NSI8120N1
NSI8120N1
    NOVOSENSE(纳芯微)
    SOIC8_150MIL
    High Reliability Dual-Channel Digital Isolators
NSI8120N1 数据手册
NSi8120/NSi8121/NSi8122: High Reliability Dual-Channel Digital Isolators Datasheet (EN) 1.8 Safety Regulatory Approvals EN TI The NSi812x devices are high reliability dual-channel digital isolator. The NSi812x device is safety certified by UL1577 support several insulation withstand voltages (3.75kVrms, 5kVrms), while providing high electromagnetic immunity and low emissions at low power consumption. The data rate of the NSi812x is up to 150Mbps, and the common-mode transient immunity (CMTI) is up to 150kV/us. The NSi812x device provides digital channel direction configuration and the default output level configuration when the input power is lost. Wide supply voltage of the NSi812x device support to connect with most digital interface directly, easy to do the level shift. High system level EMC performance enhance reliability and stability of use. AEC-Q100 (Grade 1) option is provided for all devices. AL Product Overview Key Features  UL recognition: up to 5000Vrms for 1 minute per UL1577  CQC certification per GB4943.1-2011  CSA component notice 5A  DIN VDE V 0884-11:2017-01 ID Applications  Up to 5000Vrms Insulation voltage  Date rate: DC to 150Mbps NF  Power supply voltage: 2.5V to 5.5V  All devices are AEC-Q100 qualified  High CMTI: 150kV/us  Chip level ESD: HBM: ±6kV  Industrial automation system  Isolated SPI, RS232, RS485  General-purpose multichannel isolation  Motor control Functional Block Diagrams CO  High system level EMC performance: Enhanced system level ESD, EFT, Surge immunity  Default output high level or low level option VDD1 1 8 VDD2 VDD1 1 8 VDD2 INA 2 7 OUTA OUTA 2 7 INA INB 3 6 OUTB INB 3 5 GND2 GND1 4 GND1 4 NSi8120  Isolation barrier life: >60 years  Low power consumption: 1.5mA/ch (1 Mbps)  Low propagation delay: 400 um Distance through insulation V DIN EN 60112 (VDE 0303-11); IEC 60112 EN TI Minimum internal gap AL SOIC-8 Material Group Ⅱ 3.2. DIN VDE V 0884-11(VDE V 0884-11):2017-01 INSULATION CHARATERISTICS Description Test Condition Symbol Value SOIC-16 For Rated Mains Voltage ≤ 150Vrms Ⅰto Ⅳ Ⅰto Ⅳ Ⅰto Ⅲ Ⅰto Ⅳ For Rated Mains Voltage ≤ 400Vrms Ⅰto Ⅲ Ⅰto Ⅳ ID SOIC-8 Unit NF Installation Classification per DIN VDE 0110 For Rated Mains Voltage ≤ 300Vrms CO Climatic Classification 10/105/21 Pollution Degree per DIN VDE 0110, 2 10/105/2 1 2 Table 1 Maximum repetitive isolation voltage Input to Output Test Voltage, Method B1 V IORM × 1.5 = V pd (m) , 100% production test, VIORM 565 849 Vpeak V pd (m) 847 1273 Vpeak V pd (m) 678 1018 Vpeak t ini = t m = 1 sec, partial discharge < 5 pC Input to Output Test Voltage, Method A After Environmental Tests Subgroup 1 Copyright © 2019, NOVOSENSE V IORM × 1.2= V pd (m) , t ini = 60 sec, t m = 10 sec, partial discharge < 5 pC Page 9 NSi8120/NSi8121/NSi8122 Test V IORM × 1.2= V pd (m) , t ini = 60 sec, t m = 10 sec, partial discharge < 5 pC V pd (m) 678 1018 Vpeak t = 60 sec VIOTM 5300 7000 Vpeak Test method per IEC60065,1.2/50us