0980 ESL 393-121
0980 ESL 393-121
    BELDEN
    MULTIPROTOCOL M12 SENSOR BLOCK
0980 ESL 393-121 数据手册
LioN-Power Multi-protocol – 8 Digital Inputs / 8 Digital Outputs, M12 L-coded or 7/8” Power Supply Connection, PROFINET, EtherNet/IP or EtherCAT Product Description Type 0980 ESL 393-121 0980 ESL 393-111 NEW! NEW! Description LioN-P Multi-protocol module, PROFINET, EtherNet/IP or EtherCAT de- LioN-P Multi-protocol module, PROFINET, EtherNet/IP or EtherCAT device, 8 digital input and 8 digital output channels with galvanic isolation vice, 8 digital input and 8 digital output channels with galvanic isolation, M12 LAN connection, 4-poles, D-coded, 7/8” power supply, 5-poles M12 LAN connection, 4-poles, D-coded, M12 L-coded power supply, 5-poles Order No. 934879003 934882003 Technical Data Protection Degree IP65, IP67, IP69K (only if mounted and locked in combination with Hirschmann/Lumberg connector) Ambient Temperature (Operation) Dimensions (W x H x D) Weight IP65, IP67 (only if mounted and locked in combination with Hirschmann/Lumberg connector) -20 °C to +70 °C 59.6 x 30.7 x 200 (mm) 59.6 x 26.2 x 206 (mm) 500 g 520 g Housing Material Metal, Zinc Die-cast Bus System Protocol PROFINET /EtherNet/IP/EtherCAT I/O Device Connection M12 LAN connection, 4-poles, D-coded Transmission Rate Fast Ethernet (10/100 Mbit/s), Full Duplex Rotary Address Switches Yes, 3x Power Supply Nominal Voltage 24 V DC (SELV/PELV) Nominal Voltage Range Connection Current Carrying Capacity of Connector Current Consumption (typ.) 18 to 30 V DC 7/8”, 5-poles M12, L-coded, 5-poles 16 A 9A 160 mA (+/-20% at 24 V DC) Input Channels Number of Channels Connection Channel Type Nominal Voltage Sensor Current Supply Sensor Type 8 M12, 5-poles, A-coded Type 3 acc. to IEC 61131-2 24 V DC via US (system power supply) 200 mA per Port PNP Output Channels Number of Channels Connection Channel Type Nominal Voltage Output Current per Channel Output Current per Module Protective Circuit Galvanically Isolated 8 M12, 5-poles, A-coded p-switching 24 V DC via Uaux (actuator power supply) max. 2 A max. 9 A Electronicaly: Overload protection, short-circuit protection Yes Continued Next Page Bit Assignment Bit 7 6 5 4 3 2 1 0 2A 1B 1A 6A 5B 5A M12 Input 8DI Byte 0 4B 4A 3B 3A 2B M12 Output 8DO Byte 1 8B 8A 7B 7A 6B www.lumberg-automationusa.com Data Sheet: 0980 ESL 393-121_111 1.800.Belden1 | www.lumberg-automationusa.com LioN-Power Multi-protocol – 8 Digital Inputs / 8 Digital Outputs, M12 L-coded or 7/8” Power Supply Connection, PROFINET, EtherNet/IP or EtherCAT Diagnostic Indication | 0980 ESL 393-121 and 0980 ESL 393-111 LED Indicator Condition 1...8 A Yellow Channel status 1...8 DIA A Red Periphery error 1...8 B White Channel status 1...8 DIA B Red Periphery error P1 Lnk/Act Green Green blinking Off Connection to an Ethernet device I/O device exchanging data No connection to another device P2 Lnk/Act Green Yellow blinking Off Connection to an Ethernet device I/O device exchanging data No connection to another device BF Red Off Bus error, no data exchange with I/O controller No error message DIA Red Red blinking Off Common indicator for periphery errors Firmware update No error message MS (Module status) Green Green blinking Red/green blinking Red blinking Off Device is ready for operating Wrong configuration Self test is running Firmware update IP address is available NS (Network status) Green blinking Green Red blinking Red Red/green blinking Off IP address is available Connection to master is available At least one connection has timed out IP address is already being used by another device Self test is running Device is switched off/device has no IP address Green Device is in state OPERATIONAL Green blinking Device is in state PRE-OPERATIONAL Green single flash Device is in state SAFE-OPERATIONAL Green flickerng Off Device is in state BOOTSTRAP Device is in state INIT Red "An critical communication or application controller error has occurred " Red double flash An application watchdog timeout has occurred. Red single flash "Slave device application has changed the EtherCAT state autonomously, due to local error" Red blinking General Configuration Error Red flickering Booting Error was detected Off Green Red No error Voltage 19 V
0980 ESL 393-121 价格&库存
很抱歉,暂时无法提供与“0980 ESL 393-121”相匹配的价格&库存,您可以联系我们找货
