Peripheral Integrated Circuits
In addition to GMR Sensor products, NVE has begun designing and manufacturing accessory products
for our sensors. These products are designed to be used with NVE’s sensors, or in some cases as standalone parts, to provide higher level signal processing capabilities coupled with the robust performance
characteristics that NVE products are known for.
DB-Series Power Switch ICs – In many industrial control applications, a digital current output of up
to 200 mA is required. NVE’s DB-Series parts are designed to meet these requirements. They feature
transient protection to meet rigid EMC and ESD standards, thermal shutdown for temperature
protection, reverse battery protection, a regulated voltage output, an on-chip LED driver, and short
circuit protection of the current drive output transistor. The DB001-00 is designed specifically to work
together with NVE’s AD9xx-00 short circuit protected GMR switch to create a very small IC
combination suitable for use in miniature sensor assemblies. The DB002-02 is designed to take a
generic digital input from any source, including inductive and photo sensors, and provide the digital
current output.
DC Series Voltage Regulator ICs – These ICs are designed for use in high voltage, low current
applications. They provide a wide input voltage range, up to 60V, and are available in 3.3V and 5.0V
outputs. They feature reverse battery protection and excellent immunity to transients and noise
allowing for the reduction or elimination of filtering devices at the PCB level. They are available in the
TDFN6 package, which features a small PCB footprint (2.5 mm x 2.5 mm) and an exposed lead frame
on the back for heat sinking to the PCB. DC series voltage regulators meet 42V automotive standards.
DD-Series Signal Processing IC for Analog GT Sensors – The DD001-12 is designed to be
interfaced with an NVE ABL-Series GT Sensor to provide a digital output signal with excellent
stability characteristics. It can be located away from the sensor so that the ABL package (MSOP8 or
TDFN6) can be placed in a small remote housing, resulting in the absolute minimum size sensor
package. The DD001-12 can also be used with other sensing devices which feature a sinusoidal output,
to provide the same stable current modulated signal that it provides for NVE’s ABL-Series GT
Sensors.
- 61 www.nve.com phone: 952-829-9217 fax: 952-829-9189
DB001-00 Series Power Switch IC
Features:
Designed to Work with AD9xx
High Current Output
Short Circuit, Reverse Battery, and Transient Protection
LED Driver
Excellent Temperature and Voltage Performance
Small, Low-Profile Surface Mount Package
Applications:
Output Driver for Sensor Assemblies
Usable with Magnetic, Inductive, and Photo Sensors
Description:
The DB001-00 signal processing IC is designed to take the digital input signal from NVE’s AD9xx
GMR Switch and provide a high current switched output corresponding with the sensor input. The part
functions as the “front end” of a complete sensor assembly and includes protection against short
circuits and high voltage transients from capacitive and inductive loads. The parts also feature thermal
shutdown circuitry and reverse battery protection. It provides a regulated output voltage for the sensor
and other components in the assembly and an LED driver to indicate an “ON” condition.
Together, the AD9xx GMR Switch and the DB001-00 signal processing IC form the bulk of the signal
processing required for pneumatic cylinder position sensing electronics. Using these two ICs, the end
user only requires a few capacitors and an LED in order to implement the complete sensor assembly
circuit. In addition, both the AD9xx part and the DB001-00 part come in MSOP8 packages, so that the
customer can implement the complete design on an extremely small PCB.
If ultra-miniaturization is desired, the DB001 part can be obtained in die form for COB (Chip On
Board) or flip-chip assembly.
Part Numbers and Configurations:
Part
Number
DB001-00
DB001-01
Input
Current Sinking from
AD9xx-00
AD9xx-00
Die Size (mm)
Package
Marking
1.48 x 2.25
MSOP8
FFD
1.48 x 2.25
Raw IC
30284D
- 62 www.nve.com phone: 952-829-9217 fax: 952-829-9189
Schematic:
A block representation of the DB001-00 series part is shown below:
3.3 Volts
Voltage
Regulator
VCC
Vreg
Input
Sink Out
Amplifier
Thermal
Shutdown
Source Out
LED
Ground
ISC
Packages:
Please see the package drawing section in the Appendix for dimensions of the MSOP8 package.
