Advance Information
MC9328MXL/D
Rev. 4.0, 12/2003
MC9328MXL
(i.MXL) Integrated
Portable System
Processor
Contents
1 Introduction . . . . . . . . . . . 1
2 Signals and
Connections . . . . . . . . . . 5
3 Specifications . . . . . . . . 10
4 Pin-Out and Package
Information . . . . . . . . . . 77
Contact Information
. . . . . . . . . . . . . Last Page
1 Introduction
The i.MX family builds on the DragonBall family of application processors which have
demonstrated leadership in the portable handheld market. Continuing this legacy, the i.MX
(Media Extensions) series provides a leap in performance with an ARM9™ microprocessor
core and highly integrated system functions. The i.MX products specifically address the
requirements of the personal, portable product market by providing intelligent integrated
peripherals, an advanced processor core, and power management capabilities.
The new MC9328MXL features the advanced and power-efficient ARM920T™ core that
operates at speeds up to 200 MHz. Integrated modules, which include an LCD controller,
USB support, and an MMC/SD host controller, support a suite of peripherals to enhance any
product seeking to provide a rich multimedia experience. It is packaged in either a 256-pin
Mold Array Process-Ball Grid Array (MAPBGA) or 225-pin PBGA package. Figure 1 shows
the functional block diagram of the MC9328MXL.
System Control
JTAG/ICE
Bootstrap
Power
Control
CGM
(PLLx2)
Standard
System I/O
GPIO
Connectivity
MC9328MXL
PWM
MMC/SD
Timer 1 & 2
CPU Complex
Memory Stick®
Host Controller
RTC
ARM9TDMI™
Watchdog
SPI 1 and
SPI 2
UART 1
UART 2
I Cache
AIPI 1
D Cache
VMMU
Interrupt
Controller
Multimedia
Multimedia
Accelerator
Video Port
SSI/I2S
I2C
USB Device
AIPI 2
DMAC
(11 Chnl)
Bus
Control
EIM &
SDRAMC
Human Interface
LCD Controller
Figure 1. MC9328MXL Functional Block Diagram
This document contains information on a new product. Specifications and information herein are subject to change
without notice. © Motorola, Inc., 2003. All rights reserved.
Introduction
1.1 Conventions
This document uses the following conventions:
OVERBAR is used to indicate a signal that is active when pulled low: for example, RESET.
Logic level one is a voltage that corresponds to Boolean true (1) state.
Logic level zero is a voltage that corresponds to Boolean false (0) state.
To set a bit or bits means to establish logic level one.
To clear a bit or bits means to establish logic level zero.
A signal is an electronic construct whose state conveys or changes in state convey information.
A pin is an external physical connection. The same pin can be used to connect a number of signals.
Asserted means that a discrete signal is in active logic state.
— Active low signals change from logic level one to logic level zero.
— Active high signals change from logic level zero to logic level one.
Negated means that an asserted discrete signal changes logic state.
— Active low signals change from logic level zero to logic level one.
— Active high signals change from logic level one to logic level zero.
LSB means least significant bit or bits, and MSB means most significant bit or bits. References to
low and high bytes or words are spelled out.
Numbers preceded by a percent sign (%) are binary. Numbers preceded by a dollar sign ($) or 0x
are hexadecimal.
1.2 Features
To support a wide variety of applications, the MC9328MXL offers a robust array of features, including the
following:
2
ARM920T™ Microprocessor Core
AHB to IP Bus Interfaces (AIPIs)
External Interface Module (EIM)
SDRAM Controller (SDRAMC)
DPLL Clock and Power Control Module
Two Universal Asynchronous Receiver/Transmitters (UART 1 and UART 2)
Two Serial Peripheral Interfaces (SPI1 and SPI2)
Two General-Purpose 32-bit Counters/Timers
Watchdog Timer
Real-Time Clock/Sampling Timer (RTC)
LCD Controller (LCDC)
Pulse-Width Modulation (PWM) Module
Universal Serial Bus (USB) Device
Multimedia Card and Secure Digital (MMC/SD) Host Controller Module
Memory Stick® Host Controller (MSHC)
MC9328MXL Advance Information
MOTOROLA
Introduction
Direct Memory Access Controller (DMAC)
Synchronous Serial Interface and Inter-IC Sound (SSI/I2S) Module
Inter-IC (I2C) Bus Module
Video Port
General-Purpose I/O (GPIO) Ports
Bootstrap Mode
Multimedia Accelerator (MMA)
Power Management Features
Operating Voltage Range: 1.7 V to 1.98 V core, 1.7 V to 3.3V I/O
256-pin MAPBGA Package
225-pin MAPBGA Package
1.3 Target Applications
The MC9328MXL is targeted for advanced information appliances, smart phones, Web browsers, digital
MP3 audio players, handheld computers, and messaging applications.
1.4 Revision History
Table 1 provides revision history for this release. This history includes technical content revisions only and
not stylistic or grammatical changes.
Table 1. MC9328MXL Data Sheet Revision History Rev. 4.0
Revision Location
Revision
Throughout data sheet
Removed references to 38.4 kHz clock.
Changed all references to USB from self-powered only to selfpowered and bus-powered.
Section 3.8.3, “EIM External Bus Timing,” on
page 21
Updated Figure 4 on page 15 in the EIM Interface Module section
to reflect AMD Flash rather than Intel Flash.
Signal Descriptions Table 3 on page 5
Changed DC0 to DCO
Reset Module, Table 11 on page 16
Updated width of POR and related timing information
Section 3.8.2, “DTACK Signal Timing,” on
page 19
Updated DTACK signal description and timing values for accuracy
and clarity
Part Order information Table 2 on page 4
Updated existing and added new part numbers for MC9328MXL
Section 3.1, “Maximum Ratings,” on page 10
Updated maximum rating in Table 4 on page 10
1.5 Product Documentation
The following documents are required for a complete description of the MC9328MXL and are necessary to
design properly with the device. Especially for those not familiar with the ARM920T processor or
previous DragonBall products, the following documents are helpful when used in conjunction with this
document.
MOTOROLA
3
Introduction
ARM Architecture Reference Manual (ARM Ltd., order number ARM DDI 0100)
ARM9DT1 Data Sheet Manual (ARM Ltd., order number ARM DDI 0029)
ARM Technical Reference Manual (ARM Ltd., order number ARM DDI 0151C)
EMT9 Technical Reference Manual (ARM Ltd., order number DDI O157E)
MC9328MXL Product Brief (order number MC9328MXLP/D)
MC9328MXL Reference Manual (order number MC9328MXLRM/D)
The Motorola manuals are available on the Motorola Semiconductors Web site at
http://www.motorola.com/semiconductors. These documents may be downloaded directly from the
Motorola Web site, or printed versions may be ordered. The ARM Ltd. documentation is available from
http://www.arm.com.
1.6 Ordering Information
Table 2 provides ordering information for both the 256-lead mold array process ball grid array
(MAPBGA) package and the 225-lead BGA package.
Table 2. MC9328MXL Ordering Information
Package Type
Frequency
Temperature
Solderball Type
Order Number
256-lead MAPBGA
150 MHz
-40OC to 85OC
Standard
MC9328MXLCVH15(R2)
Pb-free
MC9328MXLCVM15(R2)
Standard
MC9328MXLVH20(R2)
Pb-free
MC9328MXLVM20(R2)
Standard
MC9328MXLDVH20(R2)
Pb-free
MC9328MXLDVM20(R2)
Standard
MC9328MXLCVF15(R2)
Pb-free
MC9328MXLCVP15(R2)
Standard
MC9328MXLVF20(R2)
Pb-free
MC9328MXLVP20(R2)
Standard
MC9328MXLDVF20(R2)
Pb-free
MC9328MXLDVP20(R2)
200 MHz
0OC to 70OC
-30OC to 70OC
225-lead MAPBGA
150 MHz
200 MHz
-40OC to 85OC
0OC to 70OC
-30OC to 70OC
4
MOTOROLA
Signals and Connections
2 Signals and Connections
Table 3 identifies and describes the MC9328MXL signals that are assigned to package pins. The signals
are grouped by the internal module that they are connected to.
Table 3. MC9328MXL Signal Descriptions
Signal Name
Function/Notes
External Bus/Chip-Select (EIM)
A[24:0]
Address bus signals
D[31:0]
Data bus signals
EB0
MSB Byte Strobe—Active low external enable byte signal that controls D [31:24].
EB1
Byte Strobe—Active low external enable byte signal that controls D [23:16].
EB2
Byte Strobe—Active low external enable byte signal that controls D [15:8].
EB3
LSB Byte Strobe—Active low external enable byte signal that controls D [7:0].
OE
Memory Output Enable—Active low output enables external data bus.
CS [5:0]
Chip-Select—The chip-select signals CS [3:2] are multiplexed with CSD [1:0] and are
selected by the Function Multiplexing Control Register (FMCR). By default CSD [1:0] is
selected.
ECB
Active low input signal sent by a flash device to the EIM whenever the flash device must
terminate an on-going burst sequence and initiate a new (long first access) burst sequence.
LBA
Active low signal sent by a flash device causing the external burst device to latch the
starting burst address.
BCLK
Clock signal sent to external synchronous memories (such as burst flash) during burst
mode.
RW
RW signal—Indicates whether external access is a read (high) or write (low) cycle. Used as
a WE input signal by external DRAM.
DTACK
DTACK signal—The external input data acknowledge signal. When using the external
DTACK signal as a data acknowledge signal, the bus time-out monitor generates a bus
error when a bus cycle is not terminated by the external DTACK signal after 1022 clock
counts have elapsed.
Bootstrap
BOOT [3:0]
System Boot Mode Select—The operational system boot mode of the MC9328MXL upon
system reset is determined by the settings of these pins.
SDRAM Controller
SDBA [4:0]
SDRAM/SyncFlash non-interleave mode bank address multiplexed with address signals A
[15:11]. These signals are logically equivalent to core address p_addr [25:21] in SDRAM/
SyncFlash cycles.
SDIBA [3:0]
SDRAM/SyncFlash interleave addressing mode bank address multiplexed with address
signals A [19:16]. These signals are logically equivalent to core address p_addr [12:9] in
SDRAM/SyncFlash cycles.
MA [11:10]
SDRAM address signals
MA [9:0]
SDRAM address signals which are multiplexed with address signals A [10:1]. MA [9:0] are
selected on SDRAM/SyncFlash cycles.
DQM [3:0]
SDRAM data enable
MOTOROLA
5
Table 3. MC9328MXL Signal Descriptions (Continued)
Signal Name
Function/Notes
CSD0
SDRAM/SyncFlash Chip-select signal which is multiplexed with the CS2 signal. These two
signals are selectable by programming the system control register.
CSD1
SDRAM/SyncFlash Chip-select signal which is multiplexed with CS3 signal. These two
signals are selectable by programming the system control register. By default, CSD1 is
selected, so it can be used as SyncFlash boot chip-select by properly configuring BOOT
[3:0] input pins.
RAS
SDRAM/SyncFlash Row Address Select signal
CAS
SDRAM/SyncFlash Column Address Select signal
SDWE
SDRAM/SyncFlash Write Enable signal
SDCKE0
SDRAM/SyncFlash Clock Enable 0
SDCKE1
SDRAM/SyncFlash Clock Enable 1
SDCLK
RESET_SF
SyncFlash Reset
Clocks and Resets
EXTAL16M
Crystal input (4 MHz to 16 MHz), or a 16 MHz oscillator input when the internal oscillator
circuit is shut down.
XTAL16M
Crystal output
EXTAL32K
32 kHz crystal input
XTAL32K
32 kHz crystal output
CLKO
Clock Out signal selected from internal clock signals.
RESET_IN
Master Reset—External active low Schmitt trigger input signal. When this signal goes
active, all modules (except the reset module and the clock control module) are reset.
RESET_OUT
Reset Out—Internal active low output signal from the Watchdog Timer module and is
asserted from the following sources: Power-on reset, External reset (RESET_IN), and
Watchdog time-out.
POR
Power On Reset—Internal active high Schmitt trigger input signal. The POR signal is
normally generated by an external RC circuit designed to detect a power-up event.
JTAG
TRST
Test Reset Pin—External active low signal used to asynchronously initialize the JTAG
controller.
TDO
Serial Output for test instructions and data. Changes on the falling edge of TCK.
TDI
Serial Input for test instructions and data. Sampled on the rising edge of TCK.
TCK
Test Clock to synchronize test logic and control register access through the JTAG port.
TMS
Test Mode Select to sequence the JTAG test controller’s state machine. Sampled on the
rising edge of TCK.
