ICL3232CA-T
ICL3232CA-T
    L3HARRIS
    SSOP16
    IC TRANSCEIVER FULL 2/2 16SSOP
ICL3232CA-T 数据手册
ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 ® Data Sheet March 1, 2006 One Microamp Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers The Intersil ICL32XX devices are 3.0V to 5.5V powered RS-232 transmitters/receivers which meet ElA/TIA-232 and V.28/V.24 specifications, even at VCC = 3.0V. Targeted applications are PDAs, Palmtops, and notebook and laptop computers where the low operational, and even lower standby, power consumption is critical. Efficient on-chip charge pumps, coupled with manual and automatic powerdown functions (except for the ICL3232), reduce the standby supply current to a 1µA trickle. Small footprint packaging, and the use of small, low value capacitors ensure board space savings as well. Data rates greater than 250kbps are guaranteed at worst case load conditions. This family is fully compatible with 3.3V only systems, mixed 3.3V and 5.0V systems, and 5.0V only systems. The ICL324X are 3-driver, 5-receiver devices that provide a complete serial port suitable for laptop or notebook computers. Both devices also include noninverting alwaysactive receivers for “wake-up” capability. The ICL3221, ICL3223 and ICL3243, feature an automatic powerdown function which powers down the on-chip power-supply and driver circuits. This occurs when an attached peripheral device is shut off or the RS-232 cable is removed, conserving system power automatically without changes to the hardware or operating system. These devices power up again when a valid RS-232 voltage is applied to any receiver input. Table 1 summarizes the features of the devices represented by this data sheet, while Application Note AN9863 summarizes the features of each device comprising the ICL32XX 3V family. FN4805.21 Features • Pb-Free Plus Anneal Available as an Option (RoHS Compliant) (See Ordering Info) • 15kV ESD Protected (Human Body Model) • Drop in Replacements for MAX3221, MAX3222, MAX3223, MAX3232, MAX3241, MAX3243, SP3243 • ICL3221 is Low Power, Pin Compatible Upgrade for 5V MAX221 • ICL3222 is Low Power, Pin Compatible Upgrade for 5V MAX242, and SP312A • ICL3232 is Low Power Upgrade for HIN232/ICL232 and Pin Compatible Competitor Devices • RS-232 Compatible with VCC = 2.7V • Meets EIA/TIA-232 and V.28/V.24 Specifications at 3V • Latch-Up Free • On-Chip Voltage Converters Require Only Four External 0.1µF Capacitors • Manual and Automatic Powerdown Features (Except ICL3232) • Guaranteed Mouse Driveability (ICL324X Only) • Receiver Hysteresis For Improved Noise Immunity • Guaranteed Minimum Data Rate . . . . . . . . . . . . . 250kbps • Guaranteed Minimum Slew Rate . . . . . . . . . . . . . . . 6V/µs • Wide Power Supply Range . . . . . . . Single +3V to +5.5V • Low Supply Current in Powerdown State. . . . . . . . . . .1µA Applications • Any System Requiring RS-232 Communication Ports - Battery Powered, Hand-Held, and Portable Equipment - Laptop Computers, Notebooks, Palmtops - Modems, Printers and other Peripherals - Digital Cameras - Cellular/Mobile Phones TABLE 1. SUMMARY OF FEATURES NO. OF NO. OF PART NUMBER Tx. Rx. NO. OF MONITOR Rx. (ROUTB) DATA RATE (kbps) Rx. ENABLE FUNCTION? READY OUTPUT? MANUAL POWERDOWN? AUTOMATIC POWERDOWN FUNCTION? ICL3221 1 1 0 250 Yes No Yes Yes ICL3222 2 2 0 250 Yes No Yes No ICL3223 2 2 0 250 Yes No Yes Yes ICL3232 2 2 0 250 No No No No ICL3241 3 5 2 250 Yes No Yes No ICL3243 3 5 1 250 No No Yes Yes 1 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. 1-888-INTERSIL or 1-888-468-3774 | Intersil (and design) is a registered trademark of Intersil Americas Inc. Copyright Intersil Americas Inc. 1999-2006. All Rights Reserved All other trademarks mentioned are the property of their respective owners. ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Ordering Information PART NUMBER (NOTE 1) PART MARKING TEMP. RANGE (°C) PACKAGE PKG. DWG. # ICL3221CA ICL3221CA 0 to 70 16 Ld SSOP M16.209 ICL3221CAZ (Note 2) ICL3221CAZ 0 to 70 16 Ld SSOP (Pb-free) M16.209 ICL3221CV ICL3221CV 0 to 70 16 Ld TSSOP M16.173 ICL3221CVZ (Note 2) 3221CVZ 0 to 70 16 Ld TSSOP (Pb-free) M16.173 ICL3221IA ICL3221IA -40 to 85 16 Ld SSOP M16.209 ICL3221IAZ (Note 2) ICL3221IAZ -40 to 85 16 Ld SSOP (Pb-free) M16.209 ICL3222CA ICL3222CA 0 to 70 20 Ld SSOP M20.209 ICL3222CAZ (Note 2) ICL3222CAZ 0 to 70 20 Ld SSOP (Pb-free) M20.209 ICL3222CB ICL3222CB 0 to 70 18 Ld SOIC M18.3 ICL3222CBZ (Note 2) 3222CBZ 0 to 70 18 Ld SOIC (Pb-free) M18.3 ICL3222CP ICL3222CP 0 to 70 18 Ld PDIP E18.3 ICL3222CPZ (Note 2) ICL3222CPZ 0 to 70 18 Ld PDIP* (Pb-free) E18.3 ICL3222CV ICL3222CV 0 to 70 20 Ld TSSOP M20.173 ICL3222CVZ (Note 2) ICL3222CVZ 0 to 70 20 Ld TSSOP (Pb-free) M20.173 ICL3222IA ICL3222IA -40 to 85 20 Ld SSOP M20.209 ICL3222IAZ (Note 2) ICL3222IAZ -40 to 85 20 Ld SSOP (Pb-free) M20.209 ICL3222IB ICL3222IB -40 to 85 18 Ld SOIC M18.3 ICL3222IV ICL3222IV -40 to 85 20 Ld TSSOP M20.173 ICL3222IVZ (Note 2) ICL3222IVZ -40 to 85 20 Ld TSSOP (Pb-free) M20.173 ICL3223CA ICL3223CA 0 to 70 20 Ld SSOP M20.209 ICL3223CAZ (Note 2) ICL3223CAZ 0 to 70 20 Ld SSOP (Pb-free) M20.209 ICL3223CP ICL3223CP 0 to 70 20 Ld PDIP E20.3 ICL3223CPZ (Note 2) ICL3223CPZ 0 to 70 20 Ld PDIP* (Pb-free) E20.3 ICL3223CV ICL3223CV 0 to 70 20 Ld TSSOP M20.173 ICL3223IA ICL3223IA -40 to 85 20 Ld SSOP M20.209 ICL3223IAZ (Note 2) ICL3223IAZ -40 to 85 20 Ld SSOP (Pb-free) M20.209 ICL3223IV ICL3223IV -40 to 85 20 Ld TSSOP M20.173 ICL3223IVZ (Note 2) ICL3223IVZ -40 to 85 20 Ld TSSOP (Pb-free) M20.173 ICL3232CA ICL3232CA 0 to 70 16 Ld SSOP M16.209 ICL3232CAZ (Note 2) 3232CAZ 0 to 70 16 Ld SSOP (Pb-free) M16.209 ICL3232CB ICL3232CB 0 to 70 16 Ld SOIC M16.3 ICL3232CBZ (Note 2) 3232CBZ 0 to 70 16 Ld SOIC (Pb-free) M16.3 ICL3232CBN 3232CBN 0 to 70 16 Ld SOIC (N) M16.15 ICL3232CBNZ (Note 2) 3232CBNZ 0 to 70 16 Ld SOIC (N) (Pb-free) M16.15 ICL3232CP ICL3232CP 0 to 70 16 Ld PDIP E16.3 ICL3232CPZ (Note 2) ICL3232CPZ 0 to 70 16 Ld PDIP* (Pb-free) E16.3 ICL3232CV ICL3232CV 0 to 70 16 Ld TSSOP M16.173 2 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Ordering Information PART NUMBER (NOTE 1) (Continued) PART MARKING TEMP. RANGE (°C) ICL3232CVZ (Note 2) 3232CVZ 0 to 70 ICL3232IA ICL3232IA ICL3232IAZ (Note 2) PACKAGE PKG. DWG. # 16 Ld TSSOP (Pb-free) M16.173 -40 to 85 16 Ld SSOP M16.209 3232IAZ -40 to 85 16 Ld SSOP (Pb-free) M16.209 ICL3232IB ICL3232IB -40 to 85 16 Ld SOIC M16.3 ICL3232IBZ (Note 2) 3232IBZ -40 to 85 16 Ld SOIC (Pb-free) M16.3 ICL3232IBN 3232IBN -40 to 85 16 Ld SOIC (N) M16.15 ICL3232IBNZ (Note 2) 3232IBNZ -40 to 85 16 Ld SOIC (N) (Pb-free) M16.15 ICL3232IV ICL3232IV -40 to 85 16 Ld TSSOP M16.173 ICL3232IVZ (Note 2) 3232IVZ -40 to 85 16 Ld TSSOP (Pb-free) M16.173 ICL3241CA ICL3241CA 0 to 70 28 Ld SSOP M28.209 ICL3241CAZ (Note 2) ICL3241CAZ 0 to 70 28 Ld SSOP (Pb-free) M28.209 ICL3241CB ICL3241CB 0 to 70 28 Ld SOIC M28.3 ICL3241CBZ (Note 2) ICL3241CBZ 0 to 70 28 Ld SOIC (Pb-free) M28.3 ICL3241CV ICL3241CV 0 to 70 28 Ld TSSOP M28.173 ICL3241CVZ (Note 2) ICL3241CVZ 0 to 70 28 Ld TSSOP (Pb-free) M28.173 ICL3241IA ICL3241IA -40 to 85 28 Ld SSOP M28.209 ICL3241IAZ (Note 2) ICL3241IAZ -40 to 85 28 Ld SSOP (Pb-free) M28.209 ICL3241IB ICL3241IB -40 to 85 28 Ld SOIC M28.3 ICL3241IBZ (Note 2) ICL3241IBZ -40 to 85 28 Ld SOIC (Pb-free) M28.3 ICL3241IV ICL3241IV -40 to 85 28 Ld TSSOP M28.173 ICL3241IVZ (Note 2) ICL3241IVZ -40 to 85 28 Ld TSSOP (Pb-free) M28.173 ICL3243CA ICL3243CA 0 to 70 28 Ld SSOP M28.209 ICL3243CAZ (Note 2) ICL3243CAZ 0 to 70 28 Ld SSOP (Pb-free) M28.209 ICL3243CB ICL3243CB 0 to 70 28 Ld SOIC M28.3 ICL3243CBZ (Note 2) ICL3243CBZ 0 to 70 28 Ld SOIC (Pb-free) M28.3 ICL3243CV ICL3243CV 0 to 70 28 Ld TSSOP M28.173 ICL3243CVZ (Note 2) ICL3243CVZ 0 to 70 28 Ld TSSOP (Pb-free) M28.173 ICL3243IA ICL3243IA -40 to 85 28 Ld SSOP M28.209 ICL3243IAZ (Note 2) ICL3243IAZ -40 to 85 28 Ld SSOP (Pb-free) M28.209 *Pb-free PDIPs can be used for through hole wave solder processing only. They are not intended for use in Reflow solder processing applications. NOTES: 1. Most surface mount devices are available on tape and reel; add “-T” to suffix. 