HI5960
Data Sheet
March 31, 2005
14-Bit, 130MSPS, High Speed D/A
Converter
FN4655.6
Features
• Throughput Rate . . . . . . . . . . . . . . . . . . . . . . . . 130MSPS
The HI5960 is a 14-bit, 130MSPS (Mega Samples Per
Second), high speed, low power, D/A converter which is
implemented in an advanced CMOS process. Operating
from a single +3V to +5V supply, the converter provides
20mA of full scale output current and includes edgetriggered CMOS input data latches. Low glitch energy and
excellent frequency domain performance are achieved using
a segmented current source architecture.
• Low Power (at 100MSPS) at 5V . . . . . . . . . . . . . .175mW
at 3V. . . . . . . . . . . . . . . .32mW
• Adjustable Full Scale Output Current. . . . . 2mA to 20mA
• Internal 1.2V Bandgap Voltage Reference
• Single Power Supply from +5V to +3V
• Power Down Mode
This device complements the HI5x60 and HI5x28 family of
high speed converters, which includes 8, 10, 12, and 14-bit
devices.
• CMOS Compatible Inputs
Ordering Information
• Excellent Multitone Intermodulation Distortion
PART
NUMBER
TEMP.
RANGE
(oC)
• Excellent Spurious Free Dynamic Range
(77dBc, f S = 50MSPS, fOUT = 2.51MHz)
• Pb-Free Available (RoHS Compliant)
PACKAGE
PKG.
DWG. #
CLOCK
SPEED
Applications
HI5960IB
-40 to 85 28 Ld SOIC
M28.3
130MHz
• Cellular Basestations
HI5960IBZ
(See Note)
(Pb-free)
M28.3
130MHz
• WLL, Basestation and Subscriber Units
HI5960IA
-40 to 85 28 Ld TSSOP M28.173
130MHz
HI5960IAZ
(See Note)
(Pb-free)
130MHz
HI5960IA-T
Tape and Reel
130MHz
HI5960IAZ-T
(See Note)
Tape and Reel
(Pb-free)
130MHz
HI5960SOICEVAL1
25
Evaluation Platform
• Wireless Communications Systems
• Direct Digital Frequency Synthesis
• High Resolution Imaging Systems
• Arbitrary Waveform Generators
Pinout
130MHz
NOTE: Intersil Pb-free products employ special Pb-free material sets;
molding compounds/die attach materials and 100% matte tin plate
termination finish, which are RoHS compliant and compatible with
both SnPb and Pb-free soldering operations. Intersil Pb-free products
are MSL classified at Pb-free peak reflow temperatures that meet or
exceed the Pb-free requirements of IPC/JEDEC J STD-020.
1
• Medical/Test Instrumentation
HI5960 (SOIC, TSSOP)
TOP VIEW
D13 (MSB) 1
28 CLK
D12 2
27 DVDD
D11 3
26 DCOM
D10 4
25 ACOM
D9 5
24 AVDD
D8 6
23 COMP2
D7 7
22 IOUTA
D6 8
21 IOUTB
D5 9
20 ACOM
D4 10
19 COMP1
D3 11
18 FSADJ
D2 12
17 REFIO
D1 13
16 REFLO
D0 (LSB) 14
15 SLEEP
CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures.
1-888-INTERSIL or 321-724-7143 | Intersil (and design) is a registered trademark of Intersil Americas Inc.
Copyright © Intersil Americas Inc. 2003, 2005. All Rights Reserved. All other trademarks mentioned are the property of their respective owners.
