ASNT1011A-KMA
ASNT1011A-KMA
    ADSANTEC(先进科技)
    CQFP100
    16:1 BROADBAND DIG. MULTIPLEXER
ASNT1011A-KMA 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT1011A-KMA DC-to-17Gbps Digital Multiplexer 16:1 / Serializer  Broadband digital serializer 16 to 1 operating seamlessly from DC to 17Gbps  LVDS compliant input data buffers  Full-rate clock output  Clock divided-by-16 LVDS output buffer with 90°-step phase selection  Single +3.3V power supply  Industrial temperature range  Low power consumption of 660mW at 17Gbps  Custom 100-pin CQFP package (12mm x 12mm) Rev. 2.3.2 1 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION Fig. 1. Functional Block Diagram ASNT1011A-KMA is a low power and high-speed digital 16-to-1 multiplexer (MUX) / serializer IC. The IC shown in Fig. 1 functions seamlessly over data rates (fbit) ranging from DC to 17Gbps. The main function of the IC is to multiplex 16 parallel data channels running at a bit rate of fbit/16 into a high speed serial bit stream running at fbit. It provides a high-speed output data channel for point-to-point data transmission over a controlled impedance media of 50Ohm. The transmission media can be a printed circuit board or copper coaxial cables. The functional distance of the data transfer is dependent upon the attenuation characteristics of the transportation media and the degree of noise coupling to the signaling environment. During normal operation, the serializer’s low-speed input buffer (LS DIBx16) accepts external 16-bit wide parallel data words d00p/d00n-d15p/d15n through 16 differential LVDS inputs and delivers them to the multiplexer’s core (MUX16:1) for serialization. A full rate clock must be provided by an external source cep/cen to the high-speed clock input buffer (HS CIB) where it is routed to the high speed clock output buffer (HS COB) and the internal divider-by-16 (/16). The divider provides signaling for MUX16:1 and produces a full rate clock divided-by-16 “C16” for the low speed LVDS compliant clock output buffer (LVDS COB).The phase of clop/clon can be modified by 90° increments by utilizing pins phs1 and phs2 and the clock processing block (CLK Proc). Rev. 2.3.2 2 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com By utilizing pin bitorder, the serializer can designate either d00p/d00n or d15p/d15n as the MSB thus simplifying the interface between ASNT1011A-KMA and a proceeding ASIC. The serialized words are transmitted as 2-level signals qcmlp/qcmln by a differential CML output buffer (Data OB). A full-rate clock is transmitted by HS COB in parallel with the high-speed data. The clock and data outputs are well phase matched to each other resulting in very little relative skew over the operating temperature range of the device. Both output stages are back terminated with on-chip 50Ohm resistors. The serializer uses a single +3.3V power supply and is characterized for operation from −25°C to 125°C of junction temperature. LS DIBx16 The Low-Speed Data Input Buffer (LS DIBx16) consists of 16 proprietary universal input buffers (UIBs) that exceed the LVDS IEEE Std. 1596.3-1996 and ANSI/TIA/EIA-644-1995 standards. UIB is designed to accept differential signals with amplitudes above 60mV peak-to-peak (p-p), DC common mode voltage variation between the negative vee and positive vcc supply rails, and AC common mode noise with a frequency up to 5MHz and voltage levels ranging from 0 to 2.4V. It can also receive single-ended signals with amplitudes above 60mVp-p and threshold voltages between vee and vcc. The input termination impedance is set to 100Ohm differential. HS CIB The High-Speed Clock Input Buffer (HS CIB) can process an external CML clock signal cep/cen with frequencies from DC to 17GHz. It can also accept