2. Intersil Pb-free plus anneal products employ special Pb-free material sets; molding compounds/die attach materials and 100% matte tin plate termination finish, which are RoHS compliant and compatible with both SnPb and Pb-free soldering operations. Intersil Pb-free products are MSL classified at Pb-free peak reflow temperatures that meet or exceed the Pb-free requirements of IPC/JEDEC J STD-020. 3 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Pinouts ICL3221 (SSOP, TSSOP) TOP VIEW 16 FORCEOFF EN 1 C1+ 2 15 VCC 3 14 GND V+ C1- 4 13 T1OUT C2+ 5 12 FORCEON C2- 6 11 T1IN 10 INVALID V- 7 9 R1OUT R1IN 8 ICL3222 (PDIP, SOIC) TOP VIEW EN 1 17 VCC 3 16 GND V+ C1- 4 15 T1OUT C2+ 5 14 R1IN C2- 6 13 R1OUT V- 7 12 T1IN T2OUT 8 11 T2IN R2IN 9 ICL3222 (SSOP, TSSOP) TOP VIEW 20 SHDN EN 1 18 SHDN C1+ 2 10 R2OUT ICL3223 (PDIP, SSOP, TSSOP) TOP VIEW 20 FORCEOFF EN 1 C1+ 2 19 VCC 3 18 GND V+ C1- 4 17 T1OUT C1- 4 17 T1OUT C2+ 5 16 R1IN C2+ 5 16 R1IN C2- 6 15 R1OUT C2- 6 15 R1OUT V+ V- 14 NC 7 C1+ 2 19 VCC 3 18 GND V- 14 FORCEON 7 T2OUT 8 13 T1IN T2OUT 8 13 T1IN R2IN 9 12 T2IN R2IN 9 12 T2IN 11 NC R2OUT 10 ICL3232 (PDIP, SOIC, SSOP, TSSOP) TOP VIEW C1+ 1 V+ 2 C1- 3 11 INVALID R2OUT 10 ICL3241 (SOIC, SSOP, TSSOP) TOP VIEW 16 VCC C2+ 1 28 C1+ 15 GND C2- 2 27 V+ 14 T1OUT V- 3 26 VCC C2+ 4 13 R1IN R1IN 4 25 GND C2- 5 12 R1OUT R2IN 5 24 C1- 11 T1IN R3IN 6 23 EN 10 T2IN R4IN 7 22 SHDN V- 6 T2OUT 7 9 R2OUT R2IN 8 4 R5IN 8 21 R1OUTB T1OUT 9 20 R2OUTB T2OUT 10 19 R1OUT T3OUT 11 18 R2OUT T3IN 12 17 R3OUT T2IN 13 16 R4OUT T1IN 14 15 R5OUT FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Pinouts (Continued) ICL3243 (SOIC, SSOP, TSSOP) TOP VIEW C2+ 1 28 C1+ C2- 2 27 V+ 3 26 VCC R1IN 4 25 GND R2IN 5 24 C1- R3IN 6 23 FORCEON R4IN 7 22 FORCEOFF R5IN 8 21 INVALID T1OUT 9 20 R2OUTB V- T2OUT 10 19 R1OUT T3OUT 11 18 R2OUT T3IN 12 17 R3OUT T2IN 13 16 R4OUT T1IN 14 15 R5OUT Pin Descriptions PIN VCC FUNCTION System power supply input (3.0V to 5.5V). V+ Internally generated positive transmitter supply (+5.5V). V- Internally generated negative transmitter supply (-5.5V). GND Ground connection. C1+ External capacitor (voltage doubler) is connected to this lead. C1- External capacitor (voltage doubler) is connected to this lead. C2+ External capacitor (voltage inverter) is connected to this lead. C2- External capacitor (voltage inverter) is connected to this lead. TIN TTL/CMOS compatible transmitter Inputs. TOUT RS-232 level (nominally ±5.5V) transmitter outputs. RIN RS-232 compatible receiver inputs. ROUT TTL/CMOS level receiver outputs. ROUTB INVALID EN SHDN TTL/CMOS level, noninverting, always enabled receiver outputs. Active low output that indicates if no valid RS-232 levels are present on any receiver input. Active low receiver enable control; doesn’t disable ROUTB outputs. Active low input to shut down transmitters and on-board power supply, to place device in low power mode. FORCEOFF Active low to shut down transmitters and on-chip power supply. This overrides any automatic circuitry and FORCEON (See Table 2). FORCEON Active high input to override automatic powerdown circuitry thereby keeping transmitters active. (FORCEOFF must be high). 5 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Typical Operating Circuits ICL3221 ICL3222 C3 (OPTIONAL CONNECTION, NOTE) C3 (OPTIONAL CONNECTION, NOTE) VCC V+ V- 7 T1 11 T1IN 13 9 R1OUT 3 8 + C3 0.1µF C4 + 0.1µF T1OUT R1IN 5kΩ R1 1 EN FORCEOFF 12 INVALID FORCEON GND 16 10 VCC C1 0.1µF + C2 0.1µF + 4 5 6 + 17 C1+ 3 V+ + T1 15 T2 8 14 13 R1OUT 5kΩ R1 C4 0.1µF T1OUT T2OUT R1IN 9 10 R2OUT + C3 0.1µF 7 V- C2- 11 T2IN VCC C1C2+ 12 T1IN TO POWER CONTROL LOGIC 2 RS-232 LEVELS C1+ C15 + C2+ 6 C2- C2 0.1µF + 0.1µF 15 TTL/CMOS LOGIC LEVELS 2 + 4 C1 0.1µF TTL/CMOS LOGIC LEVELS +3.3V 0.1µF RS-232 LEVELS + + +3.3V 1 EN R2IN 5kΩ R2 14 GND NOTE: The negative terminal of C3 can be connected to either VCC or GND SHDN 18 VCC 16 NOTE: The negative terminal of C3 can be connected to either VCC or GND ICL3223 R1OUT C1C2+ V- 7 C2T1 13 17 T2 12 8 15 16 5kΩ R1 R2OUT V+ 10 1 9 EN 5kΩ R2 FORCEOFF 14 3 INVALID FORCEON GND 20 11 + C3 0.1µF C4 0.1µF + + + C2 0.1µF + T1IN T2OUT R1IN R2IN T2IN R1OUT VCC 3 4 5 11 10 C1+ 16 VCC V+ C1C2+ V- C2T1 2 + C3 0.1µF 6 C4 0.1µF + 14 T2 7 13 12 R1 R2OUT TO POWER CONTROL LOGIC 1 C1 0.1µF T1OUT 0.1µF T1OUT T2OUT R1IN RS-232 LEVELS 5 + 6 VCC +3.3V + C2 0.1µF C1+ 19 TTL/CMOS LOGIC LEVELS 2 + 4 T2IN C3 (OPTIONAL CONNECTION, NOTE) 0.1µF C1 0.1µF T1IN TTL/CMOS LOGIC LEVELS + RS-232 LEVELS +3.3V ICL3232 5kΩ 9 8 R2 R2IN 5kΩ GND 15 18 NOTE: The negative terminal of C3 can be connected to either VCC or GND 6 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 (Continued) ICL3241 V+ V- 14 T1 13 T2 12 T3 27 3 9 10 TTL/CMOS LOGIC LEVELS R2OUTB R1OUT + T1IN T1OUT T2OUT T2IN 24 1 2 27 V+ C1C2+ V- C2- 14 T1 13 T2 12 T3 3 9 10 + C3 0.1µF C4 0.1µF + T1OUT T2OUT 11 T3OUT 20 19 4 19 R1IN 5kΩ 18 5 R2IN 4 R1OUT R1IN R1 R2OUT 17 5 R2 R3IN 5kΩ 16 R4OUT 6 R3OUT R3IN R3 R4OUT 7 7 8 R5OUT EN SHDN 5kΩ R5 GND 25 7 R4 5kΩ 15 R5IN 5kΩ 16 R4IN R4 R5OUT 22 21 R4IN 5kΩ 15 23 VCC R2IN 5kΩ 17 6 R3 5kΩ 18 5kΩ R3OUT 22 VCC R2OUTB 20 23 26 C1+ T3IN 21 R2 VCC C2 0.1µF T3OUT R1 R2OUT C4 0.1µF + 28 + 11 T3IN R1OUTB + C3 0.1µF 0.1µF RS-232 LEVELS T2IN VCC + C1 0.1µF TO POWER CONTROL LOGIC T1IN 28 C1+ + 24 C11 C2+ + 2 C2- 26 TTL/CMOS LOGIC LEVELS C2 0.1µF 0.1µF RS-232 LEVELS C1 0.1µF +3.3V + RS-232 LEVELS +3.3V ICL3243 RS-232 LEVELS Typical Operating Circuits 8 5kΩ R5 R5IN FORCEON FORCEOFF INVALID GND 25 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Absolute Maximum Ratings Thermal Information VCC to Ground. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -0.3V to 6V V+ to Ground . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -0.3V to 7V V- to Ground. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . +0.3V to -7V V+ to V- . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14V Input Voltages TIN, FORCEOFF, FORCEON, EN, SHDN . . . . . . . . . -0.3V to 6V RIN . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±25V Output Voltages TOUT . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±13.2V ROUT, INVALID. . . . . . . . . . . . . . . . . . . . . . . . -0.3V to VCC +0.3V Short Circuit Duration TOUT . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Continuous ESD Rating . . . . . . . . . . . . . . . . . . . . . . . . . See Specification Table Thermal Resistance (Typical, Note 3) θJA (°C/W) 16 Ld PDIP Package* . . . . . . . . . . . . . . . . . . . . . . . 90 18 Ld PDIP Package* . . . . . . . . . . . . . . . . . . . . . . . 80 20 Ld PDIP Package* . . . . . . . . . . . . . . . . . . . . . . . 77 16 Ld Wide SOIC Package . . . . . . . . . . . . . . . . . . . 