NJM2058
QUAD OPERATIONAL AMPLIFIER
■ GENERAL DESCRIPTION
The NJM2058 integrated circuit is a quad high-gain
operational amplifier internally compensated and constructed
on a single silicon chip using an advanced epitaxial process.
Each amplifier of the NJM2058 has the same electrical
characteristics of the NJM4558.
■ FEATURES
● Operating Voltage
● Package Outline
● Bipolar Technology
■ PACKAGE OUTLINE
NJM2058D
NJM2058M
( ±4V~±18V )
DIP14,DMP14,SSOP14
NJM2058V
■ PIN CONFIGURATION
NJM2058D
NJM2058M
NJM2058V
PIN FUNCTION
1. A OUTPUT
2. A -INPUT
3. A +INPUT
4. V
5. B +INPUT
6. B -INPUT
7. B OUTPUT
8.C OUTPUT
9. C –INPUT
10.C +INPUT
11.V
12.D +INPUT
13.D –INPUT
14.D OUTPUT
■ EQUIVALENT CIRCUIT ( 1/4 Shown )
Ver.2003-03-19
-1-
NJM2058
■ ABSOLUTE MAXIMUM RATINGS
( Ta=25˚C )
PARAMETER
Supply Voltage
Differential Input Voltage
Input Voltage
SYMBOL
+ V /V
VID
VIC
Power Dissipation
PD
Operating Temperature Range
Storage Temperature Range
Topr
Tstg
RATINGS
± 18
± 30
± 15 ( note1 )
( DIP14 ) 700
( DMP14 ) 700 ( note2 )
( SSOP14 ) 300
-40~+85
-40~+125
UNIT
V
V
V
mW
˚C
˚C
( note1 ) For supply voltage less than ±15V. the absolute maximum input voltage is equal to the supply voltage.
( note2 ) At on PC board
■ ELECTRICAL CHARACTERISTICS
( Ta=25˚C,V+/V-=±15V )
PARAMETER
Input Offset Voltage
Input Offset Current
Input Bias Current
Input Resistance
Large signal Voltage Gain
Maximum Output Voltage Swing 1
Maximum Output Voltage Swing 2
Input Common Mode Voltage Range
Common Mode Rejection Ratio
Supply Voltage Rejection Ratio
Operating Current
Slew Rate
Equivalent Input Noise Voltage
-2-
SYMBOL
VIO
IIO
IB
RIN
AV
VOM1
VOM2
VICM
CMR
SVR
ICC
SR
VNI
TEST CONDITION
RS≤10kΩ
RL≥2kΩ,VO=±10V
RL≥10kΩ
RL≥2kΩ
RS≤10kΩ
RS≤10kΩ
RIAA,RS=2.2kΩ,30kHz LPF
MIN.
0.3
86
± 12
± 10
± 12
70
76.5
TYP.
0.5
5
100
± 14
± 13
± 14
90
90
7
1
1.4
MAX.
6
200
500
11.3
UNIT
mV
nA
nA
MΩ
dB
V
V
V
dB
dB
mA
V/µs
µVrms
Ver.2003-03-19
NJM2058
Ver.2003-03-19
-3-
NJM2058
■ TYPICAL CHARACTERISTICS
-4-
Ver.2003-03-19
NJM2058
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
Ver.2003-03-19
-5-
很抱歉,暂时无法提供与“NJM2058V-TE1”相匹配的价格&库存,您可以联系我们找货