waveform, VTEST=VIOSM×1.3 VIOSM 5384 5384 Vpeak VIO =500V RIO >109 >109 Ω Maximum transient isolation voltage Maximum Surge Isolation Voltage Isolation resistance Isolation capacitance AL After Input and /or Safety Subgroup 2 and Subgroup 3 f = 1MHz Input capacitance CIO 0.6 CI 2 Ps EN TI Total Power Dissipation at 25℃ θJA = 140 °C/W, V I = 5.5 V, T J = 150 °C, T A = 25 °C Safety input, output, or supply current Is 2 pF 1499 mW 150 mA 237 mA 150 ℃ CO NF ID Saftey Limiting Current (mA) Ts 180 160 140 120 100 80 60 40 20 0 pF 160 θJA = 84 °C/W, V I = 5.5 V, T J = 150 °C, T A = 25 °C Case Temperature 0.6 0 50 100 150 200 Case Temperature (℃) Figure 3.1 NSi8120N/NSi8121N/NSi8122N Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 Saftey Limiting Current (mA) 250 200 150 100 50 0 0 50 100 150 200 Case Temperature (℃) Figure 3.2 NSi8120W/NSi8121W/NSi8122W Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 Copyright © 2019, NOVOSENSE Page 10 NSi8120/NSi8121/NSi8122 3.3. REGULATORY INFORMATION The NSi8120N/NSi8121N/NSi8122N are approved by the organizations listed in table. CUL UL 1577 Component Recognition Program1 VDE Approved under CSA Component Acceptance Notice 5A DIN VDE V 088411:2017-012 CQC Certified by CQC11471543-2012 GB4943.1-2011 Single Protection, 3750Vrms Isolation voltage File (E500602) 1 File (E500602) Basic Insulation 565Vpeak, VIOSM=5384Vpeak Basic insulation at 400Vrms (565Vpeak) AL Single Protection, 3750Vrms Isolation voltage File (5024579-48800001) File (pending) In accordance with UL 1577, each NSi8120N/NSi8121N/NSi8122N is proof tested by applying an insulation test voltage ≥ 4500 V rms for 1 sec. 2 EN TI In accordance with DIN VDE V 0884-11, each NSi8120N/NSi8121N/NSi8122N is proof tested by applying an insulation test voltage ≥ 847 V peak for 1 sec (partial discharge detection limit = 5 pC). The * marking branded on the component designates DIN VDE V 0884-11 approval. The NSi8120W/NSi8121W/NSi8122W are approved by the organizations listed in table. CUL UL 1577 Component Recognition Program1 DIN VDE V 088411(VDE V 088411):2017-012 Certified by CQC11471543-2012 Single Protection, 5000Vrms Isolation voltage Basic Insulation 849Vpeak, VIOSM=5384Vpeak Basic insulation at 800Vrms (1131Vpeak) File (E500602) NF File (E500602) 1 CQC Approved under CSA Component Acceptance Notice 5A ID Single Protection, 5000Vrms Isolation voltage VDE File (5024579-48800001) GB4943.1-2011 Reinforced insulation at 400Vrms (565Vpeak) File (pending) In accordance with UL 1577, each NSi8120W/NSi8121W/NSi8122W is proof tested by applying an insulation test voltage ≥ 6000 V rms for 1 sec. 2 CO In accordance with DIN VDE V 0884-11, each NSi8120W/NSi8121W/NSi8122W is proof tested by applying an insulation test voltage ≥ 1273 V peak for 1 sec (partial discharge detection limit = 5 pC). The * marking branded on the component designates DIN VDE V 0884-11 approval. 