HI5960
Typical Applications Circuit
HI5960
D13
D13 (1)
(25) ACOM
D12
D12 (2)
D11
D11 (3)
(15) SLEEP
(16) REFLO
D10
D10 (4)
D9
D9 (5)
D8
D8 (6)
D7
D7 (7)
D6
D6 (8)
D5
D5 (9)
0.1µF
(18) FSADJ
D4 (10)
D3
D3 (11)
D2
D2 (12)
D1
D1 (13)
D0
D0 (LSB) (14)
(23) COMP2
CLK (28)
(19) COMP1
10µH
10µF
1.91kΩ
RSET
(22) IOUTA
D/A OUT
50Ω
50Ω
(21) IOUTB
DCOM (26)
(20) ACOM
DVDD (27)
(24) AVDD
BEAD
DCOM
(17) REFIO
D4
50Ω
ACOM
D/A OUT
0.1µF
0.1µF
FERRITE
BEAD
10µH
0.1µF
0.1µF
+5V OR +3V (VDD)
10µF
Functional Block Diagram
IOUTA
IOUTB
(LSB) D0
CASCODE
D1
CURRENT
SOURCE
D2
D3
D4
LATCH
D5
40
D6
LATCH
SWITCH
MATRIX
D7
40
9 LSBs
31 MSB
SEGMENTS
D8
D9
D10
D11
UPPER
5-BIT
D12
DECODER
31
(MSB) D13
COMP2
COMP1
CLK
AVDD
ACOM
DVDD
2
DCOM
INT/EXT
INT/EXT
VOLTAGE
REFERENCE
SELECT
REFERENCE
REFLO
REFIO
BIAS
GENERATION
FSADJ SLEEP
HI5960
Pin Descriptions
PIN NO.
PIN NAME
DESCRIPTION
1-14
D13 (MSB) Through
D0 (LSB)
15
SLEEP
Control Pin for Power-Down mode. Sleep Mode is active high; Connect to ground for Normal Mode. Sleep
pin has internal 20µA active pulldown current.
16
REFLO
Connect to analog ground to enable internal 1.2V reference or connect to AVDD to disable internal
reference.
17
REFIO
Reference voltage input if internal reference is disabled. Reference voltage output if internal reference is
enabled. Use 0.1µF cap to ground when internal reference is enabled.
18
FSADJ
Full Scale Current Adjust. Use a resistor to ground to adjust full scale output current. Full Scale Output
Current = 32 x VFSADJ/RSET.
19
COMP1
For use in reducing bandwidth/noise. Recommended: connect 0.1µF to AVDD .
21
IOUTB
The complimentary current output of the device. Full scale output current is achieved when all input bits
are set to binary 0.
22
IOUTA
Current output of the device. Full scale output current is achieved when all input bits are set to binary 1.
23
COMP2
Connect 0.1µF capacitor to ACOM.
24
AVDD
Analog Supply (+3V to +5V).
20, 25
ACOM
Connect to Analog Ground.
26
DCOM
Connect to Digital Ground.
27
DVDD
Digital Supply (+3V to +5V).
28
CLK
Digital Data Bit 13, (Most Significant Bit) through Digital Data Bit 0, (Least Significant Bit).
Clock Input. Input data to the DAC passes through the “master” latches when the clock is low and is
latched into the “master” latches when the clock is high. Data presented to the “slave” latch passes
through when the clock is logic high and is latched into the “slave” latches when the clock is logic low.
Adequate setup time must be allowed for the MSBs to pass through the thermometer decoder before the
clock goes high. This master-slave arrangement comprises an edge-triggered flip-flop, with the DAC
being updated on the rising clock edge. It is recommended that the clock edge be skewed such that setup
time is larger than the hold time.
3
HI5960
Absolute Maximum Ratings
Thermal Information
Digital Supply Voltage DVDD to DCOM . . . . . . . . . . . . . . . . . +5.5V
Analog Supply Voltage AVDD to ACOM . . . . . . . . . . . . . . . . . +5.5V
Grounds, ACOM TO DCOM . . . . . . . . . . . . . . . . . . . -0.3V to +0.3V
Digital Input Voltages (D9-D0, CLK, SLEEP). . . . . . . . DVDD + 0.3V
Reference Input Voltage Range. . . . . . . . . . . . . . . . . . AVDD + 0.3V
Analog Output Current (IOUT) . . . . . . . . . . . . . . . . . . . . . . . . . 24mA
Thermal Resistance (Typical, Note 1)
θJA(oC/W)
SOIC Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
75
TSSOP Package . . . . . . . . . . . . . . . . . . . . . . . . . . .
