TPS7A4518KTTR
TPS7A4518KTTR
    LSI/CSI
    TO263-6
    IC REG LIN LOW NOISE FAST TRANS
TPS7A4518KTTR 数据手册
Product Folder Sample & Buy Support & Community Tools & Software Technical Documents Reference Design TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 TPS7A45xx Low-Noise Fast-Transient-Response 1.5-A Low-Dropout Voltage Regulators 1 Features 3 Description • • • • • • • • • • • The TPS7A45xx devices are low-dropout (LDO) regulators optimized for fast transient response. The device can supply 1.5 A of output current with a dropout voltage of 300 mV. Operating quiescent current is 1 mA, dropping to less than 1 μA in shutdown. Quiescent current is well controlled; it does not rise in dropout as with many other regulators. In addition to fast transient response, the TPS7A45xx regulators have very-low output noise, which makes them ideal for sensitive RF supply applications. 1 • • • • Optimized for Fast Transient Response Output Current: 1.5 A High Output Voltage Accuracy: 1% at 25°C Dropout Voltage: 300 mV Low Noise: 35 μVRMS (10 Hz to 100 kHz) High Ripple Rejection: 68 dB at 1 kHz 1-mA Quiescent Current No Protection Diodes Needed Controlled Quiescent Current in Dropout Fixed Output Voltages: 1.5 V, 1.8 V, 2.5 V, 3.3 V Adjustable Output from 1.21 V to 20 V (TPS7A4501 Only) Less Than 1-μA Quiescent Current in Shutdown Stable With 10-μF Ceramic Output Capacitor Reverse-Battery Protection Reverse Current Protection Output voltage range is from 1.21 to 20 V. The TPS7A45xx regulators are stable with output capacitance as low as 10 μF. Small ceramic capacitors can be used without the necessary addition of ESR as is common with other regulators. Internal protection circuitry includes reverse-battery protection, current limiting, thermal limiting, and reverse-current protection. The devices are available in fixed output voltages of 1.5 V, 1.8 V, 2.5 V, 3.3 V, and as an adjustable device with a 1.21-V reference voltage. 2 Applications • • • Industrial Wireless Infrastructure Radio-Frequency Systems Device Information(1) PART NUMBER TPS7A45xx PACKAGE BODY SIZE (NOM) SOT-223 (6) 6.50 mm × 7.06 mm TO-263 (5) 10.16 mm × 15.24 mm (1) For all available packages, see the orderable addendum at the end of the data sheet. Simplified Schematic Dropout Voltage vs Output Current 500 450 Dropout Voltage – mV 400 350 TA = 125°C 300 250 200 TA = 25°C 150 100 50 0 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 Output Current – A 1 An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. PRODUCTION DATA. TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 www.ti.com Table of Contents 1 2 3 4 5 6 7 8 Features .................................................................. Applications ........................................................... Description ............................................................. Revision History..................................................... Device Comparison Table..................................... Pin Configuration and Functions ......................... Specifications......................................................... 1 1 1 2 3 3 4 7.1 7.2 7.3 7.4 7.5 7.6 4 4 4 5 5 8 Absolute Maximum Ratings ..................................... ESD Ratings.............................................................. Recommended Operating Conditions....................... Thermal Information .................................................. Electrical Characteristics........................................... Typical Characteristics .............................................. Detailed Description ............................................ 13 8.1 Overview ................................................................. 13 8.2 Functional Block Diagram ....................................... 13 8.3 Feature Description................................................. 13 8.4 Device Functional Modes........................................ 16 9 Application and Implementation ........................ 17 9.1 Application Information............................................ 17 9.2 Typical Applications ................................................ 18 10 Power Supply Recommendations ..................... 22 11 Layout................................................................... 22 11.1 Layout Guidelines ................................................. 22 11.2 Layout Example .................................................... 23 11.3 Thermal Considerations ........................................ 24 12 Device and Documentation Support ................. 26 12.1 12.2 12.3 12.4 12.5 Related Links ........................................................ Community Resources.......................................... Trademarks ........................................................... Electrostatic Discharge Caution ............................ Glossary ................................................................ 26 26 26 26 26 13 Mechanical, Packaging, and Orderable Information ........................................................... 26 4 Revision History NOTE: Page numbers for previous revisions may differ from page numbers in the current version. Changes from Revision E (August 2014) to Revision F Page • Corrected the body sizes listed for the packages ................................................................................................................. 1 • Moved Tstg to Absolute Maximum Ratings table and changed Handling Ratings to ESD Ratings table ............................... 4 • Relocated Thermal Considerations and Calculating Junction Temperature to Layout ........................................................ 24 • Added Community Resources ............................................................................................................................................. 26 Changes from Revision D (August 2011) to Revision E • Page Added Handling Rating table, Feature Description section, Device Functional Modes, Application and Implementation section, Power Supply Recommendations section, Layout section, Device and Documentation Support section, and Mechanical, Packaging, and Orderable Information section ............................................................... 