N80C196KC20
N80C196KC20
    ROCHESTER(罗切斯特)
    LCC68
    IC MCU 16BIT 16KB OTP 68PLCC
N80C196KC20 数据手册
Datasheet 8XC196KC, 8XC196KC20 Commercial/Express CHMOS Microcontroller The 80C196KC 16-bit microcontroller is a high performance member of the MCS® 96 microcontroller family. The 80C196KC is an enhanced 80C196KB device with 488 bytes RAM, 16 and 20 MHz operation and an optional 16 Kbytes of ROM/OTPR OM. Intel’s CHMOS III process provides a high performance processor along with low power consumption. The 87C196KC is an 80C196KC with 16 Kbytes on-chip OTPROM. The 83C196KC is an 80C196KC with 16 Kbytes factory programmed ROM. In this document, the 80C196KC will refer to all products unless otherwise stated. Four high-speed capture inputs are provided to record times when events occur. Six high-speed outputs are available for pulse or waveform generation. The high-speed output can also generate four software timers or start an A/D conversion. Events can be based on the timer or up/down counter. With the commercial (standard) temperature option, operational characteristics are guaranteed over the temperature range of 0°C to +70°C. With the extended (Express) temperature range option, operational characteristics are guaranteed over the temperature range of -40°C to +85°C. Unless otherwise noted, the specifications are the same for both options. Rochester Electronics Manufactured Components Rochester branded components are manufactured using either die/wafers purchased from the original suppliers or Rochester wafers recreated from the original IP. All re-creations are done with the approval of the Original Component Manufacturer. (OCM) Parts are tested using original factory test programs or Rochester developed test solutions to guarantee product meets or exceeds the OCM data sheet. Quality Overview • ISO-9001 • AS9120 certification • Qualified Manufacturers List (QML) MIL-PRF-35835 • Class Q Military • Class V Space Level • Qualified Suppliers List of Distributors (QSLD) • Rochester is a critical supplier to DLA and meets all industry and DLA standards. Rochester Electronics, LLC is committed to supplying products that satisfy customer expectations for quality and are equal to those originally supplied by industry manufacturers. The original manufacturer’s datasheet accompanying this document reflects the performance and specifications of the Rochester manufactured version of this device. Rochester Electronics guarantees the performance of its semiconductor products to the original OCM specifications. ‘Typical’ values are for reference purposes only. Certain minimum or maximum ratings may be based on product characterization, design, simulation, or sample testing. FOR REFERENCE ONLY © 2018 Rochester Electronics, LLC. All Rights Reserved 09242018 To learn more, please visit www.rocelec.com Datasheet 8XC196KC, 8XC196KC20 Commercial/Express CHMOS Microcontroller Rochester Product Selection Guide* (contact Rochester for additional package types and lead finishes) Rochester PN Frequency Package Temperature Range RoHS N80C196KC20 20 MHz 68-ld PLCC 0°C to +70°C No N80C196KC 16 MHz 68-ld PLCC 0°C to +70°C No EE80C196KC20 20 MHz 68-ld PLCC 0°C to +70°C Yes EE80C196KC 16 MHz 68-ld PLCC 0°C to +70°C Yes TN80C196KC20 20 MHz 68-ld PLCC -40°C to +85°C No TN80C196KC 16 MHz 68-ld PLCC -40°C to +85°C No EN80C196KC20 20 MHz 68-ld PLCC -40°C to +85°C Yes EN80C196KC 16 MHz 68-ld PLCC -40°C to +85°C Yes TA80C196KC20 20 MHz 68-ld Ceramic PGA -40°C to +85°C No TA80C196KC 16 MHz 68-ld Ceramic PGA -40°C to +85°C No *The Rochester ordering guide supersedes the OCM ordering guide in the attached datasheet. The original manufacturer’s datasheet accompanying this document reflects the performance and specifications of the Rochester manufactured version of this device. Rochester Electronics guarantees the performance of its semiconductor products to the original manufacturer’s specifications. ‘Typical’ values are for reference purposes only. Certain minimum or maximum ratings may be based on product characterization, design, simulation, or sample testing. FOR REFERENCE ONLY © 2018 Rochester Electronics, LLC. All Rights Reserved 09242018 To learn more, please visit www.rocelec.com 8XC196KC/8XC196KC20 COMMERCIAL/EXPRESS CHMOS MICROCONTROLLER Y Y 87C196KC-16 Kbytes of On-Chip OTPROM 83C196KC-16 Kbytes ROM 80C196KC-ROMless Y Dynamically Configurable 8-Bit or 16 and 20 MHz Available 16-Bit Buswidth 488 Byte Register RAM Y Full Duplex Serial Port 28 Interrupt Sources/16 Vectors Y High Speed I/O Subsystem Peripheral Transaction Server Y 16-Bit Timer Y 1.4 ms 16 x 16 Multiply (20 MHz) Y 16-Bit Up/Down Counter with Capture 2.4 ms 32/16 Divide (20 MHz) Y Y 3 Pulse-Width-Modulated Y Powerdown and Idle Modes