74HC273; 74HCT273
Octal D-type flip-flop with reset; positive-edge trigger
Rev. 7 — 6 September 2021
Product data sheet
1. General description
The 74HC273; 74HCT273 is an octal positive-edge triggered D-type flip-flop. The device
features clock (CP) and master reset (MR) inputs. The outputs Qn will assume the state of their
corresponding Dn inputs that meet the set-up and hold time requirements on the LOW-to-HIGH
clock (CP) transition. A LOW on MR forces the outputs LOW independently of clock and data
inputs. Inputs include clamp diodes. This enables the use of current limiting resistors to interface
inputs to voltages in excess of VCC.
2. Features and benefits
Wide supply voltage range from 2.0 V to 6.0 V
CMOS low power dissipation
High noise immunity
Latch-up performance exceeds 100 mA per JESD 78 Class II Level B
Complies with JEDEC standards:
• JESD8C (2.7 V to 3.6 V)
• JESD7A (2.0 V to 6.0 V)
Input levels:
• For 74HC273: CMOS level
• For 74HCT273: TTL level
Common clock and master reset
Eight positive edge-triggered D-type flip-flops
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from -40 °C to +85 °C and from -40 °C to +125 °C
3. Ordering information
Table 1. Ordering information
Type number Package
74HC273D
Temperature range Name
Description
Version
-40 °C to +125 °C
SO20
plastic small outline package; 20 leads; body width 7.5 mm SOT163-1
-40 °C to +125 °C
TSSOP20
plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
-40 °C to +125 °C
DHVQFN20 plastic dual in-line compatible thermal enhanced
very thin quad flat package; no leads; 20 terminals;
body 2.5 × 4.5 × 0.85 mm
74HCT273D
74HC273PW
74HCT273PW
74HC273BQ
74HCT273BQ
SOT360-1
SOT764-1
74HC273; 74HCT273
Nexperia
4. Functional diagram
CP
MR
11
3
4
7
8
13
14
17
18
1
11
D0
D1
D2
D3
D4
D5
D6
D7
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
FF1
TO
FF8
2
5
6
9
12
15
16
19
3
4
7
8
13
14
17
MR
18
CP
CP
D0
Q0
D1
Q1
D2
Q2
D3
Q3
D4
Q4
D5
Q5
D6
Q6
D7
MR
1
001aae055
Fig. 1.
Functional diagram
Q7
Fig. 2.
5
D1
6
D2
9
D3
12
D4
15
D5
16
D6
19
D7
D1
Q
Fig. 3.
Q
R
2
1D
4
5
7
6
8
9
13
12
14
15
17
16
18
19
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
IEC logic symbol
D3
D
CP
FF2
RD
3
C1
mna764
D2
D
CP
FF1
1
mna763
Logic symbol
D0
D
D0
2
11
Q
D
CP
FF3
RD
Q
CP
FF4
RD
RD
CP
MR
Q0
D4
Q1
D5
D
Q
D
CP
FF5
Q
Q4
Q
D
CP
FF7
RD
Q3
D7
D
CP
FF6
RD
Q2
D6
RD
Q5
Q
CP
FF8
RD
Q6
Q7
001aae056
Fig. 4.
Logic diagram
74HC_HCT273
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 17
74HC273; 74HCT273
Nexperia
5. Pinning information
5.1. Pinning
1
MR
terminal 1
index area
1
Q0
2
20 VCC
19 Q7
D0
3
18 D7
D1
4
17 D6
Q1
5
16 Q6
Q2
6
15 Q5
D2
7
14 D5
D3
8
13 D4
Q3
9
12 Q4
GND 10
11 CP
19 Q7
D0
3
18 D7
D1
4
17 D6
Q1
5
16 Q6
Q2
6
15 Q5
D2
7
D3
8
Q3
9
GND (1)
14 D5
13 D4
12 Q4
001aae054
Transparent top view
(1) This is not a ground pin. There is no electrical or
mechanical requirement to solder the pad. In case
soldered, the solder land should remain floating or
connected to GND.
001aae053
Fig. 5.
2
CP 11
MR
Q0
GND 10
74HC273
74HCT273
20 VCC
74HC273
74HCT273
Pin configuration SOT163-1 (SO20)
and SOT360-1 (TSSOP20)
Fig. 6.
