AO4616
www.VBsemi.tw
N- and P-Channel 30 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
N-Channel
P-Channel
ID (A)a Qg (Typ.)
RDS(on) (Ω)
30
- 30
0.018 at VGS = 10 V
8e
0.020 at VGS = 8 V
8e
6.2
e
0.024 at VGS = 4.5 V
8
0.032 at VGS = - 10 V
- 8e
e
0.034 at VGS = - 8 V
-8
0.040 at VGS = - 4.5 V
- 7.5
• Halogen-free According to IEC 61249-2-21
Definition
• TrenchFET® Power MOSFET
• 100 % Rg and UIS Tested
• Compliant to RoHS Directive 2002/95/EC
APPLICATIONS
18.5
• Motor Drive
• Mobile Power Bank
D1
S2
SO-8
S1
1
8
D1
G1
2
7
D1
S2
3
6
D2
G2
4
5
D2
G2
G1
S1
D2
ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted)
Parameter
Symbol
N-Channel
P-Channel
Drain-Source Voltage
VDS
30
- 30
Gate-Source Voltage
VGS
± 20
± 20
8e
- 8e
6.8
- 6.8
6.8b, c
- 6.6b, c
b, c
- 5.3b, c
- 40
TC = 25 °C
Continuous Drain Current (TJ = 150 °C)
TC = 70 °C
TA = 25 °C
ID
TA = 70 °C
Source-Drain Current Diode Current
TC = 25 °C
TA = 25 °C
Pulsed Source-Drain Current
Single Pulse Avalanche Current
Single Pulse Avalanche Energy
Maximum Power Dissipation
5.4
40
IDM
Pulsed Drain Current (10 µs Pulse Width)
L = 0.1 mH
2.6
- 2.6
ISM
- 1.6b, c
- 40
IAS
10
- 20
EAS
5
TC = 25 °C
3.1
3.2
TC = 70 °C
2
2.1
2b, c
2b, c
TA = 25 °C
PD
TA = 70 °C
1.28b, c
TJ, Tstg
Operating Junction and Storage Temperature Range
V
1.6b, c
40
IS
Unit
A
mJ
W
1.28b, c
- 55 to 150
°C
THERMAL RESISTANCE RATINGS
N-Channel
Parameter
Maximum Junction-to-Ambient
b, d
Maximum Junction-to-Foot (Drain)
Symbol
Typ.
Max.
t ≤ 10 s
RthJA
50
Steady State
RthJF
30
P-Channel
Typ.
Max.
62.5
47
62.5
40
29
38
Unit
°C/W
Notes:
a. Based on TC = 25 °C.
b. Surface mounted on 1" x 1" FR4 board.
c. t = 10 s.
d. Maximum under steady state conditions is 120 °C/W (n-channel) and 110 °C/W (p-channel).
e. Package limited.
E-mail:China@VBsemi TEL:86-755-83251052
1
AO4616
www.VBsemi.tw
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Parameter
Symbol
Min.
Test Conditions
Typ.a
Max.