110
Maximum Junction Temperature . . . . . . . . . . . . . . . . . . . . . . .150oC
Maximum Storage Temperature Range . . . . . . . . . -65oC to 150oC
Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . .300oC
(SOIC - Lead Tips Only)
Operating Conditions
HI5960IX . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -40oC to 85oC
CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the
device at these or any other conditions above those indicated in the operational sections of this specification is not implied.
NOTE:
1. θJA is measured with the component mounted on an evaluation PC board in free air.
AVDD = DVDD = +5V, VREF = Internal 1.2V, IOUTFS = 20mA, TA = 25oC for All Typical Values
Electrical Specifications
PARAMETER
TEST CONDITIONS
MIN
TYP
MAX
UNITS
14
Bits
SYSTEM PERFORMANCE
Resolution
Integral Linearity Error, INL
“Best Fit” Straight Line (Note 8)
-5
±2.5
+5
LSB
Differential Linearity Error, DNL
(Note 8)
-3
±1.5
+3
LSB
Offset Error, IOS
(Note 8)
-0.025
+0.025
% FSR
Offset Drift Coefficient
(Note 8)
0.1
ppm
FSR/oΧ
Full Scale Gain Error, FSE
With External Reference (Notes 2, 8)
-10
±2
+10
% FSR
With Internal Reference (Notes 2, 8)
-10
±1
+10
% FSR
With External Reference (Note 8)
±50
ppm
FSR/οΧ
With Internal Reference (Note 8)
±100
ppm
FSR/οΧ
2
mA
(Note 3, 8)
-0.3
1.25
V
Maximum Clock Rate, fCLK
(Note 3)
130
MHz
Output Settling Time, (tSETT)
±0.05% (±8 LSB) (Note 8)
35
ns
Singlet Glitch Area (Peak Glitch)
RL = 25Ω (Note 8)
5
pV•s
Output Rise Time
Full Scale Step
2.5
ns
Output Fall Time
Full Scale Step
2.5
ns
10
pF
IOUTFS = 20mA
50
pA/√Hz
IOUTFS = 2mA
30
pA/√Hz
fCLK = 100MSPS, fOUT = 20.2MHz, 30MHz Span (Notes 4, 8)
77
dBc
fCLK = 100MSPS, fOUT = 5.04MHz, 8MHz Span (Notes 4, 8)
97
dBc
fCLK = 50MSPS, fOUT = 5.02MHz, 8MHz Span (Notes 4, 8)
97
dBc
Full Scale Gain Drift
Full Scale Output Current, IFS
Output Voltage Compliance Range
DYNAMIC CHARACTERISTICS
Output Capacitance
Output Noise
AC CHARACTERISTICS
+5V Power Supply
Spurious Free Dynamic Range,
SFDR Within a Window
4
HI5960
AVDD = DVDD = +5V, VREF = Internal 1.2V, IOUTFS = 20mA, TA = 25oC for All Typical Values (Continued)
PARAMETER
TEST CONDITIONS
+5V Power Supply
Total Harmonic Distortion (THD) to
Nyquist
+5V Power Supply
SFDR to Nyquist (fCLK/2)
+5V Power Supply
Multitone Power Ratio
+3V Power Supply
+3V Power Supply
Nyquist
5
MIN
TYP
MAX
UNITS
fCLK = 100MSPS, fOUT = 4.0MHz (Notes 4, 8)
-71
dBc
fCLK = 50MSPS, fOUT = 2.0MHz (Notes 4, 8)
-75
dBc
fCLK = 25MSPS, fOUT = 1.0MHz (Notes 4, 8)
-77
dBc
fCLK = 130MSPS, fOUT = 40.4MHz (Notes 4, 8)
56
dBc
fCLK = 130MSPS, fOUT = 10.1MHz (Notes 4, 8)
67
dBc
fCLK = 130MSPS, fOUT = 5.02MHz, T = 25oC (Notes 4, 8)
68
74
dBc
fCLK = 130MSPS, fOUT = 5.02MHz, T = Min to Max (Notes 4, 8)
66
dBc
fCLK = 100MSPS, fOUT = 40.4MHz (Notes 4, 8)
55
dBc
fCLK = 100MSPS, fOUT = 20.2MHz (Notes 4, 8)