Pin configuration SOT764-1 (DHVQFN20)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
MR
1
master reset input (active LOW)
Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7
2, 5, 6, 9, 12, 15, 16, 19
flip-flop output
D0, D1, D2, D3, D4, D5, D6, D7
3, 4, 7, 8, 13, 14, 17, 18
data input
GND
10
ground (0 V)
CP
11
clock input (LOW-to-HIGH, edge-triggered)
VCC
supply voltage
74HC_HCT273
Product data sheet
3 / 17
74HC273; 74HCT273
Nexperia
6. Functional description
Table 3. Function table
H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition;
L = LOW voltage level; l = LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition;
X = don’t care; ↑ = LOW-to-HIGH clock transition.
Operating modes
Outputs
Inputs
MR
CP
Dn
Qn
reset (clear)
L
X
X
L
load "1"
H
h
H
load "0"
H
l
L
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V)
Symbol
Parameter
Min
Max
VCC
supply voltage
-0.5
+7
V
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
[1]
±20
mA
[1]
±20
mA
IO
output current
-0.5 V < VO < VCC + 0.5 V
±25
mA
ICC
supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
[2]
Conditions
Tamb = -40 °C to +125 °C
[2]
Unit
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SOT163-1 (SO20) package: Ptot derates linearly with 12.3 mW/K above 109 °C.
For SOT360-1 (TSSOP20) package: Ptot derates linearly with 10.0 mW/K above 100 °C.
For SOT764-1 (DHVQFN20) package: Ptot derates linearly with 12.9 mW/K above 111 °C.
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
74HC_HCT273
Product data sheet
Conditions
74HC273
74HCT273
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
VCC
V
VCC
VCC
V
-40
+125
-40
+125
°C
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
4 / 17
74HC273; 74HCT273
Nexperia
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C -40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
VCC = 4.5 V
3.15
2.4
1.5
3.15
1.5
V
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
74HC273
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
VI = VIH or VIL
VI = VIH or VIL
II
input leakage
current
VI = VCC or GND; VCC = 6.0 V
±0.1
±1
±1
μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
80
160
μA
CI
input
capacitance
3.5
pF
74HC_HCT273
Product data sheet
5 / 17
74HC273; 74HCT273
Nexperia
Symbol Parameter
Conditions
25 °C
Min
Typ
Max
Min
Max
Min
Max
74HCT273
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = -20 μA
4.4
4.5
4.4
4.4
V
IO = -4.0 mA
3.98
4.32
3.84
3.7
V
0.1
0.1
V
IO = 5.2 mA; VCC = 5.5 V
LOW-level
output voltage
0.15
0.26
0.33
0.4
V
II
input leakage
current
VI = VCC or GND; VCC = 5.5 V
±0.1
±1
±1
μA
ICC
supply current
VCC = 5.5 V
8.0
80
160
μA
ΔICC
additional
supply current
per input pin;
VI = VCC - 2.1 V;
other inputs at VCC or GND;
MR input
100
360
450
490
μA
CP input
175
630
787.5
857.5
μA
Dn input
15
54
67.5
73.5
μA
3.5
pF
VOL
CI
input
capacitance
10. Dynamic characteristics
Table 7. Dynamic characteristics
GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Fig. 10
Symbol Parameter
Conditions
25 °C
Min
Typ Max
Min
Max
Min
Max
74HC273
tpd
tPHL
propagation
delay
HIGH to LOW
propagation
delay
74HC_HCT273
Product data sheet
CP to Qn; see Fig. 7
[1]
VCC = 2.0 V
41
150
185
225
ns