1 Changes from Revision C (December 2010) to Revision D • 2 Page Replaced the Dissipation Ratings table with the Thermal Information table .......................................................................... 5 Submit Documentation Feedback Copyright © 2008–2015, Texas Instruments Incorporated Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 www.ti.com SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 5 Device Comparison Table DEVICE OUTPUT VOLTAGE TPS7A4501 Adjustable PIN 5 ADJ TPS7A4515 1.5 V SENSE TPS7A4518 1.8 V SENSE TPS7A4525 2.5 V SENSE TPS7A4533 3.3 V SENSE 6 Pin Configuration and Functions GND DCQ Package 6-Pin SOT-223 Top View 6 5 4 3 2 1 KTT Package 6-Pin TO-263 Top View SENSE/ADJ OUT GND IN SHDN 5 4 3 2 1 SENSE/ADJ OUT GND IN SHDN Pin Functions PIN NO. 1 DESCRIPTION NAME SHDN Shutdown. SHDN is used to put the TPS7A45xx regulators into a low-power shutdown state. The output is off when SHDN is pulled low. SHDN can be driven by 5-V logic, 3-V logic or open-collector logic with a pullup resistor. The pullup resistor is required to supply the pullup current of the open-collector gate, normally several microamperes, and SHDN current, typically 3 μA. If unused, SHDN must be connected to VIN. The device is in the low-power shutdown state if SHDN is not connected. 2 IN Input. Power is supplied to the device through IN. A bypass capacitor is required on this pin if the device is more than six inches away from the main input filter capacitor. In general, the output impedance of a battery rises with frequency, so it is advisable to include a bypass capacitor in battery-powered circuits. A bypass capacitor (ceramic) in the range of 1 μF to 10 μF is sufficient. The TPS7A45xx regulators are designed to withstand reverse voltages on IN with respect to ground and on OUT. In the case of a reverse input, which can happen if a battery is plugged in backwards, the device acts as if there is a diode in series with its input. There is no reverse current flow into the regulator, and no reverse voltage appears at the load. The device protects both itself and the load. 3 GND Ground. For the KTT package, the exposed thermal pad is connected to GND and must be soldered to the PCB for rated thermal performance. 4 OUT Output. The output supplies power to the load. A minimum output capacitor (ceramic) of 10 μF is required to prevent oscillations. Larger output capacitors are required for applications with large transient loads to limit peak voltage transients. 5 ADJ Adjust. For the adjustable version only (TPS7A4501), this is the input to the error amplifier. ADJ is internally clamped to ±7 V. It has a bias current of 3 μA that flows into the pin. ADJ voltage is 1.21 V referenced to ground, and the output voltage range is 1.21 V to 20 V. 5 SENSE Sense. For fixed-voltage versions (TPS7A4515, TPS7A4518, TPS7A4525, and TPS7A4533), SENSE is the input to the error amplifier. Optimum regulation is obtained at the point where SENSE is connected to the OUT pin of the regulator. In critical applications, small voltage drops are caused by the resistance (RP) of PCB traces between the regulator and the load. These may be eliminated by connecting SENSE to the output at the load as shown in Figure 32. Note that the voltage drop across the external PCB traces adds to the dropout voltage of the regulator. SENSE bias current is 600 μA at the rated output voltage. SENSE can be pulled below ground (as in a dual supply system in which the regulator load is returned to a negative supply) and still allow the device to start and operate. 6 GND Ground. DCQ package only. Copyright © 2008–2015, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 3 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 www.ti.com 7 Specifications 7.1 Absolute Maximum Ratings over operating virtual-junction temperature range (unless otherwise noted) (1) IN OUT Input-to-output differential Input voltage, VIN (2) SENSE MIN MAX –20 20 –20 20 –20 20 –20 20 ADJ –7 7 SHDN –20 20 Output short-circuit duration, tshort UNIT V Indefinite Maximum lead temperature (10-s soldering time), Tlead 300 °C Maximum junction temperature, TJMAX 150 °C 150 °C Storage temperature, Tstg (1) (2) –65 Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to conditions beyond the recommended operating maximum for extended periods may affect device reliability. Absolute maximum input-to-output differential voltage cannot be achieved with all combinations of rated IN pin and OUT pin voltages. With the IN pin at 20 V, the OUT pin may not be pulled below 0 V. The total measured voltage from IN to OUT can not exceed ±20 V. 7.2 ESD Ratings VALUE V(ESD) (1) (2) Human body model (HBM), per ANSI/ESDA/JEDEC JS-001, all pins Electrostatic discharge (1) ±2000 Charged device model (CDM), per JEDEC specification JESD22-C101, all pins (2) ±1000 UNIT V JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. Pins listed as 2000 V may actually have higher performance. JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. Pins listed as 1000 V may actually have higher performance. 7.3 Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) VIN Input voltage range (1) VIH SHDN high-level input voltage VIL SHDN low-level input voltage TJ Recommended operating junction temperature range (1) 4 MIN MAX VOUT + VDO 20 V 2 20 V –40 UNIT 0.25 V 125 °C TPS7A4501, TPS7A4515, and TPS7A4518 may require a higher minimum input voltage under some output voltage/load conditions as indicated under Electrical Characteristics. Submit Documentation Feedback Copyright © 2008–2015, Texas Instruments Incorporated Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 www.ti.com SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 7.4 Thermal Information TPS7A45xx THERMAL METRIC (1) (2) KTT (TO-263) DCQ (SOT-223) 5 PINS 6 PINS UNIT RθJA Junction-to-ambient thermal resistance 28.0 50.5 °C/W RθJC(top) Junction-to-case (top) thermal resistance 43.0 31.1 °C/W RθJB Junction-to-board thermal resistance 17.4 5.1 °C/W ψJT Junction-to-top characterization parameter 3.9 1.0 °C/W ψJB Junction-to-board characterization parameter 9.4 5.0 °C/W RθJC(bot) Junction-to-case (bottom) thermal resistance 0.3 — °C/W (1) (2) For more information about traditional and new thermal metrics, see the Semiconductor and IC Package Thermal Metrics application report, SPRA953. For thermal estimates of this device based on PCB copper area, see the TI PCB Thermal Calculator. 