DMA
BIG_ENDIAN
Big Endian—Input signal that determines the configuration of the external chip-select
space. If it is driven logic-high at reset, the external chip-select space will be configured to
little endian. If it is driven logic-low at reset, the external chip-select space will be configured
to big endian.
DMA_REQ
External DMA request pin.
6
MOTOROLA
Signal Name
Function/Notes
ETM
ETMTRACESYNC
ETM sync signal which is multiplexed with A24. ETMTRACESYNC is selected in ETM
mode.
ETMTRACECLK
ETM clock signal which is multiplexed with A23. ETMTRACECLK is selected in ETM mode.
ETMPIPESTAT [2:0]
ETM status signals which are multiplexed with A [22:20]. ETMPIPESTAT [2:0] are selected
in ETM mode.
ETMTRACEPKT [7:0]
ETM packet signals which are multiplexed with ECB, LBA, BCLK, PA17, A [19:16].
ETMTRACEPKT [7:0] are selected in ETM mode.
CMOS Sensor Interface
CSI_D [7:0]
Sensor port data
CSI_MCLK
Sensor port master clock
CSI_VSYNC
Sensor port vertical sync
CSI_HSYNC
Sensor port horizontal sync
CSI_PIXCLK
Sensor port data latch clock
LCD Controller
LD [15:0]
LCD Data Bus—All LCD signals are driven low after reset and when LCD is off.
FLM/VSYNC
Frame Sync or Vsync—This signal also serves as the clock signal output for the gate
driver (dedicated signal SPS for Sharp panel HR-TFT).
LP/HSYNC
Line pulse or H sync
LSCLK
Shift clock
ACD/OE
Alternate crystal direction/output enable.
CONTRAST
This signal is used to control the LCD bias voltage as contrast control.
SPL_SPR
Program horizontal scan direction (Sharp panel dedicated signal).
PS
Control signal output for source driver (Sharp panel dedicated signal).
CLS
Start signal output for gate driver. This signal is an inverted version of PS (Sharp panel
dedicated signal).
REV
Signal for common electrode driving signal preparation (Sharp panel dedicated signal).
SPI 1 and 2
SPI1_MOSI
Master Out/Slave In
SPI1_MISO
Slave In/Master Out
SPI1_SS
Slave Select (Selectable polarity)
SPI1_SCLK
Serial Clock
SPI1_SPI_RDY
Serial Data Ready
SPI2_TXD
SPI2 Master TxData Output—This signal is multiplexed with a GPI/O pin yet shows up as a
primary or alternative signal in the signal multiplex scheme table. Please refer to the SPI
and GPIO chapters in the MC9328MXL Reference Manual for information about how to
bring this signal to the assigned pin.
MOTOROLA
7
Signal Name
Function/Notes
SPI2_RXD
SPI2 Master RxData Input—This signal is multiplexed with a GPI/O pin yet shows up as a
SPI2_SS
SPI2 Slave Select—This signal is multiplexed with a GPI/O pin yet shows up as a primary or
alternative signal in the signal multiplex scheme table. Please refer to the SPI and GPIO
chapters in the MC9328MXL Reference Manual for information about how to bring this
SPI2_SCLK
SPI2 Serial Clock—This signal is multiplexed with a GPI/O pin yet shows up as a primary or
General Purpose Timers
TIN
Timer Input Capture or Timer Input Clock—The signal on this input is applied to both timers
simultaneously.
TMR2OUT
Timer 2 Output
USB Device
USBD_VMO
USB Minus Output
USBD_VPO
USB Plus Output
USBD_VM
USB Minus Input
USBD_VP
USB Plus Input
USBD_SUSPND
USB Suspend Output
USBD_RCV
USB Receive Data
USBD_OE
USB OE
USBD_AFE
USB Analog Front End Enable
Secure Digital Interface
SD_CMD
SD Command—If the system designer does not wish to make use of the internal pull-up, via
the Pull-up enable register, a 4.7K–69K external pull up resistor must be added.
SD_CLK
MMC Output Clock
SD_DAT [3:0]
Data—If the system designer does not wish to make use of the internal pull-up, via the Pullup enable register, a 50K–69K external pull up resistor must be added.
Memory Stick Interface
MS_BS
Memory Stick Bus State (Output)—Serial bus control signal
MS_SDIO
Memory Stick Serial Data (Input/Output)
MS_SCLKO
Memory Stick Serial Clock (Input)—Serial protocol clock source for SCLK Divider
MS_SCLKI
Memory Stick External Clock (Output)—Test clock input pin for SCLK divider. This pin is
only for test purposes, not for use in application mode.
MS_PI0
General purpose Input0—Can be used for Memory Stick Insertion/Extraction detect
MS_PI1
General purpose Input1—Can be used for Memory Stick Insertion/Extraction detect
UARTs – IrDA/Auto-Bauding
UART1_RXD
8
Receive Data
MOTOROLA
Signal Name
Function/Notes
UART1_TXD
Transmit Data
UART1_RTS
Request to Send
UART1_CTS
Clear to Send
UART2_RXD
Receive Data
UART2_TXD
Transmit Data
UART2_RTS
Request to Send
UART2_CTS
Clear to Send
UART2_DSR
Data Set Ready
UART2_RI
Ring Indicator
UART2_DCD
Data Carrier Detect
UART2_DTR
Data Terminal Ready
Serial Audio Port – SSI (configurable to I2S protocol)
SSI_TXDAT
Transmit Data
SSI_RXDAT
Receive Data
SSI_TXCLK
Transmit Serial Clock
SSI_RXCLK
Receive Serial Clock
SSI_TXFS
Transmit Frame Sync
SSI_RXFS
Receive Frame Sync
I2C
I2C_SCL
I2C Clock
I2C_SDA
I2C Data
PWM
PWMO
PWM Output
Digital Supply Pins
NVDD
Digital Supply for the I/O pins
NVSS
Digital Ground for the I/O pins
Supply Pins – Analog Modules
AVDD
Supply for analog blocks
AVSS
Quiet ground for analog blocks
Internal Power Supply
QVDD
Power supply pins for silicon internal circuitry
QVSS
Ground pins for silicon internal circuitry
Substrate Supply Pins
SVDD
Supply routed through substrate of package; not to be bonded
SGND
Ground routed through substrate of package; not to be bonded
MOTOROLA
9
Specifications
3 Specifications
This section contains the electrical specifications and timing diagrams for the MC9328MXL processor.
3.1 Maximum Ratings
Table 4 provides information on maximum ratings.
Table 4. Maximum Ratings
Rating
Symbol
Minimum
Maximum
Unit
Supply voltage
Vdd
-0.3
3.3
V
Maximum operating temperature range
MC9328MXLVH20/MC9328MXLVM20/
MC9328MXLVF20/MC9328MXLVP20
TA
°C
MC9328MXLDVH20/MC9328MXLDVM20/
MC9328MXLDVF20/MC9328MXLDVP20
TA
-30
70
°C
MC9328MXLCVH15/MC9328MXLCVM15/
MC9328MXLCVF15/MC9328MXLCVP15
TA
-40
85
°C
ESD at human body model (HBM)
VESD_HBM
2000
V
ESD at machine model (MM)
VESD_MM
100
V
ILatchup
200
mA
Storage temperature
Test
-55
150
°C
Power Consumption
Pmax
8001
13002
mW
Latch-up current
1.
2.
A typical application with 30 pads simultaneously switching assumes the GPIO toggling and instruction
fetches from the ARM core-that is, 7x GPIO, 15x Data bus, and 8x Address bus.
A worst-case application with 70 pads simultaneously switching assumes the GPIO toggling and
instruction fetches from the ARM core-that is, 32x GPIO, 30x Data bus, 8x Address bus. These
calculations are based on the core running its heaviest OS application at 200MHz, and where the whole
image is running out of SDRAM. QVDD at 2.0V, NVDD and AVDD at 3.3V, therefore, 180mA is the worst
measurement recorded in the factory environment, max 5mA is consumed for OSC pads, with each toggle
GPIO consuming 4mA.
3.2 Recommended Operating Range
Table 5 provides the recommended operating ranges for the supply voltages. The MC9328MXL has
multiple pairs of VDD and VSS power supply and return pins. QVDD and QVSS pins are used for internal
logic. All other VDD and VSS pins are for the I/O pads voltage supply, and each pair of VDD and VSS
provides power to the enclosed I/O pads. This design allows different peripheral supply voltage levels in a
system.
Because AVDD pins are supply voltages to the analog pads, it is recommended to isolate and noise-filter
the AVDD pins from other VDD pins.
For more information about I/O pads grouping per VDD, please refer to Table 3 on page 5.
10
MOTOROLA
Specifications
Table 5. Recommended Operating Range
Rating
Symbol
Minimum
Maximum
Unit
I/O supply voltage (if using MSHC, SPI, BTA, USBd, LCD and CSI
which are only 3 V interfaces)
NVDD
2.70
3.30
V
I/O supply voltage (if not using the peripherals listed above)
NVDD
1.70
3.30
V
Internal supply voltage (Core = 150 MHz)
QVDD
1.70
1.90
V
Internal supply voltage (Core = 200 MHz)
QVDD
1.80
2.00
V
Analog supply voltage
AVDD
1.70
3.30
V
3.3 DC Electrical Characteristics
Table 6 contains both maximum and minimum DC characteristics of the MC9328MXL.
Table 6. Maximum and Minimum DC Characteristics
Number or
Symbol
Parameter
Min
Typical
Max
Unit
Full running operating current at 1.8V for QVDD,
3.3V for NVDD/AVDD (Core = 96 MHz, System =
96 MHz, MPEG4 decoding playback from external
memory card to both external SSI audio decoder
and TFT display panel, and OS with MMU enabled
memory system is running on external SDRAM).
QVDD at
1.8v = 120mA;
NVDD+AVDD at
3.0v = 30mA
mA
Sidd1
Standby current
(Core = 150 MHz, QVDD = 1.8V, temp = 25°C)
25
µA
Sidd2
Standby current
(Core = 150 MHz, QVDD = 1.8V, temp = 55°C)
45
µA
Sidd3
Standby current
(Core = 150 MHz, QVDD = 2.0V, temp = 25°C)
35
µA
Sidd4
Standby current
(Core = 150 MHz, QVDD = 2.0V, temp = 55°C)
60
µA
Iop
VIH
Input high voltage
0.7VDD
Vdd+0.2
V
VIL
Input low voltage
0.4
V
VOH
Output high voltage (IOH = 2.0 mA)
0.7VDD
Vdd
V
VOL
Output low voltage (IOL = -2.5 mA)
0.4
V
Vit+
Positive input threshold voltage, Vi =Vih
1.126
V
Vit-
Negative input threshold voltage, Vi =Vil
0.640
V
Vhys
Hysteresis (Vit+ − Vit-) = Vih
0.3
V
±1
µA
IIL
MOTOROLA
Input low leakage current
(VIN = GND, no pull-up or pull-down)
11
Specifications
Table 6. Maximum and Minimum DC Characteristics (Continued)
Number or
Symbol
Parameter
Min
Typical
Max
Unit
IIH
Input high leakage current
(VIN = VDD, no pull-up or pull-down)
±1
µA
IOH
Output high current
(VOH = 0.8VDD, VDD = 1.8V)
4.0
mA
IOL
Output low current
(VOL = 0.4V, VDD = 1.8V)
-4.0
mA
IOZ
Output leakage current
(Vout = VDD, output is tri-stated)
±5
µA
Ci
Input capacitance
5
pF
Co
Output capacitance‘
5
pF
3.4 AC Electrical Characteristics
The AC characteristics consist of output delays, input setup and hold times, and signal skew times. All
signals are specified relative to an appropriate edge of other signals. All timing specifications are specified
at a system operating frequency from 0 MHz to 96 MHz (core operating frequency 150 MHz) with an
operating supply voltage from VDD min to VDD max under an operating temperature from TL to TH. All
timing is measured at 30 pF loading.
Table 7. Tristate Signal Timing
Pin
TRISTATE
Parameter
Minimum
Maximum
Unit
20.8
ns
Time from TRISTATE activate until I/O becomes Hi-Z
Table 8. 32k/16M Oscillator Signal Timing
Parameter
EXTAL32k input jitter (peak to peak)
EXTAL32k startup time
EXTAL16M input jitter (peak to peak)
EXTAL16M startup time
Minimum
RMS
Maximum
Unit
5
ns
800
ms
TBD
TBD
TBD
3.5 Embedded Trace Macrocell
All registers in the ETM9 are programmed through a JTAG interface. The interface is an extension of the
ARM920T processor’s TAP controller, and is assigned scan chain 6. The scan chain consists of a 40-bit
shift register comprised of the following:
12
32-bit data field
MOTOROLA
Specifications
7-bit address field
A read/write bit
The data to be written is scanned into the 32-bit data field, the address of the register into the 7-bit address
field, and a 1 into the read/write bit.