63
dBc
fCLK = 100MSPS, fOUT = 5.04MHz, T = 25oC (Notes 4, 8)
68
74
dBc
fCLK = 100MSPS, fOUT = 5.04MHz, T = Min to Max (Notes 4, 8)
66
fCLK = 100MSPS, fOUT = 2.51MHz (Notes 4, 8)
76
dBc
fCLK = 50MSPS, fOUT = 20.2MHz (Notes 4, 8)
65
dBc
fCLK = 50MSPS, fOUT = 5.02MHz, T = 25oC (Notes 4, 8)
68
74
dBc
fCLK = 50MSPS, fOUT = 5.02MHz, T = Min to Max (Notes 4, 8)
66
dBc
fCLK = 50MSPS, fOUT = 2.51MHz (Notes 4, 8)
77
dBc
fCLK = 50MSPS, fOUT = 1.00MHz (Notes 4, 8)
79
dBc
79
dBc
fCLK = 20MSPS, fOUT = 2.0MHz to 2.99MHz, 8 Tones at 110kHz
Spacing (Notes 4, 8)
76
dBc
fCLK = 100MSPS, fOUT = 10MHz to 14.95MHz, 8 Tones at 530kHz
76
dBc
80
dBc
95
dBc
95
dBc
-70
dBc
-74
dBc
-76
dBc
dBc
HI5960
PARAMETER
TEST CONDITIONS
MIN
TYP
MAX
UNITS
48
dBc
66
dBc
fCLK = 130MSPS, fOUT = 5.02MHz (Notes 4, 8)
74
dBc
49
dBc
59
dBc
fCLK = 100MSPS, fOUT = 5.04MHz (Notes 4, 8)
72
dBc
77
dBc
56
dBc
68
73
dBc
66
dBc
76
dBc
79
dBc
78
dBc
75
dBc
77
dBc
1.13
1.2
1.28
V
Internal Reference Voltage Drift
±60
ppm/οΧ
Internal Reference Output Current
Sink/Source Capability
±50
µA
Reference Input Impedance
1
MΩ
Reference Input Multiplying Bandwidth (Note 8)
1.4
MHz
+3V Power Supply
+3V Power Supply
VOLTAGE REFERENCE
Internal Reference Voltage, VFSADJ
DIGITAL INPUTS
Pin 18 Voltage with Internal Reference
D11-D0, CLK
Input Logic High Voltage with
5V Supply, VIH
(Note 3)
3.5
5
V
3V Supply, VIH
(Note 3)
2.1
3
V
Input Logic Low Voltage with
5V Supply, VIL
(Note 3)
V
3V Supply, VIL
(Note 3)
V
Sleep Input Current, IIH
-25
+25
µA
Input Logic Current, IIH
-20
+20
µA
Input Logic Current, IIL
-10
+10
µA
5
pF
Digital Input Capacitance, CIN
TIMING CHARACTERISTICS
Data Setup Time, tSU
See Figure 4 (Note 3)
1.5
ns
Data Hold Time, tHLD
1.2
ns
Propagation Delay Time, tPD
See Figure 4
2.5
ns
CLK Pulse Width, tPW1 , tPW2
4
ns
6
HI5960
PARAMETER
TEST CONDITIONS
MIN
TYP
MAX
UNITS
POWER SUPPLY CHARACTERISTICS
AVDD Power Supply
(Notes 9)
2.7
5.0
5.5
V
DVDD Power Supply
(Notes 9)
2.7
5.0
5.5
V
Analog Supply Current (IAVDD)
5V or 3V, IOUTFS = 20mA
23
mA
5V or 3V, IOUTFS = 2mA
5
mA
5V (Note 5)
7
mA
5V (Note 6)
13
mA
5V (Note 7)
10
mA
3V (Note 5)
2
mA
3V (Note 6)
6
mA
3V (Note 7)
5
mA
Supply Current (IAVDD) Sleep Mode
5V or 3V, IOUTFS = Don’t Care
2.7
mA
Power Dissipation
5V, IOUTFS = 20mA (Note 5)
150
mW
5V, IOUTFS = 20mA (Note 6)
180
200
mW
5V, IOUTFS = 20mA (Note 7)
165
mW
5V, IOUTFS = 2mA (Note 6)
80
mW
3V, IOUTFS = 20mA (Note 5)
75
mW
3V, IOUTFS = 20mA (Note 6)
87
100
mW
3V, IOUTFS = 20mA (Note 7)
84
mW
3V, IOUTFS = 2mA (Note 6)
32
mW
-0.2
+0.2
% FSR/V
Digital Supply Current (IDVDD)
Power Supply Rejection
Single Supply (Note 8)
NOTES:
2. Gain Error measured as the error in the ratio between the full scale output current and the current through RSET (typically 625µA). Ideally the
ratio should be 32.