Y Four 16-Bit Software Timers Five 8-Bit I/O Ports Y Y Y 16-Bit Watchdog Timer 8- or 10-Bit A/D Converter with Sample/Hold Y Extended Temperature Available HOLD/HLDA Bus Protocol Y Y OTPROM One-Time Programmable Version Y Y Y Register-to-Register Architecture Outputs The 80C196KC 16-bit microcontroller is a high performance member of the MCSÉ 96 microcontroller family. The 80C196KC is an enhanced 80C196KB device with 488 bytes RAM, 16 and 20 MHz operation and an optional 16 Kbytes of ROM/OTPR OM. Intel's CHMOS III process provides a high performance processor along with low power consumption. The 87C196KC is an 80C196KC with 16 Kbytes on-chip OTPROM. The 83C196KC is an 80C196KC with 16 Kbytes factory programmed ROM. In this document, the 80C196KC will refer to all products unless otherwise stated. Four high-speed capture inputs are provided to record times when events occur. Six high-speed outputs are available for pulse or waveform generation. The high-speed output can also generate four software timers or start an A/D conversion. Events can be based on the timer or up/down counter. With the commercial (standard) temperature option, operational characteristics are guaranteed over the temperature range of 0§ C to a 70§ C. With the extended (Express) temperature range option, operational characteristics are guaranteed over the temperature range of b 40§ C to a 85§ C. Unless otherwise noted, the specifications are the same for both options. See the Packaging information for extended temperature designators. *Other brands and names are the property of their respective owners. Information in this document is provided in connection with Intel products. Intel assumes no liability whatsoever, including infringement of any patent or copyright, for sale and use of Intel products except as provided in Intel's Terms and Conditions of Sale for such products. Intel retains the right to make changes to these specifications at any time, without notice. Microcomputer Products may have minor variations to this specification known as errata. COPYRIGHT © INTELCORPORATION,2004 Order Number:270942-006 July 2004 8XC196KC/8XC196KC20 270942 ±1 Figure 1. 8XC196KC Block Diagram IOC3 (0CH HWIN1 READ/WRITE) 270942 ±45 NOTE: *RSV-Reserved bits must be e 0 Figure 2. 8XC196KC New SFR Bit (CLKOUT Disable) 2 8XC196KC/8XC196KC20 Table 2. 8XC196KC Memory Map PROCESS INFORMATION This device is manufactured on PX29.5 or PX29.9, a CHMOS III process. Additional process and reliability information is available in the Intel® Quality System Handbook: http://developer.intel.com/design/quality/quality.htm 270942 – 43 NOTE: 1. EPROMs are available as One Time Programmable (OTPROM) only. Figure 3. The 8XC196KC Family Nomenclature Description External Memory or I/O Internal ROM/OTPROM or External Memory (Determined by EA) 5FFFH 2080H Reserved. Must contain FFH. (Note 5) 207FH 205EH PTS Vectors 205DH 2040H Upper Interrupt Vectors 203FH 2030H ROM/OTPROM Security Key 202FH 2020H Reserved. Must contain FFH. (Note 5) 201FH 201AH Reserved. Must Contain 20H. (Note 5) θ ja θ jc PLCC 35°C/W 13 °C/W QFP 55°C/W 16 °C/W SQFP TBD TBD All thermal impedance data is approximate for static air conditions at 1W of power dissipation. Values will change depending on operation conditions and application. See the Intel Packaging Handbook (order number 240800) for a description of Intel’s thermal impedance test methodology. 2019H CCB 2018H Reserved. Must contain FFH. (Note 5) 2017H 2014H Lower Interrupt Vectors 2013H 2000H Port 3 and Port 4 1FFFH 1FFEH External Memory 1FFDH 0200H 488 Bytes Register RAM (Note 1) 01FFH 0018H CPU SFR’s (Notes 1, 3, 4) 0017H 0000H Table 1. Thermal Characteristics Package Type Address 0FFFFH 06000H NOTES: 1. Code executed in locations 0000H to 01FFH will be forced external. 2. Reserved memory locations must contain 0FFH unless noted. 3. Reserved SFR bit locations must contain 0. 4. Refer to 8XC196KC User’s manual for SFR descriptions. 5. WARNING: Reserved memory locations must not be written or read. The contents and/or function of these locations may change with future revisions of the device. Therefore, a program that relies on one or more of these locations may not function properly. 3 8XC196KC/8XC196KC20 270942 – 2 Figure 4. 68-Lead PLCC Package 4 8XC196KC/8XC196KC20 270942 – 40 Figure 5. 8XC196KC 80-Pin QFP Package 5 8XC196KC/8XC196KC20 270942 – 44 Figure 6. 