100 16 Ld Narrow SOIC Package. . . . . . . . . . . . . . . . . . 115 18 Ld SOIC Package . . . . . . . . . . . . . . . . . . . . . . . . 75 28 Ld SOIC Package . . . . . . . . . . . . . . . . . . . . . . . . 75 16 Ld SSOP Package . . . . . . . . . . . . . . . . . . . . . . . 135 20 Ld SSOP Package . . . . . . . . . . . . . . . . . . . . . . . 122 16 Ld TSSOP Package . . . . . . . . . . . . . . . . . . . . . . 145 20 Ld TSSOP Package . . . . . . . . . . . . . . . . . . . . . . 140 28 Ld SSOP and TSSOP Packages . . . . . . . . . . . . 100 Maximum Junction Temperature (Plastic Package) . . . . . . . 150°C Maximum Storage Temperature Range . . . . . . . . . . . -65°C to 150°C Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . 300°C (SOIC, SSOP, TSSOP - Lead Tips Only) *Pb-free PDIPs can be used for through hole wave solder processing only. They are not intended for use in Reflow solder processing applications. Operating Conditions Temperature Range ICL32XXCX . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0°C to 70°C ICL32XXIX . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .-40°C to 85°C CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTE: 3. θJA is measured with the component mounted on a low effective thermal conductivity test board in free air. See Tech Brief TB379 for details. Test Conditions: VCC = 3V to 5.5V, C1 - C4 = 0.1µF; Unless Otherwise Specified. Typicals are at TA = 25°C Electrical Specifications PARAMETER TEST CONDITIONS TEMP (°C) MIN TYP MAX UNITS DC CHARACTERISTICS Supply Current, Automatic Powerdown All RIN Open, FORCEON = GND, FORCEOFF = VCC (ICL3221, ICL3223, ICL3243 Only) 25 - 1.0 10 µA Supply Current, Powerdown FORCEOFF = SHDN = GND (Except ICL3232) 25 - 1.0 10 µA Supply Current, Automatic Powerdown Disabled All Outputs Unloaded, FORCEON = FORCEOFF = SHDN = VCC VCC = 3.15V, ICL3221-32 25 - 0.3 1.0 mA VCC = 3.0V, ICL3241-43 25 - 0.3 1.0 mA LOGIC AND TRANSMITTER INPUTS AND RECEIVER OUTPUTS Input Logic Threshold Low TIN, FORCEON, FORCEOFF, EN, SHDN Full - - 0.8 V Input Logic Threshold High TIN, FORCEON, FORCEOFF, EN, VCC = 3.3V SHDN VCC = 5.0V Full 2.0 - - V Full 2.4 - - V Input Leakage Current TIN, FORCEON, FORCEOFF, EN, SHDN Full - ±0.01 ±1.0 µA Output Leakage Current (Except ICL3232) FORCEOFF = GND or EN = VCC Full - ±0.05 ±10 µA Output Voltage Low IOUT = 1.6mA Full - - 0.4 V Output Voltage High IOUT = -1.0mA Full - V VCC -0.6 VCC -0.1 AUTOMATIC POWERDOWN (ICL3221, ICL3223, ICL3243 Only, FORCEON = GND, FORCEOFF = VCC) Receiver Input Thresholds to Enable Transmitters ICL32XX Powers Up (See Figure 6) Full -2.7 - 2.7 V Receiver Input Thresholds to Disable Transmitters ICL32XX Powers Down (See Figure 6) Full -0.3 - 0.3 V INVALID Output Voltage Low IOUT = 1.6mA Full - - 0.4 V INVALID Output Voltage High IOUT = -1.0mA Full VCC-0.6 - - V 8 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Test Conditions: VCC = 3V to 5.5V, C1 - C4 = 0.1µF; Unless Otherwise Specified. Typicals are at TA = 25°C (Continued) Electrical Specifications TEMP (°C) MIN TYP MAX UNITS Receiver Threshold to Transmitters Enabled Delay (tWU) 25 - 100 - µs Receiver Positive or Negative Threshold to INVALID High Delay (tINVH) 25 - 1 - µs Receiver Positive or Negative Threshold to INVALID Low Delay (tINVL) 25 - 30 - µs PARAMETER TEST CONDITIONS RECEIVER INPUTS Input Voltage Range Input Threshold Low Input Threshold High Full -25 - 25 V VCC = 3.3V 25 0.6 1.2 - V VCC = 5.0V 25 0.8 1.5 - V VCC = 3.3V 25 - 1.5 2.4 V VCC = 5.0V 25 - 1.8 2.4 V Input Hysteresis 25 - 0.3 - V Input Resistance 25 3 5 7 kΩ TRANSMITTER OUTPUTS Output Voltage Swing All Transmitter Outputs Loaded with 3kΩ to Ground Full ±5.0 ±5.4 - V Output Resistance VCC = V+ = V- = 0V, Transmitter Output = ±2V Full 300 10M - Ω Full - ±35 ±60 mA Full - - ±25 µA T1IN = T2IN = GND, T3IN = VCC, T3OUT Loaded with 3kΩ to GND, T1OUT and T2OUT Loaded with 2.5mA Each Full ±5 - - V Maximum Data Rate RL = 3kΩ, CL = 1000pF, One Transmitter Switching Full 250 500 - kbps Receiver Propagation Delay Receiver Input to Receiver Output, CL = 150pF tPHL 25 - 0.3 - µs tPLH 25 - 0.3 - µs Output Short-Circuit Current VOUT = ±12V, VCC = 0V or 3V to 5.5V Automatic Powerdown or FORCEOFF = SHDN = GND Output Leakage Current MOUSE DRIVEABILITY (ICL324X Only) Transmitter Output Voltage (See Figure 9) TIMING CHARACTERISTICS Receiver Output Enable Time Normal Operation (Except ICL3232) 25 - 200 - ns Receiver Output Disable Time Normal Operation (Except ICL3232) 25 - 200 - ns Transmitter Skew tPHL - tPLH Full - 200 1000 ns Receiver Skew tPHL - tPLH Full - 100 500 ns Transition Region Slew Rate VCC = 3.3V, RL = 3kΩ to 7kΩ, Measured From 3V to -3V or -3V to 3V CL = 200pF to 2500pF 25 4 8.0 30 V/µs CL = 200pF to 1000pF 25 6 - 30 V/µs Human Body Model ICL3221 - ICL3243 25 - ±15 - kV IEC61000-4-2 Contact Discharge ICL3221 - ICL3243 25 - ±8 - kV IEC61000-4-2 Air Gap Discharge ICL3221 - ICL3232 25 - ±8 - kV ICL3241 - ICL3243 25 - ±6 - kV ICL3221 - ICL3243 25 - ±2 - kV ESD PERFORMANCE RS-232 Pins (TOUT, RIN) All Other Pins Human Body Model 9 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Detailed Description ICL32XX interface ICs operate from a single +3V to +5.5V supply, guarantee a 250kbps minimum data rate, require only four small external 0.1µF capacitors, feature low power consumption, and meet all ElA RS-232C and V.28 specifications. The circuit is divided into three sections: charge pump, transmitters and receivers. Charge-Pump Intersil’s new ICL32XX family utilizes regulated on-chip dual charge pumps as voltage doublers, and voltage inverters to generate ±5.5V transmitter supplies from a VCC supply as low as 3.0V. This allows these devices to maintain RS-232 compliant output levels over the ±10% tolerance range of 3.3V powered systems. The efficient on-chip power supplies require only four small, external 0.1µF capacitors for the voltage doubler and inverter functions at VCC = 3.3V. See the Capacitor Selection section, and Table 3 for capacitor recommendations for other operating conditions. The charge pumps operate discontinuously (i.e., they turn off as soon as the V+ and V- supplies are pumped up to the nominal values), resulting in significant power savings. Transmitters The transmitters are proprietary, low dropout, inverting drivers that translate TTL/CMOS inputs to EIA/TIA-232 output levels. Coupled with the on-chip ±5.5V supplies, these transmitters deliver true RS-232 levels over a wide range of single supply system voltages. Except for the ICL3232, all transmitter outputs disable and assume a high impedance state when the device enters the powerdown mode (See Table 2). These outputs may be driven to ±12V when disabled. All devices guarantee a 250kbps data rate for full load conditions (3kΩ and 1000pF), VCC ≥ 3.0V, with one transmitter operating at full speed. Under more typical conditions of VCC ≥ 3.3V, RL = 3kΩ, and CL = 250pF, one transmitter easily operates at 900kbps. Transmitter inputs float if left unconnected, and may cause ICC increases. Connect unused inputs to GND for the best performance. Receivers All the ICL32XX devices contain standard inverting receivers that three-state (except for the ICL3232) via the EN or FORCEOFF control lines. Additionally, the two ICL324X products include noninverting (monitor) receivers (denoted by the ROUTB label) that are always active, regardless of the state of any control lines. All the receivers convert RS-232 signals to CMOS output levels and accept inputs up to ±25V while presenting the required 3kΩ to 7kΩ input impedance (See Figure 1) even if the power is off (VCC = 0V). The receivers’ Schmitt trigger input stage uses hysteresis to increase noise immunity and decrease errors due to slow input signal transitions. 