SN74LS273M
SN74LS273M
    ROCHESTER(罗切斯特)
    SOIC20
    IC FF D-TYPE SNGL 8BIT 20SOIC
SN74LS273M 数据手册
SN74LS273 Octal D Flip−Flop with Clear The SN74LS273 is a high-speed 8-Bit Register. The register consists of eight D-Type Flip-Flops with a Common Clock and an asynchronous active LOW Master Reset. This device is supplied in a 20-pin package featuring 0.3 inch lead spacing. • • • • http://onsemi.com 8-Bit High Speed Register Parallel Register Common Clock and Master Reset Input Clamp Diodes Limit High-Speed Termination Effects LOW POWER SCHOTTKY MARKING DIAGRAMS GUARANTEED OPERATING RANGES Symbol VCC TA Parameter Supply Voltage Operating Ambient Temperature Range Min Typ Max Unit 4.75 5.0 5.25 V 0 25 70 °C SN74LS273N AWLYYWW 20 IOH Output Current − High −0.4 mA IOL Output Current − Low 8.0 mA PDIP−20 N SUFFIX CASE 738 1 1 LS273 AWLYYWW 20 SOIC−20 DW SUFFIX CASE 751D 1 1 74LS273 AWLYWW 20 SOEIAJ−20 M SUFFIX CASE 967 1 A WL YY WW 1 = Assembly Location = Wafer Lot = Year = Work Week ORDERING INFORMATION Device SN74LS273N SN74LS273DW Package Shipping PDIP−20 1440 Units/Box SOIC−WIDE 38 Units/Rail SN74LS273DWR2 SOIC−WIDE 2500/Tape & Reel SN74LS273M SOEIAJ−20 See Note 1 SN74LS273MEL SOEIAJ−20 See Note 1 1. For ordering information on the EIAJ version of the SOIC package, please contact your local ON Semiconductor representative. © Semiconductor Components Industries, LLC, 2006 July, 2006 − Rev. 9 1 Publication Order Number: SN74LS273/D SN74LS273 CONNECTION DIAGRAM DIP (TOP VIEW) VCC Q7 D7 D6 Q6 Q5 D5 D4 Q4 CP 20 19 18 17 16 15 14 13 12 11 1 MR 2 Q0 3 D0 4 D1 5 Q1 6 Q2 7 D2 8 D3 9 Q3 10 GND LOADING (Note a) PIN NAMES CP D0 − D7 MR Q0 − Q7 Clock (Active HIGH Going Edge) Input Data Inputs Master Reset (Active LOW) Input Register Outputs NOTES: a) 1 TTL Unit Load (U.L.) = 40 mA HIGH/1.6 mA LOW. http://onsemi.com 2 HIGH LOW 0.5 U.L. 0.5 U.L. 0.5 U.L. 10 U.L. 0.25 U.L. 0.25 U.L. 0.25 U.L. 5 U.L. SN74LS273 TRUTH TABLE MR CP Dx Qx L H H X X H L L H L H = HIGH Logic Level L = LOW Logic Level X = Immaterial LOGIC DIAGRAM 11 3 4 7 8 13 14 17 18 D0 D1 D2 D3 D4 D5 D6 D7 CP D CD Q CP D CD Q CP D CD Q CP D CD Q CP D CD Q CP D CD Q CP D CD Q CP D CD Q Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 2 5 6 9 12 15 16 19 CP 1 MR VCC = PIN 20 GND = PIN 10 = PIN NUMBERS http://onsemi.com 3 SN74LS273 FUNCTIONAL DESCRIPTION setup and hold time requirements of the D inputs is transferred to the Q outputs on the LOW-to-HIGH transition of the clock input. The SN74LS273 is an 8-Bit Parallel Register with a common Clock and common Master Reset. When the MR input is LOW, the Q outputs are LOW, independent of the other inputs. Information meeting the DC CHARACTERISTICS OVER OPERATING TEMPERATURE RANGE (unless otherwise specified) Limits Symbol Parameter VIH Input HIGH Voltage VIL Input LOW Voltage VIK Input Clamp Diode Voltage VOH Output HIGH Voltage VOL Output LOW Voltage IIH Input HIGH Current IIL Input LOW Current IOS Short Circuit Current (Note 2) Min Typ Max 2.0 0.8 −0.65 2.7 −1.5 3.5 Unit Test Conditions V Guaranteed Input HIGH Voltage for All Inputs V Guaranteed Input LOW Voltage for All Inputs V VCC = MIN, IIN = − 18 mA V VCC = MIN, IOH = MAX, VIN = VIH or VIL per Truth Table VCC = VCC MIN, VIN = VIL or VIH per Truth Table 0.25 0.4 V IOL = 4.0 mA 0.35 0.5 V IOL = 8.0 mA 20 μA VCC = MAX, VIN = 2.7 V 0.1 mA VCC = MAX, VIN = 7.0 V −0.4 mA VCC = MAX, VIN = 0.4 V −100 mA VCC = MAX ICC Power Supply Current 27 mA 2. Not more than one output should be shorted at a time, nor for more than 1 second. VCC = MAX −20 AC CHARACTERISTICS (TA = 25°C, VCC = 5.0 V) Limits Parameter Symbol Min Typ 30 40 fMAX Maximum Input Clock Frequency tPHL Propagation Delay, MR to Q Output 18 tPLH tPHL Propagation Delay, Clock to Output 17 18 Max Unit Test Conditions MHz Figure 1 27 ns Figure 2 27 27 ns Figure 1 Max AC SETUP REQUIREMENTS (TA = 25°C, VCC = 5.0 V) Limits Parameter Min Typ Unit Test Conditions tw Pulse Width, Clock or Clear 20 ns Figure 1 ts Data Setup Time 20 ns Figure 1 th Hold Time 5.0 ns Figure 1 trec Recovery Time 25 ns Figure 2 Symbol http://onsemi.com 4 SN74LS273 AC WAVEFORMS 1/f max tW CP 1.3 V 1.3 V ts(H) D * Qn ts(L) trec tPHL 1.3 V tPLH tPHL 1.3 V 1.3 V tPHL tPLH 1.3 V CP th(L) 1.3 V 1.3 V 1.3 V 1.3 V 1.3 V th(H) tW MR Qn 1.3 V 1.3 V 1.3 V 1.3 V tPLH Qn *The shaded areas indicate when the input is permitted to *change for predictable output performance. Figure 1. Clock to Output Delays, Clock Pulse Width, Frequency, Setup and Hold Times Data to Clock Figure 2. Master Reset to Output Delay, Master Reset Pulse Width, and Master Reset Recovery Time DEFINITION OF TERMS continued recognition. A negative HOLD TIME indicates that the correct logic level may be released prior to the clock transition from LOW-to-HIGH and still be recognized. RECOVERY TIME (trec) — is defined as the minimum time required between the end of the reset pulse and the clock transition from LOW-to-HIGH in order to recognize and transfer HIGH data to the Q outputs. SETUP TIME (ts) — is defined as the minimum time required for the correct logic level to be present at the logic input prior to the clock transition from LOW-to-HIGH in order to be recognized and transferred to the outputs. HOLD TIME (th) — is defined as the minimum time following the clock transition from LOW-to-HIGH that the logic level must be maintained at the input in order to ensure http://onsemi.com 5 SN74LS273 PACKAGE DIMENSIONS N SUFFIX PLASTIC PACKAGE CASE 738−03 ISSUE E −A− 20 11 1 10 NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH. 3. DIMENSION L TO CENTER OF LEAD WHEN FORMED PARALLEL. 4. DIMENSION B DOES NOT INCLUDE MOLD FLASH. B L C −T− K SEATING PLANE G M N E F D J 20 PL 0.25 (0.010) 20 PL 0.25 (0.010) M T A M http://onsemi.com 6 M T B M DIM A B C D E F G J K L M N INCHES MIN MAX 1.010 1.070 0.240 0.260 0.150 0.180 0.015 0.022 0.050 BSC 0.050 0.070 0.100 BSC 0.008 0.015 0.110 0.140 0.300 BSC 0_ 15 _ 0.020 0.040 MILLIMETERS MIN MAX 25.66 27.17 6.10 6.60 3.81 4.57 0.39 0.55 1.27 BSC 1.27 1.77 2.54 BSC 0.21 0.38 2.80 3.55 7.62 BSC 0_ 15_ 0.51 1.01 SN74LS273 PACKAGE DIMENSIONS D SUFFIX PLASTIC SOIC PACKAGE CASE 751D−05 ISSUE F A 20 q X 45 _ E h 1 10 20X B B 0.25 M T A S B S A L H M 10X 0.25 NOTES: 1. DIMENSIONS ARE IN MILLIMETERS. 2. INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M, 1994. 3. DIMENSIONS D AND E DO NOT INCLUDE MOLD PROTRUSION. 