NJM8530/NJM8532/NJM8534
14V, Low Noise, Low Power,
Rail-to-Rail Input/Output, Operational Amplifier
FEATURES (V+=5V, V-=0V, Ta=25°C)
DESCRIPTION
●Supply Voltage
1.8V to 14V
●Low Noise
10nV/√Hz at 1kHz
●Low Supply Current (All Amplifiers)
NJM8530
320μA typ.
NJM8532
580μA typ.
NJM8534
1200μA typ.
●Rail-to-Rail Input and Output
●GBW
1MHz
●Slew Rate
0.4V/μs
●Capacitive Load Drive
1000pF
●Unity Gain Stable
●Package
NJM8530
SOT-23-5
NJM8532
DMP8, SSOP8, MSOP8 (TVSP8)
NJM8534
SSOP14
APPLICATIONS
●Battery-powered instruments
Audio, Sensor applications, Medical, Security
●High-side/Low-side Current sensing amplifiers
●Active Filters
●Analog-to-digital / Digital-to-analog Buffers
●Handheld Test Equipment
The NJM8530/NJM8532/NJM8534 are single/dual/quad
rail to rail input and output single supply operational
amplifier featuring 14V supply voltage, low noise and low
power.
A wide supply voltage range from 1.8V to 14V with a rail to
rail input and output allows the device to be used in wide
variety of applications, such as audio amplifier, hi-side
current sensing, buffering and others. Furthermore, low
supply current of 580μA typical at NJM8532 combined with
a wide bandwidth of 1MHz and low very low noise of
10nV/√Hz at 1kHz make NJM8530/NJM8532/NJM8534
very suitable for a variety of battery-powered applications
that require a good balance between low power, low noise
and wide bandwidth.
NJM8530/NJM8532/NJM8534 can drive up to
approximately 1000pF, and is unity-gain stable. Operating
temperature range is -40°C to 125°C.
The NJM8530(single) is available in 5-pin SOT-23 package.
NJM8532(dual) is available in 8-pin DMP, SSOP and
MSOP(TVSP): meet JEDEC MO-187-DA / thin type
package. NJM8534(quad) is available in 14-pin SSOP
package.
Rail-to-Rail Input/Output Op-Amp (Bipolar)
Ver.5
Supply Voltage
6V
14V
Single
NJM2730
NJM8530
Dual
NJM2732
NJM8532
Quad
NJM2734
NJM8534
www.njr.com
-1-
■ PIN CONFIGURATIONS
PRODUCT NAME
NJM8530F
NJM8532M
NJM8532V
NJM8532RB1
Package
SOT-23-5
DMP8
SSOP8
MSOP8(TVSP8)
(Top View)
(Top View)
+INPUT
1
V-
2
-INPUT
3
Pin
Functions
5
4
PRODUCT NAME
NJM8534V
Package
SSOP14
A OUTPUT
1
8
V+
A -INPUT
2
7
B OUTPUT
A +INPUT
3
6
B -INPUT
V-
4
5
B +INPUT
V+
OUTPUT
(Top View)
Pin
Functions
A OUTPUT
1
14
D OUTPUT
A -INPUT
2
13
D -INPUT
A +INPUT
3
12
D +INPUT
V+
4
11
V-
B +INPUT
5
10
C +INPUT
B -INPUT
6
9
C -INPUT
B OUTPUT
7
8
C OUTPUT
■ PRODUCT NAME INFORMATION
NJM8532
Part Number
RB1
(TE1)
Package
Taping Form
■ ORDERING INFORMATION
PRODUCT NAME
NJM8530F
NJM8532M
NJM8532V
NJM8532RB1
NJM8534V
Ver.5
PACKAGE
RoHS
HALOGENFREE
TERMINAL
FINISH
MARKING
WEIGHT
(mg)
MOQ
(pcs)
SOT-23-5
DMP8
SSOP8
MSOP8 (TVSP8)
SSOP14
Sn2Bi
Sn2Bi
Sn2Bi
Sn2Bi
Sn2Bi
A6L
8532
8532
8532
8534
15
95
42
18
65
3000
2000
2000
2000
2000
www.njr.com
-2-
■ BLOCK DIAGRAM
V+
+INPUT
OUTPUT
-INPUT
V-
■ ABSOLUTE MAXIMUM RATINGS
PARAMETER
SYMBOL
Supply Voltage
RATING
V -V
Input Voltage
VIN
15
V
(2)
V -0.3 to V +0.3
(1)(2)
Differential Input Voltage
VID
±1.0
Input Current
IIN
2
V
V
(2)
mA
(3)
Power Dissipation (Ta=25°C)
SOT-23-5
DMP8
SSOP8
TVSP8
SSOP14
UNIT
2-Layer / 4-Layer
PD
480 / 650
470 / 600
430 / 540
510 / 680
500 / 620
mW
Storage Temperature Range
Tstg
-40 to 150
°C
Maximum Junction Temperature
Tjmax
150
°C
SYMBOL
VALUE
■ THERMAL CHARACTERISTICS
PACKAGE
Junction-to-Ambient Thermal Resistance
SOT-23-5
DMP8
SSOP8
TVSP8
SSOP14
2-Layer / 4-Layer
Θja
260 / 192
266 / 208
291 / 231
245 / 184
250 / 202
°C/W
(3)
Junction-to-Top of Package Characterization Parameter
SOT-23-5
DMP8
SSOP8
TVSP8
SSOP14
UNIT
(3)
2-Layer / 4-Layer
Ψjt
67 / 58
72 / 65
46 / 45
51 / 45
53 / 52
°C/W
(1) Differential voltage is the voltage difference between +INPUT and -INPUT.