3. Parameter guaranteed by design or characterization and not production tested.
4. Spectral measurements made with differential transformer coupled output and no external filtering.
5. Measured with the clock at 50MSPS and the output frequency at 10MHz.
6. Measured with the clock at 100MSPS and the output frequency at 40MHz.
7. Measured with the clock at 130MSPS and the output frequency at 10MHz.
8. See “Definition of Specifications”.
9. It is recommended that the output current be reduced to 12mA or less to maintain optimum performance for operation below 3V. DVDD and AVDD
do not have to be equal.
7
HI5960
Differential Linearity Error, DNL, is the measure of the
step size output deviation from code to code. Ideally the step
size should be 1 LSB. A DNL specification of 1 LSB or less
guarantees monotonicity.
Full Scale Gain Drift, is measured by setting the data inputs
to be all logic high (all 1s) and measuring the output voltage
through a known resistance as the temperature is varied
from TMIN to TMAX . It is defined as the maximum deviation
from the value measured at room temperature to the value
measured at either TMIN or TMAX . The units are ppm of FSR
(full scale range) per oC.
Full Scale Gain Error, is the error from an ideal ratio of 32
between the output current and the full scale adjust current
(through RSET).
Integral Linearity Error, INL, is the measure of the worst
case point that deviates from a best fit straight line of data
values along the transfer curve.
Internal Reference Voltage Drift, is defined as the
maximum deviation from the value measured at room
temperature to the value measured at either TMIN or TMAX .
The units are ppm per oC.
Offset Drift, is measured by setting the data inputs to all
logic low (all 0s) and measuring the output voltage through a
known resistance as the temperature is varied from TMIN to
TMAX . It is defined as the maximum deviation from the value
measured at room temperature to the value measured at
either TMIN or TMAX . The units are ppm of FSR (full scale
range) per degree oC.
Offset Error, is measured by setting the data inputs to all
known resistance. Offset error is defined as the maximum
deviation of the output current from a value of 0mA.
Output Settling Time, is the time required for the output
voltage to settle to within a specified error band measured
from the beginning of the output transition. The
measurement is done by switching quarter scale.
Termination impedance was 25Ω due to the parallel
resistance of the 50Ω loading on the output and the
oscilloscope’s 50Ω input. This also aids the ability to resolve
the specified error band without overdriving the oscilloscope.
Output Voltage Compliance Range, is the voltage limit
imposed on the output. The output impedance should be
chosen such that the voltage developed does not violate the
compliance range.
