Product data sheet
MZT7-03VPO-KP0
MZT7
SENSORS FOR T-SLOT CYLINDERS
MZT7-03VPO-KP0 | MZT7
A
B
C
D
E
F
Ordering information
Type
Part no.
MZT7-03VPO-KP0
1070818
Other models and accessories
www.sick.com/MZT7
Detailed technical data
Features
H
I
J
K
L
M
N
O
P
Q
R
S
T
Cylinder type
T-slot
Cylinder types with adapter
Profile cylinder
Tie rod cylinder
Round body cylinder
Dovetail groove cylinder
SMC rail CDQ2
SMC rail ECDQ2
Housing length
29.5 mm
Switching output
PNP
Switching frequency
1,000 Hz
Output function
NC
Electrical wiring
DC 3-wire
Enclosure rating
IP65 1)
IP67
1)
According to EN 60529.
Mechanics/electronics
Supply voltage
10 V DC ... 30 V DC
Power consumption
8 mA 1)
Voltage drop
≤ 2 V
Continuous current Ia
≤ 100 mA
Protection class
III
Response sensitivity, typ.
3 mT
Overrun distance, typ.
10 mm
Hysteresis, typ.
3 x cable diameter
For flexible use > 10 x cable diameter
Torsion force ± 270° / 10 cm
Torsion cycles > 2,000,000
Drag chain cycles > 2,000,000
Drag chain parameters Traversing speed max. 3.3 m/s at 5 m horizontal traversing length
Acceleration max. 5 m/s²
Cable outlet Axial
Material
Housing Plastic
Cable PUR
UL File No.
1)
2)
NRKH.E181493 & NRKH7.E181493
Without load.
Ub and Ta constant.
Safety-related parameters
MTTFD
1,300 years
DCavg
0 %
TM (mission time)
20 years
Classifications
ECl@ss 5.0
27270104
ECl@ss 5.1.4
27270104
ECl@ss 6.0
27270104
ECl@ss 6.2
27270104
ECl@ss 7.0
27270104
ECl@ss 8.0
27270104
ECl@ss 8.1
27270104
ECl@ss 9.0
27270104
ECl@ss 10.0
27270104
ECl@ss 11.0
27270104
ETIM 5.0
EC002544
ETIM 6.0
EC002544
ETIM 7.0
EC002544
ETIM 8.0
EC002544
2021-11-27 09:07:27 | Product data sheet
Subject
to change without notice
MAGNETIC CYLINDER SENSORS | SICK
3
A
B
C
D
E
F
UNSPSC 16.0901
39122230
Installation note
Tighten screw
Insert sensor
Torque
typical 0.7 Nm
LED
AF 2.5
= Position sensor element
Connection diagram
Cd-004
H
I
J
K
L
M
N
O
P
Q
R
S
T
BN
1
BK 4
BU
4
3
+ (L+)
NC
- (M)
Product data sheet | 2021-11-27 09:07:27
Subject to change without notice
Dimensional drawing (Dimensions in mm (inch))
Cable with connector M8
2
0.3
5.7 (0.22)
4.4
(0.17)
4.1
(0.11)
(0.16)
2.7
2.8 (0.11)
5.8 (0.23)
3.9 (0.15)
(0.01)
3
4.8
(0.19)
23 45
0.7 (0.03)
0.4 (0.02)
11.6 (0.46)
16.9 (0.67)
29.5 (1.16)
1
L
M8 x 1
Pin 4
Pin 1
29 ... 37 (1.14 ... 1.46)
Pin 3
① Connection
② Position sensor element
③ Display LED
④ Fixing screw SW 2.5
⑤ Retaining ribs
Part no.
Type
L
Number of cores
1104369
MZT7-03VPS-KPD
250 mm
3
1070814
MZT7-03VPS-KP0
300 mm
3
1070818
MZT7-03VPO-KP0
300 mm
3
1070819
MZT7-03VNS-KP0
300 mm
3
1070820
MZT7-03VNO-KP0
300 mm
3
Recommended accessories
www.sick.com/MZT7
Brief description
Type
Part no.
Mounting bracket for cylinder with dovetail slot, Aluminum, without mounting hardware
BEF-KHZ-ST1
2022703
Mounting bracket for integrated profile cylinder/tie-rod cylinder, zinc diecast, mounting
hardware included
BEF-KHZ-PT1
2022702
Brackets for cylinder sensors
Subject
5
A
B
C
D
E
F
H
I
J
K
L
M
N
O
P
Q
R
S
T
Brief description
Type
Part no.
