DTC123JE
Digital Transistors (Built-in Resistors)
DIGITAL TRANSISTOR (NPN)
FEATURES
Built-in bias resistors enable the configuration of an inverter circuit
without connecting external input resistors(see equivalent circuit)
The bias resistors consist of thin-film resistors with complete isolation
to allow negative biasing of the input.They also have the advantage of
almost completely eliminating parasitic effects
Only the on/off conditions need to be set for operation, making device design easy
Equivalent Circuit
SOT-523
Collector
(Output)
Base
(Input)
R1
1. IN
2. GND
R2
3. OUT
Emitter
(Common)
MARKING: E42
MAXIMUM RATINGS(Ta=25℃ unless otherwise noted)
Symbol
Parameter
Limits(DTC123JE )
Unit
50
V
-5~+12
V
mA
VCC
Supply Voltage
VIN
Input Voltage
IO
Output Current
100
PD
Power Dissipation
150
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
REV.08
1 of 3
DTC123JE
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Input voltage
Output voltage
Input current
Symbol
Conditions
VI(off)
VCC=5V,IO=100µA
VI(on)
VO=0.3V,IO=5mA
VO(on)
IO/II=5mA/0.25mA
II
Min
Typ
Max
0.5
V
1.1
V
0.3
V
VI=5V
3.6
mA
VCC=50V,VI=0
0.5
μA
kΩ
0.1
Output current
IO(off)
DC current gain
GI
Input resistance
R1
1.54
2.2
2.86
Resistance ratio
R2/R1
17
21
26
Transition frequency
REV.08
fT
Unit
VO=5V,IO=10mA
VO=10V,IO=5mA,f=100MHz
2 of 3
80
250
MHz
DTC123JE
ON Characteristics
OFF Characteristics
100
10
VO=0.3V
VCC=5V
3
(mA)
(V)
30
1
OUTPUT CURRENT
INPUT VOLTAGE
I0
VI(ON)
10
3
Ta=25℃
1
Ta=100℃
Ta=100℃
0.3
Ta=25℃
0.1
0.03
0.3
0.1
0.1
0.3
1
10
3
OUTPUT CURRENT
IO
VO(ON) ——
30
0.01
0.2
100
0.6
0.4
(mA)
VI(OFF)
GI
IO
IO
1000
0.8
INPUT VOLTAGE
1.0
(V)
1000
IO/II=20
VO=5V
300
GI
Ta=100℃
100
DC CURRENT GAIN
OUTPUT VOLTAGE
VO(ON)
(mV)
300
Ta=100℃
Ta=25℃
100
Ta=25℃
30
10
30
3
10
1
10
3
OUTPUT CURRENT
CO
1
10
3
OUTPUT CURRENT
PD
VR
IO
30
100
125
150
(mA)
Ta
400
f=1MHz
Ta=25℃
350
(mW)
8
PD
CO
(pF)
0.3
(mA)
10
6
POWER DISSIPATION
OUTPUT CAPACITANCE
1
0.1
100
30
IO
4
2
300
250
200
150
DTC123JE
100
50
8
12
REVERSE BIAS VOLTAGE
REV.08
16
VR
(V)
50
75
AMBIENT TEMPERATURE
3 of 3
100
Ta
很抱歉,暂时无法提供与“DTC123JE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.13898
- 200+0.11128
- 600+0.09589
- 3000+0.07864
- 9000+0.07064
- 21000+0.06633
- 国内价格
- 1+0.08700
- 100+0.08120
- 300+0.07540
- 500+0.06960
- 2000+0.06670
- 5000+0.06496
