| ACW4 ANALOG
ANALOG ABSOLUTE SINGLE TURN MODULAR SENSOR
Sensata-BEI Sensors' ACW4 sensors provide absolute single turn measurement with an analog output in an over-molded, modular design that offers
flexibility and protection from the environment.
Features
• With its two-part design, the ACW4 absolute single-turn offers
maximum flexibility for installation
• Rugged and excellent resistance to shock and vibration
• Robust, proven magnetic technology
• Environmentally resistant, IP 67 standard (IP69K option)
• Extended operating range from -40° C to 85° C
• Uses universal supply 5 to 30 VDC – Analog output
• Available Resolution up to 12 bits per revolution
• Variety of magnet holders available
Applications
• Factory Automation
• Process Automation
SPECIFICATIONS
Mechanical
Terminations
PVC cable
Housing
Macromelt PA638
Weight
0,150 kg
Electrical
Electrical Angle
360°
Output Function
0– 10 Vdc, 0.5 to 4.5 Vdc, or 4 – 20 mA
Minimal Cycle Time
1ms
Resolution
Single –turn, 12 bits
Accuracy
+/-0.3% on 360°
Repeatability
+/-0.1% on 360°
Supply Voltage
5Vdc, 11 to 30 Vdc, or 15 to 30 Vdc
Start-up
< 1s
Response time
< 10 ms (5L2 and 3L1 electronics), 10 kOhms (voltage out), 500 Ohms (current out)
Current Requirements
< 40mA
Protection
Overvoltage Protection: Yes
Reverse Polarity Protection: Yes
Short Circuit Protection: Yes
EMC
IEC 61000-4-2 Electrostatic discharge (ESD) 4 kV, 8 kV
IEC 61000-4-3 Electromagnetic fields 10 V/m (80MHz - 1GHz), 3V/m (1.4GHz - 2GHz), 1V/m (2GHz - 2.7GHz)
IEC 61000-4-4 Electrical fast transients (burst) 1 kV
IEC 61000-4-6 Conducted disturbances, induced by RF-fields 10 Veff.
Page 1
Copyright © 2020 Sensata Technologies, Inc.
www.sensata.com
Analog Output
Output
High
Output
50%
Output
Low
Minimum Range +/-15 degrees
Maximum Range +/-180 degrees
DIMENSIONS
All Dimensions are in millimeters.
Shaft system with magnet to be ordered separately (see Accessories).
Clockwise
direction
jn
A
50
38
8,6
很抱歉,暂时无法提供与“ACW400-0360-015”相匹配的价格&库存,您可以联系我们找货
