Si53360-B-GT
Si53360-B-GT
    SILICON
    TSSOP16_5X4.4MM
    低抖动、LVCMOS扇出时钟缓冲器 TSSOP16 1.71~3.63V 200MHz
Si53360-B-GT 数据手册
Si53360/61/62/65 Data Sheet Low-Jitter, LVCMOS Fanout Clock Buffers with up to 12 outputs and Frequency Range from dc to 200 MHz The Si53360/61/62/65 family of LVCMOS fanout buffers is ideal for clock/data distribution and redundant clocking applications. The family utilizes Silicon Labs advanced CMOS technology to fanout clocks from dc to 200 MHz with guaranteed low additive jitter, low skew, and low propagation delay variability. Built-in LDOs deliver high PSRR performance and eliminates the need for external components simplifying low jitter clock distribution in noisy environments. The CMOS buffers are available in multiple configurations with 8 outputs (Si53360/61/65), or dual banks of 6 outputs each (Si53362). These buffers can be paired with the Si534x clock generators and Si5xx oscillators to deliver end-to-end clock tree performance. KEY FEATURES • Low additive jitter: 120 fs rms • Built-in LDOs for high PSRR performance • Up to 12 LVCMOS Outputs from LVCMOS inputs • Frequency range: dc to 200 MHz • Multiple configuration options • Dual Bank option • 2:1 Input MUX option • RoHS compliant, Pb-free • Temperature range: –40 to +85 °C VDD Power Supply Filtering VDDO (Si53361 only) OEA 8 CLK0 CLK1 Si53360/61 8 Outputs VDD VDDOA Power Supply Filtering 0 OEA 1 6 OE 6 Outputs Si53362 CLK_SEL 6 CLK 8 8 Outputs Si53365 6 Outputs OEB VDDOB 1 Skyworks Solutions, Inc. • Phone [781] 376-3000 • Fax [781] 376-3100 • sales@skyworksinc.com • www.skyworksinc.com Rev. 1.3 • Skyworks Proprietary Information • Products and Product Information are Subject to Change Without Notice • July 26, 2021 1 Table of Contents 1. Ordering Guide . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 2. Functional Description. . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 2.1 LVCMOS Input Termination . . . . . . . . . . . . . . . . . . . . . . . . . . 4 2.2 Input Mux . . . . . . . . . . . . . . . . . . . . . . . . . . 4 2.3 Output Clock Termination Options . . . . . . . . . . . . . . . . . . . . . . . 5 2.4 AC Timing Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 2.5 Power Supply Noise Rejection. . . . . . . . . . . . . . . . . . . . . . . . . 6 2.6 Typical Phase Noise Performance: Single-Ended Input Clock . . . . . . . . . . . . . . 7 2.7 Input Mux Noise Isolation . . . . . . . . . . . . . 8 . . . . . . . . . . . . . 3. Electrical Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 4. Detailed Block Diagrams . . . . . . . . . . . . . . . . . . . . . . . . . . 12 5. Si5336x Pin Descriptions . . . . . . . . . . . . . . . . . . . . . . . . . . 15 5.1 Si53360 Pin Descriptions . . . . . . . . . . . . . . . . . . . . . . . . . .15 5.2 Si53361 Pin Descriptions . . . . . . . . . . . . . . . . . . . . . . . . . .17 5.3 Si53362 Pin Descriptions . . . . . . . . . . . . . . . . . . . . . . . . . .19 5.4 Si53365 Pin Descriptions . . . . . . . . . . . . . . . . . . . . . . . . . .21 6. Package Outline . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 6.1 16-Pin TSSOP Package . . . . . . . . . . . . . . . . . . . . . . . . . . .22 6.2 16-Pin QFN Package . . . . . . . . . . . . . . . . . . . . . . . . . . . .24 6.3 24-Pin QFN Package . . . . . . . . . . . . . . . . . . . . . . . . . . . .25 . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26 7. PCB Land Pattern 7.1 16-Pin TSSOP Land Pattern . . . . . . . . . . . . . . . . . . . . . . . . .26 7.2 16-Pin QFN Land Pattern . . . . . . . . . . . . . . . . . . . . . . . . . .27 7.3 24-Pin QFN Land Pattern . . . . . . . . . . . . . . . . . . . . . . . . . .29 8. Top Markings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 31 8.1 Si53360/65 Top Markings . . . . . . . . . . . . . . . . . . . . . . . . . .31 8.2 Si53361 Top Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . .32 8.3 Si53362 Top Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . .33 9. Revision History . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 34 2 Skyworks Solutions, Inc. • Phone [781] 376-3000 • Fax [781] 376-3100 • sales@skyworksinc.com • www.skyworksinc.com Rev. 1.3 • Skyworks Proprietary Information • Products and Product Information are Subject to Change Without Notice • July 26, 2021 2 Si53360/61/62/65 Data Sheet • Ordering Guide 1. Ordering Guide Table 1.1. Si5336x Ordering Guide 3 Part Number Input LVCMOS Output Output Enable Frequency Range Package Si53360-B-GT 2:1 selectable MUX LVCMOS 1 bank / 8 Outputs Single dc to 200 MHz 16-TSSOP Si53361-B-GM 2:1 selectable MUX LVCMOS 1 bank / 8 Outputs (Settable VDDO) Single dc to 200 MHz 16-QFN 3x3 mm Si53362-B-GM 2:1 selectable MUX LVCMOS 2 banks / 6 Outputs 1 per bank dc to 200 MHz 24-QFN 4x4 mm SI53365-B-GT 1 bank / 1 Input LVCMOS 1 bank / 8 Outputs Single dc to 200 MHz 16-TSSOP Skyworks Solutions, Inc. • Phone [781] 376-3000 • Fax [781] 376-3100 • sales@skyworksinc.com • www.skyworksinc.com Rev. 1.3 • Skyworks Proprietary Information • Products and Product Information are Subject to Change Without Notice • July 26, 2021 3 Si53360/61/62/65 Data Sheet • Functional Description 2. Functional Description The Si53360/61/62/65 are a family of low-jitter, low skew, fixed format (LVMCOS) buffers. These devices are available in multiple configurations customized for the end application (refer to 1. Ordering Guide for more details on configurations). 2.1 LVCMOS Input Termination The table below summarizes the various ac- and dc-coupling options supported by the LVCMOS device, and the figure shows the recommended input clock termination. Table 2.1. LVCMOS Input Clock Options LVCMOS AC-Coupled DC-Coupled 1.8 V No Yes 2.5/3.3 V Yes Yes VDD VDD = 3.3 V, 2.5 V, or 1.8 V CMOS Driver Si53360/61/62/65 Rs CLKx 50 Note: Value for Rs should be chosen so that the total source impedance matches the characteristic impedance of the PCB trace. Figure 2.1. Recommended Input Clock Termination 2.2 Input Mux The Si53360-61/62 provide two clock inputs for applications that need to select between one of two clock sources. The CLK_SEL pin selects the active clock input. The following table summarizes the input and output clock based on the input mux settings. Table 2.2. Input Mux Logic 4 CLK_SEL CLK0 CLK1 Q L L X L L H X H H X L L H X H H Skyworks Solutions, Inc. • Phone [781] 376-3000 • Fax [781] 376-3100 • sales@skyworksinc.com • www.skyworksinc.com Rev. 1.3 • Skyworks Proprietary Information • Products and Product Information are Subject to Change Without Notice • July 26, 2021 4 Si53360/61/62/65 Data Sheet • Functional Description 2.3 Output Clock Termination Options The recommended output clock termination options are shown below. Unused outputs should be left unconnected. CMOS Receivers VDD Si5336x Zout Rs Zo 50 Note: Rs = 33 ohm for 3.3 V and 2.5 V operation. Rs = 0 ohm for 1.8 V operation. Figure 2.2. LVCMOS Output Termination 5 Skyworks Solutions, Inc. • Phone [781] 376-3000 • Fax [781] 376-3100 • sales@skyworksinc.com • www.skyworksinc.com Rev. 1.3 • Skyworks Proprietary Information • Products and Product Information are Subject to Change Without Notice • July 26, 2021 5 Si53360/61/62/65 Data Sheet • Functional Description 2.4 AC Timing Waveforms TPHL CLK TSK QN VPP/2 Q VPP/2 QM VPP/2 VPP/2 TPLH TSK Propagation Delay Output-Output Skew TF Q 80% VPP 20% VPP 80% VPP Q 20% VPP TR Rise/Fall Time Figure 2.3. AC Timing Waveforms 2.5 Power Supply Noise Rejection The device supports on-chip supply voltage regulation to reject power supply noise and simplify low-jitter operation in real-world environments. This feature enables robust operation alongside FPGAs, ASICs and SoCs and may reduce board-level filtering requirements. See “AN491: Power Supply Rejection for Low-Jitter Clocks” for more information. 