10 The ICL3221/22/23/41 inverting receivers disable only when EN is driven high. ICL3243 receivers disable during forced (manual) powerdown, but not during automatic powerdown (See Table 2). ICL324X monitor receivers remain active even during manual powerdown and forced receiver disable, making them extremely useful for Ring Indicator monitoring. Standard receivers driving powered down peripherals must be disabled to prevent current flow through the peripheral’s protection diodes (See Figures 2 and 3). This renders them useless for wake up functions, but the corresponding monitor receiver can be dedicated to this task as shown in Figure 3. VCC RXIN -25V ≤ VRIN ≤ +25V RXOUT 5kΩ GND ≤ VROUT ≤ VCC GND FIGURE 1. INVERTING RECEIVER CONNECTIONS Low Power Operation These 3V devices require a nominal supply current of 0.3mA, even at VCC = 5.5V, during normal operation (not in powerdown mode). This is considerably less than the 5mA to 11mA current required by comparable 5V RS-232 devices, allowing users to reduce system power simply by switching to this new family. Pin Compatible Replacements For 5V Devices The ICL3221/22/32 are pin compatible with existing 5V RS-232 transceivers - see the Features section on the front page for details. This pin compatibility coupled with the low Icc and wide operating supply range, make the ICL32XX potential lower power, higher performance drop-in replacements for existing 5V applications. As long as the ±5V RS-232 output swings are acceptable, and transmitter input pull-up resistors aren’t required, the ICL32XX should work in most 5V applications. When replacing a device in an existing 5V application, it is acceptable to terminate C3 to VCC as shown on the Typical Operating Circuit. Nevertheless, terminate C3 to GND if possible, as slightly better performance results from this configuration. Powerdown Functionality (Except ICL3232) The already low current requirement drops significantly when the device enters powerdown mode. In powerdown, supply current drops to 1µA, because the on-chip charge pump turns off (V+ collapses to VCC, V- collapses to GND), and the transmitter outputs three-state. Inverting receiver outputs may or may not disable in powerdown; refer to Table 2 for details. This micro-power mode makes these devices ideal for battery powered and portable applications. FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Software Controlled (Manual) Powerdown The ICL3221, ICL3223, and ICL3243 utilize a two pin approach where the FORCEON and FORCEOFF inputs determine the IC’s mode. For always enabled operation, FORCEON and FORCEOFF are both strapped high. To switch between active and powerdown modes, under logic or software control, only the FORCEOFF input need be driven. The FORCEON state isn’t critical, as FORCEOFF dominates over FORCEON. Nevertheless, if strictly manual control over powerdown is desired, the user must strap FORCEON high to disable the automatic powerdown circuitry. ICL3243 inverting (standard) receiver outputs also disable when the device is in manual powerdown, thereby eliminating the possible current path through a shutdown peripheral’s input protection diode (See Figures 2 and 3). Most devices in the ICL32XX family provide pins that allow the user to force the IC into the low power, standby state. On the ICL3222 and ICL3241, the powerdown control is via a simple shutdown (SHDN) pin. Driving this pin high enables normal operation, while driving it low forces the IC into its powerdown state. Connect SHDN to VCC if the powerdown function isn’t needed. Note that all the receiver outputs remain enabled during shutdown (See Table 2). For the lowest power consumption during powerdown, the receivers should also be disabled by driving the EN input high (See next section, and Figures 2 and 3). TABLE 2. POWERDOWN AND ENABLE LOGIC TRUTH TABLE RS-232 SIGNAL PRESENT AT RECEIVER INPUT? FORCEOFF (NOTE 4) ROUTB OR SHDN FORCEON EN TRANSMITTER RECEIVER INVALID INPUT INPUT INPUT OUTPUTS OUTPUTS OUTPUTS OUTPUT MODE OF OPERATION ICL3222, ICL3241 N.A. L N.A. L High-Z Active Active N.A. Manual Powerdown N.A. L N.A. H High-Z High-Z Active N.A. Manual Powerdown w/Rcvr. Disabled N.A. H N.A. L Active Active Active N.A. Normal Operation N.A. H N.A. H Active High-Z Active N.A. Normal Operation w/Rcvr. Disabled No H H L Active Active N.A. L No H H H Active High-Z N.A. L Yes H L L Active Active N.A. H Yes H L H Active High-Z N.A. H No H L L High-Z Active N.A. L No H L H High-Z High-Z N.A. L Yes L X L High-Z Active N.A. H Manual Powerdown Yes L X H High-Z High-Z N.A. H Manual Powerdown w/Rcvr. Disabled No L X L High-Z Active N.A. L Manual Powerdown No L X H High-Z High-Z N.A. L Manual Powerdown w/Rcvr. Disabled No H H N.A. Active Active Active L Normal Operation (Auto Powerdown Disabled) Yes H L N.A. Active Active Active H Normal Operation (Auto Powerdown Enabled) No H L N.A. High-Z Active Active L Powerdown Due to Auto Powerdown Logic Yes L X N.A. High-Z High-Z Active H Manual Powerdown No L X N.A. High-Z High-Z Active L Manual Powerdown ICL3221, ICL3223 Normal Operation (Auto Powerdown Disabled) Normal Operation (Auto Powerdown Enabled) Powerdown Due to Auto Powerdown Logic ICL3243 NOTE: 4. Applies only to the ICL3241 and ICL3243. 11 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 The INVALID output always indicates whether or not a valid RS-232 signal is present at any of the receiver inputs (See Table 2), giving the user an easy way to determine when the interface block should power down. In the case of a disconnected interface cable where all the receiver inputs are floating (but pulled to GND by the internal receiver pull down resistors), the INVALID logic detects the invalid levels and drives the output low. The power management logic then uses this indicator to power down the interface block. Reconnecting the cable restores valid levels at the receiver inputs, INVALID switches high, and the power management logic wakes up the interface block. INVALID can also be used to indicate the DTR or RING INDICATOR signal, as long as the other receiver inputs are floating, or driven to GND (as in the case of a powered down driver). Connecting FORCEOFF and FORCEON together disables the automatic powerdown feature, enabling them to function as a manual SHUTDOWN input (See Figure 4). VCC FORCEON INVALID ICL3221/23/43 I/O UART CPU FIGURE 4. CONNECTIONS FOR MANUAL POWERDOWN WHEN NO VALID RECEIVER SIGNALS ARE PRESENT With any of the above control schemes, the time required to exit powerdown, and resume transmission is only 100µs. A mouse, or other application, may need more time to wake up from shutdown. If automatic powerdown is being utilized, the RS-232 device will reenter powerdown if valid receiver levels aren’t reestablished within 30µs of the ICL32XX powering up. Figure 5 illustrates a circuit that keeps the ICL32XX from initiating automatic powerdown for 100ms after powering up. This gives the slow-to-wake peripheral circuit time to reestablish valid RS-232 output levels. VCC CURRENT FLOW VCC FORCEOFF PWR MGT LOGIC VOUT = VCC Rx POWERED DOWN UART Tx SHDN = GND