TMR2104P
TMR2104P
    MDT(多维)
    SOP8_150MIL
    TMR SENSOR MAG FIELD 3MV/V/OE
TMR2104P 数据手册
Datasheet V1.0a TMR2104 Large Dynamic Range TMR linear sensor General Description The TMR2104 linear sensor utilizes a unique push-pull Wheatstone bridge composed of four unshielded TMR sensor elements. The unique bridge design provides a high sensitivity differential output that is linearly proportional to a magnetic field applied parallel to the surface of the sensor package, and it provides superior temperature compensation of the output. The TMR2104 is available in 6 mm X 5 mm X 1.5 mm SOP8 and 3mm×3mm×0.75mm DFN8L package. Features and Benefits  Tunneling Magneto resistance (TMR) Technology  High Sensitivity  Large Dynamic Range  Low Power Consumption  Excellent Thermal Stability Applications  Magnetic Field Sensing  Current Sensors  Displacement Sensing  Rotary Position Sensors TMR2104 Transfer Curve The following figure shows the response of the TMR2104 to an applied magnetic field in the range of ±80 Oe (left) and ±200 Oe (right) when the TMR2104 is biased at 1 V. 1/5 Datasheet V1.0a Pin Configuration (Arrow indicates direction of applied field that generates a positive output voltage.) Pin No. Pin Name Pin Function 1,2,7,8 N/A Not Connected 3 GND Ground 4 V- Analog Differential Output 2 5 V+ Analog Differential Output 1 6 Vcc Supply Voltage Absolute Maximum Ratings Parameter Symbol Limit Unit Supply Voltage VCC 7 V Reverse Supply Voltage VRCC 7 V Max Exposed Field HE 4000 Oe ESD Voltage VESD 4000 V Operating Temperature TA -40~125 °C Storage Temperature Tstg -50 ~150 °C (1) Specification (VCC=1.0V, TA=25°C, Differential Output) Parameter Symbol Conditions Supply Voltage VCC Operating Supply Current ICC Min Output Open Typ Max Unit 1 7 V 33 (2) μA 30 (2) KOhm Resistance(SOP8) R Sensitivity SEN Saturation Field Hsat Non-Linearity NONL Offset Voltage Voffset Hysteresis Hys Fit @±80Oe 0.5 Oe Temperature Coefficient of Resistance TCR H = 0 Oe -600 PPM/°C Temperature Coefficient of Sensitive TCS -300 PPM/°C Fit @±80Oe Fit @±80Oe 3.1 mV/V/Oe ±150 Oe 1.5 %FS -8 Notes: (1) 1 Oe (Oersted) = 1 Gauss in air = 0.1 millitesla = 79.8 A/m. (2) Custom resistance may be available upon request. 2/5 8 mV/V Datasheet V1.0a Package Information SOP8 DFN8 3/5 Datasheet V1.0a TMR Sensor Position Top view and side view(unit: mm) MultiDimension Technology Co., Ltd. Address:No.7 Guangdong Road, Zhangjiagang Free Trade Zone, Jiangsu, 215634, China Web: www.dowaytech.com/en Email: info@dowaytech.com The information provided herein by MultiDimension Technology Co., Ltd. (hereinafter MultiDimension) is believed to be accurate and reliable. Publication neither conveys nor implies any license under patent or other industrial or intellectual property rights. MultiDimension reserves the right to make changes to product specifications for the purpose of improving product quality, reliability, and functionality. MultiDimension does not assume any liability arising out of the application and use of its products. MultiDimension’s customers using or selling this product for use in appliances, devices, or systems where malfunction can reasonably be expected to result in personal injury do so at their own risk and agree to fully indemnify MultiDimension for any damages resulting from such applications. 4/5 Datasheet V1.0a 5/5
TMR2104P 价格&库存
很抱歉,暂时无法提供与“TMR2104P”相匹配的价格&库存,您可以联系我们找货
