6CS14318AF18UCG
6CS14318AF18UCG
    SJK(晶科鑫)
    HC-49S/SMD
    无源晶振 18pF 40Ω 14.318MHz ±20ppm -40℃~+85℃ HC-49S/SMD
6CS14318AF18UCG 数据手册
QUARTZ CRYSTAL UNIT SERIES 6CS/SS, Resistance Welded HC-49S/SSMD Package 深圳市晶科鑫实业有限公司 Shenzhen Crystal Technology Industrial Co., Ltd APPROVAL SHEET CUSTOMER P/N: TYPE: DESCRIPTION: P N/ SJK: 49S CRYSTAL 49SMD 14.31818MHZ MSL: -40~85℃ 6CS14318AF18UCG ENVIRONMENTAL: ■RoHS REVISION: 18PF ±40PPM A1 ■REACH ■HF □PAHS 2014-6-10 □other MOQ: 1000pcs Levels 1 SIGNATURE SUPPLIER Issue Check CUSTOMER Approve QA SJK Signature FAE_EMAIL Date Date Check Approve: □accept Approve □unaccepted Note: Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 1 /4 QUARTZ CRYSTAL UNIT SERIES 6CS/SS, Resistance Welded HC-49S/SSMD Package 1. FEATURE ⚫ ⚫ ⚫ ⚫ ⚫ Leadless type High precision characteristic covering up to high frequency range Designed for automatic mounting and reflow soldering Embossed taping specification The best choice of Bluetooth wireless communication sets, DSN, PDA and mobile phone 2. ELECTRICAL SPECIFICATIONS Output Frequency Range 14.318180MHz Mode AT/Fundamental Frequency Tolerance ±20 ppm max Load Capacitance(CL) 18.0 PF Frequency Stability Over Operating Temperature Characteristics (at 25°C) ±30ppm max Operating Temperature Range -40 °C to +85 °C Storage Temperature Range -40 °C to +125 °C Shunt Capacitance (C0) 3.0 PF Max Driver Level (Typical) 100µW Equivalent Series Resistance(ESR) 40Ω Max Aging @25°C 1st year (Max) ±3ppm/year Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 2 /4 QUARTZ CRYSTAL UNIT SERIES 6CS/SS, Resistance Welded HC-49S/SSMD Package 3. DIMENSION (Units: mm) 4. MARKING 5. REFLOW CONDITION Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 3 /4 QUARTZ CRYSTAL UNIT SERIES 6CS/SS, Resistance Welded HC-49S/SSMD Package 6. RELIABILITY TEST SPECIFICATION 1.Mechanical Endurance No. 1.1 Test Item Drop Test 1.2 Mechanical Shock 1.3 Vibration 1.4 Gross Leak Standard Sample For Automatic Gross Leak Detector, Test Pressure: 2Kg / cm2 MIL-STD-883E 1.5 Fine Leak Helium Bombing 4.5 Kg/ cm2 for 2 hr MIL-STD-883E 1.6 Solder ability Test Methods 150 cm height, 3 times on concrete floor. Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5m sec. duration time Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minute Perpendicular axes each test time 4 hours (Total test time 12 hours) Temperature Immersing depth Immersion time Flux 245 ℃ ± 5℃ 0.5 mm minimum 5 ± 1 seconds Rosin resin methyl alcohol solvent ( 1 : 4 ) REF.DOC JIS C6701 MIL-STD-202F MIL-STD-883E MIL-STD-883E 2.Environmental Endurance No. Test Item Test Methods 2.1 Resistance To Soldering Heat Pre-heat temperature Pre-heat time 60 ~ Test temperature Test time 2.2 2.3 High Temp. Storage Low Temp. Storage REF.DOC 125 ℃ 120 sec. 260 ± 5 ℃ 10 ± 1 sec. MIL-STD-202F + 125 ℃ ± 3 ℃ for 500 ± 12 hours MIL-STD-883E - 40 ℃ ± 3 ℃ for 500 ± 12 hours MIL-STD-883E Total 100 cycles of the following temperature cycle 2.4 2.5 2.6 Thermal Shock High Temp &Humidity Pressure Cooker Storage MIL-STD-883E 85℃ ± 3℃, RH 85% , 500Hrs JIS C5023 121 ± 3℃ , RH100% , 2 bar , 240Hrs JIS C6701 Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 4 /4
6CS14318AF18UCG
1. 物料型号:6CS14318AF18UCG,属于49S CRYSTAL类型。 2. 器件简介:无引脚类型,高精度特性,覆盖高频范围,设计用于自动贴装和回流焊接,采用压花胶带规格,是蓝牙无线通信设备、DSN、PDA和手机的最佳选择。 3. 参数特性: - 输出频率范围:14.318180MHz - 模式:AT/基础 - 频率容差:最大±20ppm(25°C时) - 负载电容(CL):18.0PF - 工作温度范围内的频率稳定性:最大±30ppm - 工作温度范围:-40°C至+85°C - 存储温度范围:-40°C至+125°C - 并联电容(Co):最大3.0PF - 驱动电平(典型值):100mW - 等效串联电阻(ESR):最大40Ω - 25°C下第一年老化:最大±3ppm/年 4. 功能详解:文档中未提供具体功能详解,但根据简介,该器件适用于需要高精度时钟信号的应用。 5. 应用信息:适用于蓝牙无线通信设备、DSN、PDA和手机。 6. 封装信息:SMD封装,尺寸数据详细列出,包括高度、宽度等,建议布局也在文档中给出。 7. 可靠性测试规格:包括机械耐久性测试和环境耐久性测试,如跌落测试、机械冲击、振动、泄漏测试、焊接能力、耐焊热性、高温存储、低温存储、热冲击、高温高湿、压力锅存储等。
6CS14318AF18UCG 价格&库存
很抱歉,暂时无法提供与“6CS14318AF18UCG”相匹配的价格&库存,您可以联系我们找货
6CS14318AF18UCG
  • 1+0.44415
  • 10+0.42840
  • 100+0.39060
  • 500+0.37170
库存:100
