IW3620-00
IW3620-00
    DIALOGSEMICONDUCTOR(戴乐格)
    SOIC8_150MIL_EP
    DIGITAL PWM CURRENT-MODE CONTROL
IW3620-00 数据手册
iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver 1.0 Features 2.0 Description ●● Primary-side feedback eliminates opto-isolators and simplifies design ●● Quasi-resonant operation for highest overall efficiency ●● EZ-EMI ® design to easily meet global EMI standards ●● Up to 130 kHz switching frequency enables small adapter size ●● Very tight LED constant current regulation ●● No external compensation components required ●● Built-in output constant-current control with primary-side feedback for LED driver. ●● Low start-up current (10 µA typical) ●● Built-in soft start The iW3620 is a high performance AC/DC offline LED driver which uses digital control technology to build peak current mode PWM flyback power supplies. The device operates in quasi-resonant mode at heavy load to provide high efficiency along with a number of key built-in protection features while minimizing the external component count, simplifying EMI design and lowering the total bill of material cost. The iW3620 removes the need for secondary feedback circuitry while achieving excellent line and load regulation. It also eliminates the need for loop compensation components while maintaining stability over all operating conditions. Pulse-bypulse waveform analysis allows for a loop response that is much faster than traditional solutions, resulting in improved dynamic load response. The built-in current limit function enables optimized transformer design in universal off-line applications over a wide input voltage range. ●● Built-in short circuit protection and output overvoltage protection 3.0 Applications ●● Current sense resistor short protection ●● LED lighting ●● Overtemperature Protection ●● Open circuit protection ●● Universal input range from 85 Vac to 264 Vac ●● Single-fault protection ●● Small input bulk capacitor ●● Long MTBF ●● High efficiency L VOUT + N + + RTN Optional NTC Thermistor 1 NC VCC 8 2 VSENSE 3 VIN 4 SD OUTPUT 7 ISENSE 6 GND 5 U1 iW3620 Figure 3.1 : Typical Application Circuit Rev. 1.8 iW3620 February 1, 2012 Page 1 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver 4.0 Pinout Description iW3620 1 NC 2 VSENSE 3 4 VCC 8 OUTPUT 7 VIN ISENSE 6 SD GND 5 Pin # Name Type Pin Description 1 NC - 2 VSENSE 3 VIN Analog Input Rectified AC line average voltage sense. 4 SD Analog Input 5 GND Ground 6 ISENSE 7 OUTPUT Output 8 VCC Power Input No connection. Analog Input Auxiliary voltage sense (used for primary side regulation). External shutdown control. Connect to ground through a resistor if not used. (see Section 10.16) Ground. Analog Input Primary current sense (used for cycle-by-cycle peak current control and limit). Gate drive for external MOSFET switch. Power supply for control logic and voltage sense for power-on reset circuitry. Rev. 1.8 iW3620 February 1, 2012 Page 2 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver 5.0 Absolute Maximum Ratings Absolute maximum ratings are the parameter values or ranges which can cause permanent damage if exceeded. For maximum safe operating conditions, refer to Electrical Characteristics in Section 6.0. Parameter Symbol Value Units DC supply voltage range (pin 8, ICC = 20mA max) VCC -0.3 to 18 V DC supply current at VCC pin ICC 20 mA Output (pin 7) -0.3 to 18 V VSENSE input (pin 2, IVsense ≤ 10 mA) -0.7 to 4.0 V VIN input (pin 3) -0.3 to 18 V ISENSE input (pin 6) -0.3 to 4.0 V SD input (pin 4) -0.3 to 18 V Power dissipation at TA ≤ 25°C PD 526 mW Maximum junction temperature TJ MAX 125 °C Storage temperature TSTG –65 to 150 °C Lead temperature during IR reflow for ≤ 15 seconds TLEAD 260 °C ψJB (Note 1) 70 °C/W ESD rating per JEDEC JESD22-A114 2,000 V Latch-Up test per JEDEC 78 ±100 mA Thermal Resistance Junction-to-PCB Board Surface Temperature Notes: Note 1. ψJB [Psi Junction to Board] provides an estimation of the die junction temperature relative to the PCB [Board] surface temperature. This data is measured at the ground pin (pin 5) without using any thermal adhesives. See Section 9.14 for more information. Rev. 1.8 iW3620 February 1, 2012 Page 3 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver 6.0 Electrical Characteristics VCC = 12 V, -40°C ≤ TA ≤ 85°C, unless otherwise specified (Note 1) Parameter Symbol Test Conditions Min Typ Max Unit VIN_A(STLOW) TA= 25°C, positive edge 335 369 406 mV 363 413 477 mV 15 µA VIN SECTION (Pin 3) Start-up low voltage threshold (VIN_A) at internal ADC input (see Figure 8.1) (Note 2) Start-up low voltage threshold (VIN) VIN(STLOW) Start-up current IINST VIN = 10 V, CVCC = 10 µF 10 Input impedance ZIN After start-up 5 IBVS VSENSE = 2 V kW VSENSE SECTION (Pin 2) Input leakage current 1 μA Nominal voltage threshold VSENSE(NOM) TA=25°C, negative edge 1.523 1.538 1.553 V Output OVP threshold (Note 2) VSENSE(MAX) TA=25°C, negative edge 1.790 1.846 1.900 V OUTPUT SECTION (Pin 7) Output low level ON-resistance RDS(ON)LO ISINK = 5 mA 40 W Output high level ON-resistance RDS(ON)-HP ISOURCE = 5 mA 75 W Rise time (Note 2) tR TA = 25°C, CL = 330 pF 10% to 90% 200 300 ns Fall time (Note 2) tF TA = 25°C, CL = 330 pF 90% to 10% 40 60 ns Any combination of line and load 130 140 kHz 16 V Maximum switching frequency fSW(MAX) VCC SECTION (Pin 8) Maximum operating voltage (Note 2) VCC(MAX) Start-up threshold VCC(ST) VCC rising 10.8 12 13.2 V Undervoltage lockout threshold VCC(UVL) VCC falling 5.5 6.0 6.6 V 3.5 5 mA Operating current ICCQ CL = 330 pF, VSENSE = 1.5 V Rev. 1.8 iW3620 February 1, 2012 Page 4 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver 6.0 Electrical Characteristics (cont.) VCC = 12 V, -40°C ≤ TA ≤ 85°C, unless otherwise specified (Note 1) Parameter Symbol Test Conditions Min Typ Max Unit ISENSE SECTION (Pin 6) Peak limit threshold VPEAK 1.045 1.1 1.155 V Isense short protection reference VRSNS 0.127 0.15 0.173 V CC regulation threshold limit (Note 2) VREG-TH 1.0 V SD SECTION (Pin 4) Shutdown threshold Shutdown threshold in Startup (Note 2) VSD-TH TA = 25°C 0.95 