load
50
75
T J =75°C
10 2
SS32-SS36
SS38-SS320
10 1
T J =25°C
10 0
0.0
25
T J =100°C
10 3
100
125
150
Case Temperature (°C)
80
100
T J =25°C
10
Junction Capacitance ( pF)
Instaneous Forward Current (A)
60
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
1.0
SS32/SS34
SS34A/SS38
SS310/SS312
SS315/SS320
0.4
0.6
0.8
1.0
1.2
1.4
1.6
500
200
100
SS32~SS38
SS32F~SS36F
SS310~SS320
SS38F~SS320F
10
0.1
Fig.5- Typical Transient Thermal Impedance
Transient Thermal Impedance( °C /W)
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
10
Number of Cycles at 60Hz
100
10
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
1
1
0.1
1.8
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
100
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
2/4
SS32-SS320
SMA Package Outline Dimensions
Symbol
Dimensions In Millimeters
Min.
Max.
A
2.20
B
Dimensions In Inches
Max.
2.80
Min.
0.086
1.30
1.70
0.051
0.067
C
4.70
5.30
0.185
0.209
D
1.70
2.55
0.067
0.100
E
0.90
1.50
0.035
0.059
F
0.90
1.50
0.035
0.059
0.110
SMA Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
3/4
SS32-SS320
SMA Tape and Reel
SMA Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SMA
2.89
5.35
2.68
Ø1.50
1.75
5.50
4.00
4.00
2.00
12.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SMA Tape Leader and Trailer
SMA Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø178
54.40
13.00
R78
R25.60
R6.50
12.40
17.60
±2
±1
±1
±1
±1
±1
±1
±1
4/4
很抱歉,暂时无法提供与“SS36A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.17959
- 100+0.16686
- 300+0.15412
- 500+0.14138
- 2000+0.13501
- 5000+0.13119