A register is read by scanning its address into the address field and a 0 into the read/write bit. The 32-bit
data field is ignored. A read or a write takes place when the TAP controller enters the UPDATE-DR state.
The timing diagram for the ETM9 is shown in Figure 2. See Table 9 for the ETM9 timing parameters used
in Figure 2.
2a
1
2b
3a
TRACECLK
3b
TRACECLK
(Half-Rate Clocking Mode)
Output Trace Port
Valid Data
Valid Data
4a
4b
Figure 2. Trace Port Timing Diagram
Table 9. Trace Port Timing Diagram Parameter Table
1.8V ± 0.10V
Ref
No.
Parameter
1
3.0V ± 0.30V
Unit
Minimum
Maximum
Minimum
Maximum
CLK frequency
MHz
2a
Clock high time
1.3
2
ns
2b
Clock low time
3
2
ns
3a
Clock rise time
4
3
ns
3
3
ns
3b
Clock fall time
4a
Output hold time
2.28
2
ns
4b
Output setup time
3.42
3
ns
MOTOROLA
13
Specifications
3.6 DPLL Timing Specifications
Parameters of the DPLL are given in Table 10. In this table, Tref is a reference clock period after the
pre-divider and Tdck is the output double clock period.
Table 10. DPLL Specifications
Parameter
Test Conditions
Minimum
Typical
Maximum
Unit
Reference clock freq range
Vcc = 1.8V
5
100
MHz
Pre-divider output clock
freq range
Vcc = 1.8V
5
30
MHz
Double clock freq range
Vcc = 1.8V
80
220
MHz
Pre-divider factor (PD)
1
16
Total multiplication factor (MF)
Includes both integer
and fractional parts
5
15
MF integer part
5
15
MF numerator
Should be less than the
denominator
MF denominator
1
1023
Pre-multiplier lock-in time
312.5
µsec
Freq lock-in time after
full reset
FOL mode for non-integer MF
(does not include pre-multi lock-in
time)
250
280
(56 µs)
300
Tref
partial reset
time)
220
250
(50 µs)
270
Tref
Phase lock-in time after
full reset
FPL mode and integer MF (does
not include pre-multi lock-in time)
300
350
(70 µs)
400
Tref
partial reset
270
320
(64 µs)
370
Tref
Freq jitter (p-p)
0.005
(0.01%)
0.01
2•Tdck
Phase jitter (p-p)
Integer MF, FPL mode, Vcc=1.8V
1.0
(10%)
1.5
ns
Power supply voltage
1.7
2.5
V
Power dissipation
FOL mode, integer MF,
fdck = 200 MHz, Vcc = 1.8V
4
mW
14
MOTOROLA
Specifications
3.7 Reset Module
The timing relationships of the Reset module with the POR and RESET_IN are shown in Figure 3 and
Figure 4. Be aware that NVDD must ramp up to at least 1.8V before QVDD is powered up to prevent
forward biasing.
90% AVDD
1
POR
10% AVDD
Could be adjusted due to 32kHz
Crystal start-up time
2
RESET_POR
Exact 300ms
3
7 cycles @ CLK32
RESET_DRAM
4
HRESET
14 cycles @ CLK32
RESET_OUT
CLK32
HCLK
Figure 3. Timing Relationship with POR
5
RESET_IN
14 cycles @ CLK32
HRESET
RESET_OUT
4
6
CLK32
HCLK
Figure 4. Timing Relationship with RESET_IN
MOTOROLA
15
Specifications
Table 11. Reset Module Timing Parameter Table
Ref
No.
16
1.8V ± 0.10V
3.0V ± 0.30V
Parameter
Unit
Min
Max
Min
Max
1
Width of input POWER_ON_RESET
800
800
ms
2
Width of internal POWER_ON_RESET
(CLK32 at 32 kHz)
300
300
300
300
ms
3
7K to 32K-cycle stretcher for SDRAM reset
7
7
7
7
Cycles of
CLK32
4
14K to 32K-cycle stretcher for internal system reset
HRESERT and output reset at pin RESET_OUT
14
14
14
14
Cycles of
CLK32
5
Width of external hard-reset RESET_IN
4
4
Cycles of
CLK32
6
4K to 32K-cycle qualifier
4
4
4
4
Cycles of
CLK32
MOTOROLA
Specifications
3.8 External Interface Module
The External Interface Module (EIM) handles the interface to devices external to the MC9328MXL,
including the generation of chip-selects for external peripherals and memory. The timing diagram for the
EIM is shown in Figure 5, and Table 12 on page 18 defines the parameters of signals.
(HCLK) Bus Clock
1a
1b
2a
2b
3a
3b
Address
Chip-select
Read (Write)
4a
OE (rising edge)
4c
OE (falling edge)
5b
5c
EB (falling edge)
LBA (negated rising edge)
4d
5a
EB (rising edge)
LBA (negated falling edge)
4b
5d
6a
6b
6a
6c
7a
7b
Burst Clock (rising edge)
7c
7d
Burst Clock (falling edge)
8b
Read Data
9a
8a
9b
Write Data (negated falling)
9a
9c
Write Data (negated rising)
DTACK
10a
10a
Figure 5. EIM Bus Timing Diagram
MOTOROLA
17
Specifications
Table 12. EIM Bus Timing Parameter Table
1.8V ± 0.10V
Ref No.
Unit
Min
Typical
Max
Min
Typical
Max
1a
Clock fall to address valid
2.48
3.31
9.11
2.4
3.2
8.8
ns
1b
Clock fall to address invalid
1.55
2.48
5.69
1.5
2.4
5.5
ns
2a
Clock fall to chip-select valid
2.69
3.31
7.87
2.6
3.2
7.6
ns
2b
Clock fall to chip-select invalid
1.55
2.48
6.31
1.5
2.4
6.1
ns
3a
Clock fall to Read (Write) Valid
1.35
2.79
6.52
1.3
2.7
6.3
ns
3b
Clock fall to Read (Write) Invalid
1.86
2.59
6.11
1.8
2.5
5.9
ns
4a
Clock1 rise to Output Enable Valid
2.32
2.62
6.85
2.3
2.6
6.8
ns
4b
Clock1 rise to Output Enable Invalid
2.11
2.52
6.55
2.1
2.5
6.5
ns
4c
Clock1 fall to Output Enable Valid
2.38
2.69
7.04
2.3
2.6
6.8
ns
4d
Clock1 fall to Output Enable Invalid
2.17
2.59
6.73
2.1
2.5
6.5
ns
5a
Clock1 rise to Enable Bytes Valid
1.91
2.52
5.54
1.9
2.5
5.5
ns
5b
Clock1 rise to Enable Bytes Invalid
1.81
2.42
5.24
1.8
2.4
5.2
ns
5c
Clock1 fall to Enable Bytes Valid
1.97
2.59
5.69
1.9
2.5
5.5
ns
5d
Clock1 fall to Enable Bytes Invalid
1.76
2.48
5.38
1.7
2.4
5.2
ns
6a
Clock1 fall to Load Burst Address Valid
2.07
2.79
6.73
2.0
2.7
6.5
ns
6b
Clock1 fall to Load Burst Address Invalid
1.97
2.79
6.83
1.9
2.7
6.6
ns
6c
Clock1 rise to Load Burst Address Invalid
1.91
2.62
6.45
1.9
2.6
6.4
ns
7a
Clock1 rise to Burst Clock rise
1.61
2.62
5.64
1.6
2.6
5.6
ns
7b
Clock1rise to Burst Clock fall
1.61
2.62
5.84
1.6
2.6
5.8
ns
7c
Clock1 fall to Burst Clock rise
1.55
2.48
5.59
1.5
2.4
5.4
ns
7d
Clock1 fall to Burst Clock fall
1.55
2.59
5.80
1.5
2.5
5.6
ns
8a
Read Data setup time
5.54
5.5
ns
8b
Read Data hold time
ns
9a
Clock1 rise to Write Data Valid
1.81
2.72
6.85
1.8
2.7
6.8
ns
9b
Clock1 fall to Write Data Invalid
1.45
2.48
5.69
1.4
2.4
5.5
ns
9c
Clock1 rise to Write Data Invalid
1.63
1.62
ns
DTACK setup time
2.52
2.5
ns
10a
1.
18
3.0V ± 0.30V
Parameter
Clock refers to the system clock signal, HCLK, generated from the System PLL
MOTOROLA
Specifications
3.8.1 DTACK Signal Description
The DTACK signal is the external input data acknowledge signal. When using the external DTACK signal
as a data acknowledge signal, the bus time-out monitor generates a bus error when a bus cycle is not
terminated by the external DTACK signal after 1022 HCLK counts have elapsed. Only CS5 group is
designed to support DTACK signal function when using the external DTACK signal for data
acknowledgement.
3.8.2 DTACK Signal Timing
Figure 6 shows the access cycle timing used by chip-select 5. The signal values and units of measure for
this figure are found in Table 13.
HCLK
CS5
3
RW
1
5
OE
4
EXT_DTACK
2
INT_DTACK
Figure 6. DTACK Timing, WSC=111111, DTACK_sel=0
Table 13. Access Cycle Timing Parameters
1.8V ± 0.10V
Ref
No.
3.0V ± 0.30V
Characteristic
Unit
Min
Max
Min
Max
1
CS5 asserted to OE asserted
T
T
ns
2
External DTACK input setup from CS5
asserted
ns
3
CS5 pulse width
3T
3T
ns
4
External DTACK input hold after CS5 is
negated
1.5T
1.5T
ns
5
OE negated after CS5 is negated
ns
Note:
1. n is the number of wait states in the current memory access cycle. The max n is 1022.
2. T is the system clock period (system clock is 96 MHz).
3. The external DTACK input requirement is eliminated when CS5 is programmed to use internal wait state.
MOTOROLA
19
Specifications
HCLK
CS5
RW
OE
1
EXT_DTACK (WAIT)
INT_DTACK
Figure 7. DTACK Timing, WSC=111111, DTACK_sel=1
Table 14. Access Cycle Timing Parameters
Ref
No.
1
1.8V ± 0.10V
3.0V ± 0.30V
Characteristic
asserted
Unit
Min
Max
Min
Max
ns
Note:
MOTOROLA
Specifications
3.8.3 EIM External Bus Timing
The timing diagrams in this section show the timing of accesses to memory or a peripheral.