VSD-TH(ST) 1.0 1.05 1.2 Input leakage current IBVSD VSD = 1.0 V Pull down resistance RSD TA = 25°C 7916 Pull up current source ISD TA = 25°C 96 V V 1 µA 8333 8750 W 107 118 µA Notes: Note 1. Adjust VCC above the start-up threshold before setting at 12 V. Note 2. These parameters are not 100% tested, guaranteed by design and characterization. Note 3. Operating frequency varies based on the line and load conditions, see Theory of Operation for more details. Rev. 1.8 iW3620 February 1, 2012 Page 5 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver VCC Start-up Threshold (V) VCC Supply Start-up Current (µA) 7.0 Typical Performance Characteristics 9.0 6.0 3.0 0.0 0.0 2.0 4.0 8.0 6.0 VCC (V) 10.0 12.0 14.0 12.2 12.0 11.8 11.6 -50 25 50 75 100 125 Internal Reference Voltage (V) % Deviation of Switching Frequency from Ideal 0 Ambient Temperature (°C) Figure 7.2 : Start-Up Threshold vs. Temperature Figure 7.1 : VCC Supply Current vs. VCC 0.3 % 1.548 -0.3 % 1.538 -0.9 % -1.5 % -50 -25 1.528 -25 0 25 50 75 Ambient Temperature (°C) 100 Figure 7.3 : Switching Frequency % Change vs. Temperature 125 1.518 -50 -25 0 25 50 75 Ambient Temperature (°C) 100 125 Figure 7.4 : Internal Reference vs. Temperature Rev. 1.8 iW3620 February 1, 2012 Page 6 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver 8.0 Functional Block Diagram VIN 3 ENABLE VSENSE 2 ISD VIN_A 0.2 V ~ 2.0 V Signal Conditioning VVMS Gate Driver Digital Logic Control VFB Detection Switch – IPEAK VIPK 5 1.1 V 6 ISENSE DAC RSD GND – VSD-TH OUTPUT 60 kΩ VOCP + 4 7 ADC + SD VCC Start-up ENABLE ZVin 5 kΩ 8 0V~1V + – – Figure 8.1 : iW3620 Functional Block Diagram 9.0 Theory of Operation The iW3620 is a digital controller which uses a proprietary primary-side control technology to eliminate the opto-isolated feedback and secondary regulation circuits required in traditional designs. This results in a low-cost solution for AC/DC adapters. The iW3620 uses Critical Discontinuous Conduction Mode (CDCM) or Pulse Width Modulation (PWM) mode at high output power levels and switches to Pulse Frequency Modulation (PFM) mode at light load to minimize power dissipation to meet EPA 2.0 specification. Furthermore, iWatt’s digital control technology enables fast dynamic response, tight output regulation, and full featured circuit protection with primary-side control. control algorithm to reduce system design time and improve reliability. Referring to the block diagram in Figure 8.1, the digital logic control block generates the switching on-time and off-time information based on the line voltage and the output voltage feedback signal and provides commands to dynamically control the external MOSFET current. The system loop is compensated internally by a digital error amplifier. Adequate system phase and gain margin are guaranteed by design and no external analog components are required for loop compensation. The iW3620 uses an advanced digital iWatt’s digital control scheme is specifically designed to address the challenges and trade-offs of power conversion design. This innovative technology is ideal for balancing new regulatory requirements for green mode operation with more practical design considerations such as lowest possible cost, smallest size and highest performance output control. Furthermore, accurate secondary constant-current operation is achieved without the need for any secondary-side sense and control circuits. The built-in protection features include overvoltage protection (OVP), output short circuit protection (SCP) and soft-start, AC line brown out, overcurrent protection, and Isense fault protection. Also the iW3620 automatically shuts down if it detects any of its sense pins to be either open or short. Rev. 1.8 iW3620 February 1, 2012 Page 7 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver 9.1 Pin Detail Pin 2 – VSENSE turns off so that the VCC capacitor can be charged up again towards the start-up threshold. Figure 9.1 shows the startup sequence of the iW3620. Sense signal input from auxiliary winding. This provides the secondary voltage feedback used for output regulation. Start-up Sequencing Pin 3 – VIN VIN Sense signal input from the rectified line voltage. VIN is used for line regulation. The input line voltage is scaled down using a resistor network. It is used for input undervoltage and overvoltage protection. This pin also provides the supply current to the IC during start-up. VCC(ST) VCC Pin 4 – SD External shutdown control. If the shutdown control is not used, this pin should be connected to GND via a resistor. ENABLE Pin 5 – GND Figure 9.1 : Start-up Sequencing Diagram Ground. 9.3 Understanding Primary Feedback Pin 6 – ISENSE Figure 9.2 illustrates a simplified flyback converter. When the switch Q1 conducts during tON(t), the current ig(t) is directly drawn from rectified sinusoid vg(t). The energy Eg(t) is stored in the magnetizing inductance LM. The rectifying diode D1 is reverse biased and the load current IO is supplied by the secondary capacitor CO. When Q1 turns off, D1 conducts and the stored energy Eg(t) is delivered to the output. Primary current sense. Used for cycle by cycle peak current control. Pin 7 – OUTPUT Gate drive for the external MOSFET switch. iin(t) Pin 8 – VCC Power supply for the controller during normal operation. The controller will start up when VCC reaches 12 V (typical) and will shut-down when the VCC voltage is below 6 V (typical). A decoupling capacitor should be connected between the VCC pin and GND. + When VCC is fully charged to a voltage higher than the startup threshold VCC(ST), the ENABLE signal becomes active and enables the control logic; the VIN switch turns on, and the analog-to-digital converter begins to sense the input voltage. Once the voltage on the VIN pin is above VINSTLOW, the iW3620 commences soft start function. An adaptive soft-start control algorithm is applied at startup state, during which the initial output pulses will be small and gradually get larger until the full pulse width is achieved. The peak current is limited cycle by cycle by IPEAK