80-Pin SQFP Package 6 8XC196KC/8XC196KC20 PIN DESCRIPTIONS Symbol Name and Function VCC VSS Main supply voltage (5V). Digital circuit ground (0V). There are multiple VSS pins, all of which must be connected. VREF Reference voltage for the A/D converter (5V). VREF is also the supply voltage to the analog portion of the A/D converter and the logic used to read Port 0. Must be connected for A/D and Port 0 to function. ANGND Reference ground for the A/D converter. Must be held at nominally the same potential as VSS. VPP XTAL1 Timing pin for the return from powerdown circuit. This pin also supplies the programming voltage on the EPROM device. Input of the oscillator inverter and of the internal clock generator. XTAL2 Output of the oscillator inverter. CLKOUT Output of the internal clock generator. The frequency of CLKOUT is (/2 the oscillator frequency. RESET BUSWIDTH Reset input and open drain output. Input for buswidth selection. If CCR bit 1 is a one, this pin selects the bus width for the bus cycle in progress. If BUSWIDTH is a 1, a 16-bit bus cycle occurs. If BUSWIDTH is a 0 an 8-bit cycle occurs. If CCR bit 1 is a 0, the bus is always an 8-bit bus. NMI A positive transition causes a vector through 203EH. INST Output high during an external memory read indicates the read is an instruction fetch. INST is valid throughout the bus cycle. INST is activated only during external memory accesses and output low for a data fetch. EA Input for memory select (External Access). EA equal high causes memory accesses to locations 2000H through 5FFFH to be directed to on-chip ROM/E PROM. EA equal to low causes accesses to those locations to be directed to off-chip memory. Also used to enter programming mode. ALE/ADV Address Latch Enable or Address Valid output, as selected by CCR. Both pin options provide a signal to demultiplex the address from the address/data bus. When the pin is ADV, it goes inactive high at the end of the bus cycle. ALE/ADV is activated only during external memory accesses. RD Read signal output to external memory. RD is activated only during external memory reads. WR/WRL Write and Write Low output to external memory, as selected by the CCR. WR will go low for every external write, while WRL will go low only for external writes where an even byte is being written. WR/WRL is activated only during external memory writes. BHE/WRH Bus High Enable or Write High output to external memory, as selected by the CCR. BHE will go low for external writes to the high byte of the data bus. WRH will go low for external writes where an odd byte is being written. BHE/WRH is activated only during external memory writes. Ready input to lengthen external memory cycles, for interfacing to slow or dynamic memory, or for bus sharing. When the external memory is not being used, READY has no effect. READY HSI HSO Port 0 Port 1 Port 2 Inputs to High Speed Input Unit. Four HSI pins are available: HSI.0, HSI.1, HSI.2 and HSI.3. Two of them (HSI.2 and HSI.3) are shared with the HSO Unit. Outputs from High Speed Output Unit. Six HSO pins are available: HSO.0, HSO.1, HSO.2, HSI.3, HSO.4 and HSO.5. Two of them (HSO.4 and HSO.5) are shared with the HSI Unit. 8-bit high impedance input-only port. These pins can be used as digital inputs and/or as analog inputs to the on-chip A/D converter. 8-bit quasi-bidirectional I/O port. 8-bit multi-functional port. All of its pins are shared with other functions in the 80C196KC. Pins 2.6 and 2.7 are quasi-bidirectional. 7 8XC196KC/8XC196KC20 PIN DESCRIPTIONS (Continued) Symbol Ports 3 and 4 HOLD HLDA Bus Hold acknowledge output indicating release of the bus. BREQ Bus Request output activated when the bus controller has a pending external memory cycle. PMODE Determines the EPROM programming mode. PACT A low signal in Auto Programming mode indicates that programming is in process. A high signal indicates programming is complete. Cummulative Program Output Verification. Pin is high if all locations have programmed correctly since entering a programming mode. CPVER PALE A falling edge in Slave Programming Mode and Auto Configuration Byte Programming Mode indicates that ports 3 and 4 contain valid programming address/command information (input to slave). PROG A falling edge in Slave Programming Mode indicates that ports 3 and 4 contain valid programming data (input to slave). A high signal in Slave Programmig Mode and Auto Configuration Byte Programming Mode indicates the byte programmed correctly. PVER AINC 8 Name and Function 8-bit bidirectional I/O ports with open drain outputs. These pins are shared with the multiplexed address/data bus which has strong internal pullups. Bus Hold input requesting control of the bus. Auto Increment. Active low input signal indicates that the auto increment mode is enabled. Auto Increment will allow reading or writing of sequential EPROM locations without address transactions across the PBUS for each read or write. 8XC196KC/8XC196KC20 NOTICE: This is a production data sheet. It is valid for the devices indicated in the revision history. The specifications are subject to change without notice. ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS* Ambient Temperature Under Bias.....................................-55° to +125°C Storage Temperature.........................-65° to +150°C Voltage On Any Pin to VSS.................-0.5V to +7.0V(1) Voltage from EA or VPP to VSS or ANGND..............................+13.00V *WARNING: Stressing the device beyond the ``Absolute Maximum Ratings'' may cause permanent damage. These are stress ratings only. Operation beyond the ``Operating Conditions'' is not recommended and extended exposure beyond the ``Operating Conditions'' may affect device reliability. Power Dissipation...........................................1.5W(2) NOTE: 1. This includes VPP and EA on ROM or CPU only devices. 2. Power dissipation is based on package heat transfer limitations, not device power consumption. OPERATING CONDITIONS Symbol TA Description Min Ambient Temperature Under Bias Commercial Temp. Max Units 0 a 70 §C a 85 §C 5.50 V TA Ambient Temperature Under Bias Extended Temp. b 40 VCC Digital Supply Voltage 4.50 VREF Analog Supply Voltage 4.00 5.50 V ANGND Analog Ground Voltage VSS b 0.4 VSS a 0.4 V(1) FOSC Oscillator Frequency (8XC196KC) 8 16 MHz FOSC Oscillator Frequency (8XC196KC20) 8 20 MHz NOTE: 1. ANGND and VSS should be nominally at the same potential. DC CHARACTERISTICS Symbol (Over Specified Operating Conditions) Description VIL Input Low Voltage VIH Input High Voltage (Note 1) Min Typ Max Units b 0.5 0.8 V 0.2 VCC a 1.0 VCC a 0.5 V V V VIH1 Input High Voltage on XTAL 1 0.7 VCC VCC a 0.5 VIH2 Input High Voltage on RESET 2.2 VCC a 0.5 VHYS Hysteresis on RESET 300 VOL Output Low Voltage VOL1 Output Low Voltage in RESET on P2.5 (Note 2) VOH Output High Voltage (Standard Outputs) VCC b 0.3 VCC b 0.7 VCC b 1.5 mV TestConditions VCC e 5.0V 0.3 0.45 1.5 V V V IOL e 200 mA IOL e 2.8 mA IOL e 7 mA 0.8 V IOL e a 0.4 mA V V V IOH e b 200 mA IOH e b 3.2 mA IOH e b 7 mA 9 8XC196KC/8XC196KC20 DC CHARACTERISTICS (Over Specified Operating Conditions) (Continued) Symbol Description Min VOH1 Output High Voltage (Quasi-bidirectional Outputs) VCC b 0.3 VCC b 0.7 VCC b 1.5 V V V IOH1 Logical 1 Output Current in Reset. on P2.0. Do not exceed this or device may enter test modes. b 0.8 mA VIH e VCC b 1.5V IIL2 Logical 0 Input Current in Reset on P2.0. Maximum current that must be sunk by external device to ensure test mode entry. TBD mA VIN e 0.45V IIH1 Logical 1 Input Current. Maximum current that external device must source to initiate NMI. a 200 mA VIN e VCC e 2.4V ILI Input Leakage Current (Std. Inputs) g 10 mA 0 k VIN k VCC b 0.3V ILI1 Input Leakage Current (Port 0) g3 mA ITL 1 to 0 Transition Current (QBD Pins) b 650 mA 0 k VIN k VREF VIN e 2.0V IIL Logical 0 Input Current (QBD Pins) b 70 mA VIN e 0.45V IIL1 Ports 3 and 4 in Reset b 70 mA VIN e 0.45V ICC Active Mode Current in Reset (8XC196KC) 65 75 mA XTAL1 e 16 MHz VCC e VPP e VREF e 5.5V ICC Active Mode Current in Reset (8XC196KC20) 80 92 mA XTAL1 e 20 MHz VCC e VPP e VREF e 5.5V IIDLE Idle Mode Current (8XC196KC) 17 25 mA XTAL1 e 16 MHz VCC e VPP e VREF e 5.5V IIDLE Idle Mode Current (8XC196KC20) 21 30 mA XTAL1 e 20 MHz VCC e VPP e VREF e 5.5V IPD Powerdown Mode Current 8 15 mA VCC e VPP e VREF e 5.5V IREF A/D Converter Reference Current 2 5 mA VCC e VPP e VREF e 5.5V RRST Reset Pullup Resistor CS Pin Capacitance (Any Pin to VSS) 6K Typ Max Units TestConditions 65K X 10 pF IOH e b 10 mA IOH e b 30 mA IOH e b 60 mA VCC e 5.5V, VIN e 4.0V NOTES: 1. All pins except RESET and XTAL1. 2. Violating these specifications in Reset may cause the part to enter test modes. 3. Commercial specifications apply to express parts except where noted. 4. QBD (Quasi-bidirectional) pins include Port 1, P2.6 and P2.7. 5. Standard Outputs include AD0±15, RD, WR, ALE, BHE, INST, HSO pins, PWM/P2.5, CLKOUT, RESET, Ports 3 and 4, TXD/P2.0 and RXD (in serial mode 0). The VOH specification is not valid for RESET. Ports 3 and 4 are open-drain outputs. 6. Standard Inputs include HSI pins, READY, BUSWIDTH, RXD/P2.1, EXTINT/P2.2, T2CLK/P2.3 and T2RST/P2.4. 