CRYSTAL RESONANCER
SERIES 6LC, SMD 8.0*3.8MM TUNING FORK WATCH CRYSTAL
深圳市晶科鑫实业有限公司
Shenzhen Crystal Technology Industrial Co., Ltd
APPROVAL SHEET
CUSTOMER P/N:
TYPE:
DESCRIPTION:
P N/ SJK:
SMD CRYSTAL
SMD308C 32.768KHZ
MSL:
-40~85℃
6LC32768F06UC
ENVIRONMENTAL: ■RoHS
REVISION:
6PF ±20PPM
A1
■REACH
■HF
□PAHS
2017-5-10
□other
MOQ:3000pcs/real
Levels 1
SIGNATURE
SUPPLIER
Issue
Check
CUSTOMER
Approve
QA
SJK
Signature
FAE_EMAIL
Date
Date
Check
Approve: □accept
Approve
□unaccepted
Note:
Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718
http://www.q-crystal.com
ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen
1 /4
CRYSTAL RESONANCER
1. FEATURE
Wide Frequency range
Small size
Tape & Reel
2. APPLICATIONS
Microprocessor Systems
Consumer Electronics
3. ELECTRICAL SPECIFICATIONS
Frequency
32.768KHz
Frequency Tolerance(at 25°C)
±20ppm
Load Capacitance(C L )
6PF
ESR
50 KΩ Max
Turnover Temperature
25 ± 3°C
Frequency stability vs Temperature Range
-40 °C to + 85 °C
Frequency Temperature Curve
-0.04ppm/°C² MAX
Storage Temperature Range
-55 °C to +125 °C
Operating Temperature Range
-40 °C to +85 °C
Shunt Capacitance (C0)
0.9pF Typ
Dynamic Capacitance (C1)
2.6fF Typ
Driver Level (Typical)
1 µW Max
Insulation Resistance
500MΩ MIN at DC100V±15V
Aging @25°C 1st year (Max)
±3ppm/year max
REMARK: SPECIFICATIONS SUBJECT TO CHANGE WITHOUT PRIOR NOTICE. PLEASE CONFIRM WITH
OUR SALES ENGINEER.
2 /4
CRYSTAL RESONANCER
4. DIMENSION (Units: mm)
5. MARKING
6. REFLOW CONDITION
7. FREQUENCY VS TEMPERATURE CURVE
3 /4
CRYSTAL RESONANCER
8. RELIABILITY TEST SPECIFICATION
1.Mechanical Endurance
No.
Test Item
Test Methods
REF.DOC
1.1
Drop Test
150 cm height, 3 times on concrete floor.
JIS C6701
1.2
Mechanical
Shock
1.3
Vibration
1.4
Gross Leak
Standard Sample For Automatic
Detector, Test Pressure: 2Kg / cm2
1.5
Fine Leak
Helium Bombing 4.5 Kg/ cm2 for 2 hr
1.6
Solder ability
Device are shocked to half sine wave ( 1000 G )
three mutually perpendicular axes each 3 times.
0.5m sec. duration time
Frequency range
10 ~ 2000 Hz
Amplitude
1.52 mm/20G
Sweep time
20 minute
Perpendicular axes each test time
4 hours
(Total test time 12 hours)
Temperature
Immersing depth
Immersion time
Flux
Gross
Leak
245 ℃ ± 5℃
0.5 mm minimum
5 ± 1 seconds
Rosin resin methyl alcohol
solvent ( 1 : 4 )
MIL-STD-202F
MIL-STD-883E
MIL-STD-883E
MIL-STD-883E
MIL-STD-883E
2.Environmental Endurance
No.
Test Item
Test Methods
2.1
Resistance
To
Soldering Heat
Pre-heat temperature
Pre-heat time 60 ~
Test temperature
Test time
2.2
2.3
High
Temp. Storage
Low
Temp.
Storage
REF.DOC
125 ℃
120 sec.
260 ± 5 ℃
10 ± 1 sec.
MIL-STD-202F
+ 125 ℃ ± 3 ℃ for 500 ± 12 hours
MIL-STD-883E
- 40 ℃ ± 3 ℃ for 500 ± 12 hours
MIL-STD-883E
Total 100 cycles of the following temperature cycle
2.4
2.5
2.6
Thermal Shock
High Temp
&Humidity
Pressure
Cooker Storage
MIL-STD-883E
85℃ ± 3℃, RH 85% , 500Hrs
JIS C5023
121 ± 3℃ , RH100% , 2 bar , 240Hrs
JIS C6701
4 /4
很抱歉,暂时无法提供与“6LC32768F06UC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.44540
- 30+1.39590
- 100+1.34640
- 500+1.24740
- 1000+1.19790
- 2000+1.16820
