DB002-02
DB002-02
    NVECORP
    SOIC8_150MIL
    IC PWR SWITCH BIPOLAR 1:1 8SOIC
DB002-02 数据手册
Peripheral Integrated Circuits Peripheral Integrated Circuits In addition to GMR Sensor products, NVE has begun designing and manufacturing accessory products for our sensors. These products are designed to be used with NVE’s sensors, or in some cases as standalone parts, to provide higher level signal processing capabilities coupled with the robust performance characteristics that NVE products are known for. DB-Series Power Switch ICs – In many industrial control applications, a digital current output of up to 200 mA is required. NVE’s DB-Series parts are designed to meet these requirements. They feature transient protection to meet rigid EMC and ESD standards, thermal shutdown for temperature protection, reverse battery protection, a regulated voltage output, an on-chip LED driver, and short circuit protection of the current drive output transistor. The DB001-00 is designed specifically to work together with NVE’s AD9xx-00 short circuit protected GMR switch to create a very small IC combination suitable for use in miniature sensor assemblies. The DB002-02 is designed to take a generic digital input from any source, including inductive and photo sensors, and provide the digital current output. DC Series Voltage Regulator ICs – These ICs are designed for use in high voltage, low current applications. They provide a wide input voltage range, up to 60V, and are available in 3.3V and 5.0V outputs. They feature reverse battery protection and excellent immunity to transients and noise allowing for the reduction or elimination of filtering devices at the PCB level. They are available in the TDFN6 package, which features a small PCB footprint (2.5 mm x 2.5 mm) and an exposed lead frame on the back for heat sinking to the PCB. DC series voltage regulators meet 42V automotive standards. DD-Series Signal Processing IC for Analog GT Sensors – The DD001-12 is designed to be interfaced with an NVE ABL-Series GT Sensor to provide a digital output signal with excellent stability characteristics. It can be located away from the sensor so that the ABL package (MSOP8 or TDFN6) can be placed in a small remote housing, resulting in the absolute minimum size sensor package. The DD001-12 can also be used with other sensing devices which feature a sinusoidal output, to provide the same stable current modulated signal that it provides for NVE’s ABL-Series GT Sensors. - 61 www.nve.com phone: 952-829-9217 fax: 952-829-9189 Peripheral Integrated Circuits DB001-00 Series Power Switch IC Features: • • • • • • Designed to Work with AD9xx High Current Output Short Circuit, Reverse Battery, and Transient Protection LED Driver Excellent Temperature and Voltage Performance Small, Low-Profile Surface Mount Package Applications: • • Output Driver for Sensor Assemblies Usable with Magnetic, Inductive, and Photo Sensors Description: The DB001-00 signal processing IC is designed to take the digital input signal from NVE’s AD9xx GMR Switch and provide a high current switched output corresponding with the sensor input. The part functions as the “front end” of a complete sensor assembly and includes protection against short circuits and high voltage transients from capacitive and inductive loads. The parts also feature thermal shutdown circuitry and reverse battery protection. It provides a regulated output voltage for the sensor and other components in the assembly and an LED driver to indicate an “ON” condition. Together, the AD9xx GMR Switch and the DB001-00 signal processing IC form the bulk of the signal processing required for pneumatic cylinder position sensing electronics. Using these two ICs, the end user only requires a few capacitors and an LED in order to implement the complete sensor assembly circuit. In addition, both the AD9xx part and the DB001-00 part come in MSOP8 packages, so that the customer can implement the complete design on an extremely small PCB. If ultra-miniaturization is desired, the DB001 part can be obtained in die form for COB (Chip On Board) or flip-chip