7.5 Electrical Characteristics Over recommended operating temperature range TJ = –40 to 125°C (unless otherwise noted) PARAMETER VIN Minimum input voltage TEST CONDITIONS (3) (4) 1.9 2.1 2.5 VIN = 2.5 V to 20 V, ILOAD = 1 mA to 1.5 A VIN = 2.8 V to 20 V, ILOAD = 1 mA to 1.5 A (5) VIN = 3 V, ILOAD = 1 mA TPS7A4525 VIN = 3.5 V to 20 V, ILOAD = 1 mA to 1.5 A VIN = 3.8 V, ILOAD = 1 mA TPS7A4533 VIN = 4.3 V to 20 V, ILOAD = 1 mA to 1.5 A VIN = 2.21 V, ILOAD = 1 mA Line regulation (3) (5) (2) (3) (4) (5) 25°C 1.485 1.5 1.515 Full range 1.447 1.5 1.545 25°C 1.782 1.8 1.818 Full range 1.737 1.8 1.854 25°C 2.475 2.5 2.525 Full range 2.412 2.5 2.575 25°C 3.266 3.3 3.333 3.2 3.3 3.4 Full range 25°C 1.197 1.21 1.222 VIN = 2.5 V to 20 V, ILOAD = 1 mA to 1.5 A Full range 1.174 1.21 1.246 TPS7A4515 ΔVIN = 2.21 V to 20 V, ILOAD = 1 mA Full range 2 6 TPS7A4518 ΔVIN = 2.3 V to 20 V, ILOAD = 1 mA Full range 2.5 7 TPS7A4525 ΔVIN = 3 V to 20 V, ILOAD = 1 mA Full range 3 10 TPS7A4533 ΔVIN = 3.8 V to 20 V, ILOAD = 1 mA Full range 3.5 10 ΔVIN = 2.21 V to 20 V, ILOAD = 1 mA Full range 1.5 3 TPS7A4501 TPS7A4501 (1) MAX 25°C VIN = 2.3 V, ILOAD = 1 mA ADJ pin voltage (2) Full range TPS7A4518 VADJ TYP ILOAD = 1.5 A VIN = 2.21 V, ILOAD = 1 mA Regulated output voltage MIN ILOAD = 0.5 A TPS7A4515 VOUT TJ (1) (3) UNIT V V V mV The TPS7A45xx regulators are tested and specified under pulse load conditions such that TJ ≉ TA. They are fully tested at TA = 25°C. Performance at –40 and 125°C is specified by design, characterization, and correlation with statistical process controls. Typical values represent the likely parametric nominal values determined at the time of characterization. Typical values depend on the application and configuration and may vary over time. Typical values are not ensured on production material. The TPS7A4501 is tested and specified for these conditions with the ADJ pin connected to the OUT pin. For the TPS7A4501, TPS7A4515 and TPS7A4518, dropout voltages are limited by the minimum input voltage specification under some output voltage/load conditions. Operating conditions are limited by maximum junction temperature. The regulated output voltage specification does not apply for all possible combinations of input voltage and output current. When operating at maximum input voltage, the output current range must be limited. When operating at maximum output current, the input voltage range must be limited. Copyright © 2008–2015, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 5 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 www.ti.com Electrical Characteristics (continued) Over recommended operating temperature range TJ = –40 to 125°C (unless otherwise noted) (1) PARAMETER TEST CONDITIONS TPS7A4515 VIN = 2.5 V, ΔILOAD = 1 mA to 1.5 A TPS7A4518 VIN = 2.8 V, ΔILOAD = 1 mA to 1.5 A TPS7A4525 VIN = 3.5 V, ΔILOAD = 1 mA to 1.5 A TJ MIN 25°C VIN = 4.3 V, ΔILOAD = 1 mA to 1.5 A TPS7A4533 2 TPS7A4501 VIN = 2.5 V, ΔILOAD = 1 mA to 1.5 A ILOAD = 1 mA (4) (6) (7) ILOAD = 100 mA Dropout voltage VIN = VOUT(NOMINAL) VDO ILOAD = 500 mA ILOAD = 1.5 A IGND eN GND pin current (7) (8) VIN = VOUT(NOMINAL) + 1 25°C 2 Full range IADJ ADJ pin bias current Shutdown threshold I SHDN 20 25°C 2.5 Full range 30 3 -40 to +85 °C 30 Full range 70 6 8 Full range 18 25°C 0.02 Full range 0.05 0.06 25°C 0.085 0.10 0.17 0.180 Full range 0.13 25°C Full range 25°C 0.300 0.350 0.450 1 1.5 ILOAD = 1 mA Full range 1.1 1.6 ILOAD = 100 mA Full range 3.3 3.5 ILOAD = 500 mA Full range 15 17 ILOAD = 1.5 A Full range 80 90 25°C 35 25°C Full range VOUT = ON to OFF Full range 0.25 3 7 0.9 2 0.75 1 3 20 Quiescent current in shutdown VIN = 6 V, V SHDN = 0 V 25°C 0.01 1 Ripple rejection VIN – VOUT = 1.5 V (avg), VRIPPLE = 0.5 VP-P, fRIPPLE = 120 Hz, ILOAD = 0.75 A 25°C 68 25°C VIN = VOUT(NOMINAL) + 1 Full range VIN = –20 V, VOUT = 0 V Full range mA μVRMS 0.01 VIN = 7 V, VOUT = 0 V V 0.250 Full range VOUT = OFF to ON mV 8 25°C Input reverse leakage current (9) 2 -40 to +85 °C 25°C IIL (8) 20 V SHDN = 20 V Current limit (7) 15 V SHDN = 0 V SHDN pin current ILIMIT (6) 10 Full range (3) (9) UNIT 9 ILOAD = 0 mA COUT = 10 μF, ILOAD = 1.5 A, BW = 10 Hz to 100 kHz Output voltage noise MAX 18 25°C (3) (2) Full range 25°C Load regulation TYP μA V μA μA dB 2 A 1.6 300 μA Dropout voltage is the minimum input to output voltage differential needed to maintain regulation at a specified output current. In dropout, the output voltage is equal to: VIN – VDROPOUT. To satisfy requirements for minimum input voltage, the TPS7A4501 is tested and specified for these conditions with an external resistor divider (two 4.12-kΩ resistors) for an output voltage of 2.4 V. The external resistor divider adds a 300-µA DC load on the output. GND pin current is tested with VIN = (VOUT(NOMINAL) + 1 V) and a current source load. The GND pin current decreases at higher input voltages. ADJ pin bias current flows into the ADJ pin. Submit Documentation Feedback Copyright © 2008–2015, Texas Instruments Incorporated Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 www.ti.com SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 Electrical Characteristics (continued) Over recommended operating temperature range TJ = –40 to 125°C (unless otherwise noted) (1) PARAMETER IRO Reverse output current TEST CONDITIONS (10) TJ MIN TYP (2) MAX TPS7A4515 VOUT = 1.5 V, VIN < 1.5 V 25°C 600 1000 TPS7A4518 VOUT = 1.8 V, VIN < 1.8 V 25°C 600 1000 TPS7A4525 VOUT = 2.5 V, VIN < 2.5 V 25°C 600 1000 TPS7A4533 VOUT = 3.3 V, VIN < 3.3 V 25°C 600 1000 TPS7A4501 VOUT = 1.21 V, VIN < 1.21 V 25°C 300 500 UNIT μA (10) Reverse output current is tested with the IN pin grounded and the OUT pin forced to the rated output voltage. This current flows into the OUT pin and out the GND pin. Copyright © 2008–2015, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 7 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 www.ti.com 7.6 Typical Characteristics Typical characteristics apply to all TPS7A45xx devices unless otherwise noted. 