L9110
Motor control driver chip
Features:
Low quiescent current;
Wide supply voltage range: 2.5V-12V;
800mA continuous current output capability per
channel;
Lower saturation voltage;
TTL / CMOS output level compatible, and can be
directly connected to the CPU;
Output built-in clamp diodes for inductive load;
Integrated control and drive into a monolithic IC;
With pin high-voltage protection function;
Operating temperature: 0 ℃ -80 ℃.
DP Suffix plastic package (DIP8)
SO Suffix plastic package (SOP8)
Description:
L9110 The ASIC device control and drive motor design two-channel push-pull power amplifier
discrete circuits integrated into a monolithic IC, peripheral devices and reduce the cost, improve the
reliability of the whole. This chip has two TTL / CMOS compatible with the level of the input, with good
resistance; two output terminals can directly forward and reverse movement of the drive motor, it has a
large current driving capability, each channel through 750 ~ 800mA of continuous current, peak current
capability up to 1.5 ~
2.0A; while it has a low output saturation voltage; built-in clamp diode reverse the impact of the current
release inductive load it in the drive relays, DC motors, stepper motor or switch power tube use on safe and
reliable. L9110 is widely used in toy car motor drives, stepper motor drive and switching power tube circuit.
Device pins Figure
Pin definitions:
No.
1
2
3
4
5
6
7
8
Function
Symbol
A road output pin
OA
Supply Voltage
VCC
Supply Voltage
VCC
B output pin
OB
Ground
GND
A road input pin
IA
B input pin
IB
Ground
GND
OA
GND
VCC
IB
VCC
IA
GND
OB
Test conditions: Vcc =9V , Iout =750mA
Symbol Parameters
Output high
VHout
Output low
VLout
Input high
VHin
Input low
VLin
minimum
7.50
0.35
2.5
Typical
7.60
0.45
5.0
0.5
maximum
7.70
0.55
9.0
0.7
units
V
V
V
V
地址:深圳市南山区南油立交创世纪滨海花园 4 栋 6D 邮编:518054
TEL:0755-26965868 FAX:0755-26549868 Http://www.asic.net.cn Email: Sales@asic.net.cn
L9110
Electrical characteristics:
Logical relationship:
Symbol Parameters
Range
Min
VCC
Idd
Iin
IC
IMax
Supply Voltage
2.5
Quiescent Current -
Operating current 200
Continuous
750
Current peak
Typical
6
800
1500
Max
12
2
500
850
2000
Units
IA
H
L
L
H
V
uA
uA
mA
mA
IB
L
H
L
H
OA
H
L
L
L
OB
L
H
L
L
Pin waveform diagram:
input A
input B
output A
output B
Application Circuit:
VCC
DC motor
Forward
signal
L9110
M
backward
signal
GND
很抱歉,暂时无法提供与“4489”相匹配的价格&库存,您可以联系我们找货