7. Maximum current per pin must be externally limited to the following values if VOL is held above 0.45V or VOH is held below VCC b 0.7V: IOL on Output pins: 10 mA IOH on quasi-bidirectional pins: self limiting IOH on Standard Output pins: 10 mA 8. Maximum current per bus pin (data and control) during normal operation is g 3.2 mA. 9. During normal (non-transient) conditions the following total current limits apply: IOH is self limiting Port 1, P2.6 IOL: 29 mA IOH: 26 mA HSO, P2.0, RXD, RESET IOL: 29 mA IOL: 13 mA IOH: 11 mA P2.5, P2.7, WR, BHE IOH: 52 mA AD0±AD15 IOL: 52 mA IOH: 13 mA RD, ALE, INST±CLKOUT IOL: 13 mA 10 8XC196KC/8XC196KC20 270942 ±17 ICC Max e 4.13 c Frequency a 9 mA ICC Typ e 3.50 c Frequency a 9 mA IIDLE Max e 1.25 c Frequency a 5 mA IIDLE Typ e 0.88 c Frequency a 3 mA NOTE: Frequencies below 8 MHz are shown for reference only; no testing is performed. Figure 7. I CC and I IDLE vs Frequency AC CHARACTERISTICS For use over specified operating conditions. Test Conditions: Capacitive load on all pins e 100 pF, Rise and fall times e 10 ns, FOSC e 16 MHz The system must meet these specifications Symbol Description to work with the 80C196KC: Min Max Units 2 TOSC b 68 Notes TAVYV Address Valid to READY Setup TYLYH Non READY Time TCLYX READY Hold after CLKOUT Low TLLYX READY Hold after ALE Low TAVGV Address Valid to Buswidth Setup TCLGX Buswidth Hold after CLKOUT Low TAVDV Address Valid to Input Data Valid 3 TOSC b 55 ns (Note 2) TRLDV RD Active to Input Data Valid TOSC b 22 ns (Note 2) TCLDV CLKOUT Low to Input Data Valid TOSC b 45 ns TRHDZ End of RD to Input Data Float TOSC ns TRXDX Data Hold after RD Inactive No upper limit ns ns 0 TOSC b 30 ns (Note 1) TOSC b 15 2 TOSC b 40 ns (Note 1) 2 TOSC b 68 0 0 ns ns ns NOTES: 1. If max is exceeded, additional wait states will occur. 2. If wait states are used, add 2 TOSC * N, where N e number of wait states. 11 8XC196KC/8XC196KC20 (Continued) For user over specified operating conditions. AC CHARACTERISTICS Test Conditions: Capacitive load on all pins e 100 pF, Rise and fall times e 10 ns, FOSC e 16 MHz The 80C196KC will meet these specifications: Symbol Description Min Max Units Notes FXTAL Frequency on XTAL1 (8XC196KC) 8 16 MHz (Note 1) FXTAL Frequency on XTAL1 (8XC196KC20) 8 20 MHz (Note 1) TOSC I/F XTAL (8XC196KC) 62.5 125 ns TOSC I/F XTAL (8XC196KC20) 50 125 ns TXHCH XTAL1 High to CLKOUT High or Low a 110 ns TCLCL CLKOUT Cycle Time a 20 2 TOSC ns TCHCL CLKOUT High Period TCLLH CLKOUT Falling Edge to ALE Rising b5 a 15 TLLCH ALE Falling Edge to CLKOUT Rising b 20 a 15 TLHLH ALE Cycle Time 4 TOSC TLHLL ALE High Period TOSC b 10 TAVLL Address Setup to ALE Falling Edge TOSC b 15 TLLAX Address Hold after ALE Falling Edge TOSC b 35 TLLRL ALE Falling Edge to RD Falling Edge TOSC b 30 TRLCL RD Low to CLKOUT Falling Edge TRLRH RD Low Period TRHLH RD Rising Edge to ALE Rising Edge TRLAZ RD Low to Address Float TLLWL ALE Falling Edge to WR Falling Edge TCLWL CLKOUT Low to WR Falling Edge TOSC b 10 TOSCa 15 ns ns a4 TOSCa 10 ns ns a 30 ns ns (Note 4) TOSC a 25 ns (Note 2) a5 ns TOSC b 10 0 ns a 25 ns a 15 ns TOSC b 23 TQVWH Data Stable to WR Rising Edge TCHWH CLKOUT High to WR Rising Edge TWLWH WR Low Period TOSC b 20 ns TWHQX Data Hold after WR Rising Edge TOSC b 25 ns TWHLH WR Rising Edge to ALE Rising Edge TOSC b 10 TWHBX BHE, INST after WR Rising Edge TOSC b 10 ns TWHAX AD8±15 HOLD after WR Rising TOSC b 30 ns TRHBX BHE, INST after RD Rising Edge TOSC b 10 ns TRHAX AD8±15 HOLD after RD Rising TOSC b 25 ns b5 (Note 4) TOSC a 15 ns NOTES: 1. Testing performed at 8 MHz. However, the device is static by design and will typically operate below 1 Hz. 2. Assuming back-to-back bus cycles. 3. 8-Bit bus only. 4. If wait states are used, add 2 TOSC * N, where N e number of wait states. 12 (Note 4) ns TOSC b 5 TOSC ns ns (Note 4) (Note 2) (Note 3) (Note 3) 8XC196KC/8XC196KC20 System Bus Timings 270942 ±18 13 8XC196KC/8XC196KC20 READY Timings (One Wait State) 270942 ±20 Buswidth Timings 270942 ±35 14 8XC196KC/8XC196KC20 HOLD/HLDA Timings Symbol Description Min Max Units THVCH HOLD Setup a 55 TCLHAL CLKOUT Low to HLDA Low b 15 a 15 ns ns TCLBRL CLKOUT Low to BREQ Low b 15 a 15 ns THALAZ HLDA Low to Address Float a 15 ns THALBZ HLDA Low to BHE, INST, RD, WR Weakly Driven a 20 ns TCLHAH CLKOUT Low to HLDA High b 15 a 15 ns TCLBRH CLKOUT Low to BREQ High b 15 a 15 THAHAX HLDA High to Address No Longer Float b 15 THAHBV HLDA High to BHE, INST, RD, WR Valid b 10 a 15 ns TCLLH CLKOUT Low to ALE High b5 a 15 ns Notes (Note 1) ns ns NOTE: 1. To guarantee recognition at next clock. DC SPECIFICATIONS IN HOLD Description Min Max Units Weak Pullups on ADV, RD, WR, WRL, BHE 50K 250K VCC e 5.5V, VIN e 0.45V Weak Pulldowns on ALE, INST 10K 50K VCC e 5.5V, VIN e 2.4 15 8XC196KC/8XC196KC20 270942 ±36 Maximum Hold Latency Bus Cycle Type Internal Execution 1.5 States 16-Bit External Execution 2.5 States 8-Bit External Execution 4.5 States EXTERNAL CLOCK DRIVE (8XC196KC) 16 Symbol Parameter Min Max Units 1/T XLXL Oscillator Frequency TXLXL Oscillator Period TXHXX High Time 20 ns TXLXX Low Time 20 ns TXLXH Rise Time 10 ns TXHXL Fall Time 10 ns 8 16.0 MHz 62.5 125 ns 8XC196KC/8XC196KC20 EXTERNAL CLOCK DRIVE (8XC196KC20) Symbol Parameter Min Max Units 1/T XLXL Oscillator Frequency 8 20.0 MHz TXLXL Oscillator Period 50 125 ns TXHXX High Time 17 ns TXLXX Low Time 17 ns TXLXH Rise Time 8 ns TXHXL Fall Time 8 ns EXTERNAL CLOCK DRIVE WAVEFORMS 270942 ±21 EXTERNAL CRYSTAL CONNECTIONS EXTERNAL CLOCK CONNECTIONS 270942 ±41 NOTE: Keep oscillator components close to chip and use short, direct traces to XTAL1, XTAL2 and VSS. When using crystals, C1 e C2 & 20 pF. When using ceramic resonators, consult manufacturer for recommended circuitry. AC TESTING INPUT, OUTPUT WAVEFORMS 270942 ±22 AC Testing inputs are driven at 2.4V for a Logic ``1'' and 0.45V for a Logic ``0'' Timing measurements are made at 2.0V for a Logic ``1'' and 0.8V for a Logic ``0''. 