DG301ACJ
DG301ACJ
    L3HARRIS
    DIP14
    SPDT, 1 FUNC, 1 CHANNEL, CMOS, P
DG301ACJ 数据手册
PO itle G30 , 301 303 bt TLmti, OS a- DG300A, DG301A, DG303A T CT DUC P R O P R OD U E T OL E UTE OBS UBSTIT S 303 Data Sheet LE HI-0 SSIB May 2001 TTL-Compatible, CMOS Analog Switches Features The DG300A through DG303A family of monolithic CMOS switches are truly compatible second source of the original manufacturer. The switches are latch-proof and are designed to block signals up to 30V P-P when OFF. Featuring low leakage and low power consumption, these switches are ideally suited for precision application in instrumentation, communication, data acquisition and battery powered applications. Other key features include Break-Before-Make switching, TTL and CMOS compatibility, and low ON resistance. Single supply operation (for positive switch voltages) is possible by connecting V- to 0V. • Low Power Consumption rpoion, inctor, itch OS PST, DT, ST, DT, eo, ET, alog 3119.3 • Break-Before-Make Switching - tON . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 150ns - tOFF . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 130ns • TTL, CMOS Compatible • Low rDS(ON) (Max). . . . . . . . . . . . . . . . . . . . . . . . . . . 50Ω • Single Supply Operation • True Second Source Part Number Information PART NUMBER itch utho ) eyrds ter- File Number TEMP. RANGE ( oC) DG300ABK -25 to 85 DG301ACJ 0 to 70 DG303AAK PKG. NO. PACKAGE 14 Ld CERDIP F14.3 14 Ld PDIP E14.3 -55 to 125 14 Ld CERDIP F14.3 DG303ABK -25 to 85 14 Ld CERDIP F14.3 DG303ACJ 0 to 70 14 Ld PDIP E14.3 DG303ACY 0 to 70 16 Ld SOIC M16.3 Functional Diagrams and Pinouts (Switches shown for a logic “1” input) DG300A (SPST) DG300A TRUTH TABLE S1 LOGIC SWITCH 0 OFF NC 1 14 V+ 1 ON D1 2 13 D2 NC 3 12 NC S1 4 11 S2 NC 5 10 NC IN 1 6 9 IN2 D1 Logic “0” ≤ 0.8V, Logic “1” ≥ 4.0V. IN1 IN2 S2 DG300A (CERDIP) TOP VIEW D2 GND 7 DG301A (SPDT) DG301A (PDIP) TOP VIEW DG301A TRUTH TABLE S1 D1 LOGIC SWITCH 1 SWITCH 2 0 OFF ON NC 1 14 V+ 1 ON OFF D1 2 13 D2 NC 3 12 NC Logic “0” ≤ 0.8V, Logic “1” ≥ 4.0V. S2 D2 IN S1 4 11 S2 NC 5 10 NC IN 6 9 NC GND 7 1 8 V- 8 V- CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. 1-888-INTERSIL or 321-724-7143 | Intersil and Design is a trademark of Intersil Americas Inc. | Copyright © Intersil Americas Inc. 2001 DG300A, DG301A, DG303A Functional Diagrams and Pinouts (Switches shown for a logic “1” input) DG303A (SPDT) (Continued) DG303A (CERDIP, PDIP) TOP VIEW NC 1 S1 D1 S3 D3 IN1 D2 S4 D4 14 V+ NC 1 16 V+ 15 S4 S3 2 13 S4 S3 2 D3 3 12 D4 D3 3 14 D4 D1 4 13 D2 S1 5 12 S2 IN 1 6 11 IN2 D1 4 11 D2 S1 5 10 S2 IN1 6 9 IN2 IN2 S2 DG303ACY (SOIC) TOP VIEW 10 V- GND 7 8 V- GND 7 NC 8 9 NC DG303A TRUTH TABLE LOGIC SWITCH 1 AND 2 SWITCH 3 AND 4 0 OFF ON 1 ON OFF Logic “0” ≤ 0.8V, Logic “1” ≥ 4.0V. Pin Descriptions PIN SYMBOL DESCRIPTION DG300A PIN SYMBOL DESCRIPTION 8 NC No Connection 9 NC No Connection 1 NC No Connection 2 D1 Drain (Output) Terminal for Switch 1 10 S2 Source (Input) Terminal for Switch 2 NC No Connection 3 NC No Connection 11 4 S1 Source (Input) Terminal for Switch 1 12 D2 Drain (Output) Terminal for Switch 2 5 NC No Connection 13 NC No Connection 6 IN1 