comparator. If at any time the VCC voltage drops below VCC(UVL) threshold then all the digital logic is reset. At this time VIN switch id(t) N:1 vg(t) vin(t) VO + D1 CO IO VAUX – VAUX TS(t) 9.2 Start-up Prior to start-up the VIN pin charges up the VCC capacitor through the diode between VIN and VCC (see Figure 8.1). ig(t) Q1 Figure 9.2 : Simplified Flyback Converter In order to tightly regulate the output voltage, the information about the output voltage and load current needs to be accurately sensed. In the DCM flyback converter, this information can be read via the auxiliary winding. During the Q1 on-time, the load current is supplied from the output filter capacitor CO. The voltage across LM is vg(t), assuming the voltage dropped across Q1 is zero. The current in Q1 ramps up linearly at a rate of: dig (t ) dt = vg (t ) LM (9.1) At the end of on-time, the current has ramped up to: Rev. 1.8 iW3620 February 1, 2012 Page 8 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver ig _ peak (tON ) = vg (t ) × tON LM (9.2) 9.4 Dynamic Load Transient This current represents a stored energy of: LM E = × ig _ peak (tON ) 2 g 2 (9.3) When Q1 turns off, ig(t) in LM forces a reversal of polarities on all windings. Ignoring the communication-time caused by the leakage inductance LK at the instant of turn-off, the primary current transfers to the secondary at a peak amplitude of: NP id = × ig _ peak (tON ) (t ) NS represents the output voltage and is used to regulate the output voltage. There are two components that compose the voltage drop during a load transient event. VDROP(sense) is the drop in voltage before the VSENSE signal is able to show a significant drop in output voltage. This is determined by Vmin or the reference voltage at which a load transient is detected. The smaller the Vmin means the smaller this drop in voltage is. ( (9.4) Assuming the secondary winding is master and the auxiliary winding is slave. VAUX = VO x NAUX NS (9.7) The final drop in voltage is due to the time from when VSENSE drops Vmin to when the next VSENSE signal appears. In the worst case condition this is how much voltage drops during the longest switching period. I OUT × TP (No load) COUT (9.8) 9.5 Valley Mode Switching NAUX NP Figure 9.3 : Auxiliary Voltage Waveforms The auxiliary voltage is given by: = VAUX A larger output capacitance in this case greatly reduces the VDROP(IC). 0V VAUX = -VIN x VOUT VSENSE ( nom ) Keep in mind that a smaller Vmin is less tolerant of noise and distortions in VSENSE than a larger one. VDROP ( IC ) = VAUX ) VDROP ( sense ) = VSENSE ( nom ) − VSENSE (min) × N AUX (VO + ∆V ) NS (9.5) and reflects the output voltage as shown in Figure 9.3. The voltage at the load differs from the secondary voltage by a diode drop and IR losses. The diode drop is a function of current, as are IR losses. Thus, if the secondary voltage is always read at a constant secondary current, the difference between the output voltage and the secondary voltage will be a fixed ΔV. Furthermore, if the voltage can be read when the secondary current is small; for example, at the knee of the auxiliary waveform (see Figure 9.3), then ΔV will also be small. With the iW3620, ΔV can be ignored. The real-time waveform analyzer in the iW3620 reads the auxiliary waveform information cycle by cycle. The part then generates a feedback voltage VFB. The VFB signal precisely In order to reduce switching losses in the MOSFET and EMI, the iW3620 employs valley mode switching when IOUT is above 50%. In valley mode switching, the MOSFET switch is turned on at the point where the resonant voltage across the drain and source of the MOSFET is at its lowest point (see Figure 9.4). By switching at the lowest VDS, the switching loss will be minimized. Gate VDS Figure 9.4 : Valley Mode Switching Turning on at the lowest VDS generates lowest dV/dt, thus valley mode switching can also reduce EMI. To limit the switching frequency range, the iW3620 can skips valleys Rev. 1.8 iW3620 February 1, 2012 Page 9 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver (seen in the first cycle in Figure 9.4) when the switching frequency becomes too high. iW3620 provides valley mode switching during constant current (CC) output operation. So, the EMI and switching losses are still minimized during CC mode. This feature is superior to other quasi-resonant technologies which only support valley mode switching during constant voltage operation. This is beneficial to LED driver applications where the IC mainly operates in CC mode. 9.6 Constant Voltage Operation After soft-start has been completed, the digital control block measures the output conditions. It determines output power levels and adjusts the control system according to a light load or a heavy load. If this is in the normal range, the device operates in the Constant Voltage (CV) mode, and changes the pulse width (TON), and off time (TOFF) in order to meet the output voltage regulation requirements. During this mode the PWM switching frequency is between 30 kHz and 130 kHz, depending on the line and load conditions. If less than 0.2 V is detected on VSENSE it is assumed that the auxiliary winding of the transformer is either open or shorted and the iW3620 shuts down. 9.7 Constant Current Operation The constant current mode (CC mode) maintains a constant current output. During this mode of operation the iW3620 will regulate the output current at a constant level regardless of the output voltage, while avoiding continuous conduction mode. Figure 9.5 shows the operation modes of the iW3620. To achieve this regulation the iW3620 senses the load current indirectly through the primary current. The primary current is detected by the ISENSE pin through a resistor from the MOSFET source to ground. CC mode Output Current Figure 9.5 : Power Envelope The iW3620 normally operates in a fixed frequency PWM or critical discontinuous conduction mode when IOUT is greater than approximately 10% of the specified maximum load current. As the output load IOUT is reduced, the on-time tON is decreased. At the moment that the load current drops below 10% of nominal, the controller transitions to Pulse Frequency Modulation (PFM) mode. Thereafter, the ontime will be modulated by the line voltage and the off-time is modulated by the load current. The device automatically returns to PWM mode when the load current increases. 