HI1-0516-2
HI1-0516-2
    L3HARRIS
    CDIP28
    16-CHANNEL/DIFFERENTIAL 8-CHANNE
HI1-0516-2 数据手册
Datasheet HI516 16 Channel/Differential 8 Channel CMOS High Speed Analog Multiplexer The Hl-516 is a monolithic dielectrically isolated, high speed, high performance CMOS analog multiplexer. It offers unique built-in chan­nel selection decoding plus an inhibit input for disabling all channels. The dual function of address input A3 enables the Hl-516 to be user programmed either as a single ended 16-channel multiplexer by con­necting ‘out A’ to ‘out B’ and using A3 as a digital address input, or as an 8-channel differential multiplexer by connecting A3 to the V- sup­ply. The substrate leakages and parasitic capacitances are reduced substantially by using the Harris Dielectric Isolation process to achieve optimum performance in both high and low level signal appli­cations. The low output leakage current (lDOFF < 100pA at +25°C) and fast settling (lSETTLE = 800ns to 0.01 %) characteristics of the device make it an ideal choice for high speed data acquisition systems, pre­cision instrumentation, and industrial process control. Rochester Electronics Manufactured Components Rochester branded components are manufactured using either die/wafers purchased from the original suppliers or Rochester wafers recreated from the original IP. All re-creations are done with the approval of the Original Component Manufacturer (OCM). Parts are tested using original factory test programs or Rochester developed test solutions to guarantee product meets or exceeds the OCM data sheet. Quality Overview • ISO-9001 • AS9120 certification • Qualified Manufacturers List (QML) MIL-PRF-35835 • Class Q Military • Class V Space Level • Qualified Suppliers List of Distributors (QSLD) • Rochester is a critical supplier to DLA and meets all industry and DLA standards. Rochester Electronics, LLC is committed to supplying products that satisfy customer expectations for quality and are equal to those originally supplied by industry manufacturers. The original manufacturer’s datasheet accompanying this document reflects the performance and specifications of the Rochester manufactured version of this device. Rochester Electronics guarantees the performance of its semiconductor products to the original OCM specifications. ‘Typical’ values are for reference purposes only. Certain minimum or maximum ratings may be based on product characterization, design, simulation, or sample testing. FOR REFERENCE ONLY © 2019 Rochester Electronics, LLC. All Rights Reserved 05082019 To learn more, please visit www.rocelec.com
HI1-0516-2 价格&库存
很抱歉,暂时无法提供与“HI1-0516-2”相匹配的价格&库存,您可以联系我们找货
