PSA 240/30 - BLUE
PSA 240/30 - BLUE
    COMUS
    BLUE 400VAC/0.5A RECTANGULAR PRO
PSA 240/30 - BLUE 数据手册
Group Part Number: PSA 240/30 (Alternate Part No: S1256) Proximity Switch - Reed Switch based Rectangular - Normally Open Contacts - Suggested Magnet: PSM APPLICATIONS INCLUDE PICTURE • Position and limit sensing • Linear actuators • Security system switch • Door Switch OPTIONS • Color: Standard = Blue housing / Grey wire. Also available Black = Black housing / Black wire. • Cable entry: Standard = Right hand entry. Also available Left hand entry. • Custom cable lengths, strip lengths, cable types, terminations. • If you do not see what you need, just ask, as there is a strong possibility we can do it ! • Device is intended to be mounted in an enclosure under UL recognition. DIMENSIONS Drawings not to scale. All dimensions in inches (mm) nominal. 0.787 (20.0) 0.079 (2.0) 0.197 (5.0) 0.394 (10.0) 0.787 (20.0) 1.181 (30.0) Contact Form / Style Fixing Slots 0.236 x 0.130 (6 x 3.3) 0.630 (16.0) 11.811 (300.0) 0.276 (7.0) SPECIFICATION Normally Open Switching Capacity (Resistive) 10 W/VA Max Switching Voltage 400 VAC Max Switching Current 0.5 A Max Carry Current 1.0 A Max Breakdown Voltage 600 VDC Min Contact Resistance 150 mOhms Max Switching Distance 8 mm Min Operating Temperature Range -20°C +85°C Storage Temperature Range -25°C +90°C Case Material Blue Nylon 66 Cable 2 x Round 0.14mm2 PVC covered Grey and Insulated Brown / White As part of the company policy of continued product improvement, specifications may change without notice. Our sales office will be pleased to help you with the latest information on this product range and the details of our full design and manufacturing service. All products are supplied to our standard conditions of sale unless otherwise agreed in writing. Phone: (1) 973 777 6900 www.comus-intl.com Fax: (1) 973 777 8405 Belgium: + 32 (0)12 390400 - Comus Europe Ltd (Assemtech) UK: +44 (0) 1255 862236 - Germany: +49 (0)911 923 15 943 - Netherlands: +31(0)45 54 39 345 - India: +(91) (44) 43219090 ©2015 Copyright Comus International, 454 Allwood Road, Clifton NJ 07012, USA 7 / 2015 An ISO 9001 Certified Company
PSA 240/30 - BLUE 价格&库存
很抱歉,暂时无法提供与“PSA 240/30 - BLUE”相匹配的价格&库存,您可以联系我们找货