4. MAXIMUM MOLD PROTRUSION 0.15 PER SIDE. 5. DIMENSION B DOES NOT INCLUDE DAMBAR PROTRUSION. ALLOWABLE PROTRUSION SHALL BE 0.13 TOTAL IN EXCESS OF B DIMENSION AT MAXIMUM MATERIAL CONDITION. 11 B M D 18X e A1 SEATING PLANE C T http://onsemi.com 7 DIM A A1 B C D E e H h L q MILLIMETERS MIN MAX 2.35 2.65 0.10 0.25 0.35 0.49 0.23 0.32 12.65 12.95 7.40 7.60 1.27 BSC 10.05 10.55 0.25 0.75 0.50 0.90 0_ 7_ SN74LS273 PACKAGE DIMENSIONS M SUFFIX SOEIAJ PACKAGE CASE 967−01 ISSUE O 20 NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: MILLIMETER. 3. DIMENSIONS D AND E DO NOT INCLUDE MOLD FLASH OR PROTRUSIONS AND ARE MEASURED AT THE PARTING LINE. MOLD FLASH OR PROTRUSIONS SHALL NOT EXCEED 0.15 (0.006) PER SIDE. 4. TERMINAL NUMBERS ARE SHOWN FOR REFERENCE ONLY. 5. THE LEAD WIDTH DIMENSION (b) DOES NOT INCLUDE DAMBAR PROTRUSION. ALLOWABLE DAMBAR PROTRUSION SHALL BE 0.08 (0.003) TOTAL IN EXCESS OF THE LEAD WIDTH DIMENSION AT MAXIMUM MATERIAL CONDITION. DAMBAR CANNOT BE LOCATED ON THE LOWER RADIUS OR THE FOOT. MINIMUM SPACE BETWEEN PROTRUSIONS AND ADJACENT LEAD TO BE 0.46 ( 0.018). LE 11 Q1 E HE 1 M_ L 10 DETAIL P Z D e VIEW P A A1 b 0.13 (0.005) c M 0.10 (0.004) DIM A A1 b c D E e HE L LE M Q1 Z MILLIMETERS MIN MAX −−− 2.05 0.05 0.20 0.35 0.50 0.18 0.27 12.35 12.80 5.10 5.45 1.27 BSC 7.40 8.20 0.50 0.85 1.10 1.50 10 _ 0_ 0.70 0.90 −−− 0.81 INCHES MIN MAX −−− 0.081 0.002 0.008 0.014 0.020 0.007 0.011 0.486 0.504 0.201 0.215 0.050 BSC 0.291 0.323 0.020 0.033 0.043 0.059 10 _ 0_ 0.028 0.035 −−− 0.032 ON Semiconductor and are registered trademarks of Semiconductor Components Industries, LLC (SCILLC). SCILLC reserves the right to make changes without further notice to any products herein. SCILLC makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does SCILLC assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in SCILLC data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. SCILLC does not convey any license under its patent rights nor the rights of others. SCILLC products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the SCILLC product could create a situation where personal injury or death may occur. Should Buyer purchase or use SCILLC products for any such unintended or unauthorized application, Buyer shall indemnify and hold SCILLC and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that SCILLC was negligent regarding the design or manufacture of the part. SCILLC is an Equal Opportunity/Affirmative Action Employer. This literature is subject to all applicable copyright laws and is not for resale in any manner. PUBLICATION ORDERING INFORMATION LITERATURE FULFILLMENT: Literature Distribution Center for ON Semiconductor P.O. Box 5163, Denver, Colorado 80217 USA Phone: 303−675−2175 or 800−344−3860 Toll Free USA/Canada Fax: 303−675−2176 or 800−344−3867 Toll Free USA/Canada Email: orderlit@onsemi.com N. American Technical Support: 800−282−9855 Toll Free USA/Canada Europe, Middle East and Africa Technical Support: Phone: 421 33 790 2910 Japan Customer Focus Center Phone: 81−3−5773−3850 http://onsemi.com 8 ON Semiconductor Website: www.onsemi.com Order Literature: http://www.onsemi.com/orderlit For additional information, please contact your local Sales Representative SN74LS273/D
SN74LS273M 价格&库存
很抱歉,暂时无法提供与“SN74LS273M”相匹配的价格&库存,您可以联系我们找货