9.9 Variable Frequency Operation At each of the switching cycles, the falling edge of VSENSE will be checked. If the falling edge of VSENSE is not detected, the off-time will be extended until the falling edge of VSENSE is detected. The maximum allowed transformer reset time is 75 µs for iW3620. 9.10 Internal Loop Compensation The iW3620 incorporates an internal Digital Error Amplifier with no requirement for external loop compensation. For a typical power supply design, the loop stability is guaranteed to provide at least 45 degrees of phase margin and –20dB of gain margin. 9.11 Voltage Protection Functions The iW3620 includes a function that protects against an output overvoltage (OVP). The output voltage is monitored by the VSENSE pin. If the voltage at this pin exceed its overvoltage threshold the iW3620 shuts down immediately. However, the IC remains biased which discharges the VCC supply. Once VCC drops below the UVLO threshold, the controller resets itself and then initiates a new soft-start cycle. The controller continues attempting start-up until the fault condition is removed. 9.12 PCL, OC and SRS Protection CV mode Output Voltage VNOM 9.8 PFM Mode at Light Load IOUT(CC) Peak-current limit (PCL), over-current protection (OCP) and sense-resistor short protection (SRSP) are features built-into the iW3620. With the ISENSE pin the iW3620 is able to monitor the primary peak current. This allows for cycle by cycle peak current control and limit. When the primary peak current multiplied by the ISENSE sense resistor is greater than 1.1 V over current is detected and the IC will immediately turn off the gate drive until the next cycle. The output driver will send out switching pulse in the next cycle, and the switching pulse will continue if the OCP threshold is not reached; or, the switching pulse will turn off again if the OCP threshold is still reached. Rev. 1.8 iW3620 February 1, 2012 Page 10 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver If the ISENSE sense resistor is shorted there is a potential danger of the over current condition not being detected. Thus the IC is designed to detect this sense-resistor-short fault after start-up, and shutdown immediately. The VCC will be discharged since the IC remains biased. Once VCC drops below the UVLO threshold, the controller resets itself and then initiates a new soft-start cycle. The controller continues attempting start-up, but does not fully start-up until the fault condition is removed. 9.13 Shutdown The shutdown (SD) pin in the iW3620 provides protection against overtemperature (OTP) and additional overvoltage (OVP) for the power supply. The iW3620 switches between monitoring overtemperature fault and overvoltage fault. In order to detect the resistance in the NTC for an overtemperature fault, the iW3620 connects a current source to the SD pin and checks the voltage on the pin. To ensure that the current source is settled before the voltage is checked both OTP and OVP are detected on the last cycle, as depicted in Figure 9.6. OTP Detection OVP Detection 9.14 Thermal Design The iW3620 is typically installed inside a small enclosure, where space and air volumes are constrained. Under these circumstances θJA (thermal resistance, junction to ambient) measurements do not provide useful information for this type of application. Instead we have provided ψJB which estimates the increase in die junction temperature relative to the PCB surface temperature. Figure 9.8 shows the PCB surface temperature is measured at the IC’s GND pin pad. ψJB J B Exposed Die Pad Thermal Epoxy Artic Silver Copper Thermal Pad Under Package PCB Top Copper Trace IC Die Printed Circuit Board GND pin Printed Circuit Board Thermal Vias Connect top thermal pad to bottom copper PCB Bottom Copper Trace Figure 9.8 : Ways to Improve Thermal Resistance Using ψJB, the junction temperature (TJ) of the IC can be found using the equation below. T= TB + PH ⋅ ψ JB (9.9) J Vgate where, TB is the PCB surface temperature and PH is the power applied to the chip or the product of VCC and ICCQ. Detection Switch Detection Switch: When switch is low SD pin is connected to R SD When switch is high SD pin is connected to a current source ISD Figure 9.6 : SD Pin Detection Cycles During an overvoltage monitor cycle the SD pin is connected to a resistance internal to the chip, RSD, to ground and the voltage on the SD pin is observed. Figure 9.7 shows how the SD pin is configured inside the chip. Ways to Improve Thermal Resistance ●● Increase PCB area and associated amount of copper interconnect. iW3620 ISD Detection Switch SD pin The iW3620 uses an exposed pad package to reduce the thermal resistance of the package. Although just by using an exposed package can provide some thermal resistance improvement, more significant improvements can be obtained with simple PCB layout and design. Figure 9.8 demonstrates some recommended techniques to improve thermal resistance, which are also highlighted below. OTP / OVP Fault Detect ●● Use thermal adhesive to attach the package to a thermal pad on PCB. ●● Connect PCB thermal pad to additional copper on PCB. Environment ψJB No Attachment to PCB 70 °C/W Attach Package to PCB with Thermal Adhesive 63 °C/W Use Thermal Adhesive and Thermal Vias 49 °C/W VSD-TH R SD Figure 9.7 : Internal Function of SD Pin Table 9.1 : Improvements in ψJB Based on Limited Experimentation Rev. 1.8 iW3620 February 1, 2012 Page 11 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver Effect of Thermal Resistance Improvements 85 10.1 Design Procedure 75 ΨJB (˚C/Watt) 10.0 Design Example This design example gives the procedure for a flyback converter using iW3620. Refer to Figure 12.1 for the application circuit. The design objectives