480 500 450 IOUT = 1.5 A 400 Dropout Voltage – mV Dropout Voltage – mV 360 350 TA = 125°C 300 250 200 TA = 25°C 150 240 IOUT = 0.5 A IOUT = 100 mA 120 100 50 IOUT = 1 mA 0 0 0.2 0.4 0.6 0.8 1 1.2 1.4 0 -50 1.6 Figure 1. Dropout Voltage vs Output Current VIN = 6 V IOUT = 0 A VSHDN = VIN Figure 3. Quiescent Current vs Temperature IOUT = 1 mA TPS7A4525 Figure 5. TPS7A4525 Output Voltage vs Temperature 8 Submit Documentation Feedback -25 0 25 50 75 100 125 TA – Free-Air Temperature – °C Output Current – A Figure 2. Dropout Voltage vs Temperature IOUT = 1 mA TPS7A4518 Figure 4. TPS7A4518 Output Voltage vs Temperature IOUT = 1 mA TPS7A4533 Figure 6. TPS7A4533 Output Voltage vs Temperature Copyright © 2008–2015, Texas Instruments Incorporated Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 www.ti.com SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 Typical Characteristics (continued) Typical characteristics apply to all TPS7A45xx devices unless otherwise noted. 1.2 1.23 1.225 Quiescent Current (mA) 1 Output Voltage (V) 1.22 1.215 1.21 1.205 1.2 0.8 0.6 0.4 0.2 1.195 0 1.19 -50 0 -25 0 25 50 75 Free-Air Temperature (qC) IOUT = 1 mA 100 2 125 TJ = 25°C D020 VIN = 6 V Figure 7. TPS7A4501 Output Voltage vs Temperature 4 6 8 10 12 Input Voltage (V) 14 16 18 20 D021 ROUT = 4.3 kΩ VSHDN = VIN Figure 8. Quiescent Current vs Input Voltage 10 IOUT = 10 mA IOUT = 100 mA IOUT = 300 mA 9 Ground Current (mA) 8 7 6 5 4 3 2 1 0 0 1 2 TJ = 25°C 3 4 5 6 Input Voltage (V) 7 8 9 10 D022 VOUT = 1.21 V VSHDN = VIN Figure 9. TPS7A4501 Ground Current vs Input Voltage TJ = 25°C VSHDN = VIN Figure 11. TPS7A4533 Ground Current vs Input Voltage Copyright © 2008–2015, Texas Instruments Incorporated TJ = 25°C VOUT = 1.21 V VSHDN = VIN Figure 10. TPS7A4501 Ground Current vs Input Voltage TJ = 25°C VSHDN = VIN Figure 12. TPS7A4533 Ground Current vs Input Voltage Submit Documentation Feedback Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 9 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 www.ti.com Typical Characteristics (continued) Typical characteristics apply to all TPS7A45xx devices unless otherwise noted. VSHDN = 0 V VIN = VOUT(nom) + 1 Figure 13. Ground Current vs Output Current Figure 14. Quiescent Current in Shutdown vs Input Voltage 2.5 2.25 SHDN Input Current – µA 2 1.75 1.5 1.25 1 0.75 0.5 0.25 0 0 2 4 6 8 10 12 14 16 18 20 SHDN Input Voltage – V VSHON = 0 V Figure 15. SHDN Pin Current (ISHDN) vs Temperature IOUT = 1 mA IOUT = 1 mA Figure 17. SHDN Threshold (OFF to ON) vs Temperature 10 Figure 16. SHDN Pin Current (ISHDN) vs SHDN Input Voltage Submit Documentation Feedback Figure 18. SHDN Threshold (ON to OFF) vs Temperature Copyright © 2008–2015, Texas Instruments Incorporated Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 www.ti.com SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 Typical Characteristics (continued) Typical characteristics apply to all TPS7A45xx devices unless otherwise noted. 5 4.5 ADJ Bias Current – µA 4 3.5 3 2.5 2 1.5 1 0.5 0 -50 -25 0 25 50 75 100 125 TA – Free-Air Temperature – °C ΔVOUT = 100 mV Figure 19. ADJ Bias Current vs Temperature VIN = 7 V VOUT = 0 V Figure 21. Current Limit vs Temperature Figure 20. Current Limit vs Input-to-Output Differential Voltage TJ = 25°C VIN = 0 V Current flows into OUT pin Figure 22. Reverse Output Current vs Output Voltage VRIPPLE = 0.05 VPP VIN = 2.7 V VIN = 0 V Figure 23. Reverse Output Current vs Temperature Copyright © 2008–2015, Texas Instruments Incorporated CIN = 0 TA = 25°C COUT = 10 µF (ceramic) Figure 24. Ripple Rejection vs Frequency Submit Documentation Feedback Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 11 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 www.ti.com Typical Characteristics (continued) Typical characteristics apply to all TPS7A45xx devices unless otherwise noted. IOUT = 1.5 A COUT = 10 µF (ceramic) Figure 25. Load Regulation vs Temperature VIN = 4.3 V CIN = 10 µF COUT = 10 µF (ceramic) Figure 26. Output Noise Voltage vs Frequency VIN = 4.3 V CIN = 10 µF COUT = 10 µF (ceramic) Figure 27. Load Transient Response IOUT = 1.5 A IOUT = 1.5 A Figure 28. Load Transient Response CIN = 10 µF COUT = 10 µF (ceramic) Figure 29. Line Transient Response 12 Submit Documentation Feedback Copyright © 2008–2015, Texas Instruments Incorporated Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 www.ti.com SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 8 Detailed Description 8.1 Overview The TPS7A45xx series are 1.5-A low-dropout regulators optimized for fast transient response. The devices are capable of supplying 1.5 A at a dropout voltage of 300 mV. The low operating quiescent current (1 mA) drops to less than 1 μA in shutdown. In addition to the low quiescent current, the TPS7A45xx regulators incorporate several protection features that make them ideal for use in battery-powered systems. The devices are protected against both reverse input and reverse output voltages. In battery-backup applications where the output can be held up by a backup battery when the input is pulled to ground, the TPS7A45xx acts as if it has a diode in series with its output and prevents reverse current flow. Additionally, in dual-supply applications where the regulator load is returned to a negative supply, the output can be pulled below ground by as much as (20 V – VIN) and still allow the device to start and operate. 