ASNT5114-KMC
ASNT5114-KMC
    ADSANTEC(先进科技)
    CQFlatpack-24
    32G DIFF. D FLIP-FLOP, CM ADJ.
ASNT5114-KMC 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT5114-KMC DC-32Gbps Linearized High Sensitivity D-Type Flip-Flop  High speed broadband D-Type Flip-Flop for data retiming with full rate clock  Sensitive input data buffer with increased CM range that is ideal for sampling applications  Input data single-ended common mode controls  Exhibits low jitter and limited temperature variation over industrial temperature range  4ps set-up/hold time capability  88% clock phase margin for retiming of data input eye  Fully differential CML input interfaces  Fully differential CML output interface with 400mV single-ended swing  Single +3.3V or -3.3V power supply  Power consumption: 530mW  Fabricated in SiGe for high performance, yield, and reliability  Custom CQFP 24-pin package Rev. 1.4.2 1 Nov 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION vee dcinp 206 vcc vcc 79 413 50 DFF core dp dn 206 dcinn 413 vee qp qn 79 50 vcc 50 vcc 50 vcc cp cn vcc Fig. 1. Functional Block Diagram The temperature stable ASNT5114-KMC SiGe IC provides broadband data retiming functionality and is intended for use in high-speed measurement / test equipment. The IC shown in Fig. 1 can sample a highspeed data signal dp/dn with a full-rate external clock cp/cn to create a full-rate retimed NRZ data output qp/qn. The data input buffer is designed to have increased input signal sensitivity and is able to operate over a wider range of input common mode (CM) voltages. The actual common mode voltage levels on data inputs dp/dn can be adjusted by applying voltages between vee and vcc to the corresponding control inputs dcinp/dcinn. The part’s I/O’s support the CML logic interface with on chip equivalent 50Ohm termination and may be used differentially, AC/DC coupled, single-ended, or in any combination (see also POWER SUPPLY CONFIGURATION). In case of AC-coupled input data signals, the internal common mode voltage levels at the inputs of the input buffer are defined by on-chip resistive dividers. It should be noted that the control inputs dcinp/dcinn should be always connected to voltage sources to ensure correct 50Ohm terminations for the data inputs. POWER SUPPLY CONFIGURATION The part can operate with either a negative supply (vcc = 0.0V = ground and vee = −3.3V), or a positive supply (vcc = +3.3V and vee = 0.0V = ground). In case of a positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. All the characteristics detailed below assume vcc = 0.0V and vee = -3.3V. Rev. 1.4.2 2 Nov 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 1 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground (assumed vcc). Table 1. Absolute Maximum Ratings Parameter Supply Voltage (vee) Power Consumption Input Data Voltage Swing (SE) Input Clk Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Min -40 10 10 Max -3.6 0.58 1.7 1.7 +90 +100 98 98 Units V W V V ºC ºC % % TERMINAL FUNCTIONS TERMINAL Name No. Type dp dn cp cn qp qn dcinp dcinn Name vcc vee Rev. 1.4.2 DESCRIPTION High-Speed I/Os 21 CML Differential data inputs with internal SE 50Ohm termination to Input vcc 23 3 CML Differential clock inputs with internal SE 50Ohm termination Input to vcc 5 11 CML Differential data outputs with internal SE 50Ohm termination Output to vcc. Require external SE 50Ohm termination to vcc 9 DC Controls 15 Input Input data DC common mode voltage level controls. Should be always connected to voltage sources! 17 Supply and Termination Voltages Description Pin Number Positive power supply 2, 4, 6, 8, 10, 12, 14, 16, 18, 20, 22, 24 (+3.3V or 0V) Negative power supply 1, 7, 13, 19 (0V or -3.3V) 3 Nov 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER vcc vee Ivcc Power consumption Junction temperature Data rate Swing CM Voltage Level Frequency Swing CM Voltage Level Duty Cycle Clock phase margin Data rate Logic “1” level Logic “0” level Jitter Max level Min level MIN TYP MAX UNIT COMMENTS General Parameters 0.0 V External ground -3.1 -3.3 -3.5 V ±6% 160 175 mA 530 580 mW -25 50 125 °C HS Input Data (dp/dn) DC 32 40 Gbps 0.01 1.6 V Differential or SE, p-p vcc-1.6+sw/2 vcc-sw/2 V Must match for both inputs HS Input Clock (cp/cn) DC 32 40 GHz 0.05 1.3 V Differential or SE, p-p vcc-0.7+sw/2 vcc+0.6-sw/2 V Must match for both inputs 40 50 60 % 86 88 90 % For reliable data latching HS Output Data (qp/qn) DC 32 40 Gbps vcc-0.05 vcc-0.03 vcc-0.01 V vcc-0.46 vcc-0.44 vcc-0.42 V With external 50Ohm DC termination 0.15 ps Peak-to-peak at 32Gbps DC Input Controls (dcinp/dcinn) vcc + 1.0 V vcc - 1.0 V PACKAGE INFORMATION The chip die is housed in a custom 24-pin CQFP package shown in Fig. 2. The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. The part’s identification label is ASNT5114-KMC. The first 8 characters of the name before the underscore identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the underscore represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. Rev. 1.4.2 4 Nov 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Fig. 2. CQFP 24-Pin Package Drawing (All Dimensions in mm) Rev. 1.4.2 5 Nov 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com REVISION HISTORY Revision 1.4.2 1.3.2 1.2.2 1.2.1 1.1.1 1.0.1 Rev. 1.4.2 Date 11-2020 05-2020 07-2019 01-2014 06-2013 02-2013 Changes Corrected Pin Diagram Updated Package Information Updated Letterhead Corrected title Removed data duty cycle specification First release 6 Nov 2020
ASNT5114-KMC 价格&库存
很抱歉,暂时无法提供与“ASNT5114-KMC”相匹配的价格&库存,您可以联系我们找货