GND OLD RS-232 CHIP POWER MANAGEMENT UNIT FIGURE 2. POWER DRAIN THROUGH POWERED DOWN PERIPHERAL MASTER POWERDOWN LINE 0.1µF FORCEOFF 1MΩ FORCEON ICL3221/23/43 VCC FIGURE 5. CIRCUIT TO PREVENT AUTO POWERDOWN FOR 100ms AFTER FORCED POWERUP TRANSITION DETECTOR TO WAKE-UP LOGIC ICL324X Automatic Powerdown (ICL3221/23/43 Only) VCC R2OUTB RX POWERED DOWN UART VOUT = HI-Z R2OUT TX R2IN T1IN T1OUT FORCEOFF = GND OR SHDN = GND, EN = VCC FIGURE 3. DISABLED RECEIVERS PREVENT POWER DRAIN 12 Even greater power savings is available by using the devices which feature an automatic powerdown function. When no valid RS-232 voltages (See Figure 6) are sensed on any receiver input for 30µs, the charge pump and transmitters powerdown, thereby reducing supply current to 1µA. Invalid receiver levels occur whenever the driving peripheral’s outputs are shut off (powered down) or when the RS-232 interface cable is disconnected. The ICL32XX powers back up whenever it detects a valid RS-232 voltage level on any receiver input. This automatic powerdown feature provides additional system power savings without changes to the existing operating system. FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 2.7V VALID RS-232 LEVEL - ICL32XX IS ACTIVE INDETERMINATE - POWERDOWN MAY OR MAY NOT OCCUR 0.3V INVALID LEVEL - POWERDOWN OCCURS AFTER 30ms Capacitor Selection -0.3V INDETERMINATE - POWERDOWN MAY OR MAY NOT OCCUR -2.7V VALID RS-232 LEVEL - ICL32XX IS ACTIVE FIGURE 6. DEFINITION OF VALID RS-232 RECEIVER LEVELS Automatic powerdown operates when the FORCEON input is low, and the FORCEOFF input is high. Tying FORCEON high disables automatic powerdown, but manual powerdown is always available via the overriding FORCEOFF input. Table 2 summarizes the automatic powerdown functionality. Devices with the automatic powerdown feature include an INVALID output signal, which switches low to indicate that invalid levels have persisted on all of the receiver inputs for more than 30µs (See Figure 7). INVALID switches high 1µs after detecting a valid RS-232 level on a receiver input. INVALID operates in all modes (forced or automatic powerdown, or forced on), so it is also useful for systems employing manual powerdown circuitry. When automatic powerdown is utilized, INVALID = 0 indicates that the ICL32XX is in powerdown mode. RECEIVER INPUTS INVALID } REGION VCC 0 tINVH tINVL PWR UP AUTOPWDN The charge pumps require 0.1µF capacitors for 3.3V operation. For other supply voltages refer to Table 3 for capacitor values. Do not use values smaller than those listed in Table 3. Increasing the capacitor values (by a factor of 2) reduces ripple on the transmitter outputs and slightly reduces power consumption. C2, C3, and C4 can be increased without increasing C1’s value, however, do not increase C1 without also increasing C2, C3, and C4 to maintain the proper ratios (C1 to the other capacitors). When using minimum required capacitor values, make sure that capacitor values do not degrade excessively with temperature. If in doubt, use capacitors with a larger nominal value. The capacitor’s equivalent series resistance (ESR) usually rises at low temperatures and it influences the amount of ripple on V+ and V-. TABLE 3. REQUIRED CAPACITOR VALUES VCC (V) C1 (µF) C2, C3, C4 (µF) 3.0 to 3.6 0.1 0.1 4.5 to 5.5 0.047 0.33 3.0 to 5.5 0.1 0.47 Power Supply Decoupling In most circumstances a 0.1µF bypass capacitor is adequate. In applications that are particularly sensitive to power supply noise, decouple VCC to ground with a capacitor of the same value as the charge-pump capacitor C1. Connect the bypass capacitor as close as possible to the IC. TRANSMITTER OUTPUTS INVALID OUTPUT (standard) receiver outputs placing them in a high impedance state. This is useful to eliminate supply current, due to a receiver output forward biasing the protection diode, when driving the input of a powered down (VCC = GND) peripheral (See Figure 2). The enable input has no effect on transmitter nor monitor (ROUTB) outputs. V+ Operation Down to 2.7V ICL32XX transmitter outputs meet RS-562 levels (±3.7V), at full data rate, with VCC as low as 2.7V. RS-562 levels typically ensure interoperability with RS-232 devices. VCC 0 V- FIGURE 7. AUTOMATIC POWERDOWN AND INVALID TIMING DIAGRAMS The time to recover from automatic powerdown mode is typically 100µs. Receiver ENABLE Control (ICL3221/22/23/41 Only) Several devices also feature an EN input to control the receiver outputs. Driving EN high disables all the inverting 13 Transmitter Outputs when Exiting Powerdown Figure 8 shows the response of two transmitter outputs when exiting powerdown mode. As they activate, the two transmitter outputs properly go to opposite RS-232 levels, with no glitching, ringing, nor undesirable transients. Each transmitter is loaded with 3kΩ in parallel with 2500pF. Note that the transmitters enable only when the magnitude of the supplies exceed approximately 3V. FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 5V/DIV for a single transmitter driving 1000pF and an RS-232 load at 250kbps. The static transmitters were also loaded with an RS-232 receiver. FORCEOFF T1 VCC + 0.1µF 2V/DIV + C1 C1+ VCC V+ + C3 C1T2 + C2 VCC = +3.3V C1 - C4 = 0.1µF V- C4 + C2TIN TIME (20µs/DIV) FIGURE 8. TRANSMITTER OUTPUTS WHEN EXITING POWERDOWN Mouse Driveability The ICL324X have been specifically designed to power a serial mouse while operating from low voltage supplies. Figure 9 shows the transmitter output voltages under increasing load current. The on-chip switching regulator ensures the transmitters will supply at least ±5V during worst case conditions (15mA for paralleled V+ transmitters, 7.3mA for single V- transmitter). The Automatic Powerdown feature does not work with a mouse, so FORCEOFF and FORCEON should be connected to VCC. VCC TOUT ROUT RIN EN 5K 1000pF SHDN OR FORCEOFF FIGURE 10. TRANSMITTER LOOPBACK TEST CIRCUIT 5V/DIV T1IN T1OUT 6 TRANSMITTER OUTPUT VOLTAGE (V) ICL32XX C2+ 5 VOUT+ 4 3 VCC = 3.0V 2 1 R1OUT T1 0 VCC = +3.3V C1 - C4 = 0.1µF VOUT+ -1 5µs/DIV T2 -2 ICL3241/43 -3 -4 VCC T3 1 2 FIGURE 11. LOOPBACK TEST AT 120kbps VOUT - VOUT - -5 -6 0 3 4 5 6 7 8 9 10 LOAD CURRENT PER TRANSMITTER (mA) 5V/DIV. T1IN FIGURE 9. TRANSMITTER OUTPUT VOLTAGE vs LOAD CURRENT (PER TRANSMITTER, i.e., DOUBLE CURRENT AXIS FOR TOTAL VOUT+ CURRENT) T1OUT High Data Rates The ICL32XX maintain the RS-232 ±5V minimum transmitter output voltages even at high data rates. Figure 10 details a transmitter loopback test circuit, and Figure 11 illustrates the loopback test result at 120kbps. For this test, all transmitters were simultaneously driving RS-232 loads in parallel with 1000pF, at 120kbps. Figure 12 shows the loopback results 14 R1OUT VCC = +3.3V C1 - C4 = 0.1µF 2µs/DIV. FIGURE 12. LOOPBACK TEST AT 250kbps FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Interconnection with 3V and 5V Logic The ICL32XX directly interface with 5V CMOS and TTL logic families. Nevertheless, with the ICL32XX at 3.3V, and the logic supply at 5V, AC, HC, and CD4000 outputs can drive ICL32XX inputs, but ICL32XX outputs do not reach the minimum VIH for these logic families. See Table 4 for more information. Typical Performance Curves TABLE 4. LOGIC FAMILY COMPATIBILITY WITH VARIOUS SUPPLY VOLTAGES VCC SYSTEM POWER-SUPPLY SUPPLY VOLTAGE VOLTAGE (V) (V) 3.3 5 5 5 3.3 Compatible with all TTL and CMOS logic families. Compatible with ACT and HCT CMOS, and with TTL. ICL32XX outputs are incompatible with AC, HC, and CD4000 CMOS inputs. 