8.2 Functional Block Diagram IN Reverse Current Protection Pass Element SHDN Current Limit OUT Error Amplifier + Thermal Overload SENSE/ADJ + Voltage Reference Reverse Voltage Protection GND 8.3 Feature Description 8.3.1 Adjustable Operation The TPS7A4501 has an adjustable output voltage range of 1.21 V to 20 V. The output voltage is set by the ratio of two external resistors as shown in Figure 30. The device maintains the voltage at the ADJ pin at 1.21 V referenced to ground. The current in R1 is then equal to (1.21 V/R1), and the current in R2 is the current in R1 plus the ADJ pin bias current. The ADJ pin bias current, 3 μA at 25°C, flows through R2 into the ADJ pin. The output voltage can be calculated using the formula shown in Equation 1. The value of R1 should be less than 4.17 kΩ to minimize errors in the output voltage caused by the ADJ pin bias current. Note that in shutdown the output is turned off, and the divider current is zero. Copyright © 2008–2015, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 13 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 www.ti.com Figure 30. Adjustable Operation The output voltage can be set using the following equations: R2 VOUT = 1.21V(1 + ) + IADJ ´ R2 R1 (1) (2) (3) (4) VADJ = 1.21 V IADJ = 3 µA at 25°C Output Range = 1.21 to 20 V 8.3.2 Fixed Operation The TPS7A45xx can be used in a fixed voltage configuration. The SENSE/ADJ pin should be connected to OUT for proper operation. An example of this is shown in Figure 31. The TPS7A4501 can also be used in this configuration for a fixed output voltage of 1.21 V. IN 10 µF (ceramic) VIN > 3 V 2.5 V at 1.5 A OUT 10 µF (ceramic) TPS7A4525 SENSE SHDN GND Figure 31. 3.3 to 2.5 V Regulator During fixed voltage operation, the SENSE/ADJ pin can be used for a Kelvin connection if routed separately to the load. This allows the regulator to compensate for voltage drop across parasitic resistances (RP) between the output and the load. This becomes more crucial with higher load currents. RP IN OUT TPS7A4501 VIN SHDN SENSE Load GND RP Figure 32. Kelvin Sense Connection 14 Submit Documentation Feedback Copyright © 2008–2015, Texas Instruments Incorporated Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 www.ti.com SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 8.3.3 Overload Recovery Like many IC power regulators, the TPS7A45xx has safe operating area protection. The safe area protection decreases the current limit as input-to-output voltage increases and keeps the power transistor inside a safe operating region for all values of input-to-output voltage. The protection is designed to provide some output current at all values of input-to-output voltage up to the device breakdown. When power is first turned on, as the input voltage rises, the output follows the input, allowing the regulator to start up into very heavy loads. During start up, as the input voltage is rising, the input-to-output voltage differential is small, allowing the regulator to supply large output currents. With a high input voltage, a problem can occur wherein removal of an output short does not allow the output voltage to recover. Other regulators also exhibit this phenomenon, so it is not unique to the TPS7A45xx. The problem occurs with a heavy output load when the input voltage is high and the output voltage is low. Common situations occur immediately after the removal of a short circuit or when the shutdown pin is pulled high after the input voltage has already been turned on. The load line for such a load may intersect the output current curve at two points. If this happens, there are two stable output operating points for the regulator. With this double intersection, the input power supply may need to be cycled down to zero and brought up again to make the output recover. 8.3.4 Output Voltage Noise The TPS7A45xx regulators have been designed to provide low output voltage noise over the 10-Hz to 100-kHz bandwidth while operating at full load. Output voltage noise is typically 35 nV/√Hz over this frequency bandwidth for the TPS7A4501 (adjustable version). For higher output voltages (generated by using a resistor divider), the output voltage noise is gained up accordingly. This results in RMS noise over the 10-Hz to 100-kHz bandwidth of 14 μVRMS for the TPS7A4501, increasing to 38 μVRMS for the TPS7A4533. Higher values of output voltage noise may be measured when care is not exercised with regard to circuit layout and testing. Crosstalk from nearby traces can induce unwanted noise onto the output of the TPS7A45xx. Powersupply ripple rejection must also be considered; the TPS7A45xx regulators do not have unlimited power-supply rejection and pass a small portion of the input noise through to the output. 8.3.5 Protection Features The TPS7A45xx regulators incorporate several protection features which make them ideal for use in batterypowered circuits. In addition to the normal protection features associated with monolithic regulators, such as current limiting and thermal limiting, the devices are protected against reverse input voltages, reverse output voltages and reverse voltages from output to input. Current limit protection and thermal overload protection are intended to protect the device against current overload conditions at the output of the device. For normal operation, the junction temperature should not exceed 125°C. The input of the device withstands reverse voltages of 20 V. Current flow into the device is limited to less than 1 mA (typically less than 100 μA), and no negative voltage appears at the output. The device protects both itself and the load. This provides protection against batteries that can be plugged in backward. The output of the TPS7A45xx can be pulled below ground without damaging the device. If the input is left open circuit or grounded, the output can be pulled below ground by 20 V. For fixed voltage versions, the output acts like a large resistor, typically 5 kΩ or higher, limiting current flow to typically less than 600 μA. For adjustable versions, the output acts like an open circuit; no current flows out of the pin. If the input is powered by a voltage source, the output sources the short-circuit current of the device and protects itself by thermal limiting. In this case, grounding the SHDN pin turns off the device and stops the output from sourcing the short-circuit current. The ADJ pin of the adjustable device can be pulled above or below ground by as much as 7 V without damaging the device. If the input is left open circuit or grounded, the ADJ pin acts like an open circuit when pulled below ground and like a large resistor (typically 5 kΩ) in series with a diode when pulled above ground. In situations where the ADJ pin is connected to a resistor divider that would pull the ADJ pin above its 7-V clamp voltage if the output is pulled high, the ADJ pin input current must be limited to less than 5 mA. For example, a resistor