TMR1366T
TMR1366T
    MDT(多维)
    TO226-3
    TMR SENSOR MAG SW OMNI 7G 200NA
TMR1366T 数据手册
Datasheet V1.1 TMR1366 Nano-Ampere 7 Gauss High-Sensitivity TMR Omnipolar Switch General Description The TMR1366 is a digital omnipolar magnetic switch that integrates TMR and CMOS technology in order to provide a magnetically triggered digital switch with high sensitivity, high speed, and ultra-low power consumption. It integrates a push-pull half-bridge TMR magnetic sensor and CMOS signal processing circuitry within the same package. Designed for use in applications that are both power-critical and performance-demanding, this device includes an on-chip TMR voltage generator for precise magnetic sensing, TMR voltage amplifier and comparator, a Schmitt trigger to provide switching hysteresis for noise rejection, and CMOS push-pull output. An internal band gap regulator is used to provide temperature compensated supply voltage for internal circuits, and it allows a wide range of operating supply voltages. The TMR1366 draws only 200nA resulting in ultra-low power operation, additionally it has accurate switching points, excellent thermal stability, and immunity to stray field interference. It is available in two packaging form factors: SOT23-3 (P/N TMR1366S) or TO-92S (P/N TMR1366T). Features and Benefits  Tunneling Magnetoresistance (TMR) Technology  Nano-Ampere Ultra-low Power Consumption at 200nA  Fast Internal Switching Frequency at 50Hz  Omnipolar operation with North or South Pole  High Sensitivity with BOP/BRP at 7/5 Gauss  Compatible with a Wide Range of Supply Voltages  Excellent Thermal Stability Applications  Utility Meters including Water, Gas, and Heat Meters TMR1366S(Left), TMR1366T(Right)  Proximity Switches  Rotary and Linear Position Sensing  Activation Switches for Electronic Shelf Labels (ESL) Block Diagram 1/5 Datasheet V1.1 Pin Configuration Pin No. Pin Name SOT23-3 TO-92S Pin Function TO-92S SOT23-3 VOUT 1 2 Output GND 2 3 Ground VCC 3 1 Supply Voltage Absolute Maximum Ratings Parameter Symbol Limit Unit Supply Voltage VCC 7 V Reverse Supply Voltage VRCC 0.3 V Output Current IOUTSINK 9 mA Magnetic Flux Density B 4000 G ESD level(HBM) VESD 4 kV Operating Ambient Temperature TA -40 ~125 °C Storage Temperature Tstg -50 ~ 150 °C Electrical Characteristics (VCC=3.0V, TA=25°C) Parameter Symbol Conditions Min Typ. Max Unit Supply Voltage VCC Operating 1.8 3.0 5.5 V Output High Voltage VOH Vcc-0.3 Vcc V Output Low Voltage VOL 0 0.2 V Supply Current ICC Switch Frequency F Output Open 200 nA 50 Hz Note: a 100nF capacitor is connected between VCC and GND during all tests in the above table. Magnetic Characteristics (VCC=3.0V, TA=25°C) Parameters Operate Point Release Point Hysteresis Symbol Min Typ. Max Units BOPS 7 G BOPN -7 G BRPS 5 G BRPN -5 G BH 2 G 2/5 Datasheet V1.1 Voltage and Temperature Characteristics Output Behavior vs. Magnetic Polarity Parameter South Pole North Pole Test Conditions Output B > BOPS Low (On) 0< B < BRPS High (Off) B < BOPN Low (On) 0 > B > BRPN High (Off) Note: when power is turned on under zero magnetic field, the output is “High”. Sensing Direction Switching Behavior of TMR1366 Application Information The output of the TMR1366 switches low (turns on) when a magnetic field parallel to the TMR sensor exceeds the operate point threshold, B OP. When the magnetic field is reduced below the release point, BRP, the device output goes high (turns off). The difference between the magnetic operate point and release point is the hysteresis BH of the device. It is strongly recommended that an external bypass capacitor be connected in close proximity to the device between the supply and ground to reduce noise. The typical value of the external capacitor is 0.1μF. 3/5 Datasheet V1.1 Package Information SOT23-3 package drawing TO-92S package drawing TMR Sensor Position Top view and side view (unit: mm) 4/5 Datasheet V1.1 MultiDimension Technology Co., Ltd. Address:No.7 Guangdong Road, Zhangjiagang Free Trade Zone, Jiangsu, 215634, China Web: www.dowaytech.com/en Email: info@dowaytech.com The information provided herein by MultiDimension Technology Co., Ltd. (hereinafter MultiDimension) is believed to be accurate and reliable. Publication neither conveys nor implies any license under patent or other industrial or intellectual property rights. MultiDimension reserves the right to make changes to product specifications for the purpose of improving product quality, reliability, and functionality. MultiDimension does not assume any liability arising out of the application and use of its products. MultiDimension’s customers using or selling this product for use in appliances, devices, or systems where malfunction can reasonably be expected to result in personal injury do so at their own risk and agree to fully indemnify MultiDimension for any damages resulting from such applications. 5/5
TMR1366T 价格&库存
很抱歉,暂时无法提供与“TMR1366T”相匹配的价格&库存,您可以联系我们找货