Logic Control for Switch 1 14 V+ Positive Power Supply Terminal Ground Terminal (Logic Common) DG303A 7 GND 8 V- Negative Power Supply Terminal 1 NC No Connection 9 IN2 Logic Control for Switch 2 2 S3 Source (Input) Terminal for Switch 3 10 NC No Connection 3 D3 Drain (Output) Terminal for Switch 3 D1 Drain (Output) Terminal for Switch 1 11 NC No Connection 4 12 S2 Source (Input) Terminal for Switch 2 5 S1 Source (Input) Terminal for Switch 1 13 D2 Drain (Output) Terminal for Switch 2 6 IN1 Logic Control for Switch 1 14 V+ Positive Power Supply Terminal 7 GND 8 V- Negative Power Supply Terminal 9 IN2 Logic Control for Switch 2 S2 Source (Input) Terminal for Switch 2 DG301A Ground Terminal (Logic Common) 1 NC No Connection 2 D1 Drain (Output) Terminal for Switch 1 10 3 NC No Connection 11 D2 Drain (Output) Terminal for Switch 2 D4 Drain (Output) Terminal for Switch 4 4 S1 Source (Input) Terminal for Switch 1 12 5 IN Logic Control for Switches 13 S4 Source (Input) Terminal for Switch 4 6 GND Ground Terminal (Logic Common) 14 V+ Positive Power Supply Terminal 7 V- Negative Power Supply Terminal 2 DG300A, DG301A, DG303A Absolute Maximum Ratings Thermal Information V+ to V- . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 44.0V V- to GND. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25V Digital Inputs, VS, VD (Note 1). . . . . . . . . . . . . (V-) - 2V to (V+) + 2V or 30mA, Whichever Occurs First Continuous Current, (Any Terminal). . . . . . . . . . . . . . . . . . . . . 30mA Peak Current, S or D (Pulsed 1ms, 10% Duty Cycle Max) . . 100mA Thermal Resistance (Typical, Note 2) θJA ( oC/W) θJC (oC/W) SOIC Package . . . . . . . . . . . . . . . . . . . 100 N/A PDIP Package . . . . . . . . . . . . . . . . . . . 100 N/A CERDIP Package. . . . . . . . . . . . . . . . . 75 20 Maximum Junction Temperature Hermetic Packages . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 175oC Plastic Packages . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 150oC Maximum Storage Temperature Range . . . . . . . . . . -65oC to 150oC Maximum Lead Temperature (Soldering, 10s). . . . . . . . . . . . 300oC (SOIC - Lead Tips Only) Operating Conditions Voltage Range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±15V Temperature Range “A” Suffix. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -55oC to 125oC “B” Suffix. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -25oC to 85oC “C” Suffix . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0oC to 70oC Input Low Voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8V (Max) Input High Voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.0V (Min) Input Rise and Fall Time . . . . . . . . . . . . . . . . . . . . . . . . . . . . ≤20ns CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTES: 1. Signals on SX , D X or INX exceeding V+ or V- will be clamped by internal diodes. Limit diode forward current to maximum current ratings. 