divider is used to provide a regulated 1.5-V output from the 1.21-V reference when the output is forced to 20 V. The top resistor of the resistor divider must be chosen to limit the current into the ADJ pin to less than 5 mA when the ADJ pin is at 7 V. The 13-V difference between OUT and ADJ divided by the 5-mA maximum current into the ADJ pin yields a minimum top resistor value of 2.6 kΩ. Copyright © 2008–2015, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 15 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 www.ti.com In circuits where a backup battery is required, several different input/output conditions can occur. The output voltage may be held up while the input is either pulled to ground, pulled to some intermediate voltage, or is left open circuit. When the IN pin of the TPS7A45xx is forced below the OUT pin or the OUT pin is pulled above the IN pin, input current typically drops to less than 2 μA. This can happen if the input of the device is connected to a discharged (low voltage) battery and the output is held up by either a backup battery or a second regulator circuit. The state of the SHDN pin has no effect on the reverse output current when the output is pulled above the input. 8.4 Device Functional Modes Table 1 shows the functional modes for the TPS7A45xx. Table 1. Device Modes 16 Submit Documentation Feedback SHDN DEVICE STATE H Regulated voltage L Shutdown Copyright © 2008–2015, Texas Instruments Incorporated Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 www.ti.com SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 9 Application and Implementation NOTE Information in the following applications sections is not part of the TI component specification, and TI does not warrant its accuracy or completeness. TI’s customers are responsible for determining suitability of components for their purposes. Customers should validate and test their design implementation to confirm system functionality. 9.1 Application Information This section highlights some design considerations for implementing this device in various applications. 9.1.1 Output Capacitance and Transient Response The TPS7A45xx regulators are designed to be stable with a wide range of output capacitors. The ESR of the output capacitor affects stability, most notably with small capacitors. A minimum output capacitor of 10 μF with an ESR of 3 Ω or less is recommended to prevent oscillations. Larger values of output capacitance can decrease the peak deviations and provide improved transient response for larger load current changes. Bypass capacitors, used to decouple individual components powered by the TPS7A45xx, increase the effective output capacitor value. Extra consideration must be given to the use of ceramic capacitors. Ceramic capacitors are manufactured with a variety of dielectrics, each with different behavior over temperature and applied voltage. The most common dielectrics used are Z5U, Y5V, X5R and X7R. The Z5U and Y5V dielectrics are good for providing high capacitances in a small package, but exhibit strong voltage and temperature coefficients. When used with a 5-V regulator, a 10-μF Y5V capacitor can exhibit an effective value as low as 1 μF to 2 μF over the operating temperature range. The X5R and X7R dielectrics result in more stable characteristics and are more suitable for use as the output capacitor. The X7R type has better stability across temperature, while the X5R is less expensive and is available in higher values. Voltage and temperature coefficients are not the only sources of problems. Some ceramic capacitors have a piezoelectric response. A piezoelectric device generates voltage across its terminals due to mechanical stress, similar to the way a piezoelectric accelerometer or microphone works. For a ceramic capacitor, the stress can be induced by vibrations in the system or thermal transients. Copyright © 2008–2015, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 17 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 www.ti.com 9.2 Typical Applications 9.2.1 Adjustable Output Operation IN VIN = 5 V + C1 10 PF 2.5 V at 1 A OUT R2 4.22 k TPS7A4501 C2 10 PF ADJ SHDN R1 4k GND NOTE: All capacitors are ceramic. Figure 33. Adjustable Output Voltage Operation 9.2.1.1 Design Requirements Table 2 shows the design requirements. Table 2. Design Parameters DESIGN PARAMETER EXAMPLE VALUE Input voltage (VIN) 5.0 V Output voltage (VOUT) 2.5 V Output current (IOUT) 0 to 1 A Load regulation 1% 9.2.1.2 Detailed Design Procedure The TPS7A4501 has an adjustable output voltage range of 1.21 to 20 V. The output voltage is set by the ratio of two external resistors R1 and R2 as shown in Figure 33. The device maintains the voltage at the ADJ pin at 1.21 V referenced to ground. The current in R1 is then equal to (1.21 V/R1), and the current in R2 is the current in R1 plus the ADJ pin bias current. The ADJ pin bias current, 3 µA at 25°C, flows through R2 into the ADJ pin. The output voltage can be calculated using Equation 5. R2 VOUT = 1.21V(1 + ) + IADJ ´ R2 (5) R1 The value of R1 should be less than 4.17 kΩ to minimize errors in the output voltage caused by the ADJ pin bias current. Note that in shutdown the output is turned off, and the divider current is zero. For an output voltage of 2.50 V, R1 will be set to 4.0 kΩ. R2 is then found to be 4.22 kΩ using the equation above. 4.22kW VOUT = 1.21V(1 + ) + 3µA ´ 4.22kW 4.0kW (6) VOUT = 2.50 V (7) The adjustable device is tested and specified with the ADJ pin tied to the OUT pin for an output voltage of 1.21 V. Specifications for output voltages greater than 1.21 V are proportional to the ratio of the desired output voltage to 1.21 V: VOUT/1.21 V. For example, load regulation for an output current change of 1 mA to 1.5 A is –2 mV (typ) at VOUT = 1.21 V. At VOUT = 2.50 V, the typical load regulation is: (2.50 V/1.21 V)(–2 mV) = –4.13 mV (8) Figure 34 shows the actual change in output is about 3 mV for a 1-A load step. The maximum load regulation at 25°C is –8 mV. At VOUT = 2.50 V, the maximum load regulation is: (2.50 V/1.21 V)(–8 mV) = –16.53 mV (9) Because 16.53 mV is only 0.7% of the 2.5 V output voltage, the load regulation will meet the design requirements. 