(2) The inputs are protected by diodes. If the differential input voltage exceeds 1.0V, the input current must be limited 2 mA or less by using a
restriction resistance.
(3) 2-Layer: Mounted on glass epoxy board. (76.2×114.3×1.6mm: based on EIA/JDEC standard, 2-Layer FR-4)
4-Layer: Mounted on glass epoxy board. (76.2×114.3×1.6mm: based on EIA/JDEC standard, 4-Layer FR-4), internal Cu area: 74.2×74.2mm
Ver.5
www.njr.com
-3-
■ POWER DISSIPATION vs. AMBIENT TEMPERATURE
Power Dissipation vs. Temperature
2-Layer
4-Layer
900
900
800
Power Dissipation PD [mW]
800
MSOP8 (TVSP8)
700
600
SSOP14
500
DMP8
400
300
SOT-23-5
200
SSOP8
100
MSOP8 (TVSP8)
700
SOT-23-5
600
500
DMP8
400
SSOP14
300
200
SSOP8
100
50
75
100
125
150
Ambient Temperature [°C]
25
50
75
100
125
150
■ RECOMMENDED OPERATING CONDITIONS
PARAMETER
Supply Voltage
Operating Temperature Range
Ver.5
SYMBOL
VALUE
UNIT
V -V
1.8 to 14
V
Topr
-40 to 125
°C
CONDITIONS
www.njr.com
-4-
■ ELECTRICAL CHARACTERISTICS (V+=5V, V-=0V, VCOM=2.5V, Ta=25°C, unless otherwise noted.)
PARAMETER
SYMBOL
TEST CONDITIONS
MIN
TYP
MAX
UNIT
INPUT CHARACTERISTICS
Input Offset Voltage
Input Offset Voltage Drift
VIO
ΔVIO/ΔT
Ta=-40°C to 125°C
1
4
mV
1.5
µV/°C
Input Bias Current
IB
50
250
nA
Input Offset Current
IIO
5
100
nA
RL=2kΩ to 2.5V
60
85
dB
(5)
55
70
dB
V
RL=20kΩ to 2.5V
4.9
4.95
V
RL=2kΩ to 2.5V
4.75
4.85
V
RL=20kΩ to 2.5V
0.05
0.1
V
RL=2kΩ to 2.5V
0.15
0.25
V
Sourcing, Short to 2.5V
mA
Sinking, Short to 2.5V
5
mA
320
550
μA
580
900
μA
1200
1800
μA
70
85
dB
Open-Loop Voltage Gain
AV
Common-Mode Rejection Ratio
CMR
Common-Mode Input Voltage Range
VICM
CMR≥55dB
OUTPUT CHARACTERISTICS
High-level Output Voltage
VOH
Low-level Output Voltage
VOL
Output Short-Circuit Current
ISC
POWER SUPPLY
NJM8530
NJM8532
No Signal
ISUPPLY
NJM8534
Supply Voltage Rejection Ratio
SVR
V =4V to 6V
AC CHARACTERISTICS
Slew Rate
SR
RL=2kΩ to 2.5V
0.4
V/μs
GBW
RL=2kΩ to 2.5V
1
MHz
Phase Margin
ΦM
RL=2kΩ to 2.5V
75
Deg
Equivalent Input Noise Voltage
en
f=1kHz
10
nV/√Hz
Channel Separation
NJM8532/NJM8534
CS
f=1kHz
-133
dB
Gain Bandwidth Product
(5) CMR specified is the lower of the CMR+ and CMR-.
CMR+ measured with V /2≤VCM≤V , and CMR- measured with V ≤VCM≤V /2.
Ver.5
www.njr.com
-5-
■ ELECTRICAL CHARACTERISTICS (V+=3V, V-=0V, VCOM=1.5V, Ta=25°C, unless otherwise noted.)
PARAMETER
SYMBOL
TEST CONDITIONS
MIN
TYP
MAX
UNIT
VIO
ΔVIO/ΔT
Ta=-40°C to 125°C
1
4
mV
1.8
µV/°C
Input Bias Current
IB
50
250
nA
IIO
5
100
nA
RL=2kΩ to 1.5V
60
84
dB
(5)
48
63
dB
V
RL=20kΩ to 1.5V
2.9
2.95
V
RL=2kΩ to 1.5V
2.75
2.85
V
RL=20kΩ to 1.5V
0.05
0.1
V
RL=2kΩ to 1.5V
0.15
0.25
V
Sourcing, Short to 1.5V
18
mA
Sinking, Short to 1.5V
4.8
mA
AV
CMR
VICM
CMR≥48dB
VOH
VOL
ISC
POWER SUPPLY
NJM8530
NJM8532
No Signal
ISUPPLY
NJM8534
270
460
μA
510
880
μA
1000
1800
μA
SVR
V =2.4V to 4V
68
83
dB
SR
RL=2kΩ to 1.5V
0.35
V/μs
GBW
RL=2kΩ to 1.5V
1
MHz
Phase Margin
ΦM
RL=2kΩ to 1.5V
75
Deg
en
f=1kHz
10
nV/√Hz
Channel Separation
NJM8532/NJM8534
CS
f=1kHz
-130
dB
AC CHARACTERISTICS
Slew Rate
CMR+ measured with V /2≤VCM≤V , and CMR- measured with V-≤VCM≤V /2.
Ver.5
www.njr.com
-6-
■ ELECTRICAL CHARACTERISTICS (V+=1.8V, V-=0V, VCOM=0.9V, Ta=25°C, unless otherwise noted.)