hclk
hsel_weim_cs[0]
htrans
Seq/Nonseq
hwrite
Read
haddr
V1
hready
weim_hrdata
Last Valid Data
V1
weim_hready
weim_bclk
weim_addr
Last Valid Address
V1
weim_cs
weim_r/w
Read
weim_lba
weim_oe
weim_eb (EBC=0)
weim_eb (EBC=1)
weim_data_in
V1
Figure 8. WSC = 1, A.HALF/E.HALF
MOTOROLA
21
Specifications
hclk
hsel_weim_cs[0]
htrans
Nonseq
hwrite
Write
haddr
V1
hready
hwdata
Last Valid Data
weim_hrdata
Write Data (V1)
Unknown
Last Valid Data
weim_hready
weim_bclk
weim_addr
Last Valid Address
V1
weim_cs[0]
weim_r/w
Write
weim_lba
weim_oe
weim_eb
weim_data_out
Last Valid Data
Write Data (V1)
Figure 9. WSC = 1, WEA = 1, WEN = 1, A.HALF/E.HALF
22
MOTOROLA
Specifications
hclk
hsel_weim_cs[0]
htrans
Nonseq
hwrite
Read
haddr
V1
hready
weim_hrdata
Last Valid Data
V1 Word
weim_hready
weim_bclk
weim_addr
Last Valid Addr
Address V1
Address V1 + 2
weim_cs[0]
weim_r/w
Read
weim_lba
weim_oe
weim_eb (EBC=0)
weim_eb (EBC=1)
weim_data_in
1/2 Half Word
2/2 Half Word
Figure 10. WSC = 1, OEA = 1, A.WORD/E.HALF
MOTOROLA
23
Specifications
hclk
hsel_weim_cs[0]
htrans
Nonseq
hwrite
Write
haddr
V1
hready
hwdata
Last Valid Data
Write Data (V1 Word)
weim_hrdata
Last Valid Data
weim_hready
weim_bclk
weim_addr
Last Valid Addr
Address V1 + 2
Address V1
weim_cs[0]
weim_r/w
Write
weim_lba
weim_oe
weim_eb
weim_data_out
1/2 Half Word
2/2 Half Word
Figure 11. WSC = 1, WEA = 1, WEN = 2, A.WORD/E.HALF
24
MOTOROLA
Specifications
hclk
hsel_weim_cs[3]
htrans
Nonseq
hwrite
Read
haddr
V1
hready
weim_hrdata
Last Valid Data
V1 Word
weim_hready
weim_bclk
weim_addr Last Valid Addr
Address V1
Address V1 + 2
weim_cs[3]
weim_r/w
Read
weim_lba
weim_oe
weim_eb (EBC=0)
weim_eb (EBC=1)
weim_data_in
1/2 Half Word
2/2 Half Word
Figure 12. WSC = 3, OEA = 2, A.WORD/E.HALF
MOTOROLA
25
Specifications
hclk
hsel_weim_cs[3]
htrans
Nonseq
hwrite
Write
haddr
V1
hready
hwdata Last Valid
Data
weim_hrdata
Last Valid Data
weim_hready
weim_bclk
Address V1
Address V1 + 2
weim_cs[3]
weim_r/w
Write
weim_lba
weim_oe
weim_eb
weim_data_out]
Last Valid Data
1/2 Half Word
2/2 Half Word
Figure 13. WSC = 3, WEA = 1, WEN = 3, A.WORD/E.HALF
26
MOTOROLA
Specifications
hclk
hsel_weim_cs[2]
htrans
Nonseq
hwrite
Read
haddr
V1
hready
weim_hrdata
Last Valid Data
V1 Word
weim_hready
weim_bclk
weim_addr
Last Valid Addr
Address V1 + 2
Address V1
weim_cs[2]
weim_r/w
Read
weim_lba
weim_oe
weim_eb (EBC=0)
weim_eb (EBC=1)
weim_data_in
1/2 Half Word
2/2 Half Word
Figure 14. WSC = 3, OEA = 4, A.WORD/E.HALF
MOTOROLA
27
Specifications
hclk
hsel_weim_cs[2]
htrans
Nonseq
hwrite
Write
haddr
V1
hready
hwdata
Last Valid
Data
weim_hrdata
Last Valid Data
weim_hready
weim_bclk
weim_addr
Last Valid Addr
Address V1
Address V1 + 2
weim_cs[2]
weim_r/w
Write
weim_lba
weim_oe
weim_eb
weim_data_out
Last Valid Data
1/2 Half Word
2/2 Half Word
Figure 15. WSC = 3, WEA = 2, WEN = 3, A.WORD/E.HALF
28
MOTOROLA
Specifications
hclk
hsel_weim_cs[2]
htrans
Nonseq
hwrite
Read
haddr
V1
hready
weim_hrdata
Last Valid Data
V1 Word
weim_hready
weim_bclk
weim_addr
Last Valid Addr
Address V1
Address V1 + 2
weim_cs[2]
weim_r/w
Read
weim_lba
weim_oe
weim_eb (EBC=0)
weim_eb (EBC=1)
weim_data_in
1/2 Half Word
2/2 Half Word
Figure 16. WSC = 3, OEN = 2, A.WORD/E.HALF
MOTOROLA
29
Specifications
hclk
hsel_weim_cs[2]
htrans
Nonseq
hwrite
Read
haddr
V1
hready
weim_hrdata
V1 Word
Last Valid Data
weim_hready
weim_bclk
weim_addr
Last Valid Addr
Address V1
Address V1 + 2
weim_cs[2]
weim_r/w
Read
weim_lba
weim_oe
weim_eb (EBC=0)
weim_eb (EBC=1)
weim_data_in
1/2 Half Word
2/2 Half Word
Figure 17. WSC = 3, OEA = 2, OEN = 2, A.WORD/E.HALF
30
MOTOROLA
Specifications
hclk
hsel_weim_cs[2]
htrans
Nonseq
hwrite
Write
haddr
V1
hready
hwdata
Last Valid
Data
weim_hrdata
Unknown
Last Valid Data
weim_hready
weim_bclk
weim_addr
Last Valid Addr
Address V1
Address V1 + 2
weim_cs[2]
weim_r/w
Write
weim_lba
weim_oe
weim_eb
weim_data_out
Last Valid Data
1/2 Half Word
2/2 Half Word
Figure 18. WSC = 2, WWS = 1, WEA = 1, WEN = 2, A.WORD/E.HALF
MOTOROLA
31
Specifications
hclk
hsel_weim_cs[2]
htrans
Nonseq
hwrite
Write
haddr
V1
hready
hwdata
Last Valid
Data
Unknown
weim_hrdata
Last Valid Data
weim_hready
weim_bclk
weim_addr
Last Valid Addr
Address V1
Address V1 + 2
weim_cs[2]
weim_r/w
Write
weim_lba
weim_oe
weim_eb
weim_data_out
Last Valid Data
1/2 Half Word
2/2 Half Word
Figure 19. WSC = 1, WWS = 2, WEA = 1, WEN = 2, A.WORD/E.HALF
32
MOTOROLA
Specifications
hclk
hsel_weim_cs[2]
htrans
Nonseq
Nonseq
hwrite
Read
Write
haddr
V1
V8
hready
hwdata
weim_hrdata
Last Valid Data
Write Data
Last Valid Data
Read Data
weim_hready
weim_bclk
weim_addr
Last Valid Addr
Address V1
Address V8
weim_cs[2]
weim_r/w
Write
Read
weim_lba
weim_oe
weim_eb (EBC=0)
weim_eb (EBC=1)
weim_data_in
weim_data_out
Read Data
Last Valid Data
Write Data
Figure 20. WSC = 2, WWS = 2, WEA = 1, WEN = 2, A.HALF/E.HALF
MOTOROLA
33
Specifications
Read
Idle
Write
hclk
hsel_weim_cs[2]
htrans
Nonseq
Nonseq
hwrite
Read
Write
haddr
V1
V8
hready
hwdata
weim_hrdata
Write Data
Last Valid Data
Last Valid Data
Read Data
weim_hready
weim_bclk
weim_addr
Last Valid Addr
Address V1
Address V8
weim_cs[2]
weim_r/w
Read
Write
weim_lba
weim_oe
weim_eb (EBC=0)
weim_eb (EBC=1)
weim_data_in
weim_data_out
Read Data
Last Valid Data
Write Data
Figure 21. WSC = 2, WWS = 1, WEA = 1, WEN = 2, EDC = 1, A.HALF/E.HALF
34
MOTOROLA
Specifications
hclk
hsel_weim_cs[4]
htrans
Nonseq
hwrite
Write
haddr
V1
hready
hwdata
Last Valid
Data
Write Data (Word)
weim_hrdata
Last Valid Data
weim_hready
weim_bclk
weim_addr
Last Valid Addr
Address V1
Address V1 + 2
weim_cs
weim_r/w
Write
weim_lba
weim_oe
weim_eb
weim_data_out
Last Valid Data
Write Data (1/2 Half Word)
Write Data (2/2 Half Word)
Figure 22. WSC = 2, CSA = 1, WWS = 1, A.WORD/E.HALF
MOTOROLA
35
Specifications
hclk
hsel_weim_cs[4]
htrans
Nonseq
Nonseq
hwrite
Read
Write
haddr
V1
V8
hready
hwdata
weim_hrdata
Last Valid Data
Write Data
Last Valid Data
Read Data
weim_hready
weim_bclk
weim_addr
Last Valid Addr
Address V1
Address V8
weim_cs[4]
weim_r/w
Write
Read
weim_lba
weim_oe
weim_eb (EBC=0)
weim_eb (EBC=1)
weim_data_in
weim_data_out
Read Data
Last Valid Data
Write Data
Figure 23. WSC = 3, CSA = 1, A.HALF/E.HALF
36
MOTOROLA
Specifications
hclk
hsel_weim_cs[4]
htrans
Nonseq
hwrite
Read
Read
haddr
V1
V2
Idle
Seq
hready
weim_hrdata
Last Valid Data
Read Data (V1)
Read Data (V2)
weim_hready
weim_bclk
weim_addr
Last Valid
Address V1
Address V2
CNC
weim_cs[4]
weim_r/w
Read
weim_lba
weim_oe
weim_eb (EBC=0)
weim_eb (EBC=1)
weim_data_in
Read Data
(V1)
Read Data
(V2)
Figure 24. WSC = 2, OEA = 2, CNC = 3, BCM = 1, A.HALF/E.HALF
MOTOROLA
37
Specifications
hclk
hsel_weim_cs[4]
htrans
Nonseq
hwrite
Read
Write
haddr
V1
V8
Idle
Nonseq
hready
hwdata
weim_hrdata
Last Valid Data
Write Data
Last Valid Data
Read Data
weim_hready
weim_bclk
weim_addr
Last Valid Addr
Address V1
Address V8
CNC
weim_cs[4]
weim_r/w
Read
Write
weim_lba
weim_oe
weim_eb (EBC=0)
weim_eb (EBC=1)
weim_data_in
weim_data_out
Read Data
Last Valid Data
Write Data
Figure 25. WSC = 2, OEA = 2, WEA = 1, WEN = 2, CNC = 3, A.HALF/E.HALF
38
MOTOROLA
Specifications
hclk
hsel_weim_cs[2]
htrans
Nonseq
Nonse
hwrite
Read
Read
haddr
V1
V5
Idle
hready
weim_hrdata
weim_hready
weim_bclk
weim_addr]
Last Valid Addr
Address V1
Address V5
weim_cs[2]
Read
weim_r/w
weim_lba
weim_oe
weim_eb (EBC=0)
weim_eb (EBC=1)
weim_ecb
weim_data_in
V1 Word
V2 Word
V5 Word
V6 Word
Figure 26. WSC = 3, SYNC = 1, A.HALF/E.HALF
MOTOROLA
39
Specifications
hclk
hsel_weim_cs[2]
htrans
Nonseq
Seq
Seq
Seq
hwrite
Read
Read
Read
Read
haddr
V1
V2
V3
V4
Idle
hready
weim_hrdata
Last Valid Data
V1 Word
V2 Word
V3 Word
V4 Word
weim_hready
weim_bclk
Address V1
weim_cs[2]
weim_r/w
Read
weim_lba
weim_oe
weim_eb (EBC=0)
weim_eb (EBC=1)
weim_ecb
weim_data_in
V1 Word
V2 Word
V3 Word
V4 Word
Figure 27. WSC = 2, SYNC = 1, DOL = [1/0], A.WORD/E.WORD
40
MOTOROLA
Specifications
hclk
hsel_weim_cs[2]
htrans
Nonseq
Seq
hwrite
Read
Read
haddr
V1
V2
Idle
hready
weim_hrdata
Last Valid Data
V1 Word
V2 Word
weim_hready
weim_bclk
weim_addr
Last Valid
Address V1
Address V2
weim_cs[2]
weim_r/w
Read
weim_lba
weim_oe
weim_eb (EBC=0)
weim_eb (EBC=1)
weim_ecb
weim_data_in
V1 1/2
V1 2/2
V2 1/2
V2 2/2
Figure 28. WSC = 2, SYNC = 1, DOL = [1/0], A.WORD/E.HALF
MOTOROLA
41
Specifications
hclk
hsel_weim_cs[2]
htrans
Non
seq
Seq
hwrite
Read
Read
haddr
V1
V2
Idle
hready
weim_hrdata
Last Valid Data
V1 Word
V2 Word
weim_hready
weim_bclk
weim_addr
Last
Address V1
weim_cs[2]
weim_r/w
Read
weim_lba
weim_oe
weim_eb (EBC=0)
weim_eb (EBC=1)
weim_ecb
weim_data_in
V1 1/2
V1 2/2
V2 1/2
V2 2/2
Figure 29. WSC = 7, OEA = 8, SYNC = 1, DOL = 1, BCD = 1, BCS = 2, A.WORD/E.HALF
42
MOTOROLA
Specifications
hclk
hsel_weim_cs[2]
htrans
Non
seq
Seq
hwrite
Read
Read
haddr
V1
V2
Idle
hready
weim_hrdata
Last Valid Data
V1 Word
V2 Word
weim_hready
weim_bclk
weim_addr
Last
Address V1
weim_cs[2]
weim_r/w
Read
weim_lba
weim_oe
weim_eb (EBC=0)
weim_eb (EBC=1)
weim_ecb
weim_data_in
V1 1/2
V1 2/2
V2 1/2
V2 2/2
Figure 30. WSC = 7, OEA = 8, SYNC = 1, DOL = 1, BCD = 1, BCS = 1, A.WORD/E.HALF
MOTOROLA
43
Specifications
3.9 SPI Timing Diagrams
To utilize the internal transmit (TX) and receive (RX) data FIFOs when the SPI 1 module is configured as
a master, two control signals are used for data transfer rate control: the SS signal (output) and the
SPI_RDY signal (input). The SPI 1 Sample Period Control Register (PERIODREG1) and the SPI 2
Sample Period Control Register (PERIODREG2) can also be programmed to a fixed data transfer rate for
either SPI 1 or SPI 2. When the SPI 1 module is configured as a slave, the user can configure the SPI 1
Control Register (CONTROLREG1) to match the external SPI master’s timing. In this configuration, SS
becomes an input signal, and is used to latch data into or load data out to the internal data shift registers, as
well as to increment the data FIFO. Figure 31 through Figure 35 show the timing relationship of the master
SPI using different triggering mechanisms.