assembly. Part Numbers and Configurations: Part Number DB001-00 DB001-01 Input Current Sinking from AD9xx-00 Current Sinking from AD9xx-00 Die Size (mm) Package Marking 1.48 x 2.25 MSOP8 FFD 1.48 x 2.25 Raw IC 30284D - 62 www.nve.com phone: 952-829-9217 fax: 952-829-9189 Peripheral Integrated Circuits Schematic: A block representation of the DB001-00 series part is shown below: 3.3 Volts Voltage Regulator VCC Vreg Input Sink Out Amplifier Thermal Shutdown Source Out LED Ground ISC Packages: Please see the package drawing section in the Appendix for dimensions of the MSOP8 package. Pin Configuration: VCC ISC Source Out Sink Out Vreg NVE FFD In LED Ground - 63 www.nve.com phone: 952-829-9217 fax: 952-829-9189 Peripheral Integrated Circuits Application Circuits: DB001-00 in Current Sourcing Output Configuration: Source Cap Cap2 t1 Cap Vreg AD9xx-xx Cross Axis Vreg Sink In ShortL LED VCC Ground VCC FFD NVE Ground VCC ISC Source Out Out Sink Out t2 Cap Ground Note: For current-sinking applications, connect “Source Out” to Ground; use “Sink Out” pin as output. Electrical characteristics (-40°C to +125°C, unless otherwise noted) Parameter Min Typ Max Input Voltage 4.5 30 Vreg Voltage 3.0 3.3 3.6 Vreg Output Current 10 Switched Output Current 200 Capacitive Load 100 Off State Output Leakage Current 300 Bias Current (output off) 1.0 LED Drive Current 3 Thermal Shutdown Temperature 200 Sinking Input Current Required 100 Output Transistor Saturation Voltage 0.5 1.1 1.5 Output Short Circuit Current 0.5 0.84 1.0 Absolute maximum ratings* Parameter Limit Input Voltage 36 V Reverse Battery Protection -36 V Output Current 250 mA Junction Temperature Range, TJ -40°C to +170°C Storage Temperature Range -65 °C to +170°C Units V V mA mA nF µA mA mA °C µA V A *Stresses beyond those listed under “Absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under “Electrical characteristics” is not implied. Notes: 1. This part has reverse battery protection to -36V 2. Due to package size, MSOP8 package contains 3-letter code to designate part type. - 64 www.nve.com phone: 952-829-9217 fax: 952-829-9189 Peripheral Integrated Circuits DB002-02 Series Power Switch IC Features: • • • • • • Designed to Work with Magnetic, Inductive, or Photo Sensors Up to 300 mA Continuous Current Output Short Circuit, Reverse Battery, Transient and Thermal Protection On-Chip LED Driver Excellent Temperature and Voltage Performance Available in SOIC8 Package or in Die Form Applications: • • Output Driver for Sensor Assemblies Usable with Magnetic, Inductive, and Photo Sensors Description: The DB002 series power switch IC is designed to take a digital input from a sensor element and provide a high current switched output corresponding with the sensor input. The part functions as the “front end” of a complete sensor assembly and includes protection against short circuits and high voltage transients from capacitive and inductive loads. The part also features thermal shutdown circuitry and reverse battery protection. It provides a regulated output voltage for the sensor and other components in the assembly and an LED driver to indicate an “ON” condition. The DB002 is available in the SOIC8 package (p/n DB002-02), as well as in die form (p/n DB002-01). It is designed to work with NVE’s AD1xx GMR Switch products, or any other current sourcing or CMOS/TTL digital output sensor element such as an inductive sensor or a photo sensor. Part Numbers and Configurations: Part Number DB002-01 DB002-02 Input Any Current Sourcing or CMOS/TTL Compatible Digital Output Device Any Current Sourcing or CMOS/TTL Compatible Digital Output Device Die Size (mm) Package 1.89 x 2.85 Die 1.89 x 2.85 SOIC8 Marking 30304H (Chip ID Number) - 65 www.nve.com phone: 952-829-9217 fax: 952-829-9189 DB002-02 Peripheral Integrated Circuits Functional Block Diagram and Pinout: VCC Voltage Regulator 5.0 Volts Vreg Input Sink Out Amplifier Thermal Shutdown Source Out LED Short Circuit Detection Circuitry Ground Input Ground Vreg Delay Cap DB002-02 VCC Source Out Sink Out LED Packages: Please see the package drawing section in the