a single-ended signal to cep/cen with a threshold voltage applied to the unused cen/cep pin. HS CIB can handle input signal amplitudes between 200mV and 1.2V p-p differential or single-ended. The buffer utilizes on-chip single-ended termination of 50Ohm to vcc for each input line. /16 The Divider-by-16 (/16) includes 4 divide-by-2 circuits connected in series. The high-speed clock “C” is fed into the first divide-by-2 circuit that generates half rate clock “C2”. “C2” is routed internally to the next divideby-two circuit and outside of the block to MUX16:1. Other divided down clock signals are formed and routed to MUX16:1 in similar fashion. “C16” is passed on to LVDS COB to become the output low speed clock signal clop/clon. MUX16:1 The 16 to 1 Multiplexer (MUX16:1) utilizes a tree type architecture that latches the incoming data on the negative edge of the “C16” clock signal that is supplied by /16. The 16-bit wide data word is subsequently multiplexed and delivered to Data OB as a single serial data stream running at a data rate up to 17Gbps. The latency of this circuit block is equal to roughly one period of “C16”. The input MSB corresponds to d00p/d00n when bitorder = 0 (default), or to d15p/d15n when bitorder = 1. Data OB The Data Output Buffer (Data OB) receives high-speed serial data from MUX16:1 and converts it into the CML output signal qcmlp/qcmln with a single ended swing of 600mV. The buffer requires 50Ohm external termination resistors connected between vcc and each output to match its internal 50Ohm resistors and can operate at a data rate up to 17Gbps. Rev. 2.3.2 3 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com HS COB The High Speed Clock Output Buffer (HS COB) utilizes the same termination scheme as Data OB and can operate at a frequency up to 17GHz while producing a single-ended CML output swing of 600mV. The buffer can be enabled or disabled by the external 2-state control signal offcho. The logic “0” state provides a full-rate clock output signal while the logic “1” state disables the buffer completely to save power. CLK Proc By utilizing the CMOS control pins phs1 and phs2, the phase of clop/clon can be altered in accordance with Table 1. Table 1. Output Clock Phase Selection phs1 phs2 C16 phase vee (default) vee (default) 270° 180° vee vcc 90° vcc vee 0° vcc vcc LVDS COB The LVDS Clock Output Buffer (LVDS COB) receives “C16” and converts it into an LVDS output signal clop/clon. The proprietary low-power LVDS output buffer utilizes a special architecture that ensures operation at frequencies up to 2.0GHz with a low power consumption level of 30mW. The buffer satisfies all the requirements of the IEEE Std. 1596.3-1996 and ANSI/TIA/EIA-644-1995 standards. Output Timing The phase relation between the output data qcmlp/qcmln and the full rate output clock chop/chon is specified in Table 2 and illustrated by Fig. 2. Table 2. Output Data-to-Clock Phase Difference Junction temperature, τ,ps ºC Min. Max. -25 77 80 50 82 86 125 87 91 clk edge Output Data τ Tclk Fig. 2. Output Timing Diagram Rev. 2.3.2 4 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 3 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground (assumed vee). Table 3. Absolute Maximum Ratings Parameter Supply Voltage (vcc) Power Consumption RF Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Min Max +3.6 0.72 1.0 +90 +100 98 98 -40 10 10 Units V W V ºC ºC % % TERMINAL FUNCTIONS TERMINAL Name No. Type cep cen chop chon qcmlp qcmln Rev. 2.3.2 28 27 34 33 40 39 phs1 phs2 offcho 57 56 18 bitorder 59 DESCRIPTION High-Speed I/Os Input CML differential external clock inputs with internal SE 50Ohm termination to vcc Output CML differential clock outputs. Require external SE 50Ohm termination to vcc Output CML