PARAMETER
SYMBOL
TEST CONDITIONS
MIN
TYP
MAX
UNIT
VIO
ΔVIO/ΔT
Ta=-40°C to 125°C
1
4
mV
2.4
µV/°C
Input Bias Current
IB
50
250
nA
IIO
5
100
nA
RL=2kΩ to 0.9V
60
83
dB
(5)
40
55
dB
V
RL=20kΩ to 0.9V
1.7
1.75
V
RL=2kΩ to 0.9V
1.55
1.65
V
RL=20kΩ to 0.9V
0.05
0.1
V
RL=2kΩ to 0.9V
0.15
0.25
V
Sourcing, Short to 0.9V
18
mA
Sinking, Short to 0.9V
4.7
mA
AV
CMR
VICM
CMR≥40dB
VOH
VOL
ISC
POWER SUPPLY
NJM8530
NJM8532
No Signal
ISUPPLY
NJM8534
240
430
μA
460
800
μA
900
1600
μA
SVR
V =1.8V to 2.4V
65
80
dB
SR
RL=2kΩ to 0.9V
0.3
V/μs
GBW
RL=2kΩ to 0.9V
1
MHz
Phase Margin
ΦM
RL=2kΩ to 0.9V
75
Deg
en
f=1kHz
10
nV/√Hz
Channel Separation
NJM8532/NJM8534
CS
f=1kHz
-125
dB
AC CHARACTERISTICS
Slew Rate
Ver.5
www.njr.com
-7-
■ TYPICAL CHARACTERISTICS (V-=0V, Ta=25°C, unless otherwise noted.)
Supply Current per Amplifier vs. Supply Voltage
500
Ta=25ºC
400
300
Ta=125ºC
200
GV=0dB
600
Supply Current per Amplifier [μA]
Supply Current per Amplifier vs. Temperature
GV=0dB
600
Ta=-40ºC
100
V+=14V
400
300
200
V+=1.8V
100
+4
+6
+8 +10 +12
Supply Voltage V+ [V]
+14
-50
Input Offset Voltage vs. Supply Voltage
0.8
Input Offset Voltage [mV]
1.6
1.2
Ta=125ºC
0.4
0.0
-0.4
-0.8
-1.2
-1.6
Ta=25ºC
-2.0
1.2
0.8
V+=14V
0.4
V+=5V
0.0
-0.4
-0.8
-1.2
-1.6
-2.0
Ta=-40ºC
-2.4
V+=1.8V
-2.4
-2.8
-2.8
4
6
8
10
Supply Voltage [V]
12
14
-50
Input Offset Voltage Distribution
-25
25 50 75 100 125 150
Ambient Temperature [ºC]
V+=14V, VCOM=V+/2, Ta=25ºC
35%
30%
V+=5V, VCOM=V+/2, Ta=25ºC
30%
Number of Amplifiers
VCOM=V+/2
2.0
1.6
25%
20%
15%
10%
5%
25%
20%
15%
10%
5%
0%
0%
-2.4 -2.0 -1.6 -1.2 -0.8 -0.4 0.0 0.4 0.8 1.2
Ver.5
-25
Input Offset Voltage vs. Temperature
VCOM=V+/2
2.0
35%
V+=5V
www.njr.com
-8-
Input Offset Voltage Drift Distribution
V+=1.8V, VCOM=V+/2, Ta=25ºC
35%
40%
30%
V+=14V, VCOM=V+/2
45%
25%
20%
15%
10%
5%
35%
30%
25%
20%
15%
10%
5%
0%
0%
-6.0 -4.0 -2.0 0.0 2.0 4.0 6.0 8.0 10.0
Input Offset Voltage Drift [μV/ºC]
V+=5V, VCOM=V+/2
40%
35%
35%
V+=1.8V, VCOM=V+/2
40%
30%
25%
20%
15%
10%
5%
30%
25%
20%
15%
10%
5%
0%
0%
vs. Common-Mode Input Voltage
V+=14V
V+=5V
2.0
1.0
Ta=125ºC
0.0
-1.0
Ta=-40ºC
-2.0
Ta=25ºC
-3.0
1.0
Ta=125ºC
0.0
-1.0
-2.0
Ta=25ºC
-3.0
-4.0
Ta=-40ºC
-4.0
-1 0
Ver.5
2.0
2
4
6
8
10 12
14
Common-Mode Input Voltage [V]
-1
www.njr.com
2
3
4
5
6
-9-
Input Bias Current
V+=1.8V
V+=5V
250
200
1.0
0.0
Input Bias Current [nA]
2.0
Ta=125ºC
Ta=25ºC
-1.0
-2.0
-3.0
Ta=-40ºC
150
Ta=25ºC
100
50
Ta=125ºC
-50
-100
Ta=-40ºC
-4.0
-150
-0.6
1.2
1.8
2.4
-1
Input Bias Current vs. Temperature
Open-Loop Voltage Gain [dB]
V+=5V
V+=14V
100
50
V+=1.8V
-50
-100
V+=14V
80
60
V+=1.8V
40
-25
-50
Common Mode / Supply Voltage Rejection Ratio
vs. Temperature
120
100
CMR(V+=14V)
SVR
80
60
40
CMR(V+=5V)
CMR(V+=1.8V)
-25
-25
Maximum Output Voltage vs. Output Current
V+=14V
Maximum Output Voltage [V]
Rejection Ratio [dB]
V+=5V
100
-150
Ver.5
RL=2kΩ to V+/2
120
200
150
6
Open-Loop Voltage Gain vs. Temperature
VCOM=V+/2
250
2
3
4
5
14
13
12
11
10
9
8
7
6
5
4
3
2
1
www.njr.com
ISOURCE
Ta=-40ºC
Ta=25ºC
Ta=125ºC
Ta=125ºC
Ta=25ºC
Ta=-40ºC
ISINK
0.1
1
10
Output Current [mA]
100
- 10 -
V+=5V
V+=1.8V
5.0
ISOURCE
Ta=-40ºC
4.0
3.5
Ta=25ºC
3.0
Ta=125ºC
2.5
Ta=125ºC
2.0
1.5
Ta=25ºC
1.0
Ta=-40ºC
Ta=-40ºC
1.4
0.8
Ta=125ºC
0.6
Ta=25ºC
0.4
1
10
Output Current [mA]
100
0.1
Maximum Output Voltage vs. Load Resistance
Ta=25ºC
8
6
Ta=125ºC
4
VOL
2
2
High-level Output Voltage VOH [V]
Ta=-40ºC
10
Low-level Output Voltage VOL [mV]
VOH
Ta=-40ºC
VOH
4
Ta=125ºC
