TMR1302HS
TMR1302HS
    MDT(多维)
    TO236-3
    TMR SENSOR OMNI 17G 1.5UA FAST
TMR1302HS 数据手册
Datasheet V1.2 TMR1302H TMR Omnipolar Switch General Description The TMR1302H is a digital omnipolar magnetic switch that integrates TMR and CMOS technology in order to provide a magnetically triggered digital switch with high sensitivity, high speed, high response frequency and ultra-low power consumption. It integrates a push-pull half-bridge TMR magnetic sensor and CMOS signal processing circuitry within the same package. Designed for use in applications that are both power-critical and performance-demanding, this device includes an on-chip TMR voltage generator for precise magnetic sensing, TMR voltage amplifier and comparator, a Schmitt trigger to provide switching hysteresis for noise rejection, and CMOS push-pull output. An internal band gap regulator is used to provide temperature compensated supply voltage for internal circuits, and it allows a wide range of operating supply voltages. The TMR1302H draws only 1.5μA resulting in ultra-low power operation, additionally it has fast response at 5kHz, accurate switching points, excellent thermal stability, and a wide range of supply voltages. It is available in two packaging form factors: SOT23-3 (P/N TMR1302HS), or TO-92S (P/N TMR1302HT). Features and Benefits  Tunneling Magnetoresistance (TMR) Technology  Ultra-low Power Consumption at 1.5uA  High Frequency Response at 5kHz  Operation with North or South Pole  Low Operate Points for High Sensitivity  Compatible with a Wide Range of Supply Voltages  Excellent Thermal Stability Applications  Utility Meters including Water, Gas, and Heat Meters TMR1302HS (Left), TMR1302HT (Right)  Proximity Switches  Speed Sensing  Rotary and Linear Position Sensing Block Diagram 1/5 Datasheet V1.2 Pin Configuration Pin No. Pin Name TO-92S TO-92S SOT23-3 Pin Function VOUT 1 2 Output GND 2 3 Ground VCC 3 1 Supply Voltage SOT23-3 Absolute Maximum Ratings Parameter Symbol Limit Unit Supply Voltage VCC 7 V Reverse Supply Voltage VRCC 0.3 V Output Current IOUTSINK 9 mA Magnetic Flux Density B 2800 G ESD level(HBM) VESD 4 kV Operating Ambient Temperature TA -40 ~125 °C Storage Temperature Tstg -50 ~ 150 °C Electrical Characteristics (VCC=3.0V, TA=25°C) Parameter Symbol Conditions Min Typ. Max Unit Supply Voltage VCC Operating 1.8 3.0 5.5 V Output High Voltage VOH Vcc-0.3 Vcc V Output Low Voltage VOL 0 0.2 V Supply Current ICC Response Frequency F Output Open μA 1.5 5000 Hz Note: a 100nF capacitor is connected between VCC and GND during all tests in the above table. Magnetic Characteristics (VCC = 3.0V, TA = 25°C) Parameters Operate Point Release Point Hysteresis Symbol Min Typ. Max Units BOPS 17 G BOPN -17 G BRPS 10 G BRPN -10 G BH 7 G 2/5 Datasheet V1.2 Voltage and Temperature Characteristics Output Behavior vs. Magnetic Polarity Magnetic Polarity South North Test Conditions Output B > BOPS Low (On) 0< B < BRPS High (Off) B < BOPN Low (On) 0 > B > BRPN High (Off) Note: when power is turned on under zero magnetic field, the output is “High”. Sensing Direction of Magnetic Field Magnetic Flux Application Information The output of the TMR1302H switches low (turns on) when a magnetic field parallel to the TMR sensor exceeds the operate point threshold, BOP. When the magnetic field is reduced below the release point, BRP, the device output goes high (turns off). The difference between the magnetic operate point and release point is the hysteresis BH of the device. It is strongly recommended that an external bypass capacitor be connected in close proximity to the device between the supply and ground to reduce noise. The typical value of the external capacitor is 0.1μF. 3/5 Datasheet V1.2 Package Information SOT23-3 package drawing TO-92S package drawing TMR Sensor Position Top view and side view (unit: mm) 4/5 Datasheet V1.2 MultiDimension Technology Co., Ltd. Address: No.7 Guangdong Road, Zhangjiagang Free Trade Zone, Jiangsu, 215634, China Web: www.dowaytech.com/en Email: info@dowaytech.com The information provided herein by MultiDimension Technology Co., Ltd. (hereinafter MultiDimension) is believed to be accurate and reliable. Publication neither conveys nor implies any license under patent or other industrial or intellectual property rights. MultiDimension reserves the right to make changes to product specifications for the purpose of improving product quality, reliability, and functionality. MultiDimension does not assume any liability arising out of the application and use of its products. MultiDimension’s customers using or selling this product for use in appliances, devices, or systems where malfunction can reasonably be expected to result in personal injury do so at their own risk and agree to fully indemnify MultiDimension for any damages resulting from such applications. 5/5
TMR1302HS 价格&库存
很抱歉,暂时无法提供与“TMR1302HS”相匹配的价格&库存,您可以联系我们找货