2
SS
5
3
1
SPIRDY
4
SCLK, MOSI, MISO
Figure 31. Master SPI Timing Diagram Using SPI_RDY Edge Trigger
SS
SPIRDY
SCLK, MOSI, MISO
Figure 32. Master SPI Timing Diagram Using SPI_RDY Level Trigger
SS (output)
SCLK, MOSI, MISO
Figure 33. Master SPI Timing Diagram Ignore SPI_RDY Level Trigger
SS (input)
SCLK, MOSI, MISO
Figure 34. Slave SPI Timing Diagram FIFO Advanced by BIT COUNT
44
MOTOROLA
Specifications
SS (input)
6
7
SCLK, MOSI, MISO
Figure 35. Slave SPI Timing Diagram FIFO Advanced by SS Rising Edge
Table 15. Timing Parameter Table for Figure 31 through Figure 35
1.8V ± 0.10V
Ref
No.
Parameter
3.0V ± 0.30V
Minimum
Maximum
Minimum
Maximum
Unit
1
SPI_RDY to SS output low
2T 1
2T1
ns
2
SS output low to first SCLK
edge
3 • Tsclk 2
3 • Tsclk2
ns
3
Last SCLK edge to SS output
high
2 • Tsclk
2 • Tsclk
ns
4
SS output high to SPI_RDY
low
ns
5
SS output pulse width
Tsclk +
WAIT 3
Tsclk +
WAIT3
ns
6
SS input low to first SCLK
edge
T
T
ns
7
SS input pulse width
T
T
ns
1.
2.
3.
T = CSPI system clock period (PERCLK2).
Tsclk = Period of SCLK.
WAIT = Number of bit clocks (SCLK) or 32.768 kHz clocks per Sample Period Control Register.
3.10 LCD Controller
This section includes timing diagrams for the LCD controller. For detailed timing diagrams of the LCD
controller with various display configurations, refer to the LCD controller chapter of the MC9328MXL
Reference Manual.
LSCLK
LD[15:0]
1
Figure 36. SCLK to LD Timing Diagram
MOTOROLA
45
Specifications
Table 16. LCDC SCLK Timing Parameter Table
1.8V ± 0.10V
Ref
No.
1
Parameter
3.0V ± 0.30V
Minimum
Maximum
Minimum
Maximum
Unit
2
2
ns
SCLK to LD valid
Non-display region
VSYN
Display region
T3
T1
T4
T2
HSYN
OE
LD[15:0]
Line Y
Line 1
T5
T6
Line Y
T7
XMAX
HSYN
SCLK
OE
T8
LD[15:0]
(1,1)
(1,2)
(1,X)
VSYN
T9
T10
Figure 37. 4/8/16 Bit/Pixel TFT Color Mode Panel Timing
Table 17. 4/8/16 Bit/Pixel TFT Color Mode Panel Timing
Symbol
46
Description
Minimum
Corresponding Register Value
Unit
T1
End of OE to beginning of VSYN
T5+T6
+T7+T9
(VWAIT1·T2)+T5+T6+T7+T9
Ts
T2
HSYN period
XMAX+5
XMAX+T5+T6+T7+T9+T10
Ts
T3
VSYN pulse width
T2
VWIDTH·(T2)
Ts
T4
End of VSYN to beginning of OE
2
VWAIT2·(T2)
Ts
T5
HSYN pulse width
1
HWIDTH+1
Ts
T6
End of HSYN to beginning to T9
1
HWAIT2+1
Ts
MOTOROLA
Specifications
Table 17. 4/8/16 Bit/Pixel TFT Color Mode Panel Timing (Continued)
Symbol
Description
Minimum
Unit
T7
End of OE to beginning of HSYN
1
HWAIT1+1
Ts
T8
SCLK to valid LD data
-3
3
ns
T9
End of HSYN idle2 to VSYN edge
(for non-display region)
2
2
Ts
T9
(for Display region)
1
1
Ts
T10
VSYN to OE active (Sharp = 0)
when VWAIT2 = 0
1
1
Ts
T10
VSYN to OE active (Sharp = 1)
when VWAIT2 = 0
2
2
Ts
Note:
Ts is the SCLK period which equals LCDC_CLK / (PCD + 1). Normally LCDC_CLK = 15ns.
VSYN, HSYN and OE can be programmed as active high or active low. In Figure 37, all 3 signals are active low.
The polarity of SCLK and LD[15:0] can also be programmed.
SCLK can be programmed to be deactivated during the VSYN pulse or the OE deasserted period. In Figure 37, SCLK
is always active.
For T9 non-display region, VSYN is non-active. It is used as an reference.
XMAX is defined in pixels.
MOTOROLA
47
Specifications
3.11 Multimedia Card/Secure Digital Host Controller
The DMA interface block controls all data routing between the external data bus (DMA access), internal
MMC/SD module data bus, and internal system FIFO access through a dedicated state machine that
monitors the status of FIFO content (empty or full), FIFO address, and byte/block counters for the
MMC/SD module (inner system) and the application (user programming).
3a
1
2
4b
3b
Bus Clock
4a
5b
5a
CMD_DAT Input
Valid Data
Valid Data
7
CMD_DAT Output
Valid Data
Valid Data
6b
6a
Figure 38. Chip-Select Read Cycle Timing Diagram
Table 18. SDHC Bus Timing Parameter Table
Ref
No.
1.8V ± 0.10V
3.0 ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
1
CLK frequency at Data transfer Mode
(PP)1—10/30 cards
MHz
2
CLK frequency at Identification Mode2
kHz
3a
Clock high time1—10/30 cards
6/33
10/50
ns
3b
Clock low time1—10/30 cards
15/75
10/50
ns
4a
Clock fall time1—10/30 cards
10/50
(5.00)3
10/50
ns
4b
Clock rise time1—10/30 cards
14/67
(6.67)3
10/50
ns
5a
Input hold time3—10/30 cards
5.7/5.7
5/5
ns
5b
Input setup time3—10/30 cards
5.7/5.7
5/5
ns
6a
Output hold time3—10/30 cards
5.7/5.7
5/5
ns
6b
Output setup time3—10/30 cards
5.7/5.7
5/5
ns
7
Output delay time3
ns
1.
2.
3.
48
CL ≤ 100 pF / 250 pF (10/30 cards)
CL ≤ 250 pF (21 cards)
CL ≤ 25 pF (1 card)
MOTOROLA
Specifications
3.11.1 Command Response Timing on MMC/SD Bus
The card identification and card operation conditions timing are processed in open-drain mode. The card
response to the host command starts after exactly NID clock cycles. For the card address assignment,
SET_RCA is also processed in the open-drain mode. The minimum delay between the host command and
card response is NCR clock cycles as illustrated in Figure 39. The symbols for Figure 39 through Figure 43
are defined in Table 19.
Table 19. State Signal Parameters for Figure 39 through Figure 43
Card Active
Host Active
Symbol
Definition
Symbol
Definition
Z
High impedance state
S
Start bit (0)
D
Data bits
T
Transmitter bit
(Host = 1, Card = 0)
Repetition
P
One-cycle pull-up (1)
CRC
Cyclic redundancy check bits (7 bits)
E
End bit (1)
NID cycles
Host Command
CMD S T
Content
CRC E Z
CID/OCR
Z ST
Content
ZZZ
Identification Timing
NCR cycles
Host Command
CMD S T
Content
CRC E Z
CID/OCR
Z ST
Content
ZZZ
SET_RCA Timing
Figure 39. Timing Diagrams at Identification Mode
After a card receives its RCA, it switches to data transfer mode. As shown on the first diagram in
Figure 40, SD_CMD lines in this mode are driven with push-pull drivers. The command is followed by a
period of two Z bits (allowing time for direction switching on the bus) and then by P bits pushed up by the
responding card. The other two diagrams show the separating periods NRC and NCC.
MOTOROLA
49
Specifications
NCR cycles
Host Command
CMD S T
Content
Response
CRC E Z Z P
PST
Content
CRC E Z Z Z
Command response timing (data transfer mode)
NRC cycles
Response
CMD S T
Content
Host Command
CRC E Z
Z ST
Content
CRC E Z Z Z
Timing response end to next CMD start (data transfer mode)
NCC cycles
Host Command
CMD S T
Content
CRC E Z
Host Command
Z ST
Content
CRC E Z Z Z
Timing of command sequences (all modes)
Figure 40. Timing Diagrams at Data Transfer Mode
Figure 41 on page 51 shows basic read operation timing. In a read operation, the sequence starts with a
single block read command (which specifies the start address in the argument field). The response is sent
on the SD_CMD lines as usual. Data transmission from the card starts after the access time delay NAC ,
beginning from the last bit of the read command. If the system is in multiple block read mode, the card
sends a continuous flow of data blocks with distance NAC until the card sees a stop transmission command.
The data stops two clock cycles after the end bit of the stop command.
50
MOTOROLA
Specifications
NCR cycles
Host Command
CMD S T
Content
DAT
Response
CRC E Z Z P ****** P S T
Z****Z
Content
CRC E Z
Z Z P ****** P S D D D D
Read Data
NAC cycles
Timing of single block read
NCR cycles
Host Command
CMD S T
DAT
Content
Response
Z****Z
ZZP
Content
P S DDDD
CRC E Z
P
P S DDDD
Read Data
NAC cycles
Read Data
NAC cycles
Timing of multiple block read
NCR cycles
Host Command
CMD S T
Content
Response
Content
CRC E Z
NST
DAT D D D D
DDDDE Z Z Z
Valid Read Data
Timing of stop command
(CMD12, data transfer mode)
Figure 41. Timing Diagrams at Data Read
Figure 42 shows the basic write operation timing. As with the read operation, after the card response, the
data transfer starts after NWR cycles. The data is suffixed with CRC check bits to allow the card to check
for transmission errors. The card sends back the CRC check result as a CC status token on the data line. If
there was a transmission error, the card sends a negative CRC status (101); otherwise, a positive CRC
status (010) is returned. The card expects a continuous flow of data blocks if it is configured to multiple
block mode, with the flow terminated by a stop transmission command.
MOTOROLA
51
52
Z****Z
Z****Z
CRC E Z Z P
NWR cycles
CRC status
Timing of the multiple block write command
NWR cycles
Write Data
Content
DAT Z Z P P S
CRC E Z Z X X X X X X X X Z P P S
EZPPS
Content
Content
Status
PST
DAT Z Z P P S
CRC E Z Z S
Write Data
Content
Status
ES
L*L
EZ
PP P
ES
L*L
EZ
CRC status
Busy
CRC E Z Z X X X X X X X X X X X X X X X X Z
Status
PPP
CRC status
Busy
CRC E Z Z S
Write Data
Content
Content
CRC E Z Z S
NWR cycles
Z ZZPPS
Z ZZPPS
CRC E Z Z P
Content
Response
Timing of the block write command
Content
NCR cycles
CMD E Z Z P
DAT
DAT
CMD S T
Host Command
Specifications
Figure 42. Timing Diagrams at Data Write
MOTOROLA
MOTOROLA
Content
CRC E Z Z P
DAT Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z S L
DAT S L
DAT D D D D D D D Z Z S CRC E Z Z S L
Write Data
PST
Content
ST
Content
CRC E
Host Command
Stop transmission received after last data block.
Card becomes busy programming.
EZ Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z
Stop transmission during CRC status transfer
from the card.
Stop transmission during data transfer
from the host.