6 Skyworks Solutions, Inc. • Phone [781] 376-3000 • Fax [781] 376-3100 • sales@skyworksinc.com • www.skyworksinc.com Rev. 1.3 • Skyworks Proprietary Information • Products and Product Information are Subject to Change Without Notice • July 26, 2021 6 Si53360/61/62/65 Data Sheet • Functional Description 2.6 Typical Phase Noise Performance: Single-Ended Input Clock Each of the phase noise plots superimposes Source Jitter and Total Jitter on the same diagram. • Source Jitter - Reference clock phase noise (measured Single-ended to PNA). • Total Jitter - Combined source and clock buffer phase noise measured as a single-ended output to the phase noise analyzer and integrated from 12 kHz to 20 MHz. For more information, see 3. Electrical Specifications. Note: To calculate the total RMS phase jitter when adding a buffer to your clock tree, use the root-sum-square (RSS). Total jitter measured here AG E5052 Phase Noise Analyzer CLKx CLK SYNTH SMA103A Si5336x DUT 50 50 Ohm Source jitter measured here Figure 2.4. Single-ended Measurement Method The following figure shows three phase noise plots superimposed on the same diagram. Frequency (MHz) Single-Ended Input Slew Rate (V/ns) Source Jitter (fs) Total Jitter (SE) (fs) Additive Jitter (SE) (fs) 156.25 1.0 40.3 130.28 123.89 Figure 2.5. Total Jitter Single-Ended Input (156.25 MHz) 7 Skyworks Solutions, Inc. • Phone [781] 376-3000 • Fax [781] 376-3100 • sales@skyworksinc.com • www.skyworksinc.com Rev. 1.3 • Skyworks Proprietary Information • Products and Product Information are Subject to Change Without Notice • July 26, 2021 7 Si53360/61/62/65 Data Sheet • Functional Description 2.7 Input Mux Noise Isolation The input clock mux is designed to minimize crosstalk between the CLK0 and CLK1. This improves phase jitter performance when clocks are present at both the CLK0 and CLK1 inputs. The following figure shows a measurement of the input mux’s noise isolation. Figure 2.6. Input Mux Noise Isolation (Single-ended Input Clock, 16QFN Package) 8 Skyworks Solutions, Inc. • Phone [781] 376-3000 • Fax [781] 376-3100 • sales@skyworksinc.com • www.skyworksinc.com Rev. 1.3 • Skyworks Proprietary Information • Products and Product Information are Subject to Change Without Notice • July 26, 2021 8 Si53360/61/62/65 Data Sheet • Electrical Specifications 3. Electrical Specifications Table 3.1. Recommended Operating Conditions Parameter Symbol Ambient Operating Temperature TA Test Condition VDD Supply Voltage Range LVCMOS Min Typ Max Unit –40 — 85 °C 1.71 1.8 1.89 V 2.38 2.5 2.63 V 2.97 3.3 3.63 V Min Typ Max Unit Table 3.2. Input Clock Specifications VDD = 1.8 V ± 5%, 2.5 V ± 5%, or 3.3 V ± 10%, TA = –40 to 85 °C Parameter Symbol Test Condition LVCMOS Input High Voltage VIH VDD x 0.7 — — V LVCMOS Input Low Voltage VIL — — VDD x 0.3 V Input Capacitance CIN — 5 — pF CLK0 and CLK1 pins with respect to GND Table 3.3. DC Common Characteristics (CLK_SEL, OEx) VDD = 1.8 V ± 5%, 2.5 V ± 5%, or 3.3 V ± 10%, TA = –40 to 85 °C Parameter Symbol Core Supply Current IDD1 Output Supply Current (per clock output, Si53361/62 only) IDDO1 Test Condition Min Typ Max Unit VDD = 3.3 V, Si53360/65 — 150 — mA VDD = 3.3 V, Si53361/62 — 35 — mA VDDOX = 1.8 V — 7 — mA VDDOX = 2.5 V — 10 — mA VDDOX = 3.3 V — 13 — mA Input High Voltage VIH VDD x 0.8 — — V Input Low Voltage VIL — — VDD x 0.2 V Internal Pull-up Resistor RUP — 25 — kΩ OEX, CLK_SEL Note: 1. Frequency = 200 MHz, Cload = 0 pF 9 Skyworks Solutions, Inc. • Phone [781] 376-3000 • Fax [781] 376-3100 • sales@skyworksinc.com • www.skyworksinc.com Rev. 1.3 • Skyworks Proprietary Information • Products and Product Information are Subject to Change Without Notice • July 26, 2021 9 Si53360/61/62/65 Data Sheet • Electrical Specifications Table 3.4. Output Characteristics (LVCMOS) VDD = 1.8 V ± 5%, 2.5 V ± 5%, or 3.3 V ± 10%, TA = –40 to 85 °C Parameter Symbol Test Condition Min Typ Max Unit VDD x 0.8 — — V — — VDD x 0.2 V IOH = –12 mA, VDD = 3.3 V Output Voltage High VOH IOH = –9 mA, VDD = 2.5 V IOH = –6 mA, VDD = 1.8 V IOL = 12 mA, VDD = 3.3 V Output Voltage Low VOL IOL = 9 mA, VDD = 2.5 V IOL = 6 mA, VDD = 1.8 V Table 3.5. AC Characteristics VDD = 1.8 V ± 5%, 2.5 V ± 5%, or 3.3 V ± 10%, TA = –40 to 85 °C Parameter Symbol Test Condition Min Typ Max Unit Frequency F LVCMOS dc — 200 MHz DC 200 MHz, 2pF load TR/TF
Si53360-B-GT 价格&库存
很抱歉,暂时无法提供与“Si53360-B-GT”相匹配的价格&库存,您可以联系我们找货
Si53360-B-GT
  • 1+12.08762
  • 30+11.67081
  • 100+10.83718
  • 500+10.00355
  • 1000+9.58674