for this adapter are given in Table 10.1. It meets UL, IEC, and CEC requirements. A ~ 30% 65 55 B 45 Determine the Design Specifications (Vout, Iout_max, Vin_max, Vin_min, ƒline, Ripple specification) 35 Determine Rvin Resistors 25 5 10 15 20 25 30 PCB Area (cm2) Determine Turns Ratio A: without thermal adhesive and thermal vias B: with thermal adhesive and thermal vias Determine Operating VinTon Limit Figure 9.9 : Effect of Thermal Resistance Improvements Determine Magnetizing Inductance Figure 9.9 shows improvement of approximately 30% in thermal resistance across different PCB sizes when the exposed pad is attached to PCB using a thermal adhesive and thermal vias connect the pad to a larger plate on the opposing side of the PCB. Determine Primary Turns Determine Secondary Turns Determine Bias Turns and Vcc Capacitance No Determine Vsense Resistors Can you wind this transformer ? Yes Determine Current Sensing Resistor Determine Input Bulk Capacitance Determine Output Capacitance Determine Snubber Network Determine Ton Delay Compensation Determine SD Pin Components Finish Figure 10.1 : Design Procedure Rev. 1.8 iW3620 February 1, 2012 Page 12 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver 10.2 Determine Design Specifications Parameter Symbol VIN 90 - 264 VRMS fIN 47 - 64 Hz Maximum Output Voltage VOUT(max) 24.0 V Nominal Output Voltage VOUT(nom) 21.0 V Maximum Output Current IOUT(max) 0.87 A Nominal Output Current IOUT(nom) 0.5 A Output Ripple VRIPPLE < 100 mV Power Out POUT 20 W EPA 2.0 Efficiency h 84% Input Voltage Frequency Range Table 10.1 : iW3620 Design Specification Table Use equation 10.1 and 10.2 to determine VOUT in the following calculations, where VFD is the forward voltage of the output diode. VOUT (= 110% × VOUT ( nom ) PCB ) = VOUT VOUT ( PCB ) + VFD (10.1) (10.2) For this example the nominal VOUT(nom) is 21 V, assuming VFD is 0.5, VOUT is: VOUT ( PCB ) = 110% × 21V = 23.1 VIN resistors are chosen primarily to scale down the input voltage for the IC. The default scale factor for the input voltage in the IC is 0.0043 and the internal impedance of this pin is ZIN (5 kW). Therefore, the VIN resistors should equate to: Z IN − Z IN 0.0043 (10.3) From equation 10.3, ideally RVin should be 1.16 MW. A lower value of RVin can decrease the startup time of the power supply. The value of RVin affects the (VINTON) limits of the IC. 720V ⋅ ms IN ( RVin + Z IN ) ( RVin + Z IN ) (10.5) (VIN ⋅ TON )= limit 0.0043 × (VIN ⋅ TON )= limit 0.0043 × 5k W 720V ⋅ms = 697V ⋅ms (1.12M W + 5k W ) 135V ⋅ms = 131V ⋅ms 5k W (1.12 + 5k W ) Keep in mind, by changing RVin to be something other than 1.16 MW the minimum and maximum input voltage for startup also changes. Since the iW3620 uses the exact scaled value of VIN for its calculations, there should be a filter capacitor on the input pin to filter out any noise that may appear on the VIN signal. This is especially important for line in surge conditions. 10.4 Turns Ratio The maximum allowable turns ratio between the primary and secondary winding is determined by the minimum detectable reset time of the transformer during PFM mode. NTR (max) = (VIN ⋅ TON )PFM TRESET (min) × VOUT (10.6) Setting TRESET(min) at 1.5 μs, 131V ⋅ms = 3.70 1.5ms × 23.6V For this example a turns ratio of 2.5 is chosen. 10.3 Input Selection (VIN ⋅ TON )limit =0.0043 × Z 135V ⋅ms IN For this example RVin is chosen to be 1.12 MΩ therefore, = NTR (max) VOUT = 23.1V + 0.5V = 23.6V = RVin (VIN ⋅ TON )limit =0.0043 × Z Keep in mind in valley mode switching the higher the turns ratio the lower the VDS turn-on voltage, which means less switch turn-on power loss. Also consider the voltage stress on the MOSFET (VDS) is higher with an increase in turns ratio. The voltage stress on the output diode is lower with an increase in turns ratio respectively. 10.5 Operating Maximum (VINTON) Maximum operating VINTON or (VINTON)MAX for valley mode switching is traditionally designed at full load and lowest input voltage. For the iW3620, two constraints (equation 10.7 and 10.8) need to be satisfied so that indeed (VINTON)MAX occurs at full load and lowest input voltage. (10.4) Rev. 1.8 iW3620 February 1, 2012 Page 13 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver TP (QR min) > TP' (QR min) > 1 100kHz (10.7) 1 + TRES 110kHz (10.8) TRES is the VDS resonant period as shown in Figure 10.2. TRES can be estimated to be approximately 2 μs as a starting point and then adjusted after the power supply is tested. Gate Since we calculated 399 V·μs as our VIN·TON we have enough margin. 10.6 Magnetizing Inductance A feature of the iW3620 is the lack of dependence on the magnetizing inductance for the CC curve. Although the constant current limit does not depend on the magnetizing inductance, there are still restrictions on the magnetizing inductance. The maximum LM is limited by the amount of power that needs to come out of the transformer in order for the power supply to regulate. This is given by: (VIN ⋅ TON )2max × f sw(max op) LM (max) = 2 × PXFMR (max) V ×I = OUT OUT hX PXFMR (max) VDS Where ηX is the efficiency of the transformer, for this example we assume it’s 87 %. TRES TRESET TON TPERIOD PXFMR (max) = Figure 10.2 : VDS Timing LM (max) = When both criterion are met then (VINTON)MAX can be determined by equation 10.9. (VIN   1 1 ⋅ TON )max =  f SW (max op) ×  +  VINDC (min) NTR × VOUT   where, f SW (max op) =     −1 1 TP (QRmin) (10.9) Where VINDC(min) is the minimum input voltage across the bulk capacitor. Assuming TRES is 2 μs then: 1 > + 2ms= 11.1ms 110kHz f SW (max= 85kHz , and= TP 11.76ms op) −1  1  1  399V ⋅ms + 85kHz ×   = 80 V 2.5 23.6 ×    Also, to provide enough margin for component values, usually: (VIN ⋅ TON )max < (VIN ⋅ TON )limit × 0.85 = (VIN ⋅ TON )max < 697V ⋅ ms × 0.85 ( 399V ⋅ms )2 × 85kHz = 0.497 mH 2 × 13.6W LM (min) = 2 × PXFMR ( max ) V  f SW (max op) ×  REG −TH RIsense   2 (10.12) 2 × 13.6W = 0.387 mH 2 85kHz × 1.0V 1.1W ( ) For this example, we choose LM to be 0.438 mH. Using 80 V for VINDC(min), (VIN ⋅ TON )= max 23.6V × 0.5 A = 13.6W 0.87 The minimum LM is limited by the maximum allowable peak primary current. VREG-TH corresponds to the maximum ISENSE voltage (see Section 10.11 to calculate RIsense). Therefore LM is limited by: = LM (min) TP (QR min) > 10ms TP' (QR min) (10.11) 592V ⋅ms (10.10) If these limits do not give enough tolerance for LM, increasing (VINTON)max can raise the maximum limit on LM. Take care not to go above (VINTON)limit. Also, keep in mind that if equation 10.7 and 10.8 are not met then (VINTON)max does not occur at full load and lowest input voltage, thus some of the equations here would be invalid. 