Appendix for dimensions of the SOIC8 package. - 66 www.nve.com phone: 952-829-9217 fax: 952-829-9189 Peripheral Integrated Circuits Example Application Circuit: N/C VCC Vreg AD124-00 N/C N/C Ground Source Cross Axis Delay VCC DB002-02 NVE VCC LED N/C In Source Out N/C Ground Sink Out Out Delay Cap Ground Notes on Operation: 1. A capacitor of at least 1nF value must be placed between the Delay pin and ground on the IC. 2. NVE recommends a bypass capacitor between VCC and Ground, 10nF or larger 3. In noisy environments a capacitor may be used on Vreg if necessary, up to 100nF. Electrical characteristics (-40°C to +125°C, unless otherwise noted) Parameter Min Typ Max Input Voltage 6.2 30 Vreg Voltage 4.5 5.0 5.5 Vreg Output Current 10 Switched Output Current 300 Capacitive Load 100 Off State Output Leakage Current 300 Bias Current (output off) 1.4 LED Drive Current 3 Thermal Shutdown Temperature 200 Sourcing Input Current or CMOS/TTL 5 Drive Current Required (DB002-02) Turn-On Voltage at Input Terminal 3.0 Turn-Off Voltage at Input Terminal 2.0 On/Off Hysteresis 0.25 Output Transistor Saturation Voltage 0.5 1.1 1.5 Short Circuit Protection Turn-On 400 650 Current Output Short Circuit Current 0.5 0.84 1.0 Absolute maximum ratings* Parameter Limit Input Voltage 36V Reverse Battery Protection -36V Output Current 350mA Junction Temperature Range, TJ -40°C to +170°C Storage Temperature Range -65 °C to +170°C Units V V mA mA nF µA mA mA °C µA V V V V mA A *Stresses beyond those listed under “Absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “Electrical characteristics” is not implied. - 67 www.nve.com phone: 952-829-9217 fax: 952-829-9189 Peripheral Integrated Circuits DC-Series Voltage Regulators High Voltage, Low Power Voltage Regulators Features: • • • • • • Input Voltage to 36VDC (Max Rating 45VDC) 5.0V and 3.3V Regulated Output Reverse Battery Protection Excellent Immunity to Transients and ESD High Temperature Operation Small, Low-Profile Surface Mount Package Applications: • • Industrial Sensors and Controls Automotive Sensors and Controls Description: The DC series voltage regulator ICs are designed for use in harsh, noisy environments where immunity to large voltage transients and acceptance of high input voltages are required. These regulators protect the sensitive electronic components downstream, while providing a stable regulated supply voltage. They are rated for high temperature operation, up to +170°C. The low-profile small footprint package features an exposed die attach pad, for direct heat sinking to the circuit board. Specifications Electrical characteristics (-40°C to +175°C, unless otherwise noted) Parameter Min Typ Max Input Voltage (DC001-10) 4.5 36 Output Voltage (DC001-10) 3.0 3.3 3.6 Input Voltage (DC002-10) 6.2 36 Output Voltage (DC002-10) 4.5 5.0 5.5 Output Current 20 Bias Current at Zero Output Current 900 Absolute maximum ratings* Parameter Limit Input Voltage 45V Reverse Battery Voltage -60V Output Current 25mA Junction Temperature Range, TJ -40°C to +170°C Storage Temperature Range -65 °C to +170°C Units Volts Volts Volts Volts Milliamps Microamps *Stresses beyond those listed under “Absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “Electrical characteristics” is not implied. - 68 www.nve.com phone: 952-829-9217 fax: 952-829-9189 Peripheral Integrated Circuits Notes: 1. Power dissipation rating for TDFN6 package in free air is 320°C/Watt. Soldering the package to a PCB, including the die attach paddle, improves temperature performance substantially. The input voltage and output current are limited by thermal power dissipation at the package. 