4.0 FUNCTION DESCRIPTION The NSi812x is a Dual-channel digital isolator based on a capacitive isolation barrier technique. The digital signal is modulated with RF carrier generated by the internal oscillator at the Transmitter side. Then it is transferred through the capacitive isolation barrier and demodulated at the Receiver side. The NSi812x devices are high reliability dual-channel digital isolator with AEC-Q100 qualified. The NSi812x device is safety certified by UL1577 support several insulation withstand voltages (3.75kVrms, 5kVrms), while providing high electromagnetic immunity and low emissions at low power consumption. The data rate of the NSi812x is up to 150Mbps, and the common-mode transient immunity (CMTI) is up to 150kV/us. The NSi812x device provides digital channel direction configuration and the default output level configuration when the input power is lost. Wide supply voltage of the NSi812x device support to connect with most digital interface directly, easy to do the level shift. High system level EMC performance enhance reliability and stability of use. The NSi812x has a default output status when VDDIN is unready and VDDOUT is ready as shown in Table 4.1, which helps for diagnosis when power is missing at the transmitter side. The output B follows the same status with the input A within 1us after powering up. Copyright © 2019, NOVOSENSE Page 11 NSi8120/NSi8121/NSi8122 Table 4.1 Output status vs. power status Input VDD1 status VDD2 status Output Comment H Ready Ready H Normal operation. L Ready Ready L X Unready Ready L The output follows the same status with the input within 60us after input side VDD1 is powered on. H Unready X The output follows the same status with the input within 60us after output side VDD2 is powered on. AL 5.0 Ready APPLICATION NOTE EN TI X 5.1. PCB LAYOUT The NSi812x requires a 0.1 µF bypass capacitor between VDD1 and GND1, VDD2 and GND2. The capacitor should be placed as close as possible to the package. Figure 5.1 to Figure 5.4 show the recommended PCB layout, make sure the space under the chip should keep free from planes, traces, pads and via. To enhance the robustness of a design, the user may also include resistors (50–300 Ω ) in series with the inputs and outputs if the system is excessively noisy. The series resistors also improve the system reliability such as latch-up immunity. NF ID The typical output impedance of an isolator driver channel is approximately 50 Ω, ±40%. When driving loads where transmission line effects will be a factor, output pins should be appropriately terminated with controlled impedance PCB traces. Figure5.2 Recommended PCB Layout — Bottom Layer CO Figure5.1 Recommended PCB Layout — Top Layer Figure5.3 Recommended PCB Layout — Top Layer Figure5.4 Recommended PCB Layout — Bottom Layer 5.2. HIGH SPEED PERFORMANCE Figure 5.5 shows the eye diagram of NSi812x at 200Mbps data rate output. The result shows a typical measurement on the NSi812x with 350ps p-p jitter. Copyright © 2019, NOVOSENSE Page 12 EN TI AL NSi8120/NSi8121/NSi8122 Figure5.5 NSi812x Eye Diagram 5.3. TYPICAL SUPPLY CURRENT EQUATIONS The typical supply current of NSi812x can be calculated using below equations. IDD1 and IDD2 are