Ta=-40ºC
3
Ta=25ºC
10
4
Ta=-40ºC
2
100
1k
10k
Load Resistance [Ω]
1.2
1.0
Ta=25ºC
0.8
4
Ta=-40ºC
0.6
VOL
0.4
3
2
0.2
1
Ta=25ºC
10
Ta=125ºC
100
1k
10k
Load Resistance [Ω]
100k
Ta=-40ºC
1.4
0.0
Ver.5
VOH
Ta=125ºC
100
1k
10k
Load Resistance [Ω]
100k
V+=1.8V, Gv=open, RL connected to 0V
1.6
1
Ta=125ºC
Ta=25ºC
100k
3
VOL
1
1.8
5
2
Ta=25ºC
V+=5V, Gv=open, RL connected to 0V
5
Ta=125ºC
6
1
10
Output Current [mA]
V+=14V, Gv=open, RL connected to 0V
4
Ta=-40ºC
0.0
0.1
12
Ta=125ºC
1.0
ISINK
ISINK
14
Ta=25ºC
1.2
0.2
0.5
0.0
ISOURCE
1.6
4.5
1.8
7
6
5
4
3
2
1
-2
-3
-4
-5
-6
-7
www.njr.com
V+/V-=±7V, Gv=open, RL connected to 0V
Ta=125ºC
Ta=25ºC
Ta=-40ºC
Ta=25ºC
Ta=125ºC
10
Ta=-40ºC
100
1k
10k
Load Resistance [Ω]
100k
- 11 -
V+/V-=±2.5V, Gv=open, RL connected to 0V
2.5
V+/V-=±0.9V, Gv=open, RL connected to 0V
0.9
Ta=125ºC
1.5
Ta=25ºC
1.0
0.5
Ta=-40ºC
0.0
-0.5
Ta=25ºC
-1.0
-1.5
Ta=-40ºC
Ta=125ºC
0.6
Ta=125ºC
0.3
Ta=25ºC
Ta=-40ºC
0.0
Ta=-40ºC
-0.3
Ta=25ºC
-0.6
-2.0
Ta=125ºC
-2.5
-0.9
10
100
1k
10k
Load Resistance [Ω]
100k
10
100
1k
10k
Load Resistance [Ω]
40dB Voltage Gain/Phase vs. Frequency
V+=14V, Gain=40dB, RL=2kΩ to 7V, Ta=25ºC
V+=5V, Gain=40dB, RL=2kΩ to 2.5V, Ta=25ºC
40
40
Voltage Gain
Phase
CL=1000pF
CL=470pF
CL=220pF
CL=0pF
-20
-40
-60
1k
10k
100k
1M
Frequency [Hz]
10M
CL=0pF
Phase
CL=1000pF
CL=470pF
CL=220pF
CL=0pF
-20
-120
-40
-180
100M
-60
CL=1000pF
CL=470pF
CL=220pF
-60
Phase [deg]
CL=0pF
Voltage Gain [dB]
Voltage Gain
Voltage Gain [dB]
100k
Phase [deg]
2.0
-120
CL=1000pF
CL=470pF
CL=220pF
1k
10k
100k
Frequency [Hz]
-60
1M
-180
10M
GBW vs. Temperature
V+=1.8V, Gain=40dB, RL=2kΩ to 0.9V, Ta=25ºC
RL=2kΩ to V+/2, CL=0pF, f=100kHz
2.8
40
2.4
CL=0pF
Phase
CL=1000pF
CL=470pF
CL=220pF
-20
1k
10k
100k
Frequency [Hz]
1M
1.6
1.2
0.8
-120
CL=1000pF
CL=470pF
CL=220pF
-60
Ver.5
-60
CL=0pF
-40
V+=14V
2.0
GBW [MHz]
Phase [deg]
Voltage Gain [dB]
Voltage Gain
-180
10M
V+=5V
V+=1.8V
0.4
0.0
www.njr.com
-50
-25
- 12 -
Phase Margin vs. Temperature
Voltage Gain vs. Frequency
95
V+=14V, Gv=0dB, RL=2kΩ to 7V, Ta=25ºC
CL=2200pF
V+=14V
Voltage Gain [dB]
Phase Margin [deg]
15
85
80
75
70
65
10
CL=1000pF
CL=470pF
5
CL=220pF
V+=5V
60
CL=10pF
-5
V+=1.8V
55
50
-10
-50
-25
10k
15
CL=2200pF
Voltage Gain [dB]
Voltage Gain [dB]
CL=2200pF
CL=1000pF
CL=470pF
5
CL=220pF
CL=10pF
-5
10
CL=1000pF
CL=470pF
5
CL=220pF
CL=10pF
-5
-10
-10
10k
100k
1M
10M
Frequency [Hz]
100M
10k
Overshoot vs. Capacitive Load
Overshoot [%]
V+=14V
10
5
100p
100
V+=5V
V+=1.8V
1n
1k
Capacitive Load [F]
100k
1M
10M
Frequency [Hz]
100M
Voltage Noise Densityvs. Frequency
VIN=1Vpp, Gv=0dB, RL=2kΩ to V+/2, Ta=25ºC
Equivalent Input Noise Voltage [nV/√Hz]
25
Ver.5
100M
V+=1.8V, Gv=0dB, RL=2kΩ to 0.9V, Ta=25ºC
10
1M
10M
Frequency [Hz]
V+=5V, Gv=0dB, RL=2kΩ to 2.5V, Ta=25ºC
100k
V+=5V, RL=2kΩ to 2.5V, CL=0pF, Ta=25ºC
25
10
5
10n
10k
www.njr.com
1
10
100
1k
Frequency [Hz]
10k
100k
- 13 -
Pulse Response
Slew Rate vs. Temperature
V+=5V, VIN=1Vpp, Gv=0dB, RL=2kΩ to GND, Ta=25ºC
VIN=1Vpp, Gv=0dB, CL=10pF, RL=2kΩ to 0V
1.0
Slew Rate [V/μs]
Voltage [0.5V/div]
0.8
CL=10pF
CL=1000pF
V+=14V
V+=5V
0.6
0.4
0.2
V+=1.8V
0.0
Time [5μs/div]
-50
Total Harmonic Distortion + Noise [%]
10
No Phase Reversal
THD+N vs. Output Voltage
V+=3V,
-25
V+=5V, f=10kHz, VIN=6VP-P
GV=+2, RL=2kΩ to 1.5V, CL=0pF, Ta=25ºC
input
Voltage [0.5V/div]
1
f=10kHz
0.1
f=1kHz
0.01
Ta=-40ºC
Ta=25ºC
Ta=125 ºC
f=100Hz
0.001
0.001
0.01
0.1
1
Output Voltage [Vrms]
Time [1μs/div]
10