Unit
Static
Drain-Source Breakdown Voltage
VDS Temperature Coefficient
VGS(th) Temperature Coefficient
Gate Threshold Voltage
Gate-Body Leakage
Zero Gate Voltage Drain Current
On-State Drain Currentb
Drain-Source On-State Resistanceb
Forward Transconductanceb
VDS
ΔVDS/TJ
ΔVGS(th)/TJ
VGS(th)
IGSS
IDSS
ID(on)
RDS(on)
gfs
VGS = 0 V, ID = 250 µA
N-Ch
30
VGS = 0 V, ID = - 250 µA
P-Ch
- 30
ID = 250 µA
N-Ch
V
40
ID = - 250 µA
P-Ch
- 34
ID = 250 µA
N-Ch
- 4.1
5
mV/°C
ID = - 250 µA
P-Ch
VDS = VGS, ID = 250 µA
N-Ch
1.0
VDS = VGS, ID = - 250 µA
P-Ch
- 1.0
VDS = 0 V, VGS = ± 12 V
N-Ch
± 100
P-Ch
± 100
2.0
- 2.0
VDS = 30 V, VGS = 0 V
N-Ch
1
VDS = - 30 V, VGS = 0 V
P-Ch
-1
VDS = 30 V, VGS = 0 V, TJ = 55 °C
N-Ch
10
VDS = - 30 V, VGS = 0 V, TJ = 55 °C
P-Ch
- 10
VDS = 5 V, VGS = 10 V
N-Ch
VDS = - 5 V, VGS = - 10 V
P-Ch
- 20
VGS = 10 V, ID = 6.8 A
N-Ch
V
nA
µA
A
0.018
VGS = - 10 V, ID = - 8 A
P-Ch
0.040
VGS = 8 V, ID = 6.7 A
N-Ch
0.020
VGS = - 8 V, ID = - 6.5 A
P-Ch
0.044
VGS = 4.5 V, ID = 6.6 A
N-Ch
0.024
VGS = - 4.5 V, ID = - 5 A
P-Ch
0.050
VDS = 15 V, ID = 6.8 A
N-Ch
27
VDS = - 15 V, ID = - 6.7 A
P-Ch
25
N-Ch
510
Ω
S
Dynamica
Input Capacitance
Output Capacitance
Reverse Transfer Capacitance
Total Gate Charge
Gate-Source Charge
Gate-Drain Charge
Gate Resistance
Ciss
N-Channel
VDS = 20 V, VGS = 0 V, f = 1 MHz
Coss
Crss
Qg
P-Channel
VDS = - 20 V, VGS = 0 V, f = 1 MHz
Rg
620
N-Ch
95
P-Ch
115
N-Ch
33
P-Ch
57
pF
VDS = 20 V, VGS = 10 V, ID = 10 A
N-Ch
6
10
VDS = - 20 V, VGS = - 10 V, ID = - 10 A
P-Ch
41.5
63
N-Ch
5.8
7
N-Channel
VDS = 20 V, VGS = 4.5 V, ID = 10 A
P-Ch
16
22
N-Ch
1.6
P-Channel
VDS = - 20 V, VGS = - 4.5 V, ID = - 10 A
P-Ch
4.3
N-Ch
1.4
Qgs
Qgd
P-Ch
7
P-Ch
f = 1 MHz
nC
N-Ch
0.3
1.1
2.3
P-Ch
1.2
5.7
9.6
Ω
2
AO4616
www.VBsemi.tw
Parameter
Symbol
Test Conditions
Min.
Typ.a
Max.
Unit
Dynamica
td(on)
Turn-On Delay Time
tr
Rise Time
td(off)
Turn-Off Delay Time
tf
Fall Time
td(on)
Turn-On Delay Time
tr
Rise Time
Fall Time
P-Channel
VDD = - 20 V, RL = 2 Ω
ID ≅ - 10 A, VGEN = - 10 V, Rg = 1 Ω
N-Channel
VDD = 20 V, RL = 3.7 Ω
ID ≅ 5.4 A, VGEN = 4.5 V, Rg = 1 Ω
tf
P-Channel
ID ≅ - 10 A, VGEN = - 4.5 V, Rg = 1 Ω
IS
TC = 25 °C
td(off)
Turn-Off Delay Time
N-Channel
ID ≅ 5.4 A, VGEN = 10 V, Rg = 1 Ω
N-Ch
4
8
P-Ch
10
16
N-Ch
10
17
P-Ch
9
15
N-Ch
16
22
P-Ch
23
26
N-Ch
5
9
P-Ch
10
16
N-Ch
10
16
35
P-Ch
26
N-Ch
11
P-Ch
16
26
N-Ch
13
22
P-Ch
16
26
N-Ch
5
9
P-Ch
16
26
ns
Drain-Source Body Diode Characteristics
Continuous Source-Drain Diode Current
Pulse Diode Forward Current
a
Body Diode Voltage
ISM
VSD
N-Ch
2.6
P-Ch
- 2.6
N-Ch
40
P-Ch
A
- 40
IS = 5.4 A
N-Ch
0.81
1.2
IS = - 2 A
P-Ch
- 0.77
- 1.2
N-Ch
12
25
P-Ch
31
57
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Charge
Qrr
N-Channel
IF = 5 A, dI/dt = 100 A/µs, TJ = 25 °C
N-Ch
10
17
P-Ch
29
47
Reverse Recovery Fall Time
ta
P-Channel
IF = - 5 A, dI/dt = - 100 A/µs, TJ = 25 °C
N-Ch
10
P-Ch
13
Reverse Recovery Rise Time
tb
N-Ch
7
P-Ch
23
V
ns
nC
ns
Notes:
a. Guaranteed by design, not subject to production testing.
b. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
3
AO4616
www.VBsemi.tw
N-CHANNEL TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
40
10
VGS = 10 V thru 4 V
8
ID - Drain Current (A)
30
VGS = 3 V
TC = 25 °C
4
10
2
TC = 125 °C
TC = - 55 °C
1
1.5
VDS - Drain-to-Source Voltage (V)
2
0.6
1.2
1.8
2.4
VGS - Gate-to-Source Voltage (V)
Output Characteristics
3
Transfer Characteristics
1000
0.030
C - Capacitance (pF)
RDS(on) - On-Resistance (Ω)
800
0.025
VGS = 4.5 V
0.020
VGS = 8 V
600
Ciss
400
VGS = 10 V
0.015
200
Crss
Coss
10
On-Resistance vs. Drain Current and Gate Voltage
Capacitance
10
1.8
ID = 6.8 A
8
RDS(on) - On-Resistance (Normalized)
ID = 6.8 A
40
VDS = 32 V
6
VDS = 20 V
VDS = 10 V
4
2
6
9
12
15
1.6
VGS = 10 V; 4.5 V
1.4
1.2
1.0
0.8
0.6
- 50
- 25
50
75
100
125
Qg - Total Gate Charge (nC)
TJ - Junction Temperature (°C)
Gate Charge
On-Resistance vs. Junction Temperature
150
4
AO4616
www.VBsemi.tw
100
0.05
IS - Source Current (A)
ID = 6.8 A
TJ = 150 °C
10
TJ = 25 °C
1
0.1
0.04
TJ = 125 °C
0.03
TJ = 25 °C
0.02
0.01
0.0
0.3
0.6
0.9
1.2
VSD - Source-to-Drain Voltage (V)
4
6
8
Source-Drain Diode Forward Voltage
On-Resistance vs. Gate-to-Source Voltage
10
60
1.9
48
Power (W)
VGS(th) (V)
1.6
ID = 250 μA
1.3
36
24
1
12
0.7
- 50
- 25
50
75
100
125
150
0.01
TJ - Temperature (°C)
Threshold Voltage
0.1
Time (s)
1
10
Single Pulse Power, Junction-to-Ambient
100
Limited by RDS(on)*
10
100 μs
1 ms
1
10 ms
100 ms
0.1
TA = 25 °C
Single Pulse
BVDSS Limited
1s
10 s
DC
0.01
0.1
1
10
100
* VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area, Junction-to-Ambient
5
AO4616
www.VBsemi.tw
10
8
6
4
2
50
75
100
125
150
TC - Case Temperature (°C)
Current Derating*
4
1.25
1.0
Power (W)
Power (W)
3
2
0.75
0.50
1
0.25
50
75
100
125
Power Derating, Junction-to-Foot
150
50
75
100
125
150
TA - Ambient Temperature (°C)
Power Derating, Junction-to-Ambient
* The power dissipation PD is based on TJ(max) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package
limit.