typical supply currents measured in mA, f is data rate measured in Mbps, CL is the capacitive load measured in pF NSi8120: ID IDD1 = 0.19 *a1+1.45*b1+0.82*c1. IDD2 = 1.36+ VDD1*f* CL *c1*10-9 When a1 is the channel number of low input at side 1, b1 is the channel number of high input at side 1, c1 is the channel number of switch signal input at side 1. NF NSi8121/ NSi8122: IDD1 = 0.87 +1.26*b1+0.63*c1+ VDD1*f* CL *c2*10-9 IDD2 = 0.87 +1.26*b2+0.63*c2+ VDD1*f* CL *c1*10-9 When b1 is the channel number of high input at side 1, c1 is the channel number of switch signal input at side 1, b2 is the channel number of high input at side 2, c2 is the channel number of switch signal input at side 2. PACKAGE INFORMATION CO 6.0 VDD1 1 8 VDD2 VDD1 1 8 VDD2 INA 2 7 OUTA OUTA 2 7 INA INB 3 6 OUTB INB 3 5 GND2 GND1 4 GND1 4 NSi8120 Figure 6.1 NSi8120N Package Copyright © 2019, NOVOSENSE 6 OUTB NSi8121 5 GND2 Figure 6.2 NSi8121N Package Page 13 NSi8120/NSi8121/NSi8122 VDD1 1 8 VDD2 INA 2 7 OUTA OUTB 3 GND1 4 6 INB NSi8122 5 GND2 ID EN TI AL Figure 6.3 NSi8122N Package Figure 6.4 SOIC8 Package Shape and Dimension in millimeters (inches) Table6.1 NSi8120N/ NSi8121N/ NSi8122N Pin Configuration and Description NSi8121N PIN NO. NSi8122N PIN NO. SYMBOL FUNCTION 1 1 1 VDD1 Power Supply for Isolator Side 1 7 2 INA Logic Input A 3 6 INB Logic Input B 4 4 4 GND1 Ground 1, the ground reference for Isolator Side 1 5 5 5 GND2 Ground 2, the ground reference for Isolator Side 2 6 6 3 OUTB Logic Output B 7 2 7 OUTA Logic Output A 8 8 8 VDD2 Power Supply for Isolator Side 2 2 CO 3 NF NSi8120N PIN NO. Copyright © 2019, NOVOSENSE Page 14 NSi8120/NSi8121/NSi8122 GND1 1 16 GND2 NC 2 15 NC GND1 1 16 GND2 NC 2 15 NC VDD1 3 14 VDD2 VDD1 3 14 VDD2 INA 4 13 OUTA OUTA 4 13 INA INB 5 12 OUTB INB 5 NC 6 11 NC NC 6 11 NC GND1 7 10 NC GND1 7 10 NC NSi8120 9 GND2 NC 8 NSi8121 9 GND2 Figure 6.6 NSi8121W Package EN TI Figure 6.5 NSi8120W Package AL NC 8 12 OUTB GND1 1 16 GND2 NC 2 15 NC VDD1 3 14 VDD2 INA 4 13 OUTA 12 INB NC 6 11 NC GND1 7 10 NC ID OUTB 5 NSi8122 9 GND2 NF NC 8 CO Figure 6.7 NSi8122W Package Figure 6.8 WB SOIC16 Package Shape and Dimension in millimeters and (inches) Copyright © 2019, NOVOSENSE Page 15 NSi8120/NSi8121/NSi8122 Table 6.2 NSi8120W/ NSi8121W/ NSi8122W Pin Configuration and Description NSi8121W PIN NO. NSi8122W PIN NO. SYMBOL FUNCTION 1 1 1 GND1 Ground 1, the ground reference for Isolator Side 1 2 2 2 NC No Connection. 3 3 3 VDD1 Power Supply for Isolator Side 1 4 13 4 INA Logic Input A 5 5 12 INB 6 6 6 NC 7 7 7 GND1 8 8 8 9 9 9 10 10 10 11 11 11 12 12 5 13 4 13 14 14 15 15 16 16 AL NSi8120W PIN NO. Logic Input B No Connection. EN TI Ground 1, the ground reference for Isolator Side 1 No Connection. GND2 Ground 2, the ground reference for Isolator Side 2 NC No Connection. NC No Connection. OUTB Logic Output A OUTA Logic Output B ID NC VDD2 Power Supply for Isolator Side 2 15 NC No Connection. 