CD120-100-ABZC-28V/V-SM18-B2 数据手册
| CD120 SERIES
INCREMENTAL DRAW WIRE
Introduction
Draw wire sensor assemblies combine a rotary sensor such as an encoder with a spring-loaded retractable cable on a drum. This provides a means to
translate the precision of a rotary encoder into a linear measurement.
Features
• A full 120 inches (10 feet) of measurement capability.
• Wire drum is scaled so that one revolution = 1 foot of measurement.
• Mounting bracket and encoder position can be rotated in 90°
increments to accommodate a variety of installation requirements.
Applications
• Concrete, wood, steel sawing
• Mast height measurement for fork truck AGV’s
• Extension measurement for small cranes
• Flood Control gates
• Hydraulic Cylinder Position
SPECIFICATIONS
Mechanical
Output Signal type
Optical Incremental Encoder in Quadrature with Index
Linearity
+/- 0.05% of full scale
Resolution
Range of Pulses per inch (Ref ordering block)
Cable Type
0.024” (0.60 mm) diameter stainless steel
Cable Tension
2.9 - 4.0 pounds (13 - 18 N)
Enclosure material
Aluminum
Weight
4.4 pounds, (2 Kg)
Electrical
Input Current
100mA (no load), up to 160 mA full load
Input Voltage
5-28 Vdc; Vout=Vin
Connector
M16, 7 pin Connector
M18, 10 pin Connector
SCS, cable Gland Seal
Mating Connector/Cable
31186-18XX, XX = cable length in feet
Drum Circumference
12 inches (304.8 mm)
Copyright © 2019 Sensata Technologies, Inc.
www.sensata.com
Page 1
Enviromental
Enclosure Protection Rating
IP66 with M16 or M18 connector
IP65 with cable Gland Seal
Operating Temperature
-20°C to + 85°C
Storage Temperature
-20°C to + 85°C
Other Specifications
Maximum Velocity of cable
10 m/s
Maximum Acceleration of Cable
7 m/s2
DIMENSIONS
Tolerance, unless otherwise noted:
All dimensions are in inches [mm]
120
4.72
90
3.54
192.5
7.58
127.9
5.03
2.50
3.50
68
2.67
40
1.57
21.5
.85
155
6.10
110
39 4.33
1.54
11
.43
7.6
.30
Holes
137.4
5.41
6.6
2X .26
A
92
3.61
2.4
2X .09
M3 screw
Drainage holes – 4xM3 set screws
(on each side). Remove lowest screw for
drainage of trapped moisture
DETAIL A
SCALE 1 : 1
Page 2
www.sensata.com
CD120 DRAW-WIRE, AVAILABLE FEATURES
All dimensions are in mm
4
34,5
44,5
6,5
50
18
4
8
Standard termination with a captive
washer which accepts a 6 mm (1/4”)
screw
CP termination: Threaded cable
termination is attached to a clevis. The
4 mm diameter clevis pin is provided.
B2: A cleaning brush is factory installed
to wipe away dust and moisture as the
cable retracts
Page 3
www.sensata.com
Example : CD120-500-ABZC-28V/V-M18-B2
ORDERING OPTIONS
CD120
500
ABZC
28V/V
M18
B2
Family
Draw-Wire Assembly
120 inches maximum travel
Aluminum Housing
Resolution
Note: programmable resolution, OMNI , must use an M18 termination
10 counts per inch to 500 counts per inch (See Table, Below)
Output Type
ABZC = Two Channels in Quadrature + Index and complements = Std
ABZ = Two Channels in Quadrature + Index
ABC = Two Channels in Quadrature plus complements
Check with factory for other output types.
Electrical Options
28V/V = 5 – 28 V in. Vout = Vin
28V/5 = 5 – 28 V in. Vout = 5V regulated
28V/OC = 5 – 28 V in. Vout = Open Collector
Termination
M18 = M18, 10 Pin Connector (used with ABZC)
M18 – 10 = M18 Connector with Mating Cable/Connector Assembly, -10 = 10 foot length. Available lengths are 10, 20, 30, and 50 feet.
M16 = M16, 7 Pin Connector (used with ABC or ABZ)
M16 – 10 = M16 Connector with Mating Cable/Connector Assembly, as above.
SCS-XX = Cable Gland Seal with XX feet of cable. Available lengths (XX) = 10, 20, 30 and 50 feet.
Available Features
BLANK = Standard Termination
B2 = Built-in Cleaning Brush for cable
CP = Clevis Termination
RESOLUTIONS TABLE
Resolution
Distance/ Count
10
0.100 “
25
0.040 “
50
0.020 “
100
0.010”
250
0.004”
500
OMNI*
*Available with M18 termination only
0.002”
Programmable
Page 4
www.sensata.com
PINOUT AND CONNECTION TABLES
The connector style will determine pinouts. For example, an encoder with ABC channels and an M18 connector uses the table to the right.