Power Supply Rejection, is measured using a single power
supply. The supply’s nominal +5V is varied ±10% and the
change in the DAC full scale output is noted.
Reference Input Multiplying Bandwidth, is defined as the
3dB bandwidth of the voltage reference input. It is measured
8
by using a sinusoidal waveform as the external reference
with the digital inputs set to all 1s. The frequency is
increased until the amplitude of the output waveform is
0.707 (-3dB) of its original value.
Singlet Glitch Area, is the switching transient appearing on
the output during a code transition. It is measured as the
area under the overshoot portion of the curve and is
expressed as a Volt-Time specification. This is tested using
a single code transition across a major current source.
Spurious Free Dynamic Range, SFDR, is the amplitude
difference from the fundamental signal to the largest
harmonically or non-harmonically related spur within the
specified frequency window.
Total Harmonic Distortion, THD, is the ratio of the RMS
value of the fundamental output signal to the RMS sum of
the first five harmonic components.
Detailed Description
The HI5960 is a 14-bit, current out, CMOS, digital to analog
converter. Its maximum update rate is 130MSPS and can be
powered by either single or dual power supplies in the
recommended range of +3V to +5V. Operation with clock
rates higher than 130MSPS is possible; please contact the
factory for more information. It consumes less than 180mW
of power when using a +5V supply with the data switching at
130MSPS. The architecture is based on a segmented
current source arrangement that reduces glitch by reducing
the amount of current switching at any one time. In previous
architectures that contained all binary weighted current
sources or a binary weighted resistor ladder, the converter
might have a substantially larger amount of current turning
on and off at certain, worst-case transition points such as
midscale and quarter scale transitions. By greatly reducing
the amount of current switching at certain “major” transitions,
the overall glitch of the converter is dramatically reduced,
improving settling time, transient problems, and accuracy.
Digital Inputs and Termination
The HI5960 digital inputs are guaranteed to CMOS levels.
However, TTL compatibility can be achieved by lowering the
supply voltage to 3V due to the digital threshold of the input
buffer being approximately half of the supply voltage. The
internal register is updated on the rising edge of the clock.
To minimize reflections, proper termination should be
implemented. If the lines driving the clock and the digital
inputs are long 50Ω lines, then 50Ω termination resistors
should be placed as close to the converter inputs as possible
connected to the digital ground plane (if separate grounds
are used). These termination resistors are not likely needed
as long as the digital waveform source is within a few inches
of the DAC.
Ground Planes
Separate digital and analog ground planes should be used.
All of the digital functions of the device and their
HI5960
corresponding components should be located over the
digital ground plane and terminated to the digital ground
plane. The same is true for the analog components and the
analog ground plane. Consult Application Note 9853.
Noise Reduction
To minimize power supply noise, 0.1µF capacitors should be
placed as close as possible to the converter’s power supply
pins, AVDD and DVDD . Also, the layout should be designed
using separate digital and analog ground planes and these
capacitors should be terminated to the digital ground for
DVDD and to the analog ground for AVDD . Additional
filtering of the power supplies on the board is recommended.
Voltage Reference
The internal voltage reference of the device has a nominal
value of +1.2V with a ±60ppm/ oC drift coefficient over the
full temperature range of the converter. It is recommended
that a 0.1µF capacitor be placed as close as possible to the
REFIO pin, connected to the analog ground. The REFLO pin
(16) selects the reference. The internal reference can be
selected if pin 16 is tied low (ground). If an external
reference is desired, then pin 16 should be tied high (the
analog supply voltage) and the external reference driven into
REFIO, pin 17. The full scale output current of the converter
is a function of the voltage reference used and the value of
RSET . IOUT should be within the 2mA to 20mA range,
though operation below 2mA is possible, with performance
degradation.
If the internal reference is used, VFSADJ will equal
approximately 1.2V (pin 18). If an external reference is used,
VFSADJ will equal the external reference. The calculation for
IOUT (Full Scale) is:
IOUT(Full Scale) = (VFSADJ/RSET) X 32.