Pin Configuration:
VCC
ISC
Source
Out
Sink Out
Vreg
NVE
FFD
In
LED
Ground
- 63 www.nve.com phone: 952-829-9217 fax: 952-829-9189
Application Circuits:
DB001-00 in Current Sourcing Output Configuration:
Source
Cap
Cap2
t1 Cap
Vreg
AD9xx-xx
Cross Axis
Vreg
Sink
In
ShortL
LED
VCC
Ground
VCC
FFD
NVE
Ground
VCC
ISC
Source
Out
Out
Sink Out
t2 Cap
Ground
Note:
For current-sinking applications, connect “Source Out” to Ground; use “Sink Out” pin as output.
Electrical characteristics (-40°C to +125°C, unless otherwise noted)
Parameter
Min
Typ
Max
Input Voltage
4.5
30
Vreg Voltage
3.0
3.3
3.6
Vreg Output Current
10
Switched Output Current
200
Capacitive Load
100
Off State Output Leakage Current
300
Bias Current (output off)
1.0
LED Drive Current
3
Thermal Shutdown Temperature
200
Sinking Input Current Required
100
Output Transistor Saturation Voltage
0.5
1.1
1.5
Output Short Circuit Current
0.5
0.84
1.0
Absolute maximum ratings*
Parameter
Limit
Input Voltage
36 V
Reverse Battery Protection
-36 V
Output Current
250 mA
Junction Temperature Range, TJ
-40°C to +170°C
Storage Temperature Range
-65 °C to +170°C
Units
V
V
mA
mA
nF
µA
mA
mA
°C
µA
V
A
*Stresses beyond those listed under “Absolute
maximum ratings” may cause permanent
damage to the device. These are stress ratings
only and functional operation of the device at
these or any other conditions beyond those
indicated under “Electrical characteristics” is
not implied.
Notes:
1.
This part has reverse battery protection to -36V
2.
Due to package size, MSOP8 package contains 3-letter code to designate part type.
- 64 www.nve.com phone: 952-829-9217 fax: 952-829-9189
DB002-02 Series Power Switch IC
Features:
Designed to Work with Magnetic, Inductive, or Photo Sensors
Up to 300 mA Continuous Current Output
Short Circuit, Reverse Battery, Transient and Thermal Protection
On-Chip LED Driver
Available in SOIC8 Package or in Die Form
Applications:
Description:
The DB002 series power switch IC is designed to take a digital input from a sensor element and
provide a high current switched output corresponding with the sensor input. The part functions as the
“front end” of a complete sensor assembly and includes protection against short circuits and high
voltage transients from capacitive and inductive loads. The part also features thermal shutdown
circuitry and reverse battery protection. It provides a regulated output voltage for the sensor and other
The DB002 is available in the SOIC8 package (p/n DB002-02), as well as in die form (p/n DB002-01).
It is designed to work with NVE’s AD1xx GMR Switch products, or any other current sourcing or
CMOS/TTL digital output sensor element such as an inductive sensor or a photo sensor.
Part
Number
DB002-01
DB002-02
Input
Any Current Sourcing or CMOS/TTL
Compatible Digital Output Device
Die Size
(mm)
Package
1.89 x 2.85
Die
1.89 x 2.85
SOIC8
Marking
30304H
(Chip ID Number)
- 65 www.nve.com phone: 952-829-9217 fax: 952-829-9189
DB002-02
Functional Block Diagram and Pinout:
VCC
Voltage
Regulator
5.0 Volts
Vreg
Input
Sink Out
Amplifier
Thermal
Shutdown
Source Out
LED
Short Circuit Detection
Circuitry
Ground
Input
Ground
Vreg
Delay
Cap
DB002-02
VCC
Source
Out
Sink
Out
LED
Packages:
Please see the package drawing section in the Appendix for dimensions of the SOIC8 package.
