BX-15-IC/V-IC/V-IC/V-IC/V
    SENSATA(森萨塔)
    BROADCASTER WITH OPTICAL ISOLATO
BX-15-IC/V-IC/V-IC/V-IC/V 数据手册
| BEI ELECTRONIC MODULES ENCODER SIGNAL BROADCASTER Introduction The BROADCASTER accepts standard incremental encoder inputs, (two channels in quadrature plus an index and complements) and can broadcast up to four encoder signals to four independent devices. Each of the broadcast signals is optically isolated eliminating ground loops. This compact package also allows for signal processing options, such as anti-dither filter, integer countdown or pulse and direction outputs, to be incorporated into each of the four broadcast signals independently. The broadcaster is ideal for driving multiple receivers from a single encoder in applications like electronic line shafting or synchronization of multiple devices to a single operation. The module accepts signals of 5, 12-15 and 24 VDC and provides three output options: Vout = Vin, Vout = 5 V or NPN open collector. The compact package mounts to standard EN 50 022 35mm X 7.5mm DIN rail and is 142mm wide, 78mm deep and 45mm above the DIN rail. A 155mm section of DIN rail is included. Features • Broadcasts signals from a single encoder to four independent receivers • Signal processing modules (pulse converter, integer countdown, antidither) can be added to each output for additional capabilities • Accepts all standard input voltages and types: single ended, differential and open collector • Signals are optically isolated for high noise immunity • Compact package saves installation costs SPECIFICATIONS (For Isolated Circuit And Anti-Dither Functions) Differential Line Driver (See Figure 1) The Encoder signals from 5 VDC to 24 VDC (must specify the voltage when ordering) This is the preferred type of encoder output as it has the best noise immunity. Connect each encoder signal to its like input (A to A, A/ to A/, etc). Page 1 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com Single Ended Line Driver (See Figure 2) Encoder signal from 5 VDC to 24 VDC (must specify the voltage when ordering) Connect broadcaster A to optical isolator module input channel A, B to B and Z to Z. Connect the A/, B/, and Z/ inputs of the optical isolator to circuit common of the encoder supply. Single ended operation is limited to shorter cable runs and is more susceptible to noise. Open Collector with or without Internal Pull-up Resistors (See Figure 3) Encoder NPN (sinking) outputs. Connect encoder output A to optical isolator module input A/, B to B/ and Z to Z/. Connect the A, B, and Z inputs of the broadcaster to the positive encoder supply line. This connection results in a logic inversion within the broadcaster module. To compensate for the logic reversal, swap A for A/, B for B/, and Z for Z/ at the broadcaster outputs. TERMINATION PINOUTS Encoder Side PIN Description Notes A, A/ Channel A Inputs B, B/ Channel B Inputs Z, Z/ Channel Z Inputs Input levels consistent with specified value in model number (5 V, 15 V, 24 V). Signal input current 25 mA nom. See BEI Optical Isolator Module Applications Guide for single ended and open collector connection diagrams. T1, T2, T3 Uncommitted Terminals Non-committed terminals. Provided for use as connection points for encoder power. Page 2 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com Driver Side PIN Description Notes +V Power supply 5 – 28 VDC 125 mA + load current typ. 0V Power supply common Supply lines between driver sections are not connected. Driver must be powered in order to produce an output. Supply voltage need not be the same for different driver sections. EN Output Enable HI = Output Active, LO = High Impedance Internal pull-up to V+ A, A/ Channel A Outputs B, B/ Channel B Outputs Z, Z/ Channel Z Outputs Output levels consistent with driver type and supply voltage (V/V outputs). BROADCASTER BLOCK DIAGRAM Driver #1 Input A Input AInput B Input B- +V (Supply Voltage) 0V (Circuit Ground) Input A Input A- OptoIsolator #1 Input B Input B- Input Z Input Z- Input Z Input ZEN (Enable High) Driver #4 +V (Supply Voltage) 0V (Circuit Ground) Input A Input A- OptoIsolator #4 Input B Input BInput Z Input ZEN (Enable High) Page 3 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com Example : BX-5-IC/V-IC/V-P2/5-P2/5 ORDERING OPTIONS BX Broadcaster - 5 - Output Voltage from Encoder: 5, 15, 24 IC/V - Function for Channel 1 IC/V - Function for Channel 2 Choose one for each channel: DB = Divide By, selectable integer value 