Channel Separation vs. Frequency
GV=40dB, RL=2kΩ to V+/2, Ta=25ºC
Channel Separation [dB]
-60
-80
-100
V+=1.8V
V+=3V
-120
-140
V+=5V
-160
10
Ver.5
100
1k
10k
Frequency [Hz]
100k
www.njr.com
- 14 -
■ TEST CIRCUITS
● ISUPPLY
● VIO, CMR, SVR
RG=50Ω, RF=50kΩ
V+
RF
A
V+
RG
VO
RG
VCOM
VCOM
V-
RF
VVS=V+-V-
● VOH, VOL
● GBW
RG=100Ω, RF=10kΩ, CL=0pF
VOH; Vin+ = 1V, Vin- = 0V, VCOM=V /2
VOL; Vin+ = 0V, Vin- = 1V, VCOM=V /2
RF
V+
V+
RG
VO
VO
RL
Vin+
Vin-
V-
50Ω
VCOM
V-
CL
● SR
RL=2kΩ, CL=10pF
90%
V+
Vo
VO
50Ω
Ver.5
V-
RL
90%
ΔV ΔV
10%
Δt
Δt
10%
CL
www.njr.com
- 15 -
■ APPLICATION NOTE
Single and Dual Supply Voltage Operation
The NJM8530/NJM8532/NJM8534 works with both single
supply and dual supply when the voltage supplied is
between V+ and V−. These amplifiers operate from single
1.8 to 14V supply and dual ±0.9V to ±7V supply.
+INPUT
-INPUT
When the supply voltage does not meet the condition of
electrical characteristics, the range of common-mode input
voltage is as follows:
VICM (typ.) = V to V (Ta = 25°C)
Difference of VICM when Temperature change, refer to
typical characteristic graph.
During designing, consider variations in characteristics for
use with allowance.
VOM (typ.) = V +50mV to V -50mV (RL=20kΩ, Ta=25°C)
During designing, consider variations in characteristics and
temperature characteristics for use with allowance. In
addition, also note that the output voltage range becomes
narrow as shown in typical characteristics graph when an
output current increases.
Rail-to-Rail Input
The input stage of NJM8530/NJM8532/NJM8534 has two
input differential pairs, PNP-transistor and NPN-transistor
(Figure1). When the common-mode input voltage is at the
low end of the negative supply voltage, typically (V-) to
(V-)+0.6V, the PNP-transistor input differential pair is active
and amplifies the input signal. As the common-mode input
voltage is increased above the typically (V-)+0.6V, the
NPN-transistor differential pair gradually turns on, thus both
pairs are active. When the Common-Mode Input voltage
continues increasing near the positive supply voltage,
typically (V+)-0.6V to positive supply voltage, the
PNP-transistor differential pair gradually turns off and
amplifies the input signal by NPN-transistor differential pair
only. The transition occurs at approximately 0.6V away
from both supply rails and results in a change in offset
voltage due to the different offset voltage of the differential
pairs as shown in figure2.
V+=5V
2.0
Maximum Output Voltage Range
electrical characteristics, the range of the typ. value of the
maximum output voltage is as follows:
Figure1. Simplified Schematic of Input Stage
1.0
Ta=125ºC
0.0
-1.0
-2.0
Ta=25ºC
-3.0
Ta=-40ºC
-4.0
-1
2
3
4
5
6
Figure2. Offset Voltage change with
common-mode input voltage.
Input Voltage Exceeding the Supply Voltage
Inputs of the NJM8530/NJM8532/NJM8534 are protected
by ESD diodes (shown in Figure1) that will conduct if the
input voltages exceed the power supplies by more than
approximately 300mV. Momentary voltages greater than
300mV beyond the power supply, inputs can be tolerated if
the current is limited to 2mA. Figure3 is easily
accomplished with an input resistor. If the input voltage
exceeds the supply voltage, the input current must be
limited 2mA or less by using a restriction resistance (RLIMIT)
as shown in figure3.
V+
Current Limit
2mA
Vin
R
Vout
LIMIT
VFigure3. Input Current Protection for Voltages
Exceeding the Supply Voltage.