6
AO4616
www.VBsemi.tw
1
Normalized Effective Transient
Thermal Impedance
Duty Cycle = 0.5
0.2
Notes:
0.1
0.1
PDM
0.05
t1
t2
1. Duty Cycle, D =
0.02
t1
t2
2. Per Unit Base = R thJA = 120 °C/W
3. T JM - T A = PDMZthJA(t)
Single Pulse
0.01
10 -4
10 -3
4. Surface Mounted
10 -2
10 -1
1
100
10
1000
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Ambient
1
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
0.01
10 -4
Single Pulse
10 -3
10 -2
10 -1
1
10
Normalized Thermal Transient Impedance, Junction-to-Foot
7
AO4616
www.VBsemi.tw
P-CHANNEL TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
40
10
V GS = 10 V thru 4 V
8
32
24
16
V GS = 3 V
6
4
T C = 25 °C
8
2
T C = 125 °C
T C = - 55 °C
V GS = 2 V
0.5
1.0
1.5
2.0
2
3
4
5
1000
0.090
VGS = 4.5 V
0.050
VGS = 8 V
VGS = 10 V
0.030
800
0.070
600
Ciss
400
200
Coss
Crss
30
40
16
24
32
Capacitance
1.8
10
ID = 8 A
ID = 10 A
40
8
V DS = 20 V
6
V DS = 10 V
V DS = 30 V
4
2
18
27
Gate Charge
36
45
1.6
V GS = 10 V
1.4
V GS = 4.5 V
1.2
1.0
0.8
0.6
- 50
- 25
50
75
100
125
150
8
AO4616
www.VBsemi.tw
0.15
100
ID = 8 A
0.12
10
T J = 150 °C
1
0.1
T J = 25 °C
0.09
0.06
T J = 125 °C
0.03
0.01
T J = 25 °C
0.001
0.0
0.00
0.2
0.4
0.6
0.8
1.0
1
3
2
4
5
6
7
8
9
10
0.8
50
40
ID = 250 μA
ID = 5 mA
0.2
Power (W)
VGS(th) Variance (V)
0.5
30
10
- 0.4
- 50
- 25
50
75
100
125
150
0.01
0.1
Time (s)
1
Threshold Voltage
10
100
Limited by RDS(on) *
10
1 ms
1
10 ms
100 ms
0.1
TA = 25 °C
Single Pulse
BVDSS Limited
1s
10 s
DC
0.01
0.01
0.1
1
10
100
9
AO4616
www.VBsemi.tw
10
8
6
4
2
50
75
100
125
150
4.0
1.5
3.2
1.2
2.4
0.9
Power (W)
Power (W)
Current Derating*
1.6
0.8
0.6
0.3
0.0
0.0
50
75
100
125
150
50
75
100
125
150
limit.
10
AO4616
www.VBsemi.tw
1
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
Notes:
0.1
PDM
0.05
t1
t2
1. Duty Cycle, D =
0.02
t1
t2
2. Per Unit Base = R thJA = 110 °C/W
3. T JM - TA = PDMZthJA(t)
Single Pulse
0.01
10 -4
10 -3
10 -2
4. Surface Mounted
10 -1
1
100
10
1000
1
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10 -4
10 -3
10 -2
10 -1
1
10
11
AO4616
www.VBsemi.tw
SOIC (NARROW): 8-LEAD
JEDEC Part Number: MS-012
8
6
7
5
E
1
3
2
H
4
S
h x 45
D
C
0.25 mm (Gage Plane)
A
e
B
All Leads
q
A1
L
0.004"
MILLIMETERS
INCHES
DIM
Min
Max
Min
Max
A
1.35
1.75
0.053
0.069
A1
0.10
0.20
0.004
0.008
B
0.35
0.51
0.014
0.020
C
0.19
0.25
0.0075
0.010
D
4.80
5.00
0.189
0.196
E
3.80
4.00
0.150
e
0.101 mm
1.27 BSC
0.157
0.050 BSC
H
5.80
6.20
0.228
0.244
h
0.25
0.50
0.010
0.020
L
0.50
0.93
0.020
0.037
q
0°
8°
0°
8°
S
0.44
0.64
0.018
0.026
ECN: C-06527-Rev. I, 11-Sep-06
DWG: 5498
12
AO4616
www.VBsemi.tw
RECOMMENDED MINIMUM PADS FOR SO-8
0.172
(4.369)
0.028
0.022
0.050
(0.559)
(1.270)
0.152
(3.861)
0.047
(1.194)
0.246
(6.248)
(0.711)
Recommended Minimum Pads
Dimensions in Inches/(mm)
13
AO4616
www.VBsemi.tw
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives ( collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to
the product.(www.VBsemi.tw)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: ( 1) any application and all liability arising out of or use of any products; ( 2) any and all liability,
including but not limited to special, consequential damages or incidental ; ( 3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
R oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 R i Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.tw)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
14
