1N746...1N759
SILICON PLANAR ZENER DIODES
Standard Zener voltage tolerance is ± 10%. Add suffix
"A" for ± 5% tolerance. Other tolerances, nonMax. 0.5
standard and higher Zener voltages are upon request.
Min. 27.5
Max. 1.9
Black
Cathode Band
Black
Part No.
Black
"ST" Brand
XXX
Max. 3.9
ST
H
C
Min. 27.5
E
T
M
E
S
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Power Dissipation
Ptot
Junction Temperature
Tj
Storage Temperature Range
1)
Symbol
TStg
Glass Case DO-35
Dimensions in mm
Value
Unit
1)
mW
500
175
O
- 65 to + 175
O
C
C
Valid provided that leads are kept at ambient temperature at a distance of 8 mm from case
Characteristics at Ta = 25 OC
Parameter
Thermal Resistance Junction to Ambient Air
Forward Voltage
at IF = 200 mA
1)
Symbol
RthA
VF
Max.
0.3
1)
1.2
Valid provided that leads are kept at ambient temperature at a distance of 8 mm from case.
SEMTECH ELECTRONICS LTD.
Subsidiary of Sino-Tech International (BVI) Limited
Dated : 13/06/2007
Unit
K/mW
V
1N746...1N759
Zener Voltage Range 1)
Type
Maximum Zener
Impedance
Maximum Reverse Leakage Current
IR at VR = 1 V
2)
Maximum
Regulator
Current
IZM (mA)
Ta = 25 OC
Ta = 150 OC
IR (µA)
IR (µA)
10
30
110
24
10
30
100
10
30
95
2
30
85
4.7
2
30
75
5.1
1
1N752
5.6
1
1N753
6.2
0.1
1N754
6.8
0.1
1N755
7.5
0.1
1N756
8.2
0.1
1N757
9.1
0.1
1N758
10
0.1
1N759
12
0.1
Vznom
(V)
lZT (mA)
ZZT (Ω) at IZT
1N746
3.3
1N747
3.6
1N748
3.9
1N749
4.3
1N750
1N751
2)
E
T
M
E
S
Tested with pulses tp = 20 ms
500
Power Dissipation: Ptot (mW)
1)
H
C
400
300
200
100
100
150
Ambient Temperature: Ta ( C)
200
O
Power Derating Curve
Dated : 13/06/2007
很抱歉,暂时无法提供与“1N751A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.08881
- 100+0.08281
- 300+0.07681
- 500+0.07081
- 2000+0.06781
- 5000+0.06601