Ver.5
www.njr.com
- 16 -
■ APPLICATION NOTE
The NJM8530/NJM8532/NJM8534 has internal protection
circuitry that prevents damage to the input stage from large
differential input voltages. This protection circuitry consists
of two diodes and two resistors as shown in figure1. The
diodes limit the differential voltage applied to the amplifiers’
internal circuitry to no more than diodes’ forward-voltage
drop (VF). Input bias current is specified typically 50nA for
small differential input voltages. For large differential input
voltage above the VF, this protection circuitry increases the
input current at +INPUT and -INPUT. The maximum
differential input voltage is 1.0V, but if the differential input
mA or less by using a restriction resistance.
Differential Amplifier
Figure5 shows a one op-amp differential amplifier that
consists of the single op-amp and four external resistors.
Differential amplifier amplifies the difference between its
two input pins, and rejects the common- mode input
voltage at both input pins. This is used in variety of
applications including current sensing, differential to
single-end converter, isolation amplifier to remove
common-mode noise.
R2
R1
V1
Vout
Capacitive load
The NJM8530/NJM8532/NJM8534 can use at unity gain
follower, but the unity gain follower is the most sensitive
configuration to capacitive loading. The combination of
capacitive load placed directly on the output of an amplifier
along with the output impedance of the amplifier creates a
phase lag which in turn reduces the phase margin of the
amplifier. If phase margin is significantly reduced, the
response will cause overshoot and ringing in the step
response.
The NJM8530/NJM8532/NJM8534 is unity gain stable for
capacitive loads of 1000pF (see the overshoot vs.
capacitive load graph). To drive heavier capacitive loads,
an isolation resistor, RISO as shown Figure4, should be
used. RISO improves the feedback loop’s phase margin by
making the output load resistive at higher frequencies. The
larger the value of RISO, the more stable the output voltage
will be. However, larger values of RISO result in reduced
output swing, reduced output current drive and reduced
frequency bandwidth.
R3
R4
Vref
ୖଵାୖଶ ୖସ
ୖଶ
ୖଵୀୖଷ, ୖଶୀୖସ
ୖଶ
Vout = ୖଵ(ଶିଵ)ା ୰ୣ
Figure5. Differential Amplifier
The differential amplifier’s common-mode rejection ratio
(CMR) is primarily determined by resistor mismatches, not
by the op-amp’s CMR. Ideally, the resistors are chosen
such that R2/R1 = R4/R3. The CMR due to the resistors in
differential amplifier can be calculated using the below
formula:
భశ
మ
భ
ସୖ౨౨౨
R
ISO
Vout
C
L
V-
ୖଵାୖଶ ୖଷ
Vout = ቀୖଷାୖସቁ ୖଵଶିୖଵଵା ቀୖଷାୖସቁ ୖଵ୰ୣ
CMR ୖ_ୣ୰୰୭୰ ≈ 20log ൬
V+
Vin
V2
൰
CMR ୖ_ୣ୰୰୭୰ = CMR due only to the resistors
R ୣ୰୰୭୰ = Resistor′s tolerance
Example:
R2/R1=1 and Rerror=0.1%, then CMR=54dB
R2/R1=1 and Rerror=1%, then CMR=34dB
If using resistors with 1% tolerance and gain=1, the CMR
will only be 34dB.
Figure4. Isolating capacitive load
Ver.5
www.njr.com
- 17 -
■ APPLICATION NOTE
Current Sensing
Current sensing applications are one such application in a
wide range of electronic applications and mostly used for
feedback control systems, including power metering battery
life indicators and chargers, over- current protection and
supervising circuit, automotive, and medical equipment. In
such applications, it is desirable to use a shunt with very
low resistance to minimize the series voltage drop and
minimizes wasted power, and allows the measurement of
high current. The NJM8530/NJM8532/NJM8534 is ideal for
these current sensing applications.
Figure6 shows a high-side current sensing circuit, and
Figure7 shows a low-side current sensing circuit. The
NJM8530/NJM8532/NJM8534 has rail-to-rail input and
output characteristics, thus allows the both of high-side and
low-side current sensing circuit. Futuremore, low supply
current of 290µA/ch can save the power at battery
applications.
The NJM8530/NJM8532/NJM8534 operates up to 14V,
and rail-to-rail feature allows the output voltage close to
14V (almost reach the power supply of op-amp). For
example, if using a typical shunt resistor of 0.1Ω, allows the
current sensing up to approximately 1.4A of current.
(CMR) is primarily determined by resistor mismatches. For
details, refer to Differential Amplifiers in the Applications
Information.