270942 ±42 NOTE: *Required if TTL driver used. Not needed if CMOS driver is used. FLOAT WAVEFORMS 270942 ±23 For Timing Purposes a Port Pin is no Longer Floating when a 150 mV change from Load Voltage Occurs and Begins to Float when a 150 mV change from the Loaded VOH/V OL Level occurs; IOL/I OH e g 15 mA. 17 8XC196KC/8XC196KC20 EXPLANATION OF AC SYMBOLS Each symbol is two pairs of letters prefixed by ``T'' for time. The characters in a pair indicate a signal and its condition, respectively. Symbols represent the time between the two signal/condition points. LALE/ADV BR- BREQ Conditions: Signals: HL- High Low AB- Address BHE R- RD V- Valid C- CLKOUT W- WR/WRH /WRL XZ- No Longer Valid Floating DG- DATA Buswidth X- XTAL1 H- HOLD YQ- READY Data Out HA- HLDA AC CHARACTERISTICS-SERIAL PORT-SHIFT REGISTER MODE SERIAL PORT TIMING-SHIFT REGISTER MODE (MODE 0) Symbol Parameter TXLXL Serial Port Clock Period (BRR t 8002H) TXLXH Serial Port Clock Falling Edge to Rising Edge (BRR t 8002H) TXLXL Serial Port Clock Period (BRR e 8001H) Min Max 6 TOSC 4 TOSC b 50 TXLXH Serial Port Clock Falling Edge to Rising Edge (BRR e 8001H) TQVXH Output Data Setup to Clock Rising Edge 2 TOSC b 50 TXHQX Output Data Hold after Clock Rising Edge 2 TOSC b 50 TXHQV Next Output Data Valid after Clock Rising Edge TDVXH Input Data Setup to Clock Rising Edge TXHDX Input Data Hold after Clock Rising Edge TXHQZ Last Clock Rising to Output Float ns 4 TOSC a 50 4 TOSC 2 TOSC b 50 Units ns ns 2 TOSC a 50 ns ns ns 2 TOSC a 50 TOSC a 50 ns ns 0 ns 1 TOSC ns WAVEFORM-SERIAL PORT-SHIFT REGISTER MODE SERIAL PORT WAVEFORM-SHIFT REGISTER MODE (MODE 0) 270942 ±24 18 8XC196KC/8XC196KC20 A to D CHARACTERISTICS The A/D converter is ratiometric, so absolute accuracy is dependent on the accuracy and stability of VREF. 10-BIT MODE A/D OPERATING CONDITIONS Symbol TA Description Min Ambient Temperature Commercial Temp. Max Units 0 a 70 a 85 §C §C V TA Ambient Temperature Extended Temp. b 40 VCC Digital Supply Voltage 4.50 5.50 VREF Analog Supply Voltage 4.00 5.50 TSAM Sample Time 1.0 TCONV Conversion Time 10 20 ms(1) FOSC Oscillator Frequency (8XC196KC) 8.0 16.0 MHz FOSC Oscillator Frequency (8XC196KC20) 8.0 20.0 MHz V ms(1) NOTE: ANGND and VSS should nominally be at the same potential, 0.00V. 1. The value of AD_TIME is selected to meet these specifications. 10-BIT MODE A/D CHARACTERISTICS (Over Specified Operating Conditions) Parameter Typical (1) Resolution Absolute Error Full Scale Error 0.25 g 0.5 Zero Offset Error 0.25 g 0.5 Non-Linearity 1.0 g 2.0 Differential Non-Linearity Error Channel-to-Channel Matching g 0.1 Minimum Maximum 1024 10 1024 10 0 g3 Units LSBs LSBs LSBs 0 g3 LSBs l b1 a2 LSBs 0 g1 LSBs Repeatability g 0.25 LSBs Temperature Coefficients: Offset Full Scale Differential Non-Linearity 0.009 0.009 0.009 LSB/ § C LSB/ § C LSB/ § C Off Isolation b 60 Feedthrough b 60 VCC Power Supply Rejection b 60 Input Series Resistance Voltage on Analog Input Pin DC Input Leakage Sampling Capacitor 3 *Notes Levels Bits dB 1, 2 dB 1 dB 1 X 4 VREF a 0.5 V 5, 6 g 3.0 mA 750 1.2K ANGND b 0.5 0 pF NOTES: *An ``LSB'' as used here has a value of approxiimately 5 mV. (See Embedded Microcontrollers and Processors Handbook for A/D glossary of terms). 1. These values are expected for most parts at 25§ C but are not tested or guaranteed. 2. DC to 100 KHz. 3. Multiplexer Break-Before-Make is guaranteed. 4. Resistance from device pin, through internal MUX, to sample capacitor. 5. These values may be exceeded if the pin current is limited to g 2 mA. 6. Applying voltages beyond these specifications will degrade the accuracy of all channels being converted. 7. All conversions performed with processor in IDLE mode. 19 8XC196KC/8XC196KC20 8-BIT MODE A/D OPERATING CONDITIONS Symbol TA Description Min Ambient Temperature Commercial Temp. Max Units 0 a 70 a 85 §C §C V TA Ambient Temperature Extended Temp. b 40 VCC Digital Supply Voltage 4.50 5.50 VREF Analog Supply Voltage 4.00 5.50 TSAM Sample Time 1.0 TCONV Conversion Time FOSC FOSC V ms(1) 7 20 ms(1) Oscillator Frequency (8XC196KC) 8.0 16.0 MHz Oscillator Frequency (8XC196KC20) 8.0 20.0 MHz NOTE: ANGND and VSS should nominally be at the same potential, 0.00V. 1. The value of AD_TIME is selected to meet these specifications. 