Datasheet
CA1558
Single and Dual, High Gain Operational Amplifiers
for Military, Industrial, and Commercial Applications
The CA1458, CA1558 (dual types); CA741C, CA741 (single types); high-gain operational
amplifiers lor use in military, industrial, and commercial applications.
These monolithic silicon integrated circuit devices provide output short circuit protection and
latch-free operation. These types also feature wide common mode and differential mode signal
ranges and have low offset voltage nulling capability when used with an approprialely valued
potentiometer. A 10kΩ potentiometer is used for offset nulling types CA741C, CA741. Types
CA1458, CA1558 have no specific terminals for offset nulling. Each type consists of a differential
input amplifier that effectively drives a gain and level shifting stage having a complementary emitter
follower output.
Rochester Electronics
Manufactured Components
Rochester branded components are
manufactured using either die/wafers
purchased from the original suppliers
or Rochester wafers recreated from the
original IP. All re-creations are done with
the approval of the Original Component
Manufacturer (OCM).
Parts are tested using original factory
test programs or Rochester developed
test solutions to guarantee product
meets or exceeds the OCM data sheet.
Quality Overview
• ISO-9001
• AS9120 certification
• Qualified Manufacturers List (QML) MIL-PRF-35835
• Class Q Military
• Class V Space Level
• Qualified Suppliers List of Distributors (QSLD)
• Rochester is a critical supplier to DLA and
meets all industry and DLA standards.
Rochester Electronics, LLC is committed to supplying
products that satisfy customer expectations for
quality and are equal to those originally supplied by
industry manufacturers.
The original manufacturer’s datasheet accompanying this document reflects the performance
and specifications of the Rochester manufactured version of this device. Rochester Electronics
guarantees the performance of its semiconductor products to the original OCM specifications.
‘Typical’ values are for reference purposes only. Certain minimum or maximum ratings may be
based on product characterization, design, simulation, or sample testing.
FOR REFERENCE ONLY
© 2019 Rochester Electronics, LLC. All Rights Reserved 04112019
To learn more, please visit www.rocelec.com
HARRIS
SEMICONDUCTOR
CA741, CA741C, CA1458,
CA1558, LM741, LM741C, LM1458
Single and Dual, High Gain Operational Amplif iers
for Military, Industrial and Commercial Applications
November 1996
Description
Features
Input Blas Current ••••••••••••••••••• S00nA (Max)
Input Offset Current.................. 200nA (Max)
Applications
Com parator
Multlvibrator
DC Amplifier
Summing Amplifier
Integrator or Differentiator
Narrow Band or Band
Pass Filter
Ordering In formation
PART
NUMBER
T EMP.RANGE
('C)
PACKAGE
PKG. NO.
-55 to 125
8 Ld PDIP
E8.3
CA0741CE
Oto 70
8 Ld PDIP
EB.3
CA1458E
Oto 70
8 Ld PDIP
E8.3
CA1558E
-55 to 125
8 Ld PDIP
EB.3
CA0741T
-55 lo 125
8 Pin Metal Can
T8_C
CA0741CT
Oto 70
8 Pin Metal Can
TB.C
CA1458T
Oto 70
8 Pin Metal Can
T8_C
T8.C
CA0741E
CA1558T
-55 to 125
8 Pin Metal Can
LM741 N
-55 lo 125
8 Ld PDIP
E8_3
0 to 70
8 Ld PDIP
E8_3
LM741CN
-55 to 125
8 Pin Metal Can
TB_C
LM741CH
Oto 70
8 Pin Metal Can
T8_C
LM1458N
Oto 70
8 Ld PDIP
E8.3
LM741 H
Pinouts
types); high-gain operational amplifiers lor use in military,
output short circuit protection and latch-free operation.
differential mode signal ranges and l1ave low offset voltage
potentiometer. A 1 Ok!l potentiometer is used for offset
nulling types CA741 C, CA741 (see Figure 1). Types
nulling. Each type consists of a differential input amplifier
a complementary emitter follower output.
The manufacturing process make it possible to produce IC
operational amplifiers with low burst ·popcorn" noise
characteristics. The CA741 gives limit specifications for burst
noise in the data bulletin, File Number 530. Contact your
Sales Representative for information pertinent to other oper
ational amplifier types that meet low burst noise
specifications.
Technical Data on LM Branded types is identical to the corre
sponding CA Branded types.
CA1458, CA1558 (METAL CAN)
TOP VIEW
CA741, CA741 C, LM741, LM741 C (CAN)
TOP VIEW
y.
CA1458, CA1558, LM1458 (PDIP)
TOP VIEW
CA741, CA741C, LM741, LM741 C (PDIP)
TOP VIEW
INV. INPUT (A) 2
NON-INV. INPUT (A)
3
CAUTION: These devices are sensitive to electrostatic discharge. Users should follow proper IC Handling Procedures.
Copyright © Harris Corporation 1996
3-29
7 OUTPUT (B)
6
INV. INPUT (B)
5
NON-INV. INPUT (B)
File Number 531 .3
很抱歉,暂时无法提供与“CA1458E”相匹配的价格&库存,您可以联系我们找货