CRC E Z Z Z
Card Response
Busy (Card is programming)
NCR cycles
DAT D D D D D D D D D D D D D E Z Z S L
CMD S T
Host Command
Specifications
The stop transmission command may occur when the card is in different states. Figure 43 shows the
different scenarios on the bus.
Figure 43. Stop Transmission During Different Scenarios
53
Specifications
Table 20. Timing Values for Figure 39 through Figure 43
Parameter
Symbol
Minimum
Maximum
Unit
Parameter
MMC/SD bus clock, CLK (All values are referred to minimum (VIH) and maximum
(VIL)
minimum (VIH) and
maximum (VIL)
Command response cycle
NCR
2
64
Clock
cycles
Identification response
cycle
NID
5
5
Clock
cycles
cycle
Access time delay cycle
NAC
2
TAAC + NSAC
Clock
cycles
Command read cycle
NRC
8
Clock
cycles
Command read cycle
Command-command
cycle
NCC
8
Clock
cycles
Command-command cycle
Command write cycle
NWR
2
Clock
cycles
Command write cycle
Stop transmission cycle
NST
2
2
Clock
cycles
TAAC: Data read access time -1 defined in CSD register bit[119:112]
NSAC: Data read access time -2 in CLK cycles (NSAC·100) defined in CSD register
bit[111:104]
CSD register bit[111:104]
3.11.2 SDIO-IRQ and ReadWait Service Handling
In SDIO, there is a 1-bit or 4-bit interrupt response from the SDIO peripheral card. In 1-bit mode, the
interrupt response is simply that the SD_DAT[1] line is held low. The SD_DAT[1] line is not used as data
in this mode. The memory controller generates an interrupt according to this low and the system interrupt
continues until the source is removed (SD_DAT[1] returns to its high level).
In 4-bit mode, the interrupt is less simple. The interrupt triggers at a particular period called the "Interrupt
Period" during the data access, and the controller must sample SD_DAT[1] during this short period to
determine the IRQ status of the attached card. The interrupt period only happens at the boundary of each
block (512 bytes).
54
MOTOROLA
Specifications
CMD
Content
ST
DAT[1]
CRC E Z Z P S
Interrupt Period
Response
S
EZZZ
Block Data
E
IRQ
S
ZZZ
Block Data
E
IRQ
For 4-bit
LH
DAT[1]
Interrupt Period
For 1-bit
Figure 44. SDIO IRQ Timing Diagram
ReadWait is another feature in SDIO that allows the user to submit commands during the data transfer. In
this mode, the block temporarily pauses the data transfer operation counter and related status, yet keeps the
clock running, and allows the user to submit commands as normal. After all commands are submitted, the
user can switch back to the data transfer operation and all counter and status values are resumed as access
continues.
CMD
DAT[1]
P S T CMD52
CRC E Z Z Z
S
Block Data
EZZL H
S
Block Data
E
S
Block Data
E Z Z L L L L L L L L L L L L L L L L L L L L L HZ S
Block Data
E
For 4-bit
DAT[2]
For 4-bit
Figure 45. SDIO ReadWait Timing Diagram
3.12 Memory Stick Host Controller
The Memory Stick protocol requires three interface signal line connections for data transfers: MS_BS,
MS_SDIO, and MS_SCLKO. Communication is always initiated by the MSHC and operates the bus in
either four-state or two-state access mode.
The MS_BS signal classifies data on the SDIO into one of four states (BS0, BS1, BS2, or BS3) according
to its attribute and transfer direction. BS0 is the INT transfer state, and during this state no packet
transmissions occur. During the BS1, BS2, and BS3 states, packet communications are executed. The BS1,
BS2, and BS3 states are regarded as one packet length and one communication transfer is always
completed within one packet length (in four-state access mode).
The Memory Stick usually operates in four state access mode and in BS1, BS2, and BS3 bus states. When
an error occurs during packet communication, the mode is shifted to two-state access mode, and the BS0
and BS1 bus states are automatically repeated to avoid a bus collision on the SDIO.
MOTOROLA
55
Specifications
2
1
3
4
5
MS_SCLKI
6
8
7
MS_SCLKO
9
11
10
11
MS_BS
12
12
MS_SDIO(output)
14
13
MS_SDIO (input)
(RED bit = 0)
15
16
MS_SDIO (input)
(RED bit = 1)
Figure 46. MSHC Signal Timing Diagram
Table 21. MSHC Signal Timing Parameter Table
3.0 ± 0.3V
Ref
No.
Parameter
Unit
Minimum
Maximum
1
MS_SCLKI frequency
25
MHz
2
MS_SCLKI high pulse width
ns
3
MS_SCLKI low pulse width
ns
4
MS_SCLKI rise time
3
ns
5
MS_SCLKI fall time
3
ns
6
MS_SCLKO frequency1
25
MHz
7
MS_SCLKO high pulse width1
ns
8
MS_SCLKO low pulse width1
15
ns
9
MS_SCLKO rise time1
5
ns
10
MS_SCLKO fall time1
5
ns
56
MOTOROLA
Specifications
Table 21. MSHC Signal Timing Parameter Table (Continued)
3.0 ± 0.3V
Ref
No.
Parameter
Unit
Minimum
Maximum
11
MS_BS delay time1
3
ns
12
MS_SDIO output delay time1,2
3
ns
13
MS_SDIO input setup time for MS_SCLKO rising edge (RED bit = 0)3
18
ns
14
MS_SDIO input hold time for MS_SCLKO rising edge (RED bit = 0)3
ns
15
MS_SDIO input setup time for MS_SCLKO falling edge (RED bit = 1)4
23
ns
16
MS_SDIO input hold time for MS_SCLKO falling edge (RED bit = 1)4
ns
1.
2.
3.
4.
Loading capacitor condition is less than or equal to 30pF.
An external resistor (100 ~ 200 ohm) should be inserted in series to provide current control on the
MS_SDIO pin, because of a possibility of signal conflict between the MS_SDIO pin and Memory Stick
SDIO pin when the pin direction changes.
If the MSC2[RED] bit = 0, MSHC samples MS_SDIO input data at MS_SCLKO rising edge.
If the MSC2[RED] bit = 1, MSHC samples MS_SDIO input data at MS_SCLKO falling edge.
MOTOROLA
57
Specifications
3.13 Pulse-Width Modulator
The PWM can be programmed to select one of two clock signals as its source frequency. The selected
clock signal is passed through a divider and a prescaler before being input to the counter. The output is
available at the pulse-width modulator output (PWMO) external pin. Its timing diagram is shown in
Figure 47 and the parameters are listed in Table 22.
1
2a
3b
System Clock
2b
4b
3a
4a
PWM Output
Figure 47. PWM Output Timing Diagram
Table 22. PWM Output Timing Parameter Table
Ref
No.
1.8V ± 0.10V
3.0V ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
MHz
1
System CLK frequency1
2a
Clock high time1
3.3
5/10
ns
2b
Clock low time1
7.5
5/10
ns
3a
Clock fall time1
5
5/10
ns
3b
Clock rise time1
6.67
5/10
ns
4a
Output delay time1
5.7
5
ns
4b
Output setup time1
5.7
5
ns
1.
CL of PWMO = 30 pF
3.14 SDRAM Controller
A write to an address within the memory region initiates the program sequence. The first command issued
to the SyncFlash is Load Command Register. The value in A [7:0] determines which operation the
command performs. For this write setup operation, an address of 0x40 is hardware generated. The bank
and other address lines are driven with the address to be programmed. The next command is Active which
registers the row address and confirms the bank address. The third command supplies the column address,
re-confirms the bank address, and supplies the data to be written. SyncFlash does not support burst writes,
therefore a Burst Terminate command is not required.
A read to the memory region initiates the status read sequence. The first command issued to the SyncFlash
is the Load Command Register with A [7:0] set to 0x70 which corresponds to the Read Status Register
operation. The bank and other address lines are driven to the selected address. The second command is
58
MOTOROLA
Specifications
Active which sets up the status register read. The bank and row addresses are driven during this command.
The third command of the triplet is Read. Bank and column addresses are driven on the address bus during
this command. Data is returned from memory on the low order 8 data bits following the CAS latency.
1
SDCLK
2
3S
3
CS
3H
3S
RAS
3S
3H
CAS
3S
3H
3H
WE
4S
ADDR
4H
ROW/BA
COL/BA
8
5
6
DQ
Data
7
3S
DQM
3H
Note:
CKE is high during the read/write cycle.
Figure 48. SDRAM/SyncFlash Read Cycle Timing Diagram
Table 23. SDRAM Timing Parameter Table
1.8V ± 0.10V
Ref
No.
3.0V ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
1
SDRAM clock high-level width
2.67
4
ns
2
SDRAM clock low-level width
6
4
ns
3
SDRAM clock cycle time
11.4
10
ns
CS, RAS, CAS, WE, DQM setup time
3.42
3
ns
3S
MOTOROLA
59
Specifications
Table 23. SDRAM Timing Parameter Table (Continued)
Ref
No.
1.8V ± 0.10V
3.0V ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
3H
CS, RAS, CAS, WE, DQM hold time
2.28
2
ns
4S
Address setup time
3.42
3
ns
4H
Address hold time
2.28
2
ns
5
SDRAM access time (CL = 3)
6.84
6
ns
5
SDRAM access time (CL = 2)
6.84
6
ns
5
SDRAM access time (CL = 1)
22
22
ns
6
Data out hold time
2.85
2.5
ns
7
Data out high-impedance time (CL = 3)
6.84
6
ns
7
Data out high-impedance time (CL = 2)
6.84
6
ns
7
Data out high-impedance time (CL = 1)
22
22
ns
8
Active to read/write command period (RC = 1)
tRCD1
tRCD1
ns
1.
60
tRCD = SDRAM clock cycle time. This settings can be found in the MC9328MXL reference manual.
MOTOROLA
Specifications
SDCLK
1
3
2
CS
RAS
6
CAS
WE
4
ADDR
5
7
/ BA
COL/BA
ROW/BA
8
9
DATA
DQ
DQM
Figure 49. SDRAM/SyncFlash Write Cycle Timing Diagram
Table 24. SDRAM Write Timing Parameter Table
1.8V ± 0.10V
Ref
No.
3.0V ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
1
2.67
4
ns
2
6
4
ns
3
11.4
10
ns
4
Address setup time
3.42
3
ns
5
Address hold time
2.28
2
ns
6
Precharge cycle period1
tRP2
tRP2
ns
7
Active to read/write command delay
tRCD2
tRCD2
ns
MOTOROLA
61
Specifications
Table 24. SDRAM Write Timing Parameter Table (Continued)
1.8V ± 0.10V
Ref
No.
3.0V ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
8
Data setup time
4.0
2
ns
9
Data hold time
2.28
2
ns
1.
2.
Precharge cycle timing is included in the write timing diagram.
tRP and tRCD = SDRAM clock cycle time. These settings can be found in the MC9328MXL reference
manual.
SDCLK
1
3
2
CS
RAS
6
CAS
7
7
WE
4
ADDR
5
ROW/BA
BA
DQ
DQM
Figure 50. SDRAM Refresh Timing Diagram
Table 25. SDRAM Refresh Timing Parameter Table
Ref
No.
1.8V ± 0.10V
3.0V ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
1
2.67
4
ns
2
6
4
ns
62
MOTOROLA
Specifications
Table 25. SDRAM Refresh Timing Parameter Table (Continued)
1.8V ± 0.10V
Ref
No.
3.0V ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
3
11.4
10
ns
4
Address setup time
3.42
3
ns
5
Address hold time
2.28
2
ns
6
tRP1
tRP1
ns
7
Auto precharge command period
tRC1
tRC1
ns
1.
tRP and tRC = SDRAM clock cycle time. These settings can be found in the MC9328MXL reference
manual.
SDCLK
CS
RAS
CAS
WE
ADDR
BA
DQ
DQM
CKE
Figure 51. SDRAM Self-Refresh Cycle Timing Diagram
MOTOROLA
63
Specifications
3.15 USB Device Port
Four types of data transfer modes exist for the USB module: control transfers, bulk transfers, isochronous
transfers, and interrupt transfers. From the perspective of the USB module, the interrupt transfer type is
identical to the bulk data transfer mode, and no additional hardware is supplied to support it. This section
covers the transfer modes and how they work from the ground up.
Data moves across the USB in packets. Groups of packets are combined to form data transfers. The same
packet transfer mechanism applies to bulk, interrupt, and control transfers. Isochronous data is also moved
in the form of packets, however, because isochronous pipes are given a fixed portion of the USB
bandwidth at all times, there is no end-of-transfer.