16 GND2 Ground 2, the ground reference for Isolator Side 2 CO NF 14 Copyright © 2019, NOVOSENSE Page 16 NSi8120/NSi8121/NSi8122 TAPE AND REEL INFORMATION CO NF ID EN TI AL 7.0 Copyright © 2019, NOVOSENSE Page 17 EN TI AL NSi8120/NSi8121/NSi8122 CO NF ID Figure 7.1 Tape and Reel Information of SOIC8 Copyright © 2019, NOVOSENSE Page 18 CO NF ID EN TI AL NSi8120/NSi8121/NSi8122 Figure 7.2 Tape and Reel Information of WB SOIC16 Copyright © 2019, NOVOSENSE Page 19 NSi8120/NSi8121/NSi8122 8.0 ORDER INFORMATION Part No. Isolation Rating(kV) Number of side 1 inputs Number of side 2 inputs Max Data Rate (Mbps) Default Output State Temperature Automotive Package NF ID EN TI AL NSi8120N0 3.75 2 0 150 Low NO SOIC8 -40 to 125℃ NSi8120N1 3.75 2 0 150 High NO SOIC8 -40 to 125℃ NSi8121N0 3.75 1 1 150 Low NO SOIC8 -40 to 125℃ NSi8121N1 3.75 1 1 150 High NO SOIC8 -40 to 125℃ NSi8122N0 3.75 1 1 150 Low NO SOIC8 -40 to 125℃ NSi8122N1 3.75 1 1 150 High NO SOIC8 -40 to 125℃ NSi8120W0 5 2 0 150 Low NO WB SOIC16 -40 to 125℃ NSi8120W1 5 2 0 150 High NO WB SOIC16 -40 to 125℃ NSi8121W0 5 1 1 150 Low NO WB SOIC16 -40 to 125℃ NSi8121W1 5 1 1 150 High NO WB SOIC16 -40 to 125℃ NSi8122W0 5 1 1 150 Low NO WB SOIC16 -40 to 125℃ NSi8122W1 5 1 1 150 High NO WB SOIC16 -40 to 125℃ NSi8120N0Q 3.75 2 0 150 Low YES SOIC8 -40 to 125℃ NSi8120N1Q 3.75 2 0 150 High YES SOIC8 -40 to 125℃ NSi8121N0Q 3.75 1 1 150 Low YES SOIC8 -40 to 125℃ NSi8121N1Q 3.75 1 1 150 High YES SOIC8 -40 to 125℃ NSi8122N0Q 3.75 1 1 150 Low YES SOIC8 -40 to 125℃ NSi8122N1Q 3.75 1 1 150 High YES SOIC8 -40 to 125℃ NSi8120W0Q 5 2 0 150 Low YES WB SOIC16 -40 to 125℃ NSi8120W1Q 5 2 0 150 High YES WB SOIC16 -40 to 125℃ NSi8121W0Q 5 1 1 150 Low YES WB SOIC16 -40 to 125℃ NSi8121W1Q 5 1 1 150 High YES WB SOIC16 -40 to 125℃ NSi8122W0Q 5 1 1 150 Low YES WB SOIC16 -40 to 125℃ NSi8122W1Q 5 1 1 150 High YES WB SOIC16 -40 to 125℃ NOTE: All packages are RoHS-compliant with peak reflow temperatures of 260 °C according to the JEDEC industry standard classifications and peak solder temperatures. All devices are AEC-Q100 qualified. CO Part Number Rule: NSi(81)(2)(1)(N)(1)(Q) Series Number Total Channel Amount: N=N Channels N=1,2,4… N=0: I2C Part Reverse Channel Amount: N=N Channels N=0,1,2… Copyright © 2019, NOVOSENSE Q = Automotive version Fail-Safe Output State: 0 = Logic Low 1 = Logic High Package Type: N= NB SOIC8 W= WB SOIC16 Page 20 NSi8120/NSi8121/NSi8122 9.0 REVISION HISTORY Description Original Change to Ordering information Add maximum operation current specification. Change block diagram Correct Table 6.2 Pin No. Add specification “Input Pull high or low Current” Date 2017/11/15 2018/3/26 2018/6/20 2018/7/28 2018/8/20 2018/9/10 1.6 Add “Maximum Input/Output Pulse Voltage” 2018/10/9 1.7 1.8 Change to Ordering information Change Certification Information AL Revision 1.0 1.1 1.2 1.3 1.4 1.5 CO NF ID EN TI 2018/12/20 2019/06/17 Copyright © 2019, NOVOSENSE Page 21
NSI8120N1 价格&库存
很抱歉,暂时无法提供与“NSI8120N1”相匹配的价格&库存,您可以联系我们找货
NSI8120N1
  • 1+3.38960
  • 10+3.12684
  • 30+3.07429
  • 100+2.91663
库存:1
NSI8120N1
    • 1+7.65720
    • 10+6.36120
    • 30+5.64840
    • 100+4.84920
    • 500+4.48200
    • 1000+4.32000
    NSI8120N1
      • 1+6.08580