8-BIT MODE A/D CHARACTERISTICS Parameter Typical Resolution Absolute Error Full Scale Error g 0.5 Zero Offset Error g 0.5 Non-Linearity Differential Non-Linearity Error (Over Specified Operating Conditions) Minimum Maximum Units * 256 8 256 8 Levels Bits 0 g1 LSBs LSBs LSBs 0 g1 LSBs l b1 a1 LSBs g1 LSBs Channel-to-Channel Matching Repeatability g 0.25 LSBs Temperature Coefficients: Offset Full Scale Differential Non-Linearity 0.003 0.003 0.003 LSB/ § C LSB/ § C LSB/ § C Off Isolation Notes dB 2, 3 Feedthrough b 60 b 60 dB 2 VCC Power Supply Rejection b 60 dB 2 Input Series Resistance Voltage on Analog Input Pin DC Input Leakage Sampling Capacitor 3 750 1.2K Xs 4 VSS b 0.5 VREF a 0.5 V 5, 6 0 g 3.0 mA pF NOTES: *An ``LSB'' as used here has a value of approximately 20 mV. (See Embedded Microcontrollers and Processors Handbook for A/D glossary of terms). 1. These values are expected for most parts at 25§ C but are not tested or guaranteed. 2. DC to 100 KHz. 3. Multiplexer Break-Before-Make is guaranteed. 4. Resistance from device pin, through internal MUX, to sample capacitor. 5. These values may be exceeded if pin current is limited to g 2 mA. 6. Applying voltages beyond these specifications will degrade the accuracy of all channels being converted. 7. All conversions performed with processor in IDLE mode. 20 8XC196KC/8XC196KC20 EPROM SPECIFICATIONS OPERATING CONDITIONS DURING PROGRAMMING Symbol Description Min Max Units TA Ambient Temperature During Programming 20 30 C VCC Supply Voltage During Programming 4.5 5.5 V(1) VREF Reference Supply Voltage During Programming 4.5 5.5 V(1) VPP Programming Voltage 12.25 12.75 V(2) VEA EA Pin Voltage 12.25 12.75 V(2) FOSC Oscillator Frequency During Auto and Slave Mode Programming 6.0 8.0 MHz FOSC Oscillator Frequency During Run-Time Programming (8XC196KC) 6.0 16.0 MHz FOSC Oscillator Frequency During Run-Time Programming (8XC196KC20) 6.0 20.0 MHz NOTES: 1. VCC and VREF should nominally be at the same voltage during programming. 2. VPP and VEA must never exceed the maximum specification, or the device may be damaged. 3. VSS and ANGND should nominally be at the same potential (0V). 4. Load capacitance during Auto and Slave Mode programming e 150 pF. AC EPROM PROGRAMMING CHARACTERISTICS Symbol Description Min Max 1100 Units TSHLL Reset High to First PALE Low TOSC TLLLH PALE Pulse Width 50 TOSC TAVLL Address Setup Time 0 TOSC TLLAX Address Hold Time 100 TPLDV PROG Low to Word Dump Valid TPHDX Word Dump Data Hold TDVPL Data Setup Time 0 TOSC TPLDX Data Hold Time 400 TOSC TPLPH(1) PROG Pulse Width 50 TOSC TPHLL PROG High to Next PALE Low 220 TOSC TLHPL PALE High to PROG Low 220 TOSC TPHPL PROG High to Next PROG Low 220 TOSC TPHIL PROG High to AINC Low TILIH AINC Pulse Width TILVH TILPL TPHVL PROG High to PVER Valid TOSC 50 50 TOSC TOSC 0 TOSC 240 TOSC PVER Hold after AINC Low 50 TOSC AINC Low to PROG Low 170 TOSC 220 TOSC NOTE: 1. This specification is for the Word Dump Mode. For programming pulses, use the Modified Quick Pulse Algorithm. See user's manual for further information. 21 8XC196KC/8XC196KC20 DC EPROM PROGRAMMING CHARACTERISTICS Symbol IPP Description Min VPP Supply Current (When Programming) Max Units 100 mA NOTE: Do not apply VPP until VCC is stable and within specifications and the oscillator/clock has stabilized or the device may be damaged. EPROM PROGRAMMING WAVEFORMS SLAVE PROGRAMMING MODE DATA PROGRAM MODE WITH SINGLE PROGRAM PULSE 270942 ±27 NOTE: P3.0 must be high (``1'') SLAVE PROGRAMMING MODE IN WORD DUMP WITH AUTO INCREMENT 270942 ±28 NOTE: P3.0 must be low (``0'') 22 8XC196KC/8XC196KC20 SLAVE PROGRAMMING MODE TIMING IN DATA PROGRAM WITH REPEATED PROG PULSE AND AUTO INCREMENT 270942 ±29 8XC196KB TO 8XC196KC DESIGN CONSIDERATIONS 1. Memory Map. The 8XC196KC has 512 bytes of RAM/SFRs and an optional 16K of ROM/OTPR OM. The extra 256 bytes of RAM will reside in locations 100H ±1FFH and the extra 8K of ROM/OTPR OM will reside in locations 4000H ±5FFFH. These locations are external memory on the 8XC196KB. 2. The CDE pin on the KB has become a VSS pin on the KC to support 16/20 MHz operation. 3. EPROM programming. The 8XC196KC has a different programming algorithm to support 16K of on-board memory. When performing Run-Time Programming, use the section of code in the 8XC196KC User's Guide. 4. ONCE Mode Entry. The ONCE mode is entered on the 8XC196KC by driving the TXD pin low on the rising edge of RESET. The TXD pin is held high by a pullup that is specified by IOH1. This Pullup must not be overridden or the 8XC196KC will enter the ONCE mode. 5. During the bus HOLD state, the 8XC196KC weakly holds RD, WR, ALE, BHE and INST in their inactive states. The 8XC196KB only holds ALE in its inactive state. 