M16 Connector
Channels Designated in Model Number
M18 Connector
Pin
ABZ
ABC
Pin
Channel
A
A
A
A
A
B
B
B
B
B
C
Z
A
C
Z
D
+V
E
D
+V (Supply Voltage)
E
B
F
0V (Circuit Common)
F
0V
G
Case Ground (CG)
G
CG
H
A
I
B
J
Z
Wire Color
(22AWG)
ABZ
ABC
ABZC
YEL
A
A
A
BLUE
B
B
B
ORN
Z
Z
W-Yel
A
A
W-Blu
B
B
W-Orn
Z
RED
+V (Supply Voltage)
BLK
0V (Circuit Common)
GRN
Case Ground (CG0)
WHITE
Shield Drain (Shielded Cable Only)
WAVEFORM DIAGRAM
INDEX GATED WITH B LOW
Z
180°
A
B
Cable Extends
Cable Retracts
AGENCY APPROVALS & CERTIFICATIONS
EN 61000-6-4 and EN 61000-6-2
Page 5
www.sensata.com
MOUNTING INSTRUCTIONS
CD120 Mounting Instructions
1. Mount the CD120 mounting plate securely to a stable flat surface using M6 or
1/4” bolts and washers.
2. Attach the draw wire to your moving equipment using the eyelet provided with an
M4, #8 screw or a 3/16” pin. If you have purchased a special termination, then
use the mounting instructions for that wire termination.
WARNING:
• Damage may occur if draw wire is released and allowed to freely retract without
tension.
• Make certain the draw wire path is clear of objects or sharp edges to prevent
cable damage.
• Draw wire should exit as straight as possible. A pulley may be used to redirect it
How to Change Encoder Positioning
1. Remove the four #10-32 hex socket cap screws
and washers from the encoder flange. (5/32 in. hex
driver).
2. Rotate the encoder flange in 90° increments. You
may need to pull it out a little to get it loose enough
to turn.
3. If the encoder is completely removed, you can
rotate the encoder shaft a little to align the driving
gear with the draw wire hub. It should insert with
little or no resistance. Do Not Force the gear into
place.
4. Replace the screws and lock washers and tighten
to 13 in-lb [1.4 N-m].
How to Change the Mounting Plate Position
1. Remove the four M4 hex socket cap screws from the
mounting plate (3 mm hex driver)
2. Align the mounting plate on the side you wish to attach it.
3. Replace the screws and tighten to 13 in-lb [1.4 N-m].
Page 6
www.sensata.com
ACCESSORIES
Description
M16 Cable Connector Assembly
When ordered separately. Cable Assembly may be
ordered directly as part of the model number
M18 Cable Connector Assembly
Omnicoder® Programming Cable
Ordered Separately
Part Number
MS31186-1610 = 10’
MS31186-1620 = 20’
MS31186-1630 = 30’
MS31186-1650 = 50’
MS31186-1810 = 10’
MS31186-1820 = 20’
MS31186-1830 = 30’
MS31186-1850 = 50’
60031-101
Page 7
Sensata Technologies, Inc. (“Sensata”) data sheets are solely intended to assist designers (“Buyers”) who are developing systems that
incorporate Sensata products (also referred to herein as “components”). Buyer understands and agrees that Buyer remains responsible
for using its independent analysis, evaluation and judgment in designing Buyer’s systems and products. Sensata data sheets have
been created using standard laboratory conditions and engineering practices. Sensata has not conducted any testing other than that
specifically described in the published documentation for a particular data sheet. Sensata may make corrections, enhancements,
improvements and other changes to its data sheets or components without notice.
Buyers are authorized to use Sensata data sheets with the Sensata component(s) identified in each particular data sheet. HOWEVER, NO
OTHER LICENSE, EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE TO ANY OTHER SENSATA INTELLECTUAL PROPERTY RIGHT, AND
NO LICENSE TO ANY THIRD PARTY TECHNOLOGY OR INTELLECTUAL PROPERTY RIGHT, IS GRANTED HEREIN. SENSATA DATA SHEETS
ARE PROVIDED “AS IS”. SENSATA MAKES NO WARRANTIES OR REPRESENTATIONS WITH REGARD TO THE DATA SHEETS OR USE
OF THE DATA SHEETS, EXPRESS, IMPLIED OR STATUTORY, INCLUDING ACCURACY OR COMPLETENESS. SENSATA DISCLAIMS
ANY WARRANTY OF TITLE AND ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, QUIET
ENJOYMENT, QUIET POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHTS WITH REGARD
TO SENSATA DATA SHEETS OR USE THEREOF.
All products are sold subject to Sensata’s terms and conditions of sale supplied at www.sensata.com SENSATA ASSUMES NO LIABILITY
FOR APPLICATIONS ASSISTANCE OR THE DESIGN OF BUYERS’ PRODUCTS. BUYER ACKNOWLEDGES AND AGREES THAT IT IS SOLELY
RESPONSIBLE FOR COMPLIANCE WITH ALL LEGAL, REGULATORY AND SAFETY-RELATED REQUIREMENTS CONCERNING ITS PRODUCTS,
AND ANY USE OF SENSATA COMPONENTS IN ITS APPLICATIONS, NOTWITHSTANDING ANY APPLICATIONS-RELATED INFORMATION
OR SUPPORT THAT MAY BE PROVIDED BY SENSATA.
Mailing Address: Sensata Technologies, Inc., 529 Pleasant Street, Attleboro, MA 02703, USA.
Spec. Sheet No. 02323-001 Rev:05/02/19
CONTACT US
Americas
+1 (800) 350 2727 – Option 1
sales.beisensors@sensata.com
Europe, Middle East & Africa
+33 (3) 88 20 8080
position-info.eu@sensata.com
Asia Pacific
sales.isasia@list.sensata.com
China +86 (21) 2306 1500
Japan +81 (45) 277 7117
Korea +82 (31) 601 2004
India +91 (80) 67920890
Rest of Asia +886 (2) 27602006
ext 2808
www.sensata.com