10.7 Primary Winding In order to keep the transformer from saturation, the maximum flux density must not be exceeded. Therefore the minimum primary winding must meet: Rev. 1.8 iW3620 February 1, 2012 Page 14 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver N PRI ≥ (VIN ⋅ TON )max Bmax × Ae = VSENSE VOUT _ PCB × K SENSE (10.13) (10.17) Where: Where BMAX is maximum allowed flux density and Ae is the RBVsns N K SENSE × Vsense core area. From the transformer core datasheet we find that= RBVsns + RTVsns ) N SEC ( (10.18) for this example BMAX is 320 mT. For an RM6 core, Ae is 35 2 mm . Internally, VSENSE is compared to a reference voltage 399V ⋅ ms VSENSE(nom). Where, VSENSE(nom) is 1.538 V. N 36 ≥ = PRI 320mT × 35mm 2 For this example, we choose 75 primary turns. 10.8 Secondary Winding From the primary winding turns, we obtain the secondary winding. N PRI NTR N SEC = (10.14) N SEC = 10.9 Bias Winding and VCC Capacitance VCC is the supply to the iW3620 and should be below 16 V. The bias winding needs to ensure than VCC does not exceed 16 V during normal operation. N SEC (VCC + VFD ) VOUT (10.15) 30 (11V + 0.5 ) = 15 23.6 Choose a value for NBIAS to be close to this number, for this example we choose 15 turns. The VCC capacitor (CVcc) stores the VCC charge during IC operation and the controller checks this voltage and makes sure it is within range before starting and operating. The startup time is a function of how quickly this capacitor can charge up. tSTART −UP = CVCC × VCC ( ST ) VINAC × 2 RVin From here we can find the ratio necessary for RBVsns and RTVsns. For this example we set RTVsns to be 20 kΩ. Assuming we use the same winding for both VSENSE and VCC: RBVsns ( RBVsns + 20k W ) × 15 30 − I INST At this point the transformer design is complete. This would be a good time to confirm that this transformer is feasible to build. 10.11 Current Sense Resistor The ISENSE resistor determines the maximum current output of the power supply. The output current of the power supply is determined by: I OUT = Set VCC at around 11 V = N BIAS (10.19) ∴ RBVsns = 3.0k W 75 = 30 2.5 N BIAS = VOUT _ PCB 1.538V = 0.065 23.6V K= SENSE = 0.065 Thus, in our example: VSENSE ( nom ) K SENSE = (10.16) 10.10 VSENSE Resistors and Winding 1 2 × NTR × I PRI ( pk ) × TRESET × hX TPERIOD (10.20) When the maximum current output is achieved the voltage seen on the ISENSE pin (VIsense) should reach its maximum. Thus, at constant current limit: I PRI ( pk ) = VIsense (CC ) RIsense (10.21) Substituting this into equation 10.20 we get: VIsense = (CC ) TPERIOD × KC TRESET (10.22) For iW3620 KC is 0.5 V, therefore RIsense depends on the maximum output current by; = RIsense The output voltage regulation is mainly determined by the feedback signal VSENSE. Rev. 1.8 iW3620 February 1, 2012 NTR × KC × hX 2 × I OUT ( nom ) (10.23) Page 15 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver From Table 10.1 IOUT(nom) is given to be 0.5 A, therefore RIsense is: RIsense = I SEC ( pk ) 2.5 × 0.5V = × 0.87 =1.08W 2 × 0.5 A 10.12 Input Bulk Capacitor The input bulk capacitor, CBULK is chosen to maintain enough input power to sustain constant output power even as the input voltage is dropping. In order for this to be true CBULK must be: PIN = V  2 × PIN × 0.25 + 21π × arcsin  INDC (min)  2 ×VINAC (min)  = 2 2 2 × VINAC (min) − VINDC (min) × f line ( )    (10.24) VOUT (Cable ) × I OUT hpower supply VINAC(min) is the minimum input voltage (rms) to be inputted into the power supply and fline is the lowest line frequency for the power supply (in this case 47 Hz). VINDC(min) is determined in Section 10.5 to be 80 V. 23.6V × 0.5 A = 13.88W 0.85 2 × 13.88W × 0.25 + 21π × arcsin  CBULK= 2 × 852 − 802 × 47 = PIN ( ) ( 80V 2 ×85VAC )= 10.13 Output Capacitance 22mF ) LM × NTR × h X I OUT ( HIGH ) × TP (No load) VDROP ( IC ) (10.28) Then solving for VDROP(IC), where VDynamic(DROP) is the maximum allowable drop in voltage for the design during dynamic response, and VDROP(sense) is the drop in voltage before VSENSE signal is low enough to register a dynamic transient. I OUT ( HIGH ) × TP (No load) VDynamic ( Drop ) − VDROP ( sense ) (10.29) RPreload × (VIN ⋅ TON ) PFM 2 2 × LM × VOUT × hNo load (10.30) Assume that we want no more than 2.0 V drop on VOUT(PCB) during load transient from no load to 100% load and the efficiency of the power supply at no load (ηNo load) is 50% , then COUT(Dynamic) is: 20k W × (131V ⋅ms ) 2 2 × 0.438mH × 23.6V 2 VDROP ( sense ) = (1.538V − 1.48V ) × × 0.5 = 352ms 23.6V = 0.890V 1.538V Plug everything into equation 10.29: 2 (10.26) The ISEC(pk) is: I SEC ( pk ) = COUT ( Dynamic ) = (10.25) 2 2 × NTR × h X × VOUT (VIN ⋅ TON )MAX Assume that the load transient goes from no load to IOUT(HIGH). Then from Section 9.4, equation 9.8 we find that the relationship between output capacitance (COUT(Dynamic)) and VDROP(IC) is : TP ( No load ) = The output capacitor supplies the load current when the secondary current is below the output current. QOUT = The actual ripple is higher than the above calculations suggest, because the calculations do not include ESR. 2 QOUT VOUT ( ripple) 3.74mC = 37mF 100mV COUT (Steady State)= = TP ( No load ) Assuming an ideal capacitor where ESR (equivalent series resistance) and ESL (equivalent series inductance) are negligible then: ( 0.438mH × (1.98 A − 0.5 A ) = 3.74mC 2 × 2.52 × 0.87 × 23.6V Where TP(No load) is the maximum period under no load condition, given by equation 10.30: The output capacitance affects both the steady state ripple and the dynamic response of the power supply. LM × I SEC ( pk ) − I OUT ( nom ) QOUT = COUT ( Dynamic ) = For this example CBULK is chosen to be 47 µF. COUT (Steady State) = 399V ⋅ms 0.87 1.98 A × 2.5 ×= 0.438mH 2 We recommend using ±1% tolerance resistors for RIsense. CBULK So to keep VOUT(ripple) to be 100 mV, COUT ( Dynamic= ) 0.5 A × 352ms = 159mF ( 2V − 0.890V ) Pick the larger capacitance value between COUT(Dynamic) and COUT(Steady State). In this case COUT is chosen to be 470 μF. (10.27) Rev. 1.8 iW3620 February 1, 2012 Page 16 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver 10.14 Snubber Network The snubber network is implemented to reduce the voltage stress on the MOSFET immediately following the turn off of the gate drive. The goal is to dissipate the energy from the leakage inductance of the transformer. For simplicity and a more conservative design first assume the energy of the leakage inductance is only dissipated through the snubber. Thus: 1 2 2 2 1  2  × Llk × I PRI ( pk ) =2 × CSNUB × VSnub ( pk ) − VSnub ( val )  (10.31) Llk can be measured from the transformer. VSnub(pk) and VSnub(val) refer to the voltage measured across the snubber capacitor. Choose a CSNUB, keeping in mind that the larger the value of CSNUB the lower the voltage stress is on the MOSFET. However, capacitors are more expensive the larger their capacitance. Choose CSNUB based on these two criteria and select VSnub(pk) and VSnub(val). Now a resistor needs to be selected to dissipate VSnub(pk) to VSnub(val) during the ontime of the gate driver. The dissipation of this resistor is given by: VSnub (val ) VSnub ( pk ) 1.  Measure the difference between high line and low line constant current limit without filter components. 2.  Find the curve that best matches this difference from Figure 11.1. 3.  Find the LM that matches the power supply, and find the tRC. 4.  Find RDly and CDly from equation 10.33 t RC = RDly × CDly (10.33) 10.16 SD Protection The SD pin can be configured to provide three different types of protection: OTP protection, OVP protection and both OVP and OTP Protection. Figure 10.3 shows the three configurations plus the configuration for no OTP and OVP protection. RSD1(ext) SD pin =e − TP ( min op) RNTC RSNUB ⋅CSNUB Using equation 10.32 solve for RSNUB. This gives a conservative estimate of what CSNUB and RSNUB should be. Included in the snubber network is also a resistor in series with a diode. The diode directs current to the snubber capacitor when the MOSFET is turned off; however there is some reverse current that goes through the diode immediately after the MOSFET is turned back on. This reverse current occurs because there is a short period of time when the diode still conducts after switching from forward biased to reverse biased. This conduction distorts the falling edge of the VSENSE signal and affects the operation of the IC. So, the resistor in series with the diode is there to diminish the reverse current that goes through the diode immediately after the MOSFET is turned on. 10.15 TON Delay Filter iW3620 also contains a feature that allows for adjustment to match high line and low line constant current curves. The mismatch in high line and low line is due to the delay from the IC propagation delay, driver turn-on delay, and the MOSFET turn-on delay. The driver turn-on delay maybe further increased by a gate resistor to the MOSFET. To adjust for these delays the iW3620 factors these delays into its calculations and slightly over compensates for them to provide flexibility. RDly and CDly provide extra delay in the circuit to tweak the compensation. To determine values RDly and CDly follow these steps: SD pin RSD2(ext) RSD(ext) (optional) (10.32) RNTC OUTPUT a) Overtemperature Protection only b) Overtemperature Protection and Overvoltage Protection SD pin RSD(ext) RSD(ext) SD pin c) Overvoltage Protection only d) No Overtemperature Protection and no overvoltage protection Figure 10.3 : SD Pin Application Configurations OTP Only To detect an overtemperature protection the iW3620 sends a 107 mA current (ISD) to the SD pin every four cycles (see Section 9.13). On the last cycle the iW3620 observes the voltage on the SD pin and detects an OTP fault if the voltage is lower than VSD-TH, 1.0 V during normal operation and 1.2 V during startup. So RSD(ext) in series with NTC must meet ( RNTC +RSD(ext ) ) × I SD > VSD−TH (10.34) in order not to trigger OTP fault during normal operation. OVP Only For the other four cycles, the iW3620 connects the SD pin to RSD to ground (see Section 9.13). At the last cycle the iW3620 observes the voltage on the SD pin and detects an Rev. 1.8 iW3620 February 1, 2012 Page 17 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver OVP fault if the voltage is higher than VSD-TH, 1 V. In order to not trigger OVP fault, assuming 0 V drop across the series diode, RSD(ext) must meet: 3.  VCC winding and rectifier diode loop. L VOUT + VOUT _ PCB N SEC × N AUX × RSD RSD < VSD −TH + RSD (ext ) N 3) Both OTP and OVP Optional NTC Thermistor To find RSD1(ext) so that OVP can be detected, use equation 10.35. To find RSD2(ext) in series with the NTC use equation 10.34. No OTP and OVP If OTP and OVP from the SD pin are not needed, simply place a resistor, RSD(ext) to ground from the SD pin. Make sure RSD(ext) meets equation 10.36 so OTP protection does not trip. (10.36) Note that this means OVP is not detected through the SD pin; however, OVP from VSENSE pin is still active and the iW3620 still shuts down if overvoltage condition is detected. + + (10.35) where, RSD = 8.333 kΩ RSD (ext ) × I SD > VSD −TH 2) 1) 1 NC 2 VSENSE 3 VIN 4 SD RTN VCC 8 OUTPUT 7 ISENSE 6 GND 5 U1 iW3620 Figure 10.4 : Switching Loops To improve ESD performance provide a low impedance path from the ground pin of the transformer to the ac power source and make sure this path does not go through the IC ground pin. A discharge spark gap helps to transfer ESD and EOS energy from the secondary side of the power supply