VCC = 4.5 V
15
30
37
45
ns
VCC = 5.0 V; CL = 15 pF
15
ns
VCC = 6.0 V
13
26
31
38
ns
VCC = 2.0 V
44
150
185
225
ns
VCC = 4.5 V
16
30
37
45
ns
15
ns
VCC = 6.0 V
14
26
31
38
ns
MR to Qn; see Fig. 8
6 / 17
74HC273; 74HCT273
Nexperia
Symbol Parameter
Conditions
25 °C
Min
tt
tW
transition time
pulse width
Qn output; see Fig. 7
Typ Max
Min
Max
Min
Max
[2]
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
6
13
15
19
ns
VCC = 2.0 V
80
14
100
120
ns
VCC = 4.5 V
16
5
ns
VCC = 6.0 V
14
4
17
ns
VCC = 2.0 V
60
17
75
90
ns
VCC = 4.5 V
12
6
15
18
ns
VCC = 6.0 V
10
5
13
15
ns
VCC = 2.0 V
50
-6
65
75
ns
VCC = 4.5 V
10
-2
13
15
ns
VCC = 6.0 V
9
-2
11
13
ns
VCC = 2.0 V
60
11
75
90
ns
VCC = 4.5 V
12
4
15
18
ns
VCC = 6.0 V
10
3
13
15
ns
VCC = 2.0 V
3
-6
3
3
ns
VCC = 4.5 V
3
-2
3
3
ns
VCC = 6.0 V
3
-2
3
3
ns
VCC = 2.0 V
6
20.6
4.8
4
MHz
VCC = 4.5 V
30
103
24
MHz
66
MHz
35
122
28
24
MHz
pF
CP input HIGH or LOW;
see Fig. 7
MR input LOW; see Fig. 8
trec
tsu
th
fmax
recovery time
set-up time
hold time
maximum
frequency
MR to CP; see Fig. 8
Dn to CP; see Fig. 9
CP input; see Fig. 7
VCC = 6.0 V
CPD
power
dissipation
capacitance
74HC_HCT273
Product data sheet
per package;
VI = GND to VCC
[3]
7 / 17
74HC273; 74HCT273
Nexperia
Symbol Parameter
Conditions
25 °C
Min
Typ Max
Min
Max
Min
Max
74HCT273
tpd
propagation
delay
tPHL
tt
[1]
VCC = 4.5 V
16
30
38
45
ns
15
ns
23
34
43
51
ns
ns
7
15
19
22
ns
16
9
ns
16
8
ns
10
-2
13
15
ns
12
5
15
18
ns
3
-4
3
3
ns
30
56
24
MHz
36
MHz
23
pF
HIGH to LOW
propagation
delay
transition time
VCC = 4.5 V
[2]
VCC = 4.5 V
tW
pulse width
VCC = 4.5 V
VCC = 4.5 V
trec
recovery time
VCC = 4.5 V
tsu
set-up time
th
hold time
VCC = 4.5 V
VCC = 4.5 V
fmax
maximum
frequency
power
dissipation
capacitance
per package;
VI = GND to VCC - 1.5 V
VCC = 4.5 V
CPD
[1]
[2]
[3]
[3]
tpd is the same as tPHL and tPLH.
tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi + Σ (CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
2
Σ (CL x VCC x fo) = sum of outputs;
CL = output load capacitance in pF;
VCC = supply voltage in V.
74HC_HCT273
Product data sheet
8 / 17
74HC273; 74HCT273
Nexperia
10.1. Waveforms and test circuit
1/fmax
VI
CP input
VM
VM
GND
tW
tW
t PHL
VOH
Qn output
VOL
90%
t PLH
VM
10%
tTHL
tTLH
001aae062
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 7.
Propagation delay clock input (CP) to output (Qn), clock (CP) pulse width, output transition time and the
maximum clock pulse frequency
VI
VM
MR input
GND
tW
trec
VI
CP input
VM
GND
tPHL
VOH
VM
Qn output
VOL
mna464
Fig. 8.
Propagation delay master reset (MR) to output (Qn), pulse width master reset (MR) and recovery time
master reset (MR) to clock (CP)
74HC_HCT273
Product data sheet
9 / 17
74HC273; 74HCT273
Nexperia
VI
VM
CP input
GND
t su
t su
th
th
VI
VM
Dn input
GND
VOH
VM
Qn output
VOL
mna767
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig. 9.
Data set-up and hold times data input (Dn)
Table 8. Measurement points
Type
Input
Output
VI
VM
VM
74HC273
VCC
0.5VCC
0.5VCC
74HCT273
3V
1.3 V
1.3 V
74HC_HCT273
Product data sheet
10 / 17
74HC273; 74HCT273
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
VCC
VO
DUT
RT
RL
S1
open
CL
001aad983
Test data is given in Table 9.