2. θJA is measured with the component mounted on an evaluation PC board in free air. V+ = +15V, V- = -15V, GND = 0V, TA = 25oC Electrical Specifications “A” SUFFIX PARAMETER TEST CONDITIONS “B” AND “C” SUFFIX MIN (NOTE 3) TYP MAX MIN (NOTE 3) TYP MAX UNITS DYNAMIC CHARACTERISTICS Turn-ON Time, tON See Figure 3 - 150 300 - 150 - ns Turn-OFF Time, tOFF See Figure 3 - 130 250 - 130 - ns Break-Before-Make Interval, tD See Figure 2, DG301A/DG303A - 50 - - 50 - ns Charge Injection, Q CL = 10nF, RS = 0, VS = 0 - 3 - - 3 - mV OFF Isolation (Note 4) VIN = 0, RL = 1kΩ, VS = 1VRMS , f = 500kHz - 62 - - 62 - dB - -74 - - -74 - dB VS = 0 - 14 - - 14 - pF VD = 0 - 14 - - 14 - pF VS = VD = 0 - 40 - - 40 - pF VIN = 0 - 6 - - 6 - pF VIN = 15V - 7 - - 7 - pF VIN = 5.0V -1 -0.001 - -1 -0.001 - µA VIN = 15.0V - 0.001 1 - 0.001 1 µA VIN = 0V -1 -0.001 - -1 -0.001 - µA Crosstalk (Channel-to-Channel) Source OFF Capacitance, C S(OFF) Drain OFF Capacitance, C D(OFF) f = 1MHz, VIN = 0.8V or VIN = 4.0V Channel ON Capacitance, C D(ON) + CS(ON) Input Capacitance, C IN f = 1MHz DIGITAL INPUT CHARACTERISTICS Input Current with Voltage High, IIH Input Current with Voltage Low, IIL 3 DG300A, DG301A, DG303A V+ = +15V, V- = -15V, GND = 0V, TA = 25oC (Continued) Electrical Specifications “A” SUFFIX PARAMETER “B” AND “C” SUFFIX MIN (NOTE 3) TYP MAX MIN (NOTE 3) TYP MAX UNITS -15 - 15 -15 - 15 V IS = -10mA, VD = 10V - 30 50 - 30 50 Ω IS = 10mA, VD = -10V - 30 50 - 30 50 Ω VS = 14V, VD = -14V - 0.1 1 - 0.1 5 nA VS = -14V, VD = 14V -1 -0.1 - -5 -0.1 - nA VS = -14V, VD = 14V - 0.1 1 - 0.1 5 nA VS = 14V, VD = -14V -1 -0.1 - -5 -0.1 - nA VD = VS = 14V - 0.1 1 - 0.1 5 nA VD = VS = -14V -2 -0.1 - -5 -0.1 - nA - 0.23 0.5 - 0.23 0.5 mA -10 -0.001 - -10 -0.001 - µA - 0.001 10 - 0.001 10 µA -10 -0.001 - -10 -0.001 - µA TEST CONDITIONS ANALOG SWITCH CHARACTERISTICS Analog Signal Range, VANALOG IS = 10mA, VIN = 0.8V or 4V Drain-Source ON Resistance, rDS(ON) VIN = 0.8V or VIN = 4.0V Source OFF Leakage Current, IS(OFF) Drain OFF Leakage Current, ID(OFF) Channel ON Leakage Current, ID(ON) VIN = 0.8V or VIN = 4.0V VIN = 0.8V or VIN = 4.0V VIN = 0.8V or VIN = 4.0V POWER SUPPLY CHARACTERISTICS Positive Supply Current, I+ Negative Supply Current, IPositive Supply Current, I+ VIN = 4V (One Input) (All Others = 0) VIN = 0.8V (All Inputs) Negative Supply Current, I- Electrical Specifications V+ = +15V, V- = -15V, GND = 0V, TA = Full Temperature Range “A” SUFFIX “B” AND “C” SUFFIX MIN (NOTE 3) TYP MAX MIN (NOTE 3) TYP MAX UNITS VIN = 5.0V -1 - - - - - µA VIN = 15.0V - - 1 - - - µA VIN = 0V -1 - - - - - µA -15 - 15 - - - V IS = -10mA, VD = 10V - - 75 - - - Ω IS = 10mA, VD = -10V - - 75 - - - Ω VS = 14V, VD = -14V - - 100 - - - nA VS = -14V, VD = 14V -100 - - - - - nA PARAMETER TEST CONDITION DIGITAL INPUT CHARACTERISTICS Input Current with Voltage High, IIH Input Current with Voltage Low, IIL ANALOG SWITCH CHARACTERISTICS Analog Signal Range, VANALOG IS = 10mA, VIN = 0.8V or 4V Drain-Source ON Resistance, rDS(ON) VIN = 0.8V or VIN = 4.0V Source OFF Leakage Current, IS(OFF) VIN = 0.8V or VIN = 4.0V 4 DG300A, DG301A, DG303A Electrical Specifications V+ = +15V, V- = -15V, GND = 0V, TA = Full Temperature Range (Continued) “A” SUFFIX PARAMETER MIN (NOTE 3) TYP MAX MIN (NOTE 3) TYP MAX UNITS VS = -14V, VD = 14V - - 100 - - - nA VS = 14V, VD = -14V -100 - - - - VD = VS = 14V - - 100 - - - nA VD = VS = -14V -200 - - - - - nA - - 1 - - - mA -100 - - - - - µA - - 100 - - - µA -100 - - - - - µA TEST CONDITION Drain OFF Leakage Current, ID(OFF) VIN = 0.8V or VIN = 4.0V Channel ON Leakage Current, ID(ON) VIN = 0.8V or VIN = 4.0V “B” AND “C” SUFFIX nA POWER SUPPLY CHARACTERISTICS Positive Supply Current, I+ Negative Supply Current, IPositive Supply Current, I+ VIN = 4V (One Input) (All Others = 0) VIN = 0.8V (All Inputs) Negative Supply Current, INOTES: 3. For design only, not 100% tested. 