Rs
14V
Load
I
Rs
100kΩ
14V
1kΩ
Vout
1kΩ
100kΩ
Figure7. Low-Side Current Sensing
I
14V
100kΩ
1kΩ
Load
14V
Vout
1kΩ
100kΩ
Figure6. High-Side Current Sensing
Ver.5
www.njr.com
- 18 -
SOT-23-5
Unit: mm
■ PACKAGE DIMENSIONS
2.9 ±0.2
0 ∼15 °
1.9 ±0.2
4
0.6
2.8 ± 0.2
1.6
+0.2
-0.1
0.2
5
2
1
3
0.1
0.95 ±0.1
+0 . 1
-0 . 0 3
0.4 ±0.1
0.1
0.1max
1.1 ± 0.1
0.6max
■ EXAMPLE OF SOLDER PADS DIMENSIONS
2.4
1.0
0.7
0.95
Ver.5
0.9 5
www.njr.com
- 19 -
DMP8
Unit: mm
0 ∼10 °
5.0 ± 0.3
4
1
.1
0.15 +0
-0 .0 5
1.27
0.15 ± 0.1
1.6 ± 0.15
0.74max
0.5 ±0.2
6.8 ±0.3
5
5.0 ±0.2
8
0.1
0.35 ±0.1
0.12
M
1 .27
6 .1 0
1.27
0.72
3.8 1
Ver.5
www.njr.com
- 20 -
SSOP8
Unit: mm
.3
3.5 +0
-0 .1
0 ∼10 °
8
0. 5 ± 0 .2
6.4 ± 0 .3
4.4 ± 0. 2
5
4
1 .15 ± 0.1
0.65
0.1
0.22 ±0.1
0.1
M
0.15
+0.1
-0.05
0.1 ± 0.1
1
0.9max
0.65
5.9 0
1. 0
0.35
1.95
Ver.5
www.njr.com
- 21 -
MSOP8 (TVSP8)
JEDEC MO-187-DA/THIN TYPE
Unit: mm
2.9 ±0.1
0 ∼10゚
1
0 .55 ± 0.1
4.0 ± 0.2
5
2.8 ± 0.1
8
4
0.127 +0.05
-0.03
0.65
0.08
0.2 ±0.05
0.05 M
0 .1 ± 0. 05
1.0max
0.475 ±0.1
0.65
3.5
1 .0
0.23
1.95
Ver.5
www.njr.com
- 22 -
SSOP14
Unit: mm
5.0
0 ∼ 10゚
+0.3
-0.1
7
+0.1
1.1 5 ± 0.1
0.65
0.15 -0.05
0.1 ± 0.1
0.67max
0.10
0.22 ±0.1
0.5 ± 0.2
4 .4 ± 0.2
1
6.4 ± 0.3
8
14
0.10 M
0.35
5.90
1.00
0.65
3.90
Ver.5
www.njr.com
- 23 -
SOT-23-5
Unit: mm
■ PACKING SPEC
TAPING DIMENSIONS
SYMBOL
A
B
D0
D1
E
F
P0
P1
P2
T
T2
K0
W
W1
Feed direction
P0
φD0
T
B
W1
W
F
E
P2
A
K0
φD1
P1
T2
DIMENSION
3.3±0.1
3.2±0.1
1.55
1.05
1.75±0.1
3.5±0.05
4.0±0.1
4.0±0.1
2.0±0.05
0.25±0.05
1.82
1.5±0.1
8.0±0.3
5.5
REMARKS
BOTTOM DIMENSION
BOTTOM DIMENSION
THICKNESS 0.1MAX
REEL DIMENSIONS
W1
SYMBOL
A
B
C
D
E
W
W1
E
A
D
B
C
DIMENSION
φ180±1
φ 60±1
φ 13±0.2
φ 21±0.8
2±0.5
9±0.5
1.2±0.2
W
TAPING STATE
Insert direction
Sealing with covering tape
(TE1)
Drawing direction
Empty tape
Device attaching tape
more than 20pitch
3000pcs/reel
Empty tape
Covering tape
more than 20pitch reel more than 1 round
PACKING STATE
Label
Label
Put a reel into a box
Ver.5
www.njr.com
- 24 -
DMP8
Unit: mm
■ PACKING SPEC
TAPING DIMENSIONS
φD0
P1
φD1
SYMBOL
A
B
D0
D1
E
F
P0
P1
P2
T
T2
W
W1
T
B
W1
W
F
P0
E
F ee d d ir ec ti o n
P2
A
T2
DIMENSION
7.1
5.4
1.55±0.05
2.05±0.1
1.75±0.1
7.5±0.1
4.0±0.1
12.0±0.1
2.0±0.1
0.3±0.05
2.3
16.0±0.3
13.5
REMARKS
BOTTOM DIMENSION
BOTTOM DIMENSION
THICKNESS 0.1max
REEL DIMENSIONS
W1
SYMBOL
A
B
C
D
E
W
W1
E
A
D
B
C
DIMENSION
φ330±2
φ 80±1
φ 13±0.2
φ 21±0.8
2±0.5
17.5±0.5
2±0.2
W
TAPING STATE
Insert direction
(TE1)
Empty tape
Feed direction
more than 20pitch
Empty tape
Devices
2000pcs/reel
more than 20pitch
Covering tape
reel more than 1round
PACKING STATE
Label
Label
Ver.5
www.njr.com
- 25 -
SSOP8
Unit: mm
■ PACKING SPEC
TAPING DIMENSIONS
Feed direction
P2
P0
φ D0
SYMBOL
A
B
D0
D1
E
F
P0
P1
P2
T
T2
W
W1
B
W1
W
F
E
T
P1
A
φ D1
T2
DIMENSION
6.7
3.9
1.55±0.05
1.55±0.1
1.75±0.1
5.5±0.05
4.0±0.1
8.0±0.1
2.0±0.05
0.3±0.05
2.2
12.0±0.3
9.5
REMARKS
BOTTOM DIMENSION
BOTTOM DIMENSION
THICKNESS 0.1max
REEL DIMENSIONS
W1
C
SYMBOL
A
B
C
D
E
W
W1
A
B
D
E
DIMENSION
φ254±2
φ100±1
φ 13±0.2
φ 21±0.8
2±0.5
13.5±0.5
2±0.2
W
TAPING STATE
Insert direction
(TE1)
Devices
Empty tape
Feed direction
more than 20pitch
2000pcs/reel
Empty tape
Covering tape
more than 20pitch reel more than 1round
PACKING STATE
Label
Label
Ver.5
www.njr.com
- 26 -
MSOP8 (TVSP8)
MEET JEDEC MO-187-DA/THIN TYPE
Unit: mm
■ PACKING SPEC
TAPING DIMENSIONS
Feed direction
P0
φ D0
T
B
W1
W
F
E
P2
A
φ D1
P1
T2
SYMBOL
A
B
D0
D1
E
F
P0
P1
P2
T
T2
W
W1
DIMENSION
4.4
3.2
1.5 +0.1
1.75±0.1
5.5±0.05
4.0±0.1
8.0±0.1
2.0±0.05
0.30±0.05
1.75 (MAX.)