1-256 AD= Anti-Dither Px = Pulse Up/Down where x = multiple, either 1, 2, or 4 PxD = Pulse Direction where x = multiple, either 1, 2, or 4 IC = Isolation Circuit (Standard) P2/5 - Function for Channel 3 P2/5 Function for Channel 4 Output Voltage/Type: /V = Multivoltage 5-28 Volts in, Vout = Vin /5 = Multivoltage 5-28 Volts in, Vout = 5V regulated /OC = Multivoltage 5-28 Volts in, Vout = Open Collector ADDITIONAL MODULES AND ACCESSORIES Power Supply With a wide range of acceptable input voltages (AC and DC) this DIN Rail mountable power supply is usable in virtually all industrial applications worldwide. It has built in surge protection to reduce faults due to transients and it has 100% reserve capacity for startup and overload conditions. Cable And Cable Assemblies Cable reels for your own custom wiring requirements or cable assemblies are available, using high quality custom BEI standard cable consisting of four, low capacitance shielded twisted pairs with an overall shield, extra large conductors for power, and signal ground; all within an abrasion-resistant PVC jacket. Cable Reels 100 ft. reel 500 ft. reel Cable Assemblies Part Nos. for MS3106F14S-6S Mating Connector 10 ft. # 31186-1410 | 20 ft. # 31186-1420 | 30ft. # 31186-1430 Part Nos. for MS3106F16S-1S Mating Connector 10 ft. # 31186-1610 | 20 ft. # 31186-1620 | 30ft. # 31186-1630 Part Nos. for MS3106F18S-1S Mating Connector 10 ft. # 31186-1810 | 20 ft. # 31186-1820 | 30ft. # 31186-1830 Part No. 37048-003-100 Part No. 37048-003-500 Page 4 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com WARNINGS HAZARD OF ELECTRIC SHOCK, EXPLOSION OR ARC FLASH • Disconnect all power before installing or working with this equipment • Verify all connections and replace all covers before turning on power Failure to follow these instructions will result in death or serious injury. Page 5 Sensata Technologies, Inc. (“Sensata”) data sheets are solely intended to assist designers (“Buyers”) who are developing systems that incorporate Sensata products (also referred to herein as “components”). Buyer understands and agrees that Buyer remains responsible for using its independent analysis, evaluation and judgment in designing Buyer’s systems and products. Sensata data sheets have been created using standard laboratory conditions and engineering practices. Sensata has not conducted any testing other than that specifically described in the published documentation for a particular data sheet. Sensata may make corrections, enhancements, improvements and other changes to its data sheets or components without notice. Buyers are authorized to use Sensata data sheets with the Sensata component(s) identified in each particular data sheet. HOWEVER, NO OTHER LICENSE, EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE TO ANY OTHER SENSATA INTELLECTUAL PROPERTY RIGHT, AND NO LICENSE TO ANY THIRD PARTY TECHNOLOGY OR INTELLECTUAL PROPERTY RIGHT, IS GRANTED HEREIN. SENSATA DATA SHEETS ARE PROVIDED “AS IS”. SENSATA MAKES NO WARRANTIES OR REPRESENTATIONS WITH REGARD TO THE DATA SHEETS OR USE OF THE DATA SHEETS, EXPRESS, IMPLIED OR STATUTORY, INCLUDING ACCURACY OR COMPLETENESS. SENSATA DISCLAIMS ANY WARRANTY OF TITLE AND ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, QUIET ENJOYMENT, QUIET POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHTS WITH REGARD TO SENSATA DATA SHEETS OR USE THEREOF. All products are sold subject to Sensata’s terms and conditions of sale supplied at www.sensata.com SENSATA ASSUMES NO LIABILITY FOR APPLICATIONS ASSISTANCE OR THE DESIGN OF BUYERS’ PRODUCTS. BUYER ACKNOWLEDGES AND AGREES THAT IT IS SOLELY RESPONSIBLE FOR COMPLIANCE WITH ALL LEGAL, REGULATORY AND SAFETY-RELATED REQUIREMENTS CONCERNING ITS PRODUCTS, AND ANY USE OF SENSATA COMPONENTS IN ITS APPLICATIONS, NOTWITHSTANDING ANY APPLICATIONS-RELATED INFORMATION OR SUPPORT THAT MAY BE PROVIDED BY SENSATA. Mailing Address: Sensata Technologies, Inc., 529 Pleasant Street, Attleboro, MA 02703, USA. Copyright © 2018 Sensata Technologies, Inc. Rev:12/04/18 CONTACT US Americas +1 (800) 350 2727 – Option 1 sales.beisensors@sensata.com Europe, Middle East & Africa +33 (3) 88 20 8080 position-info.eu@sensata.com Asia Pacific sales.isasia@list.sensata.com China +86 (21) 2306 1500 Japan +81 (45) 277 7117 Korea +82 (31) 601 2004 India +91 (80) 67920890 Rest of Asia +886 (2) 27602006 ext 2808 www.sensata.com
BX-15-IC/V-IC/V-IC/V-IC/V 价格&库存
很抱歉,暂时无法提供与“BX-15-IC/V-IC/V-IC/V-IC/V”相匹配的价格&库存,您可以联系我们找货