18 Submit Documentation Feedback Copyright © 2008–2015, Texas Instruments Incorporated Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 www.ti.com SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 9.2.1.3 Application Curve Figure 34. 1-A Load Transient Response Copyright © 2008–2015, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 19 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 www.ti.com 9.2.2 Paralleling Regulators for Higher Output Current NOTE: All capacitors are ceramic. Figure 35. Paralleling Regulators for Higher Output Current 9.2.2.1 Design Requirements Table 3 shows the design requirements. Table 3. Design Requirements DESIGN PARAMETER EXAMPLE VALUE Input voltage (VIN) 6.0 V Output voltage (VOUT) 3.3 V Output current (IOUT) 3.0 A 9.2.2.2 Detailed Design Procedure In an application requiring higher output current, an adjustable output regular can be placed in parallel with a fixed output regulator to increase the current capacity. Two sense resistors and a comparator can be used to control the feedback loop of the adjustable regulator in order to balance the current between the two regulators. In Figure 35 resistors R1 and R2 are used to sense the current flowing into each regulator and should have a very low resistance to avoid unnecessary power loss. R1 and R2 should have the same value and a tolerance of 1% or better so the current is shared equally between the regulators. For this example, a value of 0.01 Ω will be used. 20 Submit Documentation Feedback Copyright © 2008–2015, Texas Instruments Incorporated Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 www.ti.com SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 The TLV3691 rail-to-rail nanopower comparator output will alternate between VIN and GND depending on the currents flowing into each of the two regulators. To design this control circuit, begin by looking at the case where the two output currents are approximately equal and the comparator output is low. In this case, the output of the TPS7A4501 should be set the same as the fixed voltage regulator. The TPS7A4533 has a 3.3 V fixed output, so this will be the set point for the adjustable regulator. Begin by selecting a R7 value less than 4.17 kΩ. In this example, 3.3 kΩ will be used. R5 will need to have a high resistance to satisfy Equation 14, for this example 100 kΩ was chosen. Then find the parallel resistance of R5 and R7 since they are both connected from the ADJ pin to GND using Equation 10. R5 ´ R7 = 3.19kΩ (R5 | |R7) =   R5 + R7 (10) Once the R5 and R7 parallel resistance in calculated, the value for R6 can be found using Equation 11. V R6 = OUT (R5 | |R7) - (R5 || R7) 1.22V 3.3V R6 = (3.19kW ) - (3.19kW ) 1.22V R6 = 5.45 kΩ (11) (12) (13) In the case where the TPS7A4533 is sourcing more current than TPS7A4501, the comparator output will go high. This will lower the voltage at the ADJ pin causing the TPS7A4501 to try and raise the output voltage by sourcing more current. The TPS7A4533 will then react by sourcing less current to try and keep the output from rising. When the current through the TPS7A4533 becomes less than the TPS7A4501, the comparator output will return to GND. In order for this to happen, Equation 14 must be satisfied: æ R7 ö æ R6 ö VIN ç ÷ + (VIN - VOUT )ç R5 + R6 ÷ < Vref R5 R7 + è ø è ø (14) 3.3kW 5.45kW æ ö æ ö 6V ç ÷ + (2.7V) ç 100kW + 5.45kW ÷ < 1.21V è 100kW + 3.3kW ø è ø (15) (16) (17) 0.19 V + 0.14 V < 1.21 V 0.33 V < 1.21 V 9.2.2.3 Application Curve Figure 36. Parallel Regulators Sharing Load Current Copyright © 2008–2015, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 21 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 www.ti.com 10 Power Supply Recommendations The device is designed to operate with an input voltage supply up to 20 V. The minimum input voltage should provide adequate headroom greater than the dropout voltage in order for the device to have a regulated output. If the input supply is noisy, additional input capacitors with low ESR can help improve the output noise performance. 11 Layout 11.1 Layout Guidelines 1. For best performance, all traces should be as short as possible. 2. Use wide traces for IN, OUT, and GND to minimize the parasitic electrical effects. 3. A minimum output capacitor of 10 μF with an ESR of 3 Ω or less is recommended to prevent oscillations. X5R and X7R dielectrics are preferred. 4. Place the Output Capacitor as close as possible to the OUT pin of the device. 5. The tab of the DCQ package should be connected to ground. 6. The exposed thermal pad of the KTT package should be connected to a wide ground plane for effective heat dissipation. 22 Submit Documentation Feedback Copyright © 2008–2015, Texas Instruments Incorporated Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 www.ti.com SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 11.2 Layout Example Figure 37. TO-263 Layout Example (KTT) Copyright © 2008–2015, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 23 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 www.ti.com Layout Example (continued) Figure 38. SOT-223 Layout Example (DCQ) 11.3 Thermal Considerations The power handling capability of the device is limited by the recommended maximum operating junction temperature (125°C). The power dissipated by the device is made up of two components: 1. Output current multiplied by the input/output voltage differential: IOUT (VIN – VOUT) 2. GND pin current multiplied by the input voltage: IGNDVIN The GND pin current can be found using the GND pin current graphs in Typical Characteristics. Power dissipation is equal to the sum of the two components listed above. The TPS7A45xx series regulators have internal thermal limiting designed to protect the device during overload conditions. For continuous normal conditions, the recommended maximum operating junction temperature is 125°C. It is important to give careful consideration to all sources of thermal resistance from junction to ambient. Additional heat sources mounted nearby must also be considered. For surface-mount devices, heat sinking is accomplished by using the heat-spreading capabilities of the PCB and its copper traces. Copper board stiffeners and plated through-holes can also be used to spread the heat generated by power devices. 