1 piece, Mounting bracket on round body cylinder with piston diameter of 12 mm, ambient temperature min 0 °C max 50 °C, plastic, Aluminum
BEF-KHZ-RT-12
2077681
1 piece, Mounting bracket on round body cylinder with piston diameter of 16 mm, ambient temperature min 0 °C max 50 °C, plastic, Aluminum
BEF-KHZ-RT-16
2077680
1 piece, Mounting bracket on round body cylinder with piston diameter of 20 mm, ambient temperature min 0 °C max 50 °C, plastic, Aluminum
BEF-KHZ-RT-20
2077679
1 piece, Mounting bracket on round body cylinder with piston diameter of 25 mm, ambient temperature min 0 °C max 50 °C, plastic, Aluminum
BEF-KHZ-RT-25
2077678
1 piece, Mounting bracket on round body cylinder with piston diameter of 32 mm, ambient temperature min 0 °C max 50 °C, plastic, Aluminum
BEF-KHZ-RT-32
2077677
1 piece, Mounting bracket on round body cylinder with piston diameter of 40 mm, ambient temperature min 0 °C max 50 °C, plastic, Aluminum
BEF-KHZ-RT-40
2077676
1 piece, Mounting bracket on round body cylinder with piston diameter of 50 mm, ambient temperature min 0 °C max 50 °C, plastic, Aluminum
BEF-KHZ-RT-50
2077675
1 piece, Mounting bracket on round body cylinder with piston diameter of 63 mm, ambient temperature min 0 °C max 50 °C, plastic, Aluminum
BEF-KHZ-RT-63
2077674
1 piece, Mounting bracket on round body cylinder with piston diameter of 8 mm ...
130 mm, ambient temperature min –30 °C max 80 °C, stainless steel, Zinc cast
BEF-KHZ-RT1-130
2077684
25 mm, ambient temperature min –30 °C max 80 °C, stainless steel, Zinc cast
BEF-KHZ-RT1-25
2077682
63 mm, ambient temperature min –30 °C max 80 °C, stainless steel, Zinc cast
BEF-KHZ-RT1-63
2077683
Mounting bracket for mounting on SMC rails CDQ2 (T-slot), Aluminum, without mounting
hardware
BEF-KHZ-TT2
2046440
Mounting bracket for mounting on SMC rails ECDQ2 (T-slot), Aluminum, without mounting hardware
BEF-KHZ-TT1
2046439
BEF-SG-MRZT
2077201
Head A: female connector, M8, 3-pin, straight, A-coded
Head B: Flying leads
Cable: Sensor/actuator cable, PUR, halogen-free, unshielded, 2 m
YF8U13020UA1XLEAX
2094782
Cable: Sensor/actuator cable, PVC, unshielded, 2 m
YF8U13020VA1XLEAX
2095860
Cable: Sensor/actuator cable, PUR, halogen-free, unshielded, 3 m
YF8U13030UA1XLEAX
2094787
Cable: Sensor/actuator cable, PUR, halogen-free, unshielded, 5 m
YF8U13050UA1XLEAX
2094788
Cable: Sensor/actuator cable, PVC, unshielded, 5 m
YF8U13050VA1XLEAX
2095884
Head A: female connector, M8, 3-pin, angled, A-coded
YG8U13020UA1XLEAX
2094794
Device protection (mechanical)
Protective adapter, die-cast zinc, mounting hardware included
Plug connectors and cables
6
Brief description
Type
Part no.
YG8U13020VA1XLEAX
2096165
YG8U13050VA1XLEAX
2096166
Head B: Cable: unshielded
DOS-0803-G
7902077
DOS-0803-W
7902078
Head A: male connector, M8, 3-pin, straight
STE-0803-G
6037322
Subject
7
Online data sheet
SICK at a glance
SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely
and efficiently, protecting individuals from accidents and preventing damage to the environment.
We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in
Europe, Asia and North America, system solutions are tested and optimized in accordance with customer
specifications. All this makes us a reliable supplier and development partner.
Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity.
For us, that is “Sensor Intelligence.”
Worldwide presence:
Contacts and other locations – www.sick.com
SICK AG | Waldkirch | Germany | www.sick.com