4. OFF isolation = 20 Log VS /V D, where VS = input to OFF switch, and VD = output. Test Circuits and Waveforms ∆VO RS SX DX VD VD INX VS CL = 10nF INX ON ON OFF FIGURE 1. CHARGE INJECTION TEST CIRCUIT AND MEASUREMENT POINTS LOGIC “1” = SWITCH ON 5V LOGIC INPUT V+ 15V VS1 = 3V S1 D1 VS2 = 3V S2 D2 LOGIC INPUT GND V-15V VS1 SWITCH OUTPUT VO1 RL2 300 Ω IN RL1 300 Ω CL2 VO2 CL1 33pF 33pF 0V SWITCH OUTPUT (VO1) 50% 0V tD VS2 SWITCH OUTPUT (VO2) 0V 50% 0V FIGURE 2. BREAK-BEFORE MAKE TEST CIRCUIT AND MEASUREMENT POINTS (DG301A, DG303A) 5 DG300A, DG301A, DG303A Test Circuits and Waveforms (Continued) LOGIC “1” = SWITCH ON V+ +15V VS = 3V S SWITCH OUTPUT VO D LOGIC INPUT SWITCH INPUT LOGIC INPUT IN RL 300 kΩ GND V-15V tr < 20ns tf < 20ns 5V 50% 0V VS CL 33pF 90% SWITCH OUTPUT 10% 0V tON FIGURE 3. t ON and tOFF TEST CIRCUIT AND MEASUREMENT POINTS Die Characteristics DIE DIMENSIONS: 89 mils x 99 mils x 12 mils METALLIZATION: Type: Al Thickness: 10kÅ ±1kÅ PASSIVATION: Type: PSG Over Nitride PSG Thickness: 7kÅ ±1.4kÅ Nitride Thickness: 8kÅ ±1.2kÅ WORST CASE CURRENT DENSITY: 1 x 105 A/cm2 6 tOFF DG300A, DG301A, DG303A Metallization Mask Layouts DG300A DG301A PIN 14 V+ PIN 14 V+ PIN 2 D1 PIN 13 D2 PIN 2 D1 PIN 13 D2 PIN 4 S1 PIN 11 S2 PIN 4 S1 PIN 11 S2 PIN 6 IN 1 NC PIN 7 GND PIN 6 IN 1 PIN 9 IN 2 PIN 8 V- NC PIN 7 GND PIN 8 V- DG303A PIN 14 V+ PIN 2 S3 PIN 13 S4 PIN 3 D3 PIN 4 D1 PIN 12 D4 PIN 11 D2 PIN 5 S1 PIN 10 S2 PIN 6 IN 1 NC PIN 7 GND PIN 8 V- PIN 9 IN 2 All Intersil products are manufactured, assembled and tested utilizing ISO9000 quality systems. Intersil Corporation’s quality certifications can be viewed at website www.intersil.com/design/quality/iso.asp Intersil products are sold by description only. Intersil Corporation reserves the right to make changes in circuit design and/or specifications at any time without notice. Accordingly, the reader is cautioned to verify that data sheets are current before placing orders. Information furnished by Intersil is believed to be accurate and reliable. However, no responsibility is assumed by Intersil or its subsidiaries for its use; nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Intersil or its subsidiaries. For information regarding Intersil Corporation and its products, see web site www.intersil.com Sales Office Headquarters EUROPE Intersil SA Mercure Center 100, Rue de la Fusee 1130 Brussels, Belgium TEL: (32) 2.724.2111 FAX: (32) 2.724.22.05 NORTH AMERICA Intersil Corporation 2401 Palm Bay Rd. Palm Bay, FL 32905 TEL: (321) 724-7000 FAX: (321) 724-7240 7 ASIA Intersil Ltd. 8F-2, 96, Sec. 1, Chien-kuo North, Taipei, Taiwan 104 Republic of China TEL: 886-2-2515-8508 FAX: 886-2-2515-8369
DG301ACJ 价格&库存
很抱歉,暂时无法提供与“DG301ACJ”相匹配的价格&库存,您可以联系我们找货