USBD_AFE
(Output)
1
t VMO_ROE 4
t ROE_VPO
USBD_ROE
(Output)
tPERIOD
6
3
tVPO_ROE
USBD_VPO
(Output)
USBD_VMO
(Output)
USBD_SUSPND
tROE_VMO
tFEOPT
2
5
(Output)
USBD_RCV
(Input)
USBD_VP
(Input)
USBD_VM
(Input)
Figure 52. USB Device Timing Diagram for Data Transfer to USB Transceiver (TX)
Table 26. USB Device Timing Parameter Table for Data Transfer to USB Transceiver (TX)
1.8V ± 0.10V
Ref No.
64
3.0V ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
1
tROE_VPO; USBD_ROE active to
USBD_VPO low
83.14
83.47
83.14
83.47
ns
2
tROE_VMO; USBD_ROE active to
USBD_VMO high
81.55
81.98
81.55
81.98
ns
3
tVPO_ROE; USBD_VPO high to
USBD_ROE deactivated
83.54
83.80
83.54
83.80
ns
MOTOROLA
Specifications
1.8V ± 0.10V
Ref No.
3.0V ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
4
tVMO_ROE; USBD_VMO low to
USBD_ROE deactivated (includes SE0)
248.90
249.13
248.90
249.13
ns
5
tFEOPT; SE0 interval of EOP
160.00
175.00
160.00
175.00
ns
6
tPERIOD; Data transfer rate
11.97
12.03
11.97
12.03
Mb/s
USBD_AFE
(Output)
USBD_ROE
(Output)
USBD_VPO
(Output)
USBD_VMO
(Output)
USBD_SUSPND
(Output)
USBD_RCV
(Input)
1
tFEOPR
USBD_VP
(Input)
USBD_VM
(Input)
Figure 53. USB Device Timing Diagram for Data Transfer from USB Transceiver (RX)
Table 27. USB Device Timing Parameter Table for Data Transfer from USB Transceiver (RX)
1.8V ± 0.10V
Ref No.
1
3.0V ± 0.30V
Parameter
Unit
tFEOPR; Receiver SE0 interval of EOP
MOTOROLA
Minimum
Maximum
Minimum
Maximum
82
82
ns
65
Specifications
3.16 I2C Module
The I2C communication protocol consists of seven elements: START, Data Source/Recipient, Data
Direction, Slave Acknowledge, Data, Data Acknowledge, and STOP.
SDA
5
3
4
SCL
2
1
6
Figure 54. Definition of Bus Timing for I2C
Table 28. I2C Bus Timing Parameter Table
1.8V ± 0.10V
Ref No.
3.0V ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
182
160
ns
1
Hold time (repeated) START condition
2
Data hold time
ns
3
Data setup time
11.4
10
ns
4
HIGH period of the SCL clock
80
120
ns
5
LOW period of the SCL clock
480
320
ns
6
Setup time for STOP condition
182.4
160
ns
3.17 Synchronous Serial Interface
The transmit and receive sections of the SSI can be synchronous or asynchronous. In synchronous mode,
the transmitter and the receiver use a common clock and frame synchronization signal. In asynchronous
mode, the transmitter and receiver each have their own clock and frame synchronization signals.
Continuous or gated clock mode can be selected. In continuous mode, the clock runs continuously. In
gated clock mode, the clock functions only during transmission. The internal and external clock timing
diagrams are shown in Figure 56 through Figure 58 on page 68.
Normal or network mode can also be selected. In normal mode, the SSI functions with one data word of
I/O per frame. In network mode, a frame can contain between 2 and 32 data words. Network mode is
typically used in star or ring-time division multiplex networks with other processors or codecs, allowing
interface to time division multiplexed networks without additional logic. Use of the gated clock is not
allowed in network mode. These distinctions result in the basic operating modes that allow the SSI to
communicate with a wide variety of devices.
66
MOTOROLA
Specifications
1
STCK Output
2
4
STFS (bl) Output
6
8
STFS (wl) Output
12
11
10
STXD Output
31
32
SRXD Input
Note:
SRXD input in synchronous mode only.
Figure 55. SSI Transmitter Internal Clock Timing Diagram
1
SRCK Output
3
5
SRFS (bl) Output
7
9
SRFS (wl) Output
13
14
SRXD Input
Figure 56. SSI Receiver Internal Clock Timing Diagram
MOTOROLA
MC9328MXL Advance Information
67
Specifications
15
16
17
STCK Input
18
STFS (bl) Input
24
22
STFS (wl) Input
28
27
26
STXD Output
34
33
SRXD Input
Note: SRXD Input in Synchronous mode only
Figure 57. SSI Transmitter External Clock Timing Diagram
15
16
17
SRCK Input
19
21
SRFS (bl) Input
25
23
SRFS (wl) Input
30
29
SRXD Input
Figure 58. SSI Receiver External Clock Timing Diagram
Table 29. SSI (Port C Primary Function) Timing Parameter Table
1.8V ± 0.10V
Ref No.
3.0V ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
Internal Clock Operation1 (Port C Primary Function2)
68
1
STCK/SRCK clock period1
95
83.3
ns
2
STCK high to STFS (bl) high3
1.5
4.5
1.3
3.9
ns
3
SRCK high to SRFS (bl) high3
-1.2
-1.7
-1.1
-1.5
ns
MOTOROLA
Specifications
Table 29. SSI (Port C Primary Function) Timing Parameter Table (Continued)
1.8V ± 0.10V
Ref No.
3.0V ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
4
STCK high to STFS (bl) low3
2.5
4.3
2.2
3.8
ns
5
SRCK high to SRFS (bl) low3
0.1
-0.8
0.1
-0.8
ns
6
STCK high to STFS (wl) high3
1.48
4.45
1.3
3.9
ns
7
SRCK high to SRFS (wl) high3
-1.1
-1.5
-1.1
-1.5
ns
8
STCK high to STFS (wl) low3
2.51
4.33
2.2
3.8
ns
9
SRCK high to SRFS (wl) low3
0.1
-0.8
0.1
-0.8
ns
10
STCK high to STXD valid from high
impedance
14.25
15.73
12.5
13.8
ns
11a
STCK high to STXD high
0.91
3.08
0.8
2.7
ns
11b
STCK high to STXD low
0.57
3.19
0.5
2.8
ns
12
STCK high to STXD high impedance
12.88
13.57
11.3
11.9
ns
13
SRXD setup time before SRCK low
21.1
18.5
ns
14
SRXD hold time after SRCK low
ns
External Clock Operation (Port C Primary Function2)
15
92.8
81.4
ns
16
STCK/SRCK clock high period
27.1
40.7
ns
17
STCK/SRCK clock low period
61.1
40.7
ns
18
92.8
ns
19
92.8
ns
92.8
ns
21
92.8
ns
22
92.8
ns
23
92.8
ns
24
92.8
ns
25
92.8
ns
26
impedance
18.01
28.16
15.8
24.7
ns
27a
8.98
18.13
7.0
15.9
ns
27b
9.12
18.24
8.0
16.0
ns
MOTOROLA
69
Specifications
1.8V ± 0.10V
Ref No.
3.0V ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
28
18.47
28.5
16.2
25.0
ns
29
1.14
1.0
ns
30
SRXD hole time after SRCK low
ns
Synchronous Internal Clock Operation (Port C Primary Function2)
31
SRXD setup before STCK falling
32
SRXD hold after STCK falling
15.4
13.5
ns
ns
Synchronous External Clock Operation (Port C Primary Function2)
33
34
1.
2.
3.
1.14
1.0
ns
ns
All the timings for the SSI are given for a non-inverted serial clock polarity (TSCKP/RSCKP = 0) and a
non-inverted frame sync (TFSI/RFSI = 0). If the polarity of the clock and/or the frame sync have been
inverted, all the timing remains valid by inverting the clock signal STCK/SRCK and/or the frame sync
STFS/SRFS shown in the tables and in the figures.
There are 2 sets of I/O signals for the SSI module. They are from Port C primary function (pad 257 to pad
261) and Port B alternate function (pad 283 to pad 288). When SSI signals are configured as outputs, they
can be viewed both at Port C primary function and Port B alternate function. When SSI signals are
configured as input, the SSI module selects the input based on status of the FMCR register bits in the
Clock controller module (CRM). By default, the input are selected from Port C primary function.
bl = bit length; wl = word length.
Table 30. SSI (Port B Alternate Function) Timing Parameter Table
Ref
No.
1.8V ± 0.10V
3.0V ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
Internal Clock Operation1 (Port B Alternate Function2)
70
1
95
83.3
ns
2
1.7
4.8
1.5
4.2
ns
3
-0.1
1.0
-0.1
1.0
ns
4
3.08
5.24
2.7
4.6
ns
5
1.25
2.28
1.1
2.0
ns
6
1.71
4.79
1.5
4.2
ns
7
-0.1
1.0
-0.1
1.0
ns
8
3.08
5.24
2.7
4.6
ns
MOTOROLA
Specifications
Table 30. SSI (Port B Alternate Function) Timing Parameter Table (Continued)
1.8V ± 0.10V
Ref
No.
3.0V ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
9
1.25
2.28
1.1
2.0
ns
10
impedance
14.93
16.19
13.1
14.2
ns
11a
1.25
3.42
1.1
3.0
ns
11b
2.51
3.99
2.2
3.5
ns
12
12.43
14.59
10.9
12.8
ns
13
ns
14
ns
External Clock Operation (Port B Alternate Function2)
15
92.8
81.4
ns
16
27.1
40.7
ns
17
61.1
40.7
ns
18
92.8
ns
19
92.8
ns
92.8
ns
21
92.8
ns
22
92.8
ns
23
92.8
ns
24
92.8
ns
25
92.8
ns
26
impedance
18.9
29.07
16.6
25.5
ns
27a
9.23
20.75
8.1
18.2
ns
27b
10.60
21.32
9.3
18.7
ns
28
17.90
29.75
15.7
26.1
ns
29
1.14
1.0
ns
30
ns
MOTOROLA
71
Specifications
Ref
No.
1.8V ± 0.10V
3.0V ± 0.30V
Parameter
Unit
Minimum
Maximum
Minimum
Maximum
Synchronous Internal Clock Operation (Port B Alternate Function2)
31
32
18.81
16.5
ns
ns
Synchronous External Clock Operation (Port B Alternate Function2)
33
34
1.
2.
3.
72
1.14
1.0
ns
ns
There are 2 set of I/O signals for the SSI module. They are from Port C primary function (pad 257 to pad
configured as inputs, the SSI module selects the input based on FMCR register bits in the Clock controller
MOTOROLA
Specifications
3.18 CMOS Sensor Interface
The CMOS Sensor Interface (CSI) module consists of a control register to configure the interface timing, a
control register for statistic data generation, a status register, interface logic, a 32 × 32 image data receive
FIFO, and a 16 × 32 statistic data FIFO.
3.18.1 Gated Clock Mode
Figure 59 shows the timing diagram when the CMOS sensor output data is configured for negative edge
and the CSI is programmed to received data on the positive edge. Figure 60 on page 73 shows the timing
diagram when the CMOS sensor output data is configured for positive edge and the CSI is programmed to
received data in negative edge. The parameters for the timing diagrams are listed in Table 31 on page 74.
1
VSYNC
7
HSYNC
5
6
2
PIXCLK
Valid Data
DATA[7:0]
3
Valid Data
Valid Data
4
Figure 59. Sensor Output Data on Pixel Clock Falling Edge
CSI Latches Data on Pixel Clock Rising Edge
1
VSYNC
7
HSYNC
6
5
2
PIXCLK
Valid Data
DATA[7:0]
3
Valid Data
Valid Data
4
Figure 60. Sensor Output Data on Pixel Clock Rising Edge
CSI Latches Data on Pixel Clock Falling Edge
MOTOROLA
73
Specifications
Table 31. Gated Clock Mode Timing Parameters
Ref No.