12.0±0.3
9.5
REMARKS
BOTTOM DIMENSION
BOTTOM DIMENSION
THICKNESS 0.1max
REEL DIMENSIONS
W1
C
SYMBOL
A
B
C
D
E
W
W1
B
A
D
E
DIMENSION
φ254±2
φ100±1
φ 13±0.2
φ 21±0.8
2±0.5
13.5±0.5
2.0±0.2
W
TAPING STATE
Insert direction
(TE2)
Devices
Empty tape
Feed direction
more than 20pitch
2000pcs/reel
Empty tape
Covering tape
PACKING STATE
Label
Label
Ver.5
www.njr.com
- 27 -
SSOP14
Unit: mm
■ PACKING SPEC
TAPING DIMENSIONS
Feed direction
φ D0
P0
T
B
W1
W
F
E
P2
SYMBOL
A
B
D0
D1
E
F
P0
P1
P2
T
T2
W
W1
A
φ D1
P1
T2
DIMENSION
6.95
5.4
1.55±0.05
1.55±0.1
1.75±0.1
5.5±0.05
4.0±0.1
8.0±0.1
2.0±0.05
0.3±0.05
2.2
12.0±0.3
9.5
REMARKS
BOTTOM DIMENSION
BOTTOM DIMENSION
THICKNESS 0.1max
REEL DIMENSIONS
W1
C
SYMBOL
A
B
C
D
E
W
W1
A
B
D
E
DIMENSION
φ254±2
φ100±1
φ 13±0.2
φ 21±0.8
2±0.5
13.5±0.5
2±0.2
W
TAPING STATE
Insert direction
(TE1)
Empty tape
Feed direction
PACKING STATE
Devices
more than 20pitch
2000pcs/reel
Label
Empty tape
Covering tape
Label
Ver.5
www.njr.com
- 28 -
■ RECOMMENDED MOUNTING METHOD
INFRARED REFLOW SOLDERING PROFILE
f
260°C
e
230°C
220°C
d
a
b
180°C
c
d
e
f
g
150°C
Temperature ramping rate
Pre-heating temperature
Pre-heating time
Temperature ramp rate
220°C or higher time
230°C or higher time
Peak temperature
1 to 4°C/s
150 to 180°C
60 to 120s
1 to 4°C/s
shorter than 60s
shorter than 40s
lower than 260°C
1 to 6°C/s
The temperature indicates at the surface of mold package.
Room
Temp.
a
b
c
g
■ REVISION HISTORY
Ver.5
DATE
REVISION
CHANGES
July 1, 2019
5
Changed design of datasheet format.
www.njr.com
- 29 -
[ CAUTION ]
1.
NJR strives to produce reliable and high quality semiconductors. NJR’s semiconductors are intended for specific applications
and require proper maintenance and handling. To enhance the performance and service of NJR's semiconductors, the devices,
machinery or equipment into which they are integrated should undergo preventative maintenance and inspection at regularly
scheduled intervals. Failure to properly maintain equipment and machinery incorporating these products can result in
catastrophic system failures
2.
The specifications on this datasheet are only given for information without any guarantee as regards either mistakes or
omissions. The application circuits in this datasheet are described only to show representative usages of the product and not
intended for the guarantee or permission of any right including the industrial property rights.
All other trademarks mentioned herein are the property of their respective companies.
3.
To ensure the highest levels of reliability, NJR products must always be properly handled.
The introduction of external contaminants (e.g. dust, oil or cosmetics) can result in failures of semiconductor products.
4.
NJR offers a variety of semiconductor products intended for particular applications. It is important that you select the proper
component for your intended application. You may contact NJR's Sale's Office if you are uncertain about the products listed in
this datasheet.
5.
Special care is required in designing devices, machinery or equipment which demand high levels of reliability. This is
particularly important when designing critical components or systems whose failure can foreseeably result in situations that
could adversely affect health or safety. In designing such critical devices, equipment or machinery, careful consideration
should be given to amongst other things, their safety design, fail-safe design, back-up and redundancy systems, and diffusion
design.
6.
The products listed in this datasheet may not be appropriate for use in certain equipment where reliability is critical or where
the products may be subjected to extreme conditions. You should consult our sales office before using the products in any of
the following types of equipment.
7.
8.
9.
Ver.5
Aerospace Equipment
Equipment Used in the Deep Sea
Power Generator Control Equipment (Nuclear, steam, hydraulic, etc.)
Life Maintenance Medical Equipment
Fire Alarms / Intruder Detectors
Vehicle Control Equipment (Airplane, railroad, ship, etc.)
Various Safety Devices
NJR's products have been designed and tested to function within controlled environmental conditions. Do not use products
under conditions that deviate from methods or applications specified in this datasheet. Failure to employ the products in the
proper applications can lead to deterioration, destruction or failure of the products. NJR shall not be responsible for any bodily
injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of the
products. The products are sold without warranty of any kind, either express or implied, including but not limited to any implied
warranty of merchantability or fitness for a particular purpose.
Warning for handling Gallium and Arsenic (GaAs) Products (Applying to GaAs MMIC, Photo Reflector). These products use
Gallium (Ga) and Arsenic (As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn,
destroy, or process chemically to make them as gas or power. When the product is disposed of, please follow the related
regulation and do not mix this with general industrial waste or household waste.
The product specifications and descriptions listed in this datasheet are subject to change at any time, without notice.
www.njr.com
- 30 -
