012'*3*4('5)****67089:9;**9?**@+4**AB;++=*********************
0CD*+,($*-./)***6709:E;9]$
J*$B-"ST"1,4$90W"-&1,"U$$
^5R//Z$&'$DE_^$F_`$a)22+"'$b5R//Z$
M*$AST.#&W"1'$="-."+$!"+.+'&1,"U$ FRcI&d*$
N*$='0-&["$9"Z/"-&'T-"$!&1["U$$
QCR_$e$bNE_$
P*$)/"-&'.1[$9"Z/"-&'T-"$
QFR_$e$bNE_$
5R*B-"ST"1,4$='&f.W.'4U$
!"2"-$'0$)/"-&'.1[$9"Z/"-&'T-"$
^5R@@I$QDE_$e$bNE_$
55*$%-.#"$>"#"WU$$$$$$$$$$$$$$$$$$$5RRTghI&d$
5D*$>0&X$;&/&,.'&1,"\;>]U$$
M*R/B$
5F*$=iT1'$;&/&,.'&1,"U$$
F*R/B$I8Y$
5C*$?1+TW&'.01$-"+.+'&1,"$U$$
ERRIc$Z.1$h%;$5RRG$
5E*$8[.1[U$$
^5*R//Zh5]$X&'&$&1X$F-X$0-X"-$,T-#"$2.''.1[$X&'&$0#"-$
0/"-&'.01$'"Z/"-&'T-"$T1X"-$/"-$D_$'"+'*$
?'"Z$
I.1$
(0Z$
I&d$
71.'+$
(0'"+$
=W0/"5$
QR*RE$
QR*RE$
//Z$
aQ5R_eJR_$
=W0/"D$
QR*5$
R*5$
//Z$
aQFR_eNE_$
Page 5
TEL 0722-7509016
FAX 0722-7509036
!! ;"(51'9/,(3'#,01*/2/*&(/3.,#
@&-&Z"'"-$
9i"-Z.+'0-$+.V"$U$R*JZZdR*FZZ
I.1$ 9#9&'?/.8#
"#-!'./0&)1,!
Frequency (MHz)
eg. 26.0=26.000000MHz
26.0
T YWW
Week of the year
Y: Year code
TKD
Page 7
TEL 0722-7509016
FAX 0722-7509036
2+'3+)()4*!
'.4(/&.5*!
5$
@&,q&["$
;"-&Z.,$\8?D)F]$
D$
>.X$
LG\B"h;0h(.]$
F$
;-4+'&W$OW&1q$
AW",'-0X"$
=.)D$
(0fW"$I"'&W\8T]$
E$
8Xi"+.#"$
!"+.1s8[$
J$
9i"-Z.+'0-$
;"-&Z.,$\8?D)F]b$
8[b(.$
M$
=0WX"-$
=1$
C$
Page 8
TEL 0722-7509016
FAX 0722-7509036
!! A"RELIABILITY SPECIFICATION#
REFER!
&4('!
FREE FALL
2+)%&4&+)*!
BASIS OF VERDICT!
FREE DROPPING FROM 100 cm HEIGHT 3 TIMES
ON A HARD WOODEN BOARD.
FREQUENCY
VIBRATION
6&*!2!"78$!
10
55Hz,
AMPLITUDE (TOTAL EXCURSION)
SWEEP TIME
F±2ppm
CI±15% or 5Ω
1.5mm 15%,
F±2ppm
CI±15% or 5Ω
1MIN, 3 DIRECTION(X, Y, Z) EACH
FOR 2 Hrs.
THE CRYSTAL UNIT SHALL BE SUBJECTED TO 500
SUCCESSIVE CHANGE OF TEMPERATURE CYCLES
+85+4/-0
TEMPERATURE
CYCLE
30
+25
3min
F±2ppm
CI±15% or 5Ω
2
30
3min
1 Cycle
15±5sec
260±5℃
RESISTANCE
TO SOLDERING
HEAT
150~200℃
90±30sec
HIGH TEMP. &
HUMIDITY
HIGH
TEMPERATURE
STORAGE
F±2pm
CI±15% or 5Ω
2 times
217℃
STORED AT 60 2
240
105±45sec
AND HUMIDITY 90
95% FOR
12 H.
STORED AT 85±2
F±2ppm
CI±15% or 5Ω
FOR 500±12H. ( If Customer's
temperature request is higher than the
standard,Temperature test must be done for customer
F±5ppm
CI±15% or 5Ω
requirements. )
LOW
TEMPERATURE
STORAGE
STORED AT –40±2
temperature request is lower than the
F±5ppm
CI±15% or 5Ω
requirements. )
Page 9
TEL 0722-7509016
FAX 0722-7509036
FINE LEAK
SOLDERABILITY
HELIUM BOMBING 5.0
5.5 Kgf / cm FOR 2 HOURS.
THE LEAD IS IMMERSED IN A 260 5
SOLDER
BATH WITHIN 2±0.6 SECONDS.
≤1×10-9Pa.m3/s
more than 95% of lead shall be
covered by new solder
SHALL BE PRESSURIZED AT A SPEED OF
APPROX.0.5mm/sec IN
THE DIRECTION INDICATED BY THE ARROW
UNTIL THE
TERMINAL
STRENGTH
BENDING WIDTH REACHES 3mm AND HELD FOR 5
SECONDS.
No peeling-off at a soldered part
A R0.5 JIG SHALL BE USED TO APPLY A 10N DEAD
LOAD IN THE
DIRECTION INDICATED BY THE ARROW TO THE
ELEMENT AND
RETAIN IT FOR 10 SECONDS.
STICKING
TENDENCY
A R0.5 PRESSURIZED BAR SHALL BE USED TO
APPLY A 10N
LOAD IN THE CENTER OF ELEMENT AND RETAIN
ELEMENT
ASSEMBLY
IT FOR 10
SECONDS.
STRENGTH
Page 10
TEL 0722-7509016
FAX 0722-7509036
!! B"#0&*?/.8#
9#$$2.//&(/!4:3(;T1.'UZZ
很抱歉,暂时无法提供与“SXT25Y026000B71T01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.93600
- 10+0.85600
- 30+0.84000
- 国内价格
- 1+0.93599
- 10+0.85599
- 30+0.83999