- 66 www.nve.com phone: 952-829-9217 fax: 952-829-9189
Example Application Circuit:
N/C
VCC
Vreg
AD124-00
N/C
N/C
Ground
Source
Cross Axis
Delay
VCC
DB002-02
NVE
VCC
LED
N/C
In
Source
Out
N/C
Ground
Sink Out
Out
Delay
Cap
Ground
Notes on Operation:
1.
A capacitor of at least 1nF value must be placed between the Delay pin and ground on the IC.
2.
NVE recommends a bypass capacitor between VCC and Ground, 10nF or larger
3.
In noisy environments a capacitor may be used on Vreg if necessary, up to 100nF.
Parameter
Min
Typ
Max
Input Voltage
6.2
30
Vreg Voltage
4.5
5.0
5.5
Vreg Output Current
10
300
Capacitive Load
100
300
1.4
LED Drive Current
3
200
Sourcing Input Current or CMOS/TTL
5
Drive Current Required (DB002-02)
Turn-On Voltage at Input Terminal
3.0
Turn-Off Voltage at Input Terminal
2.0
On/Off Hysteresis
0.25
0.5
1.1
1.5
Short Circuit Protection Turn-On
400
650
Current
0.5
0.84
1.0
Parameter
Limit
Input Voltage
36V
-36V
Output Current
350mA
-40°C to +170°C
-65 °C to +170°C
Units
V
V
mA
mA
nF
µA
mA
mA
°C
µA
V
V
V
V
mA
A
only, and functional operation of the device at
not implied.
- 67 www.nve.com phone: 952-829-9217 fax: 952-829-9189
DC-Series Voltage Regulators
High Voltage, Low Power Voltage Regulators
Features:
Input Voltage to 36VDC (Max Rating 45VDC)
5.0V and 3.3V Regulated Output
Excellent Immunity to Transients and ESD
High Temperature Operation
Applications:
Industrial Sensors and Controls
Automotive Sensors and Controls
Description:
The DC series voltage regulator ICs are designed for use in harsh, noisy environments where immunity
to large voltage transients and acceptance of high input voltages are required. These regulators protect
the sensitive electronic components downstream, while providing a stable regulated supply voltage.
They are rated for high temperature operation, up to +170°C. The low-profile small footprint package
features an exposed die attach pad, for direct heat sinking to the circuit board.
Specifications
Electrical characteristics (-40°C to +175°C, unless otherwise noted)
Parameter
Min
Typ
Max
Input Voltage (DC001-10)
4.5
36
Output Voltage (DC001-10)
3.0
3.3
3.6
Input Voltage (DC002-10)
6.2
36
Output Voltage (DC002-10)
4.5
5.0
5.5
Output Current
Bias Current at Zero Output Current
900
Parameter
Limit
Input Voltage
45V
Reverse Battery Voltage
-60V
Output Current
25mA
-40°C to +170°C
-65 °C to +170°C
Units
Volts
Volts
Volts
Volts
Milliamps
Microamps
maximum ratings” may cause permanent damage
to the device. These are stress ratings only, and
functional operation of the device at these or any
other conditions beyond those indicated under
“Electrical characteristics” is not implied.
- 68 www.nve.com phone: 952-829-9217 fax: 952-829-9189
Notes:
1.
Power dissipation rating for TDFN6 package in free air is 320°C/Watt. Soldering the package to a PCB, including the die
attach paddle, improves temperature performance substantially. The input voltage and output current are limited by thermal
power dissipation at the package.
2.
Due to package size, TDFN6 package has a three-letter code to designate part type.
Package:
Please see the package drawing section in the Appendix for dimensions of the TDFN6 package.
Pin Configuration
Vreg (Out)
No Connect
VCC (In)
No Connect
DC001-10,
DC002-10
Ground
No Connect
Note: The die attach pad is exposed on the back of this package. NVE recommends that it be connected to
the ground pin and the PCB for improved temperature performance.