If the full scale output current is set to 20mA by using the
internal voltage reference (1.2V) and a 1.91kΩ RSET
resistor, then the input coding to output current will resemble
the following:
TABLE 1. INPUT CODING vs OUTPUT CURRENT
INPUT CODE (D13-D0)
IOUTA (mA)
IOUTB (mA)
1111 11111 11111
10
10
0000 00000 00000
Outputs
IOUTA and IOUTB are complementary current outputs. The
sum of the two currents is always equal to the full scale
output current minus one LSB. If single ended use is
desired, a load resistor can be used to convert the output
current to a voltage. It is recommended that the unused
output be either grounded or equally terminated. The voltage
developed at the output must not violate the output voltage
compliance range of -0.3V to 1.25V. RLOAD (the impedance
9
loading each current output) should be chosen so that the
desired output voltage is produced in conjunction with the
output full scale current. If a known line impedance is to be
driven, then the output load resistor should be chosen to
match this impedance. The output voltage equation is:
VOUT = IOUT X RLOAD .
These outputs can be used in a differential-to-single-ended
arrangement to achieve better harmonic rejection. The
SFDR measurements in this data sheet were performed with
a 1:1 transformer on the output of the DAC (see Figure 1).
With the center tap grounded, the output swing of pins 21
and 22 will be biased at zero volts. The loading as shown in
Figure 1 will result in a 500mV signal at the output of the
transformer if the full scale output current of the DAC is set
to 20mA.
REQ IS THE IMPEDANCE
LOADING EACH OUTPUT
50Ω
VOUT = (2 x IOUT x REQ)V
IOUTB
PIN 21
100Ω
PIN 22
HI5960
50Ω
IOUTA
50Ω
50Ω REPRESENTS THE
SPECTRUM ANALYZER
FIGURE 1.
VOUT = 2 x IOUT x REQ, where REQ is ~12.5Ω. Allowing the
center tap to float will result in identical transformer output,
however the output pins of the DAC will have positive DC
offset. Since the DAC’s output voltage compliance range is 0.3V to +1.25V, the center tap may need to be left floating or
DC offset in order to increase the amount of signal swing
available. The 50Ω load on the output of the transformer
represents the spectrum analyzer’s input impedance.
HI5960
Timing Diagrams
50%
CLK
D13-D0
GLITCH AREA = 1/2 (H x W)
V
HEIGHT (H)
ERROR BAND
IOUT
t(ps)
WIDTH (W)
tSETT
tPD
FIGURE 2. OUTPUT SETTLING TIME DIAGRAM
tPW1
FIGURE 3. PEAK GLITCH AREA (SINGLET) MEASUREMENT
METHOD
tPW2
50%
CLK
tSU
tSU
tHLD
tSU
tHLD
tHLD
D13-D0
tPD
tSETT
IOUT
tPD
tSETT
tPD
tSETT
FIGURE 4. PROPAGATION DELAY, SETUP TIME, HOLD TIME AND MINIMUM PULSE WIDTH DIAGRAM
10
HI5960
Small Outline Plastic Packages (SOIC)
M28.3 (JEDEC MS-013-AE ISSUE C)
N
28 LEAD WIDE BODY SMALL OUTLINE PLASTIC PACKAGE
INDEX
AREA
H
0.25(0.010) M
B M
INCHES
E
SYMBOL
-B-
1
2
3
L
SEATING PLANE
-A-
h x 45o
A
D
-C-
e
A1
B
0.25(0.010) M
C
0.10(0.004)
C A M
B S
1. Symbols are defined in the “MO Series Symbol List” in Section 2.2
of Publication Number 95.
2. Dimensioning and tolerancing per ANSI Y14.5M-1982.
3. Dimension “D” does not include mold flash, protrusions or gate
burrs. Mold flash, protrusion and gate burrs shall not exceed
0.15mm (0.006 inch) per side.