25 VOUT+ 4 SLEW RATE (V/µs) 20 2 1 TRANSMITTER AT 250kbps 1 OR 2 TRANSMITTERS AT 30kbps 0 -2 15 -SLEW +SLEW 10 VOUT - -4 -6 0 1000 2000 3000 4000 5 5000 0 1000 FIGURE 13. TRANSMITTER OUTPUT VOLTAGE vs LOAD CAPACITANCE 3000 4000 5000 FIGURE 14. SLEW RATE vs LOAD CAPACITANCE 45 45 ICL3221 ICL3222 - ICL3232 40 35 SUPPLY CURRENT (mA) 40 250kbps 30 25 20 120kbps 15 10 20kbps 5 0 2000 LOAD CAPACITANCE (pF) LOAD CAPACITANCE (pF) SUPPLY CURRENT (mA) Compatible with all CMOS families. VCC = 3.3V, TA = 25°C 6 TRANSMITTER OUTPUT VOLTAGE (V) 3.3 COMPATIBILITY 250kbps 35 30 25 120kbps 20 15 20kbps 10 5 0 1000 2000 3000 4000 5000 LOAD CAPACITANCE (pF) FIGURE 15. SUPPLY CURRENT vs LOAD CAPACITANCE WHEN TRANSMITTING DATA 15 0 0 1000 2000 3000 4000 5000 LOAD CAPACITANCE (pF) FIGURE 16. SUPPLY CURRENT vs LOAD CAPACITANCE WHEN TRANSMITTING DATA FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Typical Performance Curves 3.5 ICL324X 40 250kbps 35 30 120kbps 25 20 20kbps 15 10 ICL3221 - ICL3232 2.5 2.0 1.5 1.0 ICL324X 0.5 ICL324X 5 0 NO LOAD ALL OUTPUTS STATIC 3.0 SUPPLY CURRENT (mA) 45 SUPPLY CURRENT (mA) VCC = 3.3V, TA = 25°C (Continued) 0 2000 1000 3000 4000 5000 LOAD CAPACITANCE (pF) FIGURE 17. SUPPLY CURRENT vs LOAD CAPACITANCE WHEN TRANSMITTING DATA 0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 SUPPLY VOLTAGE (V) FIGURE 18. SUPPLY CURRENT vs SUPPLY VOLTAGE Die Characteristics SUBSTRATE POTENTIAL (POWERED UP): GND TRANSISTOR COUNT: ICL3221: 286 ICL3222: 338 ICL3223: 357 ICL3232: 296 ICL324X: 464 PROCESS: Si Gate CMOS 16 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Dual-In-Line Plastic Packages (PDIP) E16.3 (JEDEC MS-001-BB ISSUE D) N 16 LEAD DUAL-IN-LINE PLASTIC PACKAGE E1 INDEX AREA 1 2 3 INCHES N/2 -B- -AE D BASE PLANE -C- A2 SEATING PLANE A L D1 e B1 D1 A1 eC B 0.010 (0.25) M C A B S MILLIMETERS SYMBOL MIN MAX MIN MAX NOTES A - 0.210 - 5.33 4 A1 0.015 - 0.39 - 4 A2 0.115 0.195 2.93 4.95 - B 0.014 0.022 0.356 0.558 - C L B1 0.045 0.070 1.15 1.77 8, 10 eA C 0.008 0.014 C D 0.735 0.775 eB NOTES: 1. Controlling Dimensions: INCH. In case of conflict between English and Metric dimensions, the inch dimensions control. 0.355 19.68 5 D1 0.005 - 0.13 - 5 E 0.300 0.325 7.62 8.25 6 E1 0.240 0.280 6.10 7.11 5 e 0.100 BSC 2. Dimensioning and tolerancing per ANSI Y14.5M-1982. eA 0.300 BSC 3. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of Publication No. 95. eB - 4. Dimensions A, A1 and L are measured with the package seated in JEDEC seating plane gauge GS-3. L 0.115 N 5. D, D1, and E1 dimensions do not include mold flash or protrusions. Mold flash or protrusions shall not exceed 0.010 inch (0.25mm). 6. E and eA are measured with the leads constrained to be perpendicular to datum -C- . 0.204 18.66 16 2.54 BSC 7.62 BSC 0.430 - 0.150 2.93 16 6 10.92 7 3.81 4 9 Rev. 0 12/93 7. eB and eC are measured at the lead tips with the leads unconstrained. eC must be zero or greater. 8. B1 maximum dimensions do not include dambar protrusions. Dambar protrusions shall not exceed 0.010 inch (0.25mm). 9. N is the maximum number of terminal positions. 10. Corner leads (1, N, N/2 and N/2 + 1) for E8.3, E16.3, E18.3, E28.3, E42.6 will have a B1 dimension of 0.030 - 0.045 inch (0.76 - 1.14mm). 17 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Dual-In-Line Plastic Packages (PDIP) N E18.3 (JEDEC MS-001-BC ISSUE D) E1 INDEX AREA 1 2 3 18 LEAD DUAL-IN-LINE PLASTIC PACKAGE N/2 INCHES -B- SYMBOL -AD -C- SEATING PLANE A2 D1 e B1 D1 A1 eC B 0.010 (0.25) M C A B S MIN MAX NOTES A - 0.210 - 5.33 4 0.015 - 0.39 - 4 A2 0.115 0.195 2.93 4.95 - C L B 0.014 0.022 0.356 0.558 - eA B1 0.045 0.070 1.15 1.77 8, 10 C 0.008 0.014 0.204 0.355 - D 0.845 0.880 21.47 D1 0.005 - 0.13 - 5 A L MAX A1 E BASE PLANE MILLIMETERS MIN C eB NOTES: 1. Controlling Dimensions: INCH. In case of conflict between English and Metric dimensions, the inch dimensions control. 2. Dimensioning and tolerancing per ANSI Y14.5M-1982. 3. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of Publication No. 95. 4. Dimensions A, A1 and L are measured with the package seated in JEDEC seating plane gauge GS-3. 5. D, D1, and E1 dimensions do not include mold flash or protrusions. Mold flash or protrusions shall not exceed 0.010 inch (0.25mm). 6. E and eA are measured with the leads constrained to be perpendicular to datum -C- . 22.35 5 E 0.300 0.325 7.62 8.25 6 E1 0.240 0.280 6.10 7.11 5 e 0.100 BSC 2.54 BSC - eA 0.300 BSC 7.62 BSC 6 eB - 0.430 - 10.92 7 L 0.115 0.150 2.93 3.81 4 N 18 18 9 Rev. 2 11/03 7. eB and eC are measured at the lead tips with the leads unconstrained. eC must be zero or greater. 8. B1 maximum dimensions do not include dambar protrusions. Dambar protrusions shall not exceed 0.010 inch (0.25mm). 9. N is the maximum number of terminal positions. 10. Corner leads (1, N, N/2 and N/2 + 1) for E8.3, E16.3, E18.3, E28.3 may have a B1 dimension of 0.030 - 0.045 inch (0.76 - 1.14mm). 18 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Small Outline Plastic Packages (SOIC) M16.15 (JEDEC MS-012-AC ISSUE C) N INDEX AREA H 0.25(0.010) M 16 LEAD NARROW BODY SMALL OUTLINE PLASTIC PACKAGE B M INCHES E -B- 1 2 3 L SEATING PLANE -A- A D h x 45° -C- e A1 B 0.25(0.010) M C 0.10(0.004) C A M SYMBOL MIN MAX MIN MAX NOTES A 0.0532 0.0688 1.35 1.75 - A1 0.0040 0.0098 0.10 0.25 - B 0.013 0.020 0.33 0.51 9 C 0.0075 0.0098 0.19 0.25 - D 0.3859 0.3937 9.80 10.00 3 E 0.1497 0.1574 3.80 4.00 4 e α B S 1. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of Publication Number 95. 0.050 BSC 1.27 BSC - H 0.2284 0.2440 5.80 6.20 - h 0.0099 0.0196 0.25 0.50 5 L 0.016 0.050 0.40 1.27 6 N α NOTES: MILLIMETERS 16 0° 16 8° 0° 7 8° Rev. 1 6/05 2. Dimensioning and tolerancing per ANSI Y14.5M-1982. 3. Dimension “D” does not include mold flash, protrusions or gate burrs. Mold flash, protrusion and gate burrs shall not exceed 0.15mm (0.006 inch) per side. 4. Dimension “E” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.25mm (0.010 inch) per side. 5. The chamfer on the body is optional. If it is not present, a visual index feature must be located within the crosshatched area. 6. “L” is the length of terminal for soldering to a substrate. 7. “N” is the number of terminal positions. 8. Terminal numbers are shown for reference only. 9. The lead width “B”, as measured 0.36mm (0.014 inch) or greater above the seating plane, shall not exceed a maximum value of 0.61mm (0.024 inch). 10. Controlling dimension: MILLIMETER. Converted inch dimensions are not necessarily exact. 19 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Thin Shrink Small Outline Plastic Packages (TSSOP) M16.173 N 16 LEAD THIN SHRINK SMALL OUTLINE PLASTIC PACKAGE INDEX AREA E 0.25(0.010) M E1 2 INCHES GAUGE PLANE -B1 B M 0.05(0.002) -A- SYMBOL MIN MAX MIN MAX NOTES A - 0.043 - 1.10 - A1 3 L A D -C- e α A1 b 0.10(0.004) M 0.25 0.010 SEATING PLANE c 0.10(0.004) C A M 0.05 0.15 - A2 0.033 0.037 0.85 0.95 - b 0.0075 0.012 0.19 0.30 9 c 0.0035 0.008 0.09 0.20 - D 0.193 0.201 4.90 5.10 3 E1 0.169 0.177 4.30 4.50 4 e A2 B S 0.002 0.246 L 0.020 α 1. These package dimensions are within allowable dimensions of JEDEC MO-153-AB, Issue E. 0.006 0.026 BSC E N NOTES: MILLIMETERS 0.65 BSC 0.256 6.25 0.028 0.50 16 0o 6.50 0.70 16 8o 0o 6 7 8o Rev. 1 2/02 2. Dimensioning and tolerancing per ANSI Y14.5M-1982. 