ASNT1124-KMM
ASNT1124-KMM
    ADSANTEC(先进科技)
    CQFP44
    4:1 BROADB. DIG. DDR MULTIPLEXER
ASNT1124-KMM 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT1124-KMM DC-64Gbps Broadband Digital DDR 4:1 Multiplexer  Ideal for high speed proof-of-concept prototyping  Differential CML I/O data and clock buffers  Differential duty cycle adjustment control for input clock  SE amplitude adjustment control for output data  Half-rate clock input (DDR mode)  Quarter-rate clock output  Single +3.3V or -3.3V power supply  Power consumption: 1.18W  Fabricated in SiGe for high performance, yield, and reliability  Custom CQFP 44-pin package vcc vee vcc d1p vcc d1n vcc vcc ampadj vcc qp ASNT1124-KMM d2p vcc d2n vcc vcc qn vcc 1 cep vcc cen vcc vcc d3n vcc dccp vcc dccn vcc vcc vee vcc d3p Rev. 1.2.2 vee vcc Exhibits low jitter and limited temperature variation over industrial temperature range vcc c4op vcc  d0n vcc d0p vcc c4on High speed broadband 4:1 Multiplexer (MUX) vcc  May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION vcc 50 Ohm d0p d0n ampadj 50 Ohm vccо d1p d1n qp qn d2p d2n 50 Ohm d3p d3n 50 Ohm cep cen c4op c4on DIV 50 Ohm 50 Ohm dccp dccn vcc 1000 Ohm Fig. 1. Functional Block Diagram The ASNT1124-KMM SiGe IC is a low power and high-speed digital 4 to 1 serializer-multiplexer (MUX) that functions seamlessly over data rates (fbit) ranging from DC to its maximum frequency. The main function of the part shown in Fig. 1 is to multiplex 4 parallel differential CML data signals d0p/d0n, d1p/d1n, d2p/d2n, d3p/d3n running at a bit rate of fbit/4 into a high speed serial bit stream qp/qn running at a bit rate of fbit. Differential or single-ended half-rate clock cep/cen (DDR mode) must be provided by an external source for the part to function properly. The serialized data words qp/qn and the clock divided-by-4 signal c4op/c4on are transmitted through CML output interfaces. The clock and data outputs are phase-matched to each other resulting in very little relative skew over the operating temperature range of the device. The part’s I/O’s support the CML logic interface with on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination (see also POWER SUPPLY CONFIGURATION). In the DC-coupling mode, the input signal’s common mode voltage should comply with the specifications shown in ELECTRICAL CHARACTERISTICS. In the AC-coupling mode, the input termination provides the required common mode voltage automatically. The differential DC signaling mode is recommended for optimal performance. Rev. 1.2.2 2 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Output Amplitude Adjustment Port The output amplitude is controlled through a SE tuning port ampadj. The simulated dependence of the output amplitude vs. the control voltage is shown in Fig. 2. The ampadj control signal should not be set higher than the default value of vcc – 0.66V (see Electrical Characteristics table for allowable range.) Fig. 2. Simulated Output Amplitude vs. Control Voltage Diagram Input Clock Duty Cycle Adjustment Port In AC coupled mode of operation duty cycle of the input clock signal can be adjusted via a pair of DC analog tuning ports dccp and dccn. By lowering the voltage of one of the ports below vcc while keeping the other one at vcc or not connected the common mode voltage of the corresponding clock input can be lowered below vcc. If both control inputs are left not connected the common mode voltages of both clock inputs are at vcc. The dependence of either input clock common mode voltage on the control voltage is shown in Fig. 3. Fig. 3. Dependence of cep (or cen) Common Mode Voltage on dccp (or dccn) Voltage Rev. 1.2.2 3 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com POWER SUPPLY CONFIGURATION The part can operate with either negative supply (vcc = 0.0V = ground and vee = −3.3V), or positive supply (vcc = +3.3V and vee = 0.0V = ground). In case of the positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. All the characteristics detailed below assume vcc = 0.0V and vee = -3.3V. ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 1 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground. Table 1. Absolute Maximum Ratings Parameter Supply Voltage (vee) Power Consumption RF Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Rev. 1.2.2 Min -40 10 10 4 Max -3.6 1.3 1.4 +90 +100 98 98 Units V W V ºC ºC % % May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com TERMINAL FUNCTIONS TERMINAL Name No. Type d0p d0n d1p d1n d2p d2n d3p d3n c4op c4on ampadj dccp dccn cep cen qp qn Name vcc vee Rev. 1.2.2 DESCRIPTION Low-Speed I/Os 30 CML Differential quarter-rate data inputs with internal SE 50Ohm input termination to vcc 32 37 CML Differential quarter-rate data inputs with internal SE 50Ohm input termination to vcc 39 41 CML Differential quarter-rate data inputs with internal SE 50Ohm input termination to vcc 43 4 CML Differential quarter-rate data inputs with internal SE 50Ohm input termination to vcc 6 26 CML Differential quater-rate clock outputs with internal SE 50Ohm output termination to vcc. Require external SE 50Ohm termination to vcc 28 Analog DC Control Inputs 21 Analog SE tuning port terminated to internal resistive divider between vee input and vcc. 15 Analog Differential or SE tuning ports with internal SE connections to inputs dp/dn through 1000Ohm resistors. 13 High-Speed I/Os 8 CML Differential half-rate clock input signals with internal 50Ohm input termination to vcc 10 19 CML Differential full-rate data outputs with internal SE 50Ohm output termination to vcc. Require external SE 50Ohm termination to vcc 17 Supply and Termination Voltages Description Pin Number Positive power supply 1, 3, 5, 7, 9, 11, 12, 14, 16, 18, 20, 22, 23, 25, 27, 29, (+3.3V or 0) 31, 33, 34, 36, 38, 40, 42, 44 Negative power supply 2, 24, 35 (0V or -3.3V) 5 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER MIN TYP MAX UNIT COMMENTS General Parameters -3.1 -3.3 -3.5 V ±6% vee 0.0 V External ground vcc Ivee 358 mA Power consumption 1180 mW Junction temperature -40 25 125 °C LS Input Data (d0p/d0n, d1p/d1n, d2p/d2n, d3p/d3n) Data Rate DC 10 16 Gb/s Swing 0.2 0.8 V Differential or SE, p-p CM Voltage Level vcc-0.8 vcc V Must match for both inputs HS Input Clock (cep/cen) Frequency DC 20 32 GHz Swing 0.2 0.8 V Differential or SE, p-p CM Voltage Level vcc-0.8 vcc V Must match for both inputs Duty Cycle 40 50 60 % DC Tuning port (dccp/dccn) Control voltage range vee vcc DC Tuning port (ampadj) Control voltage range vcc-1.4 vcc-0.66 V Default voltage is vcc-0.66V HS Output Data (qp/qn) Data Rate DC 40 64 Gb/s Logic “1” level V vcc Logic “0” level vcc-0.4 V With external 50Ohm DC termination Output Jitter 2 ps Peak-to-peak at 40Gb/s LS Output Clock (c4op/c4on) Frequency DC 10 16 GHz Logic “1” level V vcc Logic “0” level vcc-0.4 V With external 50Ohm DC termination Duty Cycle 50 % Output Jitter 1 ps Peak-to-peak at 10GHz PACKAGE INFORMATION The chip die is housed in a custom 44-pin CQFP package shown in Fig. 4. The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. The part’s identification label is ASNT1124-KMM. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part Rev. 1.2.2 6 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. The IC complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. Fig. 4. CQFP 44-Pin Package Drawing (All Dimensions in mm) Rev. 1.2.2 7 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com REVISION HISTORY Revision 1.2.2 1.1.2 1.1.1 Date 05-2020 07-2019 07-2015 1.0.1 1.0.0 05-2015 09-2014 Rev. 1.2.2 Changes Updated Package Information Updated Letterhead Correction of the duty cycle control function description including: - block diagram - pinout diagram - part description - terminal functions Corrected power consumption and current consumption Modified maximum voltage value on DC tuning port ampadj First release Preliminary release 8 May 2020
ASNT1124-KMM 价格&库存
很抱歉,暂时无法提供与“ASNT1124-KMM”相匹配的价格&库存,您可以联系我们找货