- 69 www.nve.com phone: 952-829-9217 fax: 952-829-9189
DD-Series Signal Processing ICs
For use with ABL-Series Sensors
Features:
Converts Analog Sensor to Digital Operation
Two-Wire Output
50% Duty Cycle
DC (Zero Speed) Operation
Applications:
Linear and Angular Speed Sensing
Linear and Angular Position Sensing
Direction Detection
Description:
The DD-Series signal processing IC is designed to take an analog, sinusoidal input signal such as that
provided by NVE’s ABL-Series sensors and convert it to a two wire, current modulated digital output.
Inputs as small as 2 mV peak-to-peak can be provided to the IC, along with large signal offsets. The
DD001-12 part will provide a 50% duty cycle digital output signal.
The DD001-12 part contains a voltage regulator circuit, programmable amplifier, offset detection and
correction circuitry, and an EEPROM for setting gain and current levels. The voltage regulator output
(3.3V) is used to power the external sensor element, which should be connected between VREG and
VGND. Nominal current levels for the current modulated output are 3 mA and 10 mA. These can be
factory programmed to different levels for specific customer requirements.
Using the DD-Series signal processing IC allows the user to put the sensor element, which can very
small in a remote location, and pipe the signals from the sensor to the DD001-12 for digitizing
purposes. In addition, if two phase shifted sensor outputs are available (such as with the ABL014-00,
ABL015-00, and ABL015-00sensors), two DD001-12 parts can be used to provide two phase shifted
digital signals, for the purpose of detecting the direction of the gear tooth or encoder wheel.
The two-wire output of the DD001-12 can be easily converted to a three-wire current-sinking output
with the circuit shown in the GT Sensor applications section.
- 70 www.nve.com phone: 952-829-9217 fax: 952-829-9189
Specifications:
Parameter
Input Voltage
Input Voltage Signal
Input Current
Supply Current – Off
(Input Voltage=12V)
Supply Current – On
(Input Voltage=12V)
Output Duty Cycle
Regulated Voltage Output
Current Supplied by Regulated Voltage Output
Operating Temperature Range
Frequency of Operation
ESD
Absolute Maximum Ratings
Parameter
Supply Voltage
Output Current
Min
4.5
2
Typ
3.0
Max
36
200
10
3.8
Unit
1
Volts
2
mV
µA
3
mA
2.2
7.0
8.0
9.0
mA
40
3.0
50
3.3
60
3.6
10
+150
10k
-40
3
Volts
mA
°C
Hz
4
V
Limit
45V
-60V
16mA
-40°C to +170°C
-65°C to +170°C
Signal Output
10
Current
Output
(mA)
5
Time
Notes:
1.
The supply voltage must appear across the power and ground terminals of the part. Any additional voltage drop due to the
presence of a series resistor is not included in this specification.
2.
3.
Input signal range can be adjusted by programming the amplifier gain to a specific value; contact NVE for details.
Supply currents can be factory programmed to different levels, for example 3 mA and 6 mA, or 7 mA and 14 mA; contact
NVE for details.
4.
Pin-to-pin voltage, Human Body Model for ESD.
- 71 www.nve.com phone: 952-829-9217 fax: 952-829-9189
Schematic:
A block representation of the DD-Series parts is shown below:
Vreg
Voltage
Regulator
3.3V
Switching
Current
Source
Bridge +
A
Offset
Detector
Bridge -
A
EEPROM
Gain
Current Level
Packages:
The DD-Series parts are available in the TDFN SO8 package. Please see the package drawing section
in this catalog for dimensions.
Pin Configuration:
TDFN-SO8 Package
Test
Test
Vreg
VCC
Ground
DD001-12
Test
Bridge+
Note: Bridge + and Bridge - should be
connected only to the sensor element outputs
for ESD and loading reasons. Vreg can supply
up to 10 mA at 3.3V (330Ω load). Also, all
pins labeled “Test” must be floating, i.e., not
connected to each other or any other circuit
node.
Bridge-
- 72 www.nve.com phone: 952-829-9217 fax: 952-829-9189