Parameter
Min
Max
Unit
1
csi_vsync to csi_hsync
180
ns
2
csi_hsync to csi_pixclk
1
ns
3
csi_d setup time
1
ns
4
csi_d hold time
1
ns
5
csi_pixclk high time
10.42
ns
6
csi_pixclk low time
10.42
ns
7
csi_pixclk frequency
MHz
The limitation on pixel clock rise time / fall time are not specified. It should be calculated from the hold
time and setup time, according to:
Rising-edge latch data
max rise time allowed = (positive duty cycle - hold time)
max fall time allowed = (negative duty cycle - setup time)
In most of case, duty cycle is 50 / 50, therefore
max rise time = (period / 2 - hold time)
max fall time = (period / 2 - setup time)
For example: Given pixel clock period = 10ns, duty cycle = 50 / 50, hold time = 1ns, setup time = 1ns.
positive duty cycle = 10 / 2 = 5ns
=> max rise time allowed = 5 - 1 = 4ns
negative duty cycle = 10 / 2 = 5ns
=> max fall time allowed = 5 - 1 = 4ns
Falling-edge latch data
max fall time allowed = (negative duty cycle - hold time)
max rise time allowed = (positive duty cycle - setup time)
74
MOTOROLA
Specifications
3.18.2 Non-Gated Clock Mode
Figure 61 shows the timing diagram when the CMOS sensor output data is configured for negative edge
and the CSI is programmed to received data on the positive edge. Figure 62 on page 75 shows the timing
received data in negative edge. The parameters for the timing diagrams are listed in Table 32 on page 75.
1
VSYNC
6
4
5
PIXCLK
Valid Data
DATA[7:0]
2
Valid Data
Valid Data
3
Figure 61. Sensor Output Data on Pixel Clock Falling Edge
1
VSYNC
6
4
5
PIXCLK
Valid Data
DATA[7:0]
2
Valid Data
Valid Data
3
Figure 62. Sensor Output Data on Pixel Clock Rising Edge
Table 32. Non-Gated Clock Mode Parameters
Ref No.
1
MOTOROLA
Parameter
csi_vsync to csi_pixclk
Min
Max
Unit
180
ns
75
Specifications
Table 32. Non-Gated Clock Mode Parameters (Continued)
Ref No.
Parameter
Min
Max
Unit
2
csi_d setup time
1
ns
3
csi_d hold time
1
ns
4
10.42
ns
5
csi_pixclk low time
10.42
ns
6
MHz
In most of case, duty cycle is 50 / 50, therefore:
76
MOTOROLA
MOTOROLA
4 Pin-Out and Package Information
Table 33 illustrates the package pin assignments for the 256-pin MAPBGA package.
Table 33. MC9328MXL 256 MAPBGA Pin Assignments
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
A
NVSS1
DAT3
CLK
NVSS4
USBD_
AFE
NVDD4
NVSS3
UART1_
RTS
UART1_
RXD
NVDD3
N.C.
N.C.
QVDD4
N.C.
N.C.
N.C.
B
A24
DAT1
CMD
SSI1_RXDAT
USBD_
ROE
USBD_VP
SSI0_
RXCLK
SSI0_
TXCLK
SPI1_
SCLK
N.C.
N.C.
N.C.
QVSS4
N.C.
N.C.
N.C.
C
A23
D31
DAT0
SSI1_RXCLK
USBD_
RCV
UART2_
CTS
UART2_
RXD
SSI0_
RXFS
UART1_
TXD
N.C.
N.C.
N.C.
N.C.
N.C.
N.C.
N.C.
D
A22
D30
D29
SSI1_RXFS
USBD_
SUSPND
USBD_
VPO
USBD_
VMO
SSI0_
RXDAT
SPI1_
SPI_RDY
N.C.
N.C.
N.C.
N.C.
N.C.
N.C.
N.C.
E
A20
A21
D28
D26
DAT2
USBD_VM
UART2_
RTS
SSI0_
TXDAT
SPI1_SS
N.C.
N.C.
N.C.
N.C.
N.C.
N.C.
N.C.
F
A18
D27
D25
A19
A16
SSI1_
TXFS
UART2_
TXD
SSI0_
TXFS
SPI1_
MISO
N.C.
N.C.
REV
N.C.
N.C.
LSCLK
SPL_SPR
G
A15
A17
D24
D23
D21
SSI1_
TXDAT
SSI1_
TXCLK
UART1_
CTS
SPI1_
MOSI
N.C.
CLS
CONTRAST
OE_ACD
HSYNC
VSYNC
LD1
H
A13
D22
A14
D20
NVDD1
NVDD1
NVSS1
QVSS1
QVDD1
PS
LD0
LD2
LD4
LD5
LD9
LD3
J
A12
A11
D18
D19
NVDD1
NVDD1
NVSS1
NVDD1
NVSS2
NVSS2
LD6
LD7
LD8
LD11
QVDD3
QVSS3
K
A10
D16
A9
D17
NVDD1
NVSS1
NVSS1
NVDD1
NVDD2
NVDD2
LD10
LD12
LD13
LD14
TOUT2
LD15
L
A8
A7
D13
D15
D14
NVDD1
NVSS1
CAS
TCK
TIN
PWMO
CSI_MCLK
CSI_D0
CSI_D1
CSI_D2
CSI_D3
M
A5
D12
D11
A6
SDCLK
NVSS1
RW
MA10
RAS
RESET_IN
BIG_ENDI
AN
CSI_D4
CSI_
HSYNC
CSI_VSYNC
CSI_D6
CSI_D5
N
A4
EB1
D10
D7
A0
D4
PA17
D1
DQM1
RESET_SF
RESET_
OUT
BOOT2
CSI_
PIXCLK
CSI_D7
TMS
TDI
P
A3
D9
EB0
CS3
D6
ECB
D2
D3
DQM3
SDCKE1
BOOT3
BOOT0
TRST
I2C_CLK
I2C_DATA
XTAL32K
R
EB2
EB3
A1
CS4
D8
D5
LBA
BCLK
D0
DQM0
SDCKE0
POR
BOOT1
TDO
QVDD2
EXTAL32K
T
NVSS1
A2
OE
CS5
CS2
CS1
CS0
MA11
DQM2
SDWE
CLKO
AVDD1
TRISTATE
EXTAL16M
XTAL16M
QVSS2
77
1
78
Table 34 illustrates the package pin assignments for the 225-pin PBGA package.
Table 34. MC9328MXL 225 PBGA Pin Assignments
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
A
CMD
SSI1_
RXCLK
SSI1_
TXCLK
USBD_
ROE
USBD_
SUSPND
USBD_VM
SSI0_
RXFS
SSI0_
TXCLK
SPI1_RDY
SPI1_
SCLK
REV
PS
LD2
LD4
LD5
B
DAT3
CLK
SSI1_
RXDAT
USBD_
AFE
USBD_RCV
USBD_
VMO
SSI0_
RXDAT
UART1_
TXD
SPI1_SS
LSCLK
SPL_
SPR
LD0
LD3
LD6
LD7
C
D31
DAT0
SSI1_
RXFS
SSI1_
TXFS
DAT2
USBD_
VPO
UART2_
RXD
SSI0_
TXFS
UART1_
RTS
CONTRAST
VSYNC
LD8
LD9
LD12
NVDD2
D
A23
A24
DAT1
SSI1_
TXDAT
NVDD1
USBD_VP
QVDD4
UART2_
TXD
NVDD3
SPI1_
MOSI
HSYNC
LD1
LD11
TOUT2
LD13
E
A21
A22
D30
D29
NVDD1
QVSS
UART2_
RTS
UART1_
RXD
UART1_
CTS
SPI1_
MISO
OE_
ACD
LD10
TIN
CSI_D0
CSI_
MCLK
F
A20
A19
D28
D27
NVDD1
NVDD1
UART2_
CTS
SSI0_
RXCLK
SSI0_
TXDAT
CLS
QVDD3
LD14
LD15
CSI_D2
CSI_D4
G
A17
A18
D26
D25
NVDD1
NVSS
NVDD4
NVSS
NVSS
QVSS
PWMO
CSI_D3
CSI_D7
CSI_HSYNC
CSI_D5
H
A15
A16
D23
D24
D22
NVSS
NVSS
NVSS
NVSS
NVDD2
CSI_D1
CSI_
VSYNC
CSI_
PIXCLK
I2C_DATA
TMS
J
A14
A12
D21
D20
NVDD1
NVSS
NVSS
QVDD1
NVSS
CSI_D6
I2C_
CLK
TCK
TDO
BOOT1
BOOT0
K
A13
A11
CS2
D19
NVDD1
NVSS
QVSS
NVDD1
NVSS
D1
BOOT2
TDI
BIG_
ENDIAN
RESET_
OUT
XTAL32K
L
A10
A9
D17
D18
NVDD1
NVDD1
CS5
D2
ECB
NVSS
NVSS
POR
QVSS
XTAL16M
EXTAL32K
M
D16
D15
D13
D10
EB3
NVDD1
CS4
CS1
BCLK
RW
NVSS
BOOT3
QVDD2
RESET_IN
EXTAL16M
N
A8
A7
D12
EB0
D9
D8
CS3
CS0
PA17
D0
DQM2
DQM0
SDCKE0
TRISTATE
TRST
P
D14
A5
A4
A3
A2
A1
D6
D5
MA10
MA11
DQM1
RAS
SDCKE1
CLKO
RESETSF
R
A6
D11
EB1
EB2
OE
D7
A0
SDCLK
D4
LBA
D3
DQM3
CAS
SDWE
AVDD1
MOTOROLA
4.1 MAPBGA 256 Package Dimensions
Figure 63 illustrates the 256 MAPBGA 14 mm × 14 mm × 1.30 mm package, which has 0.8 mm spacing
between the pads. The device designator for the MAPBGA package is VH.
Case Outline 1367
TOP VIEW
BOTTOM VIEW
SIDE VIEW
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2.
INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14 5M-1994.
3.
MAXIMUM SOLDER BALL DIAMETER MEASURED PARALLEL TO DATUM A.
4.
DATUM A, THE SEATING PLANE IS DEFINED BY SPHERICAL CROWNS OF THE SOLDER BALLS.
Figure 63. MC9328MXL 256 MAPBGA Mechanical Drawing
MOTOROLA
79
4.2 PBGA 225 Package Dimensions
Figure 64 illustrates the 225 PBGA 13 mm × 13 mm × 0.8 mm package.
Case Outline 1304B
TOP VIEW
BOTTOM VIEW
SIDE VIEW
NOTES:
2.
3.
4.
5.
PARALLELISM MEASUREMENT SHALL EXCLUDE ANY EFFECT OF MARK ON TOP SURFACE OF
PACKAGE.
Figure 64. MC9328MXL 225 PBGA Mechanical Drawing
80
MOTOROLA
NOTES
MOTOROLA
81
HOW TO REACH US:
Information in this document is provided solely to enable system and software implementers to
use Motorola products. There are no express or implied copyright licenses granted hereunder to
USA/EUROPE/LOCATIONS NOT LISTED:
design or fabricate any integrated circuits or integrated circuits based on the information in this
Motorola Literature Distribution
P.O. Box 5405, Denver, Colorado 80217
1-800-521-6274 or 480-768-2130
document.
JAPAN:
for any particular purpose, nor does Motorola assume any liability arising out of the application or
Motorola reserves the right to make changes without further notice to any products herein.
Motorola makes no warranty, representation or guarantee regarding the suitability of its products
use of any product or circuit, and specifically disclaims any and all liability, including without
Motorola Japan Ltd.; SPS, Technical Information Center,
3-20-1, Minami-Azabu, Minato-ku, Tokyo 106-8573, Japan
81-3-3440-3569
limitation consequential or incidental damages. “Typical” parameters which may be provided in
Motorola data sheets and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals” must be validated
ASIA/PACIFIC:
Motorola Semiconductors H.K. Ltd.; Silicon Harbour Centre,
2 Dai King Street, Tai Po Industrial Estate, Tai Po, N.T.,
Hong Kong
852-26668334
HOME PAGE:
for each customer application by customer’s technical experts. Motorola does not convey any
license under its patent rights nor the rights of others. Motorola products are not designed,
intended, or authorized for use as components in systems intended for surgical implant into the
body, or other applications intended to support or sustain life, or for any other application in which
the failure of the Motorola product could create a situation where personal injury or death may
occur. Should Buyer purchase or use Motorola products for any such unintended or unauthorized
application, Buyer shall indemnify and hold Motorola and its officers, employees, subsidiaries,
http://motorola.com/semiconductors
affiliates, and distributors harmless against all claims, costs, damages, and expenses, and
reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death
associated with such unintended or unauthorized use, even if such claim alleges that Motorola
was negligent regarding the design or manufacture of the part.
Motorola and the Stylized M Logo are registered in the U.S. Patent and Trademark Office. All other
product or service names are the property of their respective owners. The ARM POWERED
logo is the registered trademarks of ARM Limited. ARM9, ARM920T, and ARM9TDMI are
the trademarks of ARM Limited.
Motorola, Inc. is an Equal Opportunity/Affirmative Action Employer.
© Motorola, Inc. 2003
MC9328MXL/D