directly to the external ac power source. In a switch-mode power supply there are several ground signals, namely: the power ground, the switching ground and the control logic ground. These ground signals should be connected by a star connection. Ground traces should be kept as short as possible. A thick trace on the switching ground helps to lessen switching losses. Since for this example OTP and OVP are not necessary we place a resistor from SD pin to ground and calculate its value from equation 10.36. RNTC > 1.2V 100mA = 12k W 10.17 PCB Layout In the iW3620, there are two signals that are important to control the output performance; these are the ISENSE signal and the VSENSE signal. The ISENSE resistor should be close to the source of the MOSFET to avoid any trace resistance from contaminating the ISENSE signal. Also, the ISENSE signal should be placed close to the ISENSE pin. The VSENSE signal should be placed close to the transformer to improve the quality of the sensing signal. Also for better output performance all bypass capacitors should be placed close to their respective pins. To reduce EMI, switching loops need to be minimized. These loops include (see Figure 10.4): 1.  The input bulk capacitor, primary winding, MOSFET and RIsense loop. 2.  The output diode, output capacitor and secondary winding loop. Rev. 1.8 iW3620 February 1, 2012 Page 18 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver 11.0 Performance Characteristics 120 ∆IOUT (Note1) 50 mA 40 mA 30 mA 20 mA 10 mA (RDly x CDly), τRC (ns) 100 80 60 40 20 0 0.0 0.5 1.0 1.5 2.0 2.5 Magnetizing Inductance LM (mH) 3.0 Figure 10.5 : TON Compensation Chart 12.0 Application Circuit L 2 A / 250 V 470 µH VOUT 10 kΩ + Cbulk 0.1 µF N Cbulk 47 µF + Rvin 560 kΩ Rvin 560 kΩ 470 pF Csnub 10 nF Rsnub 120 kΩ + Cvcc 4.7 µF Cout + 470 µF 0Ω Rpreload 20 kΩ 10 Ω RTN Rtvsns 20 kΩ Rbvsns 3.0 kΩ 68 pF Rntc 20 kΩ VCC 8 1 NC 2 VSENSE 3 VIN ISENSE 6 4 SD GND 5 OUTPUT 7 U1 iW3620 Rgate 10 Ω Rdly 1 kΩ Cdly 270 pF Risense 1.1 Ω Figure 12.1 : Typical Application Circuit Note 1: ΔIOUT refers to the difference in constant current limit between 264 Vac and 90 Vac when no RDLY and CDLY are applied. Rev. 1.8 iW3620 February 1, 2012 Page 19 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver 13.0 Physical Dimensions 8-Lead Small Outline (SOIC) Package E M 8 5 1 4 8 5 N H 4 e TOP VIEW 1 EXPOSED PAD BOTTOM VIEW Inches Symbol D MIN MAX MIN A 0.051 0.067 1.30 1.70 A1 0.0020 0.0060 0.05 0.150 A COPLANARITY 0.10 (0.004) B SEATING PLANE L α C SIDE VIEWS MAX B 0.014 0.019 0.36 0.48 C 0.007 0.010 0.18 0.25 D 0.189 0.197 4.80 5.00 E 0.150 0.157 3.81 3.99 e A1 Millimeters 0.050 BSC 1.27 BSC H 0.228 0.244 5.79 6.20 N 0.086 0.118 2.18 3.00 2.39 M 0.094 0.126 L 0.016 0.050 0.41 1.27 α 0° 8° 3.20 Figure 13.1 : Physical dimensions, 8-lead SOIC package Compliant to JEDEC Standard MS12F Controlling dimensions are in inches; millimeter dimensions are for reference only This product is RoHS compliant and Halide free. Soldering Temperature Resistance: [a] Package is IPC/JEDEC Std 020D Moisture Sensitivity Level 3 Dimension D does not include mold flash, protrusions or gate burrs. Mold flash, protrusions or gate burrs shall not exceed 0.15 mm per end. Dimension E does not include interlead flash or protrusion. Interlead flash or protrusion shall not exceed 0.25 mm per side. The package top may be smaller than the package bottom. Dimensions D and E are determined at the outermost extremes of the plastic bocy exclusive of mold flash, tie bar burrs, gate burrs and interlead flash, but including any mismatch between the top and bottom of the plastic body. 14.0 Ordering Information Part Number Package Description iW3620-00 SOIC-8 Tape & Reel1 Note 1: Tape & Reel packing quantity is 2,500/reel. Rev. 1.8 iW3620 February 1, 2012 Page 20 iW3620 Digital PWM Current-Mode Controller for AC/DC LED Driver About iWatt iWatt Inc. is a fabless semiconductor company that develops intelligent power management ICs for computer, communication, and consumer markets. The company’s patented pulseTrain™ technology, the industry’s first truly digital approach to power system regulation, is revolutionizing power supply design. Trademark Information © 2012 iWatt, Inc. All rights reserved. iWatt, EZ-EMI and pulseTrain are trademarks of iWatt, Inc. All other trademarks and registered trademarks are the property of their respective companies. Contact Information Web: http://www.iwatt.com E-mail: info@iwatt.com Phone: 408-374-4200 Fax: 408-341-0455 iWatt Inc. 675 Campbell Technology Parkway, Suite 150 Campbell, CA 95008 Disclaimer iWatt reserves the right to make changes to its products and to discontinue products without notice. The applications information, schematic diagrams, and other reference information included herein is provided as a design aid only and are therefore provided as-is. iWatt makes no warranties with respect to this information and disclaims any implied warranties of merchantability or non-infringement of third-party intellectual property rights. iWatt cannot assume responsibility for use of any circuitry other than circuitry entirely embodied in an iWatt product. No circuit patent licenses are implied. Certain applications using semiconductor products may involve potential risks of death, personal injury, or severe property or environmental damage (“Critical Applications”). IWATT SEMICONDUCTOR PRODUCTS ARE NOT DESIGNED, INTENDED, AUTHORIZED, OR WARRANTED TO BE SUITABLE FOR USE IN LIFE‑SUPPORT APPLICATIONS, DEVICES OR SYSTEMS, OR OTHER CRITICAL APPLICATIONS. Inclusion of iWatt products in critical applications is understood to be fully at the risk of the customer. Questions concerning potential risk applications should be directed to iWatt, Inc. iWatt semiconductors are typically used in power supplies in which high voltages are present during operation. High-voltage safety precautions should be observed in design and operation to minimize the chance of injury. Rev. 1.8 iW3620 February 1, 2012 Page 21
IW3620-00 价格&库存
很抱歉,暂时无法提供与“IW3620-00”相匹配的价格&库存,您可以联系我们找货