24 Submit Documentation Feedback Copyright © 2008–2015, Texas Instruments Incorporated Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 www.ti.com SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 Thermal Considerations (continued) Table 4 lists thermal resistance for several different board sizes and copper areas. All measurements were taken in still air on 1/16-inch FR-4 board with 1-oz copper. Table 4. Thermal Data (KTT Package, 5-Pin TO-263) COPPER AREA (1) TOPSIDE (1) BACKSIDE BOARD AREA THERMAL RESISTANCE (JUNCTION TO AMBIENT) 2500 mm2 2500 mm2 2500 mm2 23°C/W 2 1000 mm 2 2500 mm 2500 mm2 25°C/W 125 mm2 2500 mm2 2500 mm2 33°C/W Device is mounted on topside. 11.3.1 Calculating Junction Temperature Example: Given an output voltage of 3.3 V, an input voltage range of 4 to 6 V, an output current range of 0 to 500 mA, and a maximum ambient temperature of 50°C, what is the operating junction temperature? The power dissipated by the device is equal to: IOUT(MAX)(VIN(MAX) – VOUT) + IGND(VIN(MAX)) where • • • IOUT(MAX) = 500 mA VIN(MAX) = 6 V IGND at (IOUT = 500 mA, VIN = 6 V) = 10 mA (18) So, P = 500 mA × (6 V – 3.3 V) + 10 mA × 6 V = 1.41 W (19) Using a KTT package, the thermal resistance is in the range of 23°C/W to 33°C/W, depending on the copper area. So the junction temperature rise above ambient is approximately equal to: 1.41 W × 28°C/W = 39.5 °C (20) The junction temperature rise can then be added to the maximum ambient temperature to find the operating junction temperature (TJ): TJ = 50°C + 39.5°C = 89.5°C Copyright © 2008–2015, Texas Instruments Incorporated (21) Submit Documentation Feedback Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 25 TPS7A4501, TPS7A4515, TPS7A4518, TPS7A4525, TPS7A4533 SLVS720F – JUNE 2008 – REVISED NOVEMBER 2015 www.ti.com 12 Device and Documentation Support 12.1 Related Links The table below lists quick access links. Categories include technical documents, support and community resources, tools and software, and quick access to sample or buy. Table 5. Related Links PARTS PRODUCT FOLDER SAMPLE & BUY TECHNICAL DOCUMENTS TOOLS & SOFTWARE SUPPORT & COMMUNITY TPS7A4501 Click here Click here Click here Click here Click here TPS7A4515 Click here Click here Click here Click here Click here TPS7A4518 Click here Click here Click here Click here Click here TPS7A4525 Click here Click here Click here Click here Click here TPS7A4533 Click here Click here Click here Click here Click here 12.2 Community Resources The following links connect to TI community resources. Linked contents are provided "AS IS" by the respective contributors. They do not constitute TI specifications and do not necessarily reflect TI's views; see TI's Terms of Use. TI E2E™ Online Community TI's Engineer-to-Engineer (E2E) Community. Created to foster collaboration among engineers. At e2e.ti.com, you can ask questions, share knowledge, explore ideas and help solve problems with fellow engineers. Design Support TI's Design Support Quickly find helpful E2E forums along with design support tools and contact information for technical support. 12.3 Trademarks E2E is a trademark of Texas Instruments. All other trademarks are the property of their respective owners. 12.4 Electrostatic Discharge Caution These devices have limited built-in ESD protection. The leads should be shorted together or the device placed in conductive foam during storage or handling to prevent electrostatic damage to the MOS gates. 12.5 Glossary SLYZ022 — TI Glossary. This glossary lists and explains terms, acronyms, and definitions. 13 Mechanical, Packaging, and Orderable Information The following pages include mechanical, packaging, and orderable information. This information is the most current data available for the designated devices. This data is subject to change without notice and revision of this document. For browser-based versions of this data sheet, refer to the left-hand navigation. 26 Submit Documentation Feedback Copyright © 2008–2015, Texas Instruments Incorporated Product Folder Links: TPS7A4501 TPS7A4515 TPS7A4518 TPS7A4525 TPS7A4533 PACKAGE OPTION ADDENDUM www.ti.com 13-Aug-2021 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan (2) Lead finish/ Ball material MSL Peak Temp Op Temp (°C) Device Marking (3) (4/5) (6) TPS7A4501DCQR ACTIVE SOT-223 DCQ 6 2500 RoHS & Green NIPDAU Level-2-260C-1 YEAR -40 to 125 PS7A4501 TPS7A4501DCQT ACTIVE SOT-223 DCQ 6 250 RoHS & Green NIPDAU Level-2-260C-1 YEAR -40 to 125 PS7A4501 TPS7A4501KTTR ACTIVE DDPAK/ TO-263 KTT 5 500 RoHS & Green SN Level-3-245C-168 HR -40 to 125 TPS7A4501 TPS7A4515DCQR ACTIVE SOT-223 DCQ 6 2500 RoHS & Green NIPDAU Level-2-260C-1 YEAR -40 to 125 PS7A4515 TPS7A4515DCQT ACTIVE SOT-223 DCQ 6 250 RoHS & Green NIPDAU Level-2-260C-1 YEAR TPS7A4515KTTR ACTIVE DDPAK/ TO-263 KTT 5 500 RoHS & Green SN Level-3-245C-168 HR -40 to 125 TPS7A4515 TPS7A4518DCQR ACTIVE SOT-223 DCQ 6 2500 RoHS & Green NIPDAU Level-2-260C-1 YEAR -40 to 125 PS7A4518 TPS7A4518DCQT ACTIVE SOT-223 DCQ 6 250 RoHS & Green NIPDAU Level-2-260C-1 YEAR TPS7A4518KTTR ACTIVE DDPAK/ TO-263 KTT 5 500 RoHS & Green SN Level-3-245C-168 HR -40 to 125 TPS7A4518 TPS7A4518KTTRG3 ACTIVE DDPAK/ TO-263 KTT 5 500 RoHS & Green SN Level-3-245C-168 HR -40 to 125 TPS7A4518 TPS7A4525DCQR ACTIVE SOT-223 DCQ 6 2500 RoHS & Green NIPDAU Level-2-260C-1 YEAR -40 to 125 PS7A4525 TPS7A4525DCQT ACTIVE SOT-223 DCQ 6 250 RoHS & Green NIPDAU Level-2-260C-1 YEAR TPS7A4525KTTR ACTIVE DDPAK/ TO-263 KTT 5 500 RoHS & Green SN Level-3-245C-168 HR -40 to 125 TPS7A4525 TPS7A4533DCQR ACTIVE SOT-223 DCQ 6 2500 RoHS & Green NIPDAU Level-2-260C-1 YEAR -40 to 125 PS7A4533 TPS7A4533DCQT ACTIVE SOT-223 DCQ 6 250 RoHS & Green NIPDAU Level-2-260C-1 YEAR -40 to 125 PS7A4533 TPS7A4533KTTR ACTIVE DDPAK/ TO-263 KTT 5 500 RoHS & Green SN Level-3-245C-168 HR -40 to 125 TPS7A4533 (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. Addendum-Page 1 PS7A4515 PS7A4518 PS7A4525 Samples PACKAGE OPTION ADDENDUM www.ti.com 13-Aug-2021 OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
TPS7A4518KTTR 价格&库存
很抱歉,暂时无法提供与“TPS7A4518KTTR”相匹配的价格&库存,您可以联系我们找货