3. Dimension “D” does not include mold flash, protrusions or gate burrs. Mold flash, protrusion and gate burrs shall not exceed 0.15mm (0.006 inch) per side. 4. Dimension “E1” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.15mm (0.006 inch) per side. 5. The chamfer on the body is optional. If it is not present, a visual index feature must be located within the crosshatched area. 6. “L” is the length of terminal for soldering to a substrate. 7. “N” is the number of terminal positions. 8. Terminal numbers are shown for reference only. 9. Dimension “b” does not include dambar protrusion. Allowable dambar protrusion shall be 0.08mm (0.003 inch) total in excess of “b” dimension at maximum material condition. Minimum space between protrusion and adjacent lead is 0.07mm (0.0027 inch). 10. Controlling dimension: MILLIMETER. Converted inch dimensions are not necessarily exact. (Angles in degrees) 20 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Small Outline Plastic Packages (SSOP) M16.209 (JEDEC MO-150-AC ISSUE B) N INDEX AREA 16 LEAD SHRINK SMALL OUTLINE PLASTIC PACKAGE H 0.25(0.010) M 2 GAUGE PLANE 3 0.25 0.010 SEATING PLANE -A- INCHES E -B- 1 B M A D -C- α e C 0.10(0.004) C A M SYMBOL MIN MAX MIN MAX NOTES A - 0.078 - 2.00 - A1 0.002 - 0.05 - - A2 0.065 0.072 1.65 1.85 - B 0.009 0.014 0.22 0.38 9 C 0.004 0.009 0.09 0.25 - D 0.233 0.255 5.90 6.50 3 E 0.197 0.220 5.00 5.60 4 e A2 A1 B 0.25(0.010) M L B S 1. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of Publication Number 95. 0.026 BSC H 0.292 L 0.022 N α NOTES: MILLIMETERS 0.65 BSC 0.322 7.40 0.037 0.55 16 0° - 8.20 - 0.95 6 16 8° 0° 7 8° Rev. 3 6/05 2. Dimensioning and tolerancing per ANSI Y14.5M-1982. 3. Dimension “D” does not include mold flash, protrusions or gate burrs. Mold flash, protrusion and gate burrs shall not exceed 0.20mm (0.0078 inch) per side. 4. Dimension “E” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.20mm (0.0078 inch) per side. 5. The chamfer on the body is optional. If it is not present, a visual index feature must be located within the crosshatched area. 6. “L” is the length of terminal for soldering to a substrate. 7. “N” is the number of terminal positions. 8. Terminal numbers are shown for reference only. 9. Dimension “B” does not include dambar protrusion. Allowable dambar protrusion shall be 0.13mm (0.005 inch) total in excess of “B” dimension at maximum material condition. 10. Controlling dimension: MILLIMETER. Converted inch dimensions are not necessarily exact. 21 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Small Outline Plastic Packages (SOIC) M16.3 (JEDEC MS-013-AA ISSUE C) N INDEX AREA 16 LEAD WIDE BODY SMALL OUTLINE PLASTIC PACKAGE H 0.25(0.010) M B M INCHES E -B- 1 2 3 L SEATING PLANE -A- A D h x 45° -C- e A1 B 0.25(0.010) M C 0.10(0.004) C A M SYMBOL MIN MAX MIN MAX NOTES A 0.0926 0.1043 2.35 2.65 - A1 0.0040 0.0118 0.10 0.30 - B 0.013 0.0200 0.33 0.51 9 C 0.0091 0.0125 0.23 0.32 - D 0.3977 0.4133 10.10 10.50 3 E 0.2914 0.2992 7.40 7.60 4 e α B S 1. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of Publication Number 95. 0.050 BSC 1.27 BSC - H 0.394 0.419 10.00 10.65 - h 0.010 0.029 0.25 0.75 5 L 0.016 0.050 0.40 1.27 6 N α NOTES: MILLIMETERS 16 0° 16 8° 0° 7 8° Rev. 1 6/05 2. Dimensioning and tolerancing per ANSI Y14.5M-1982. 3. Dimension “D” does not include mold flash, protrusions or gate burrs. Mold flash, protrusion and gate burrs shall not exceed 0.15mm (0.006 inch) per side. 4. Dimension “E” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.25mm (0.010 inch) per side. 5. The chamfer on the body is optional. If it is not present, a visual index feature must be located within the crosshatched area. 6. “L” is the length of terminal for soldering to a substrate. 7. “N” is the number of terminal positions. 8. Terminal numbers are shown for reference only. 9. The lead width “B”, as measured 0.36mm (0.014 inch) or greater above the seating plane, shall not exceed a maximum value of 0.61mm (0.024 inch) 10. Controlling dimension: MILLIMETER. Converted inch dimensions are not necessarily exact. 22 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Small Outline Plastic Packages (SOIC) M18.3 (JEDEC MS-013-AB ISSUE C) N INDEX AREA 18 LEAD WIDE BODY SMALL OUTLINE PLASTIC PACKAGE H 0.25(0.010) M B M INCHES E -B- 1 2 3 L SEATING PLANE -A- A D h x 45° -C- e A1 B 0.25(0.010) M C 0.10(0.004) C A M SYMBOL MIN MAX MIN MAX NOTES A 0.0926 0.1043 2.35 2.65 - A1 0.0040 0.0118 0.10 0.30 - B 0.013 0.0200 0.33 0.51 9 C 0.0091 0.0125 0.23 0.32 - D 0.4469 0.4625 11.35 11.75 3 E 0.2914 0.2992 7.40 7.60 4 e α B S 1. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of Publication Number 95. 0.050 BSC 1.27 BSC - H 0.394 0.419 10.00 10.65 - h 0.010 0.029 0.25 0.75 5 L 0.016 0.050 0.40 1.27 6 N α NOTES: MILLIMETERS 18 0° 18 8° 0° 7 8° Rev. 1 6/05 2. Dimensioning and tolerancing per ANSI Y14.5M-1982. 3. Dimension “D” does not include mold flash, protrusions or gate burrs. Mold flash, protrusion and gate burrs shall not exceed 0.15mm (0.006 inch) per side. 4. Dimension “E” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.25mm (0.010 inch) per side. 5. The chamfer on the body is optional. If it is not present, a visual index feature must be located within the crosshatched area. 6. “L” is the length of terminal for soldering to a substrate. 7. “N” is the number of terminal positions. 8. Terminal numbers are shown for reference only. 9. The lead width “B”, as measured 0.36mm (0.014 inch) or greater above the seating plane, shall not exceed a maximum value of 0.61mm (0.024 inch) 10. Controlling dimension: MILLIMETER. Converted inch dimensions are not necessarily exact. 23 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Thin Shrink Small Outline Plastic Packages (TSSOP) M20.173 N INDEX AREA E 0.25(0.010) M E1 2 INCHES GAUGE PLANE -B1 20 LEAD THIN SHRINK SMALL OUTLINE PLASTIC PACKAGE B M SYMBOL 3 L 0.05(0.002) -A- MAX MILLIMETERS MIN MAX NOTES A - 0.047 - 1.20 - A1 0.002 0.006 0.05 0.15 - A2 0.031 0.051 0.80 1.05 - b 0.0075 0.0118 0.19 0.30 9 A D -C- α e A2 A1 b 0.10(0.004) M 0.25 0.010 SEATING PLANE MIN c 0.10(0.004) C A M B S c 0.0035 0.0079 0.09 0.20 - D 0.252 0.260 6.40 6.60 3 E1 0.169 0.177 4.30 4.50 4 e 0.026 BSC 1. These package dimensions are within allowable dimensions of JEDEC MO-153-AC, Issue E. - E 0.246 0.256 6.25 6.50 - L 0.0177 0.0295 0.45 0.75 6 8o 0o N NOTES: 0.65 BSC α 20 0o 20 7 8o Rev. 1 6/98 2. Dimensioning and tolerancing per ANSI Y14.5M-1982. 3. Dimension “D” does not include mold flash, protrusions or gate burrs. Mold flash, protrusion and gate burrs shall not exceed 0.15mm (0.006 inch) per side. 4. Dimension “E1” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.15mm (0.006 inch) per side. 5. The chamfer on the body is optional. If it is not present, a visual index feature must be located within the crosshatched area. 6. “L” is the length of terminal for soldering to a substrate. 7. “N” is the number of terminal positions. 8. Terminal numbers are shown for reference only. 9. Dimension “b” does not include dambar protrusion. Allowable dambar protrusion shall be 0.08mm (0.003 inch) total in excess of “b” dimension at maximum material condition. Minimum space between protrusion and adjacent lead is 0.07mm (0.0027 inch). 