Revision - Date: 2018/11/01
P r o d u c t
S p e c i f i c a t i o n
S EN SO R S O LU TIO N S
DigiPileTM Thermopile Sensor
TPiS 1S 1051 / 5028
Features and Benefits
Introduction
The DigiPile TPiS 1S 1051 is one sensor
out of a new family of digital thermopile
infrared sensors, brought to you from
Excelitas Technologies.
It combines the time-proven MEMS stateof-the art sensing element with a fully
integrated A/D converter and an
integrated ambient temperature sensor.
An internal clock and control unit enables
the TPiS 1S 1051 digital output detector to
open a dialog with any outside microprocessor without additional components.
The move from analogue to digital
enables the DigiPile to deliver a number of
ad-vantages like cost and space savings
from fewer components (no external low
offset / low noise amplifier is needed),
significantly reduced susceptibility against
environmental
influences
like
e.g.
humidity.
The TPiS 1S 1051 is offered in a smallsized 3.0x3.0 mm2 CLCC package with a
IR transmissive filter.
ADC Tobj
Decimator
Low Pass
ADC Tamb
Decimator
Low Pass
Voltage
Reference
Oscillator
Serial
Interface
TP
VDD
VSS
Digital
In/Out
Digital Output Sensor
17 Bit Tobj Output “direct link”
14 Bit Tamb Output “direct link”
Operating voltage down to
2.4V
Low current consumption
Small-sized SMD package
Applications
Non-contact temperature
measurements
Thermometry
Product
1
Technical Data
Parameter
Symbol
Min
Typ
Max
Unit
Remarks / Conditions
Specification
Operating Conditions
Operating Voltage
VDD
2.4
3.3
3.6
V
Supply Current
Operating Temperature
IDD
11
15
µA
VDD = 3.3 V
To
-20
70
°C
Ts
-40
100
°C
The electrical parameters may vary from
specified values accordance with their
temperature dependence.
Avoid storage in humid environment.
Storage Temperature
Thermopile Characteristics
Sensitive Area
Sensitivity of TP
Sensitivity of TP
Noise of TP
Time Constant
A
0.15
mm2
counts / T
210
280
8
15
counts/K
counts/K
counts
ms
Tobj = 40°C, Tamb = 25°C
counts / T
counts/K
counts
counts
Linear for Tamb from 0°C to 90°C
9400
16
+/- 10
Degree
Degree
Ambient Temperature sensor Characteristics
Sensitivity of Tamb
Count @ Tamb = 25°C
7000
Noise of ambient sensor
Optical Characteristics
Field of View
Optical Axis
Average Filter
Transmittance
Average Filter
Transmittance
Cut on Wavelength
Electrical Characteristics
ADC Resolution Tobj
ADC Resolution Tamb
ADC Sensitivity of Tobj
ADC Offset Tobj
Input Low Voltage
Input High Voltage
Pull Down Current
Pull Up / Down Current
LPF Cut-Off Frequency
2
90
8200
5
~120
TA
75
> 77
TA
λ (5 %)
VIL
VIH
5.2
5.5
0.7
64000
17
14
0.8
64500
0.8 VDD
200
130
8
Tobj = 100°C, Tamb = 25°C
Tamb = 298K (=25°C)
At 50% intensity points
Wavelength Range from 7.5 µm to 13.5 µm
< 0.5
Wavelength Range < 5 µm
5.8
µm
At 25°C
0.9
65000
0.2 VDD
Bits
Bits
µV/count
counts
V
V
µA
µA
Hz
Max Count = 217
Max Count = 214
Direct link pin to VDD
Direct link pin to VSS
Filter Characteristics
Figure 1
Typical filter
transmission curve
www.excelitas.com
TPiS 1S 1051 / 5028
2
Product
Figure 2
Typical FoV
Specification
3
Physical Configuration
Figure 3
Mechanical
dimensions
All dimensions are in
mm.
Housing: CLCC
package with infrared
transmissive filter
Top view
Bottom view
Side view
Figure 4
End view
Pin out.
Housing: CLCC
transmissive filter
Pin out top view
www.excelitas.com
Side view
Pin out bottom view
view
TPiS 1S 1051 / 5028
3
Product
3.1 Soldering
300
Specification
The detector TPiS 1S 1051 is a lead-free component and fully complies with the RoHS
regulations, especially with existing roadmaps of lead-free soldering. Reflow soldering is
recommended. A typical lead free reflow profile is shown in figure 4. Specific reflow soldering
parameters depend on the solder alloy used.
This device has a moisture sensitivity level of 1 (MSL 1). However, storage at high humidity
conditions should be avoided.
Figure 5
Typical lead free
solder profile
Peak Temperature
235 - 255 °C
250
Temperature [°C]
200
Reflow Zone
time above ~217 °C
typical 60 - 75 s
Soaking Zone
typical 60 - 90 s
150
100
很抱歉,暂时无法提供与“TPIS 1S 1051”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+76.955221000+9.33426
- 国内价格 香港价格
- 1+134.295081+16.28928
- 10+106.3357110+12.89796
- 25+100.7430025+12.21959
- 100+86.74920100+10.52222
- 500+81.15278500+9.84340