6. A RESET pulse from the 8XC196KC is 16 states rather than 4 states as on the 8XC196KB (i.e., a watchdog timer overflow). This provides a longer RESET pulse for other devices in the system. 8XC196KC ERRATA 1. Missed EXTINT on P0.7. The 80C196KC20 could possibly miss an EXTINT on P0.7. See techbit MC0893. 2. HSI_MODEdivide-by-eight. See Faxback Ý2192. 3. IPD hump. See Faxback Ý2311. 23 8XC196KC/8XC196KC20 DATA SHEET REVISION HISTORY This data sheet is valid for devices with a ``H'', ``L'' or ``M'' at the end of the topside tracking number. The topside tracking number consists of nine characters and is the second line on the top side of the device. Data sheets are changed as new device information becomes available. Verify with your local Intel sales office that you have the latest version before finalizing a design or ordering devices. The following are differences between the 270942-006 datasheet and the 270942-005 datasheet: 1. Package prefix variables have changed. Variables are now indicated by an "x" The following are differences between the 270942-004 and 270942-005 datasheets: 1. Removed ``Word Addressable Only'' from Port 3 and 4 in Table 2. 2. Renamed PVAL to CPVER. 3. Removed TLLYV and TLLGV from the waveform diagrams. 4. Added HSI_MODE divide-by-eight and IPD hump to 8XC196KC errata. The following are important differences between the 270942-002 and 270942-004 data sheets: 1. NMI during PTS, QBD port glitch and Divide HOLD/READY erratas were fixed and have been removed from the data sheet. The HSI errata is also removed as this is now considered normal operation. 2. Combined 16 and 20 MHz data sheets. Data sheet 270924-001 (20 MHz) is now obsolete. 3. Added 80-lead SQFP package pinout. 4. Added documentation for CLKOUT disable bit. 5. iJA for QFP package was changed to 55§ C/W from 42§ C/W. 6. iJC for QFP package was changed to 16§ C/W from TBD§ C/W. 7. TSAM (MIN) in 10-bit mode was changed to 1.0 ms from 3.0 ms. 8. TSAM (MIN) in 8-bit mode was changed to 1.0 ms from 2.0 ms. 9. IIL1 specification for port 2.0 was renamed IIL2. 10. IIL2 (MAX) is changed to TBD from b 6 mA. IIH1 (MAX) is changed to a 200 mA from a 100 mA. IIH1 test condition changes to VIN e 2.4V from VIN e 5.5V. 13. VHYS is changed to 300 mV from 150 mV. 14. ICC (TYP) at 16 MHz is changed to 65 mA from 50 mA. 11. 12. 15. 16. ICC (MAX) at 16 MHz is changed to 75 mA from 70 mA. ICC (TYP) at 20 MHz is changed to 80 mA from 60 mA. 17. ICC (MAX) at 20 MHz is changed to 92 mA from 86 mA. IIDLE (TYP) at 16 MHz is changed to 17 mA from 15 mA. IIDLE (MAX) at 16 MHz is changed to 25 mA from 30 mA. 20. IIDLE (TYP) at 20 MHz is changed to 21 mA from 15 mA. 21. IIDLE (MAX) at 20 MHz is changed to 30 mA from 35 mA. 18. 19. 22. IPD (TYP) at 16 MHz is changed to 8 mA from 15 mA. 23. IPD (MAX) at 16 MHz is changed to 15 mA from TBD. 24. IPD (TYP) at 20 MHz is changed to 8 mA from 18 mA. 25. IPD (MAX) at 20 MHz is changed to 15 mA from TBD. 26. TCLDV (MAX) is changed to TOSC b 45 ns from TOSC b 50 ns. 27. TLLAX (MIN) is changed to TOSC b 35 ns from TOSC b 40 ns. 28. TCHWH (MIN) is changed to b 5 ns from b 10 ns. 29. TRHAX (MIN) is changed to TOSC b 25 ns from TOSC b 30 ns. 30. THALAZ (MAX) is changed to a 15 ns from a 10 ns. 31. THALBZ (MAX) is changed to a 20 ns from a 15 ns. 8XC196KC/8XC196KC20 32. THAHBV (MAX) is now specified at a 15 ns, was formerly unspecified. 33. The TLLYV and TLLGV specifications were removed. These specifications are not required in high-speed systems designs. 34. Added EXTINT, P0.7 errata to Errata section. The following are the important differences between the -001 and -002 versions of data sheet 270942. 1. Express and Commercial devices are combined into one data sheet. The Express only data sheet 270794-001 is obsolete. 2. Removed KB/KC feature set differences, pin definition table, and SFR locations and bitmaps. 3. Added programming pin function to package drawings and pin descriptions. 4. Changed absolute maximum temperature under bias from 0§ C to a 70§ C to b 55§ C to a 125§ C. 5. Replaced VOH2 specification with IOH1 and IIL1 specifications. 6. Added IIH1 specification for NMI pulldown resistors. 7. Added maximum hold latency table. 8. Added external oscillator and external clock circuit drawings. 9. Changed Clock Drive TXHXX and TXLXX Min spec to 20 ns. 10. Fixed Serial Port TXLXH specification. 11. Added 8- and 10-bit mode A/D operating conditions tables. 12. Specified operating range for sample and convert times. 13. Added specification for voltage on analog input pin. 14. Put operating conditions for EPROM programming into tabular format. 25
N80C196KC20 价格&库存
很抱歉,暂时无法提供与“N80C196KC20”相匹配的价格&库存,您可以联系我们找货