10. Controlling dimension: MILLIMETER. Converted inch dimensions are not necessarily exact. (Angles in degrees) 24 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Shrink Small Outline Plastic Packages (SSOP) M20.209 (JEDEC MO-150-AE ISSUE B) N INDEX AREA 20 LEAD SHRINK SMALL OUTLINE PLASTIC PACKAGE H 0.25(0.010) M E 2 3 0.25 0.010 SEATING PLANE -A- INCHES GAUGE PLANE -B1 B M A D -C- α e A1 B 0.25(0.010) M L MIN MAX A2 C B S MAX NOTES A 0.068 0.078 1.73 1.99 0.002 0.008’ 0.05 0.21 A2 0.066 0.070’ 1.68 1.78 B 0.010’ 0.015 0.25 0.38 C 0.004 0.008 0.09 0.20’ D 0.278 0.289 7.07 7.33 3 E 0.205 0.212 5.20’ 5.38 4 0.026 BSC 0.301 0.311 7.65 7.90’ L 0.025 0.037 0.63 0.95 8 deg. 0 deg. N 20 0 deg. 9 0.65 BSC H α NOTES: MILLIMETERS MIN A1 e 0.10(0.004) C A M SYMBOL 6 20 7 8 deg. Rev. 3 11/02 1. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of Publication Number 95. 2. Dimensioning and tolerancing per ANSI Y14.5M-1982. 3. Dimension “D” does not include mold flash, protrusions or gate burrs. Mold flash, protrusion and gate burrs shall not exceed 0.20mm (0.0078 inch) per side. 4. Dimension “E” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.20mm (0.0078 inch) per side. 5. The chamfer on the body is optional. If it is not present, a visual index feature must be located within the crosshatched area. 6. “L” is the length of terminal for soldering to a substrate. 7. “N” is the number of terminal positions. 8. Terminal numbers are shown for reference only. 9. Dimension “B” does not include dambar protrusion. Allowable dambar protrusion shall be 0.13mm (0.005 inch) total in excess of “B” dimension at maximum material condition. 10. Controlling dimension: MILLIMETER. Converted inch dimensions are not necessarily exact. 25 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Thin Shrink Small Outline Plastic Packages (TSSOP) M28.173 N INDEX AREA E 0.25(0.010) M E1 2 SYMBOL 3 0.05(0.002) -A- INCHES GAUGE PLANE -B1 28 LEAD THIN SHRINK SMALL OUTLINE PLASTIC PACKAGE B M L A D -C- α e A1 b 0.10(0.004) M 0.25 0.010 SEATING PLANE A2 c 0.10(0.004) C A M B S MIN 1. These package dimensions are within allowable dimensions of JEDEC MO-153-AE, Issue E. MILLIMETERS MIN MAX NOTES A - 0.047 - 1.20 - A1 0.002 0.006 0.05 0.15 - A2 0.031 0.051 0.80 1.05 - b 0.0075 0.0118 0.19 0.30 9 c 0.0035 0.0079 0.09 0.20 - D 0.378 0.386 9.60 9.80 3 E1 0.169 0.177 4.30 4.50 4 e 0.026 BSC 0.65 BSC - E 0.246 0.256 6.25 6.50 - L 0.0177 0.0295 0.45 0.75 6 8o 0o N NOTES: MAX α 28 0o 28 7 8o Rev. 0 6/98 2. Dimensioning and tolerancing per ANSI Y14.5M-1982. 3. Dimension “D” does not include mold flash, protrusions or gate burrs. Mold flash, protrusion and gate burrs shall not exceed 0.15mm (0.006 inch) per side. 4. Dimension “E1” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.15mm (0.006 inch) per side. 5. The chamfer on the body is optional. If it is not present, a visual index feature must be located within the crosshatched area. 6. “L” is the length of terminal for soldering to a substrate. 7. “N” is the number of terminal positions. 8. Terminal numbers are shown for reference only. 9. Dimension “b” does not include dambar protrusion. Allowable dambar protrusion shall be 0.08mm (0.003 inch) total in excess of “b” dimension at maximum material condition. Minimum space between protrusion and adjacent lead is 0.07mm (0.0027 inch). 10. Controlling dimension: MILLIMETER. Converted inch dimensions are not necessarily exact. (Angles in degrees) 26 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Shrink Small Outline Plastic Packages (SSOP) M28.209 (JEDEC MO-150-AH ISSUE B) N INDEX AREA 28 LEAD SHRINK SMALL OUTLINE PLASTIC PACKAGE H 0.25(0.010) M 2 GAUGE PLANE 3 0.25 0.010 SEATING PLANE -A- INCHES E -B- 1 B M A D -C- α e C 0.10(0.004) C A M SYMBOL MIN MAX MIN MAX NOTES A - 0.078 - 2.00 - A1 0.002 - 0.05 - - A2 0.065 0.072 1.65 1.85 - B 0.009 0.014 0.22 0.38 9 C 0.004 0.009 0.09 0.25 - D 0.390 0.413 9.90 10.50 3 E 0.197 0.220 5.00 5.60 4 e A2 A1 B 0.25(0.010) M L B S NOTES: 0.026 BSC H 0.292 L 0.022 N α 1. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of Publication Number 95. MILLIMETERS 0.65 BSC 0.322 7.40 0.037 0.55 28 0° - 0.95 6 28 8° 0° - 8.20 7 8° Rev. 2 6/05 2. Dimensioning and tolerancing per ANSI Y14.5M-1982. 3. Dimension “D” does not include mold flash, protrusions or gate burrs. Mold flash, protrusion and gate burrs shall not exceed 0.20mm (0.0078 inch) per side. 4. Dimension “E” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.20mm (0.0078 inch) per side. 5. The chamfer on the body is optional. If it is not present, a visual index feature must be located within the crosshatched area. 6. “L” is the length of terminal for soldering to a substrate. 7. “N” is the number of terminal positions. 8. Terminal numbers are shown for reference only. 9. Dimension “B” does not include dambar protrusion. Allowable dambar protrusion shall be 0.13mm (0.005 inch) total in excess of “B” dimension at maximum material condition. 10. Controlling dimension: MILLIMETER. Converted inch dimensions are not necessarily exact. 27 FN4805.21 March 1, 2006 ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Small Outline Plastic Packages (SOIC) M28.3 (JEDEC MS-013-AE ISSUE C) N 28 LEAD WIDE BODY SMALL OUTLINE PLASTIC PACKAGE INDEX AREA H 0.25(0.010) M B M INCHES E SYMBOL -B- 1 2 3 L SEATING PLANE -A- h x 45o A D -C- e A1 B C 0.10(0.004) 0.25(0.010) M C A M B S MILLIMETERS MIN MAX NOTES A 0.0926 0.1043 2.35 2.65 - 0.0040 0.0118 0.10 0.30 - B 0.013 0.0200 0.33 0.51 9 C 0.0091 0.0125 0.23 0.32 - D 0.6969 0.7125 17.70 18.10 3 E 0.2914 0.2992 7.40 7.60 4 0.05 BSC 10.00 h 0.01 0.029 0.25 0.75 5 L 0.016 0.050 0.40 1.27 6 8o 0o 28 0o 10.65 - 0.394 N 0.419 1.27 BSC H α NOTES: MAX A1 e α MIN 28 1. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of Publication Number 95. - 7 8o Rev. 0 12/93 2. Dimensioning and tolerancing per ANSI Y14.5M-1982. 3. Dimension “D” does not include mold flash, protrusions or gate burrs. Mold flash, protrusion and gate burrs shall not exceed 0.15mm (0.006 inch) per side. 4. Dimension “E” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.25mm (0.010 inch) per side. 5. The chamfer on the body is optional. If it is not present, a visual index feature must be located within the crosshatched area. 6. “L” is the length of terminal for soldering to a substrate. 7. “N” is the number of terminal positions. 8. Terminal numbers are shown for reference only. 9. The lead width “B”, as measured 0.36mm (0.014 inch) or greater above the seating plane, shall not exceed a maximum value of 0.61mm (0.024 inch) 10. Controlling dimension: MILLIMETER. Converted inch dimensions are not necessarily exact. All Intersil U.S. products are manufactured, assembled and tested utilizing ISO9000 quality systems. Intersil Corporation’s quality certifications can be viewed at www.intersil.com/design/quality Intersil products are sold by description only. Intersil Corporation reserves the right to make changes in circuit design, software and/or specifications at any time without notice. Accordingly, the reader is cautioned to verify that data sheets are current before placing orders. Information furnished by Intersil is believed to be accurate and reliable. However, no responsibility is assumed by Intersil or its subsidiaries for its use; nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Intersil or its subsidiaries. For information regarding Intersil Corporation and its products, see www.intersil.com 28 FN4805.21 March 1, 2006
ICL3232CA-T 价格&库存
很抱歉,暂时无法提供与“ICL3232CA-T”相匹配的价格&库存,您可以联系我们找货