4. Dimension “E” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.25mm (0.010
inch) per side.
5. The chamfer on the body is optional. If it is not present, a visual
index feature must be located within the crosshatched area.
6. “L” is the length of terminal for soldering to a substrate.
7. “N” is the number of terminal positions.
8. Terminal numbers are shown for reference only.
9. The lead width “B”, as measured 0.36mm (0.014 inch) or greater
above the seating plane, shall not exceed a maximum value of
0.61mm (0.024 inch)
10. Controlling dimension: MILLIMETER. Converted inch dimensions are not necessarily exact.
11
MILLIMETERS
MIN
MAX
NOTES
A
0.0926
0.1043
2.35
2.65
0.0040
0.0118
0.10
0.30
B
0.013
0.0200
0.33
0.51
9
C
0.0091
0.0125
0.23
0.32
D
0.6969
0.7125
17.70
18.10
3
E
0.2914
0.2992
7.40
7.60
4
0.05 BSC
10.00
h
0.01
0.029
0.25
0.75
5
L
0.016
0.050
0.40
1.27
6
8o
0o
28
0o
10.65
0.394
N
0.419
1.27 BSC
H
α
NOTES:
MAX
A1
e
α
MIN
28
7
8o
Rev. 0 12/93
HI5960
Thin Shrink Small Outline Plastic Packages (TSSOP)
M28.173
N
INDEX
AREA
E
0.25(0.010) M
E1
2
INCHES
GAUGE
PLANE
-B1
28 LEAD THIN SHRINK SMALL OUTLINE PLASTIC
PACKAGE
B M
3
L
0.05(0.002)
-A-
0.25
0.010
SEATING PLANE
A
D
-C-
α
e
A2
A1
b
c
0.10(0.004)
0.10(0.004) M
C A M
B S
SYMBOL
MIN
MAX
MIN
MAX
NOTES
A
0.047
1.20
A1
0.002
0.006
0.05
0.15
A2
0.031
0.051
0.80
1.05
b
0.0075
0.0118
0.19
0.30
9
c
0.0035
0.0079
0.09
0.20
D
0.378
0.386
9.60
9.80
3
E1
0.169
0.177
4.30
4.50
4
e
0.026 BSC
E
0.246
L
0.0177
N
α
NOTES:
MILLIMETERS
0.65 BSC
0.256
6.25
0.0295
0.45
28
0o
0.75
6
28
8o
0o
6.50
7
8o
1. These package dimensions are within allowable dimensions of
JEDEC MO-153-AE, Issue E.
Rev. 0 6/98
3. Dimension “D” does not include mold flash, protrusions or gate burrs.
Mold flash, protrusion and gate burrs shall not exceed 0.15mm
4. Dimension “E1” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.15mm (0.006 inch) per
side.
5. The chamfer on the body is optional. If it is not present, a visual index
9. Dimension “b” does not include dambar protrusion. Allowable dambar
protrusion shall be 0.08mm (0.003 inch) total in excess of “b” dimension at maximum material condition. Minimum space between protrusion and adjacent lead is 0.07mm (0.0027 inch).
are not necessarily exact. (Angles in degrees)
All Intersil U.S. products are manufactured, assembled and tested utilizing ISO9000 quality systems.
Intersil Corporation’s quality certifications can be viewed at www.intersil.com/design/quality
Intersil products are sold by description only. Intersil Corporation reserves the right to make changes in circuit design, software and/or specifications at any time without
notice. Accordingly, the reader is cautioned to verify that data sheets are current before placing orders. Information furnished by Intersil is believed to be accurate and
reliable. However, no responsibility is assumed by Intersil or its subsidiaries for its use; nor for any infringements of patents or other rights of third parties which may result
from its use. No license is granted by implication or otherwise under any patent or patent rights of Intersil or its subsidiaries.
For information regarding Intersil Corporation and its products, see www.intersil.com
12