Definitions for test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig. 10. Test circuit for measuring switching times
Table 9. Test data
Type
Input
S1 position
Load
VI
tr, tf
CL
RL
tPHL, tPLH
74HC273
VCC
6 ns
15 pF, 50 pF
1 kΩ
open
74HCT273
3V
6 ns
15 pF, 50 pF
1 kΩ
open
74HC_HCT273
Product data sheet
11 / 17
74HC273; 74HCT273
Nexperia
11. Package outline
SO20: plastic small outline package; 20 leads; body width 7.5 mm
SOT163-1
D
E
A
X
c
y
HE
v M A
Z
Q
A2
A
(A 3 )
A1
pin 1 index
θ
Lp
L
1
10
e
bp
detail X
w M
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
mm
2.65
0.3
0.1
2.45
2.25
0.25
0.49
0.36
0.32
0.23
13.0
12.6
7.6
7.4
1.27
10.65
10.00
1.4
1.1
0.4
1.1
1.0
0.25
0.25
0.1
0.9
0.4
inches
0.1
0.012 0.096
0.004 0.089
0.01
0.019 0.013
0.014 0.009
0.51
0.49
0.30
0.29
0.05
0.419
0.043
0.055
0.394
0.016
0.043
0.039
0.01
0.01
0.004
0.035
0.016
Z
(1)
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT163-1
075E04
MS-013
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 11. Package outline SOT163-1 (SO20)
74HC_HCT273
Product data sheet
12 / 17
74HC273; 74HCT273
Nexperia
TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm
D
SOT360-1
E
A
X
c
HE
y
v M A
Z
11
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
10
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
6.6
6.4
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT360-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig. 12. Package outline SOT360-1 (TSSOP20)
74HC_HCT273
Product data sheet
13 / 17
74HC273; 74HCT273
Nexperia
DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
20 terminals; body 2.5 x 4.5 x 0.85 mm
B
D
SOT764-1
A
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
e1
C
e
b
2
9
v
w
C A B
C
y1 C
y
L
1
10
Eh
e
19
12
X
Dh
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
A(1)
A1
b
max 1.00 0.05 0.30
nom 0.90 0.02 0.25
min 0.80 0.00 0.18
mm
c
D(1)
Dh
E(1)
Eh
e
e1
L
v
0.2
4.6
4.5
4.4
3.15
3.00
2.85
2.6
2.5
2.4
1.15
1.00
0.85
0.5
3.5
0.5
0.4
0.3
0.1
w
y
0.05 0.05
y1
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
References
Outline
version
IEC
JEDEC
JEITA
SOT764-1
MO-241
sot764-1_po
European
projection
Issue date
03-01-27
14-12-12
Fig. 13. Package outline SOT764-1 (DHVQFN20)
74HC_HCT273
Product data sheet
14 / 17
74HC273; 74HCT273
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT273 v.7
20210906
Product data sheet
74HC_HCT273 v.6
Modifications:
74HC_HCT273 v.6
20200903
Modifications:
Types 74HC273DB and 74HCT273DB (SOT339-1) removed.
20160226
Modifications:
74HC_HCT273 v.4
20130610
Modifications:
Product data sheet
Product data sheet
74HC_HCT273 v.3
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
20060124
Product data sheet
74HC_HCT273_CNV v.2
19970827
Product specification -
Product data sheet
74HC_HCT273 v.4
Type numbers 74HC273N and 74HCT273N (SOT146-1) removed.
74HC_HCT273 v.3
74HC_HCT273
74HC_HCT273 v.5
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Section 2 updated.
Table 4: Derating values for Ptot total power dissipation have been updated.
74HC_HCT273 v.5
Product data sheet
74HC_HCT273_CNV v.2
15 / 17
74HC273; 74HCT273
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74HC_HCT273
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
16 / 17
74HC273; 74HCT273
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 3
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................4
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 6
10.1. Waveforms and test circuit........................................ 9
11. Package outline........................................................ 12
12. Abbreviations............................................................ 15
13. Revision history........................................................15
14. Legal information......................................................16
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 6 September 2021
74HC_HCT273
Product data sheet
17 / 17