2. Due to package size, TDFN6 package has a three-letter code to designate part type. Package: Please see the package drawing section in the Appendix for dimensions of the TDFN6 package. Pin Configuration Vreg (Out) No Connect VCC (In) No Connect DC001-10, DC002-10 Ground No Connect Note: The die attach pad is exposed on the back of this package. NVE recommends that it be connected to the ground pin and the PCB for improved temperature performance. - 69 www.nve.com phone: 952-829-9217 fax: 952-829-9189 Peripheral Integrated Circuits DD-Series Signal Processing ICs For use with ABL-Series Sensors Features: • • • • • • Converts Analog Sensor to Digital Operation Two-Wire Output 50% Duty Cycle DC (Zero Speed) Operation Excellent Temperature and Voltage Performance Small, Low-Profile Surface Mount Package Applications: • • • Linear and Angular Speed Sensing Linear and Angular Position Sensing Direction Detection Description: The DD-Series signal processing IC is designed to take an analog, sinusoidal input signal such as that provided by NVE’s ABL-Series sensors and convert it to a two wire, current modulated digital output. Inputs as small as 2 mV peak-to-peak can be provided to the IC, along with large signal offsets. The DD001-12 part will provide a 50% duty cycle digital output signal. The DD001-12 part contains a voltage regulator circuit, programmable amplifier, offset detection and correction circuitry, and an EEPROM for setting gain and current levels. The voltage regulator output (3.3V) is used to power the external sensor element, which should be connected between VREG and VGND. Nominal current levels for the current modulated output are 3 mA and 10 mA. These can be factory programmed to different levels for specific customer requirements. Using the DD-Series signal processing IC allows the user to put the sensor element, which can very small in a remote location, and pipe the signals from the sensor to the DD001-12 for digitizing purposes. In addition, if two phase shifted sensor outputs are available (such as with the ABL014-00, ABL015-00, and ABL015-00sensors), two DD001-12 parts can be used to provide two phase shifted digital signals, for the purpose of detecting the direction of the gear tooth or encoder wheel. The two-wire output of the DD001-12 can be easily converted to a three-wire current-sinking output with the circuit shown in the GT Sensor applications section. - 70 www.nve.com phone: 952-829-9217 fax: 952-829-9189 Peripheral Integrated Circuits Specifications: Parameter Input Voltage Input Voltage Signal Input Current Supply Current – Off (Input Voltage=12V) Supply Current – On (Input Voltage=12V) Output Duty Cycle Regulated Voltage Output Current Supplied by Regulated Voltage Output Operating Temperature Range Frequency of Operation ESD Absolute Maximum Ratings Parameter Supply Voltage Reverse Battery Voltage Output Current Junction Temperature Range Storage Temperature Range Min 4.5 2 Typ 3.0 Max 36 200 10 3.8 Unit 1 Volts 2 mV µA 3 mA 2.2 7.0 8.0 9.0 mA 40 3.0 50 3.3 60 3.6 10 +150 10k -40 0 2000 3 % Volts mA °C Hz 4 V Limit 45V -60V 16mA -40°C to +170°C -65°C to +170°C Signal Output 10 Current Output (mA) 5 Time Notes: 1. The supply voltage must appear across the power and ground terminals of the part. Any additional voltage drop due to the presence of a series resistor is not included in this specification. 2. 3. Input signal range can be adjusted by programming the amplifier gain to a specific value; contact NVE for details. Supply currents can be factory programmed to different levels, for example 3 mA and 6 mA, or 7 mA and 14 mA; contact NVE for details. 4. Pin-to-pin voltage, Human Body Model for ESD. - 71 www.nve.com phone: 952-829-9217 fax: 952-829-9189 Peripheral Integrated Circuits Schematic: A block representation of the DD-Series parts is shown below: Vreg Voltage Regulator 3.3V Switching Current Source Bridge + A Offset Detector Bridge - A EEPROM Gain Current Level Packages: The DD-Series parts are available in the TDFN SO8 package. Please see the package drawing section in this catalog for dimensions. Pin Configuration: TDFN-SO8 Package Test Test Vreg VCC Ground DD001-12 Test Bridge+ Note: Bridge + and Bridge - should be connected only to the sensor element outputs for ESD and loading reasons. Vreg can supply up to 10 mA at 3.3V (330Ω load). Also, all pins labeled “Test” must be floating, i.e., not connected to each other or any other circuit node. Bridge- - 72 www.nve.com phone: 952-829-9217 fax: 952-829-9189
DB002-02 价格&库存
很抱歉,暂时无法提供与“DB002-02”相匹配的价格&库存,您可以联系我们找货