differential data outputs. Require external SE 50Ohm termination to vcc Controls LS In., Low-speed output clock phase selection (default: both low) CMOS LS In., HS COB control (active: high, buffer is disabled; default: low, CMOS full-rate output clock) LS IN., Input bit order selection (active: high, d15p/d15n is serialized CMOS first; default: low, d00p/d00n is serialized first) 5 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com TERMINAL Name No. Type clop clon d00p d00n d01p d01n d02p d02n d03p d03n d04p d04n d05p d05n d06p d06n d07p d07n d08p d08n d09p d09n d10p d10n d11p d11n d12p d12n d13p d13n d14p d14n d15p d15n Rev. 2.3.2 46 45 60 61 63 64 66 67 69 70 72 73 77 78 80 81 83 84 86 87 89 90 92 93 95 96 98 99 3 4 6 7 9 10 DESCRIPTION Low-Speed I/Os Output LVDS clock outputs. Can transmit four different clock phases as defined by phs1 and phs2 Input LVDS data inputs 6 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Name vcc vee NC Supply and Termination Voltages Description Pin Number Positive power supply 5, 8, 11, 14, 24, 25, 26, 29, 32, 35, 38, 41, 44, 47, 52, (+3.3V) 55, 62, 65, 68, 71, 76, 79, 82, 85, 88, 91, 94, 97, 100 Negative power supply 1, 15, 16, 17, 23, 30, 36, 37, 50, 51, 58, 75 (GND or 0V) Unconnected pin 2, 12, 13, 19, 20, 21, 22, 31, 42, 43, 48, 49, 53, 54, 74 ELECTRICAL CHARACTERISTICS PARAMETER vcc vee Power consumption Junction temperature Data Rate Differential Swing CM Voltage Level Frequency Swing (Diff or SE) CM Voltage Level Duty Cycle Data Rate Logic “1” level Logic “0” level Jitter Frequency Logic “1” level Logic “0” level Jitter Duty Cycle Frequency Interface Logic “1” level Logic “0” level Rev. 2.3.2 MIN TYP MAX UNIT COMMENTS General Parameters +3.14 +3.3 +3.47 V ±5% 0.0 V 660 mW -25 50 125 °C LS Input Data (d00p/d00n-d15p/d15n) 0.0 1063 Mbps 0.06 0.8 V Peak-to-peak V vee vcc HS Input Clock (cep/cen) 0.0 17 GHz 0.2 1.2 V Peak-to-peak vcc -0.8 vcc V 40% 50% 60% HS Output Data (qcmlp/qcmln) 0.0 17 Gbps V vcc vcc -0.6 V 12 ps Peak-to-peak @12.5Gb/s HS Output Clock (chop/chon) 0.0 17 GHz V vcc vcc -0.6 V 6 ps Peak-to-peak @12.5GHz 50% LS Output Clock (clop/clon) 0.0 1063 MHz LVDS Meets the IEEE Std. CMOS Control Inputs vcc -0.4 V vee +0.4 V 7 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com PACKAGE INFORMATION Fig. 3. Package Drawing Rev. 2.3.2 8 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com The chip die is housed in a custom 100-pin CQFP package. The dimensioned drawings are shown in Fig. 3. The package’s leads will be trimmed to a length of 1.0mm. After trimming, the package’s leads will be further processed as follows: 1. The lead’s gold plating will be removed per the following sections of J-STD-001D: 3.9.1 Solderability 3.2.2 Solder Purity Maintenance 3.9.2 Solderability Maintenance 3.9.3 Gold Removal 2. The leads will be tinned with Sn63Pb37 solder The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is power for a positive supply. The part’s identification label is ASNT1011A-KMA. The first 9 digits of the name before the underscore identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 digits after the underscore represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. REVISION HISTORY Revision 2.3.2 2.2.2 2.2.1 Date 01-2020 07-2019 05-2015 2.1 02-2012 2.0 01-2012 1.0 01-2011 Rev. 2.3.2 Changes Updated Package Information Letterhead Updated Corrected Absolute Maximum Ratings section Revised Package Information section Updated format Revised Description section Revised Package Information section Revised Electrical Characteristics section Revised Package Information section Added Absolute Maximums Rating table Added Pin Diagram First release 9 January 2020
ASNT1011A-KMA 价格&库存
很抱歉,暂时无法提供与“ASNT1011A-KMA”相匹配的价格&库存,您可以联系我们找货
