IS31FL3208A-QFLS4-TR
    LUMISSIL
    QFN-28_4X4MM-EP
    IC LED DRIVER W/ SELECTABLE PWM,
IS31FL3208A-QFLS4-TR 数据手册
IS31FL3208A 18-CHANNEL LED DRIVER; SELECTABLE PWM FREQUENCY August 2018 GENERAL DESCRIPTION FEATURES IS31FL3208A is comprised of 18 constant current channels each with independent PWM control, designed for driving LEDs, PWM frequency can be 23kHz (default) or 3.45kHz. The output current of each channel can be set at up to 38mA (Max.) by an external resistor and independently scaled by a factor of 1, 11/12, 9/12 and 7/12. The average LED current of each channel can be changed in 256 steps by changing the PWM duty cycle through an I2C interface.    The chip can be turned off by pulling the SDB pin low or by using the software shutdown feature to reduce power consumption. IS31FL3208A is available in QFN-28 (4mm × 4mm) package. It operates from 2.7V to 5.5V over the temperature range of -40°C to +125°C.          2.7V to 5.5V supply Each channel output current up to 38mA Accuracy between channels and ICs:
IS31FL3208A-QFLS4-TR 价格&库存
很抱歉,暂时无法提供与“IS31FL3208A-QFLS4-TR